eldoncito2019
with a script can I know when my router synchronizes the internet time?
Tue Oct 18, 2022 6:04 pm
Guys
with a script can I know when my router synchronizes the internet time?, I ask because when the RB restarts sometimes it takes several minutes to synchronize the correct time, I want to know in the script that exact time. Thanks for replying and helping me.
EL DONCITO.
Jotne
Re: Possible solution
Tue Oct 18, 2022 6:10 pm
Why.
What con you do different if you know the exact time when the router is synchronized?
Command to see status:
:put [/system/ntp/client/get status]
synchronized
pe1chl
Tue Oct 18, 2022 6:13 pm
When you use NTP servers to synchronize the time, a message is logged when the time is reset to a different value, which normally happens when you reboot.
So configure some NTP servers and optionally remove the cloud time sync.
eldoncito2019
Tue Oct 18, 2022 6:26 pm
That is where the detail is, I have not been able to configure an NTP server and I get the time is from the cloud
EL DONCITO.
pe1chl
Re: with a script can I know when my router synchronizes the internet time?
Wed Oct 19, 2022 11:09 am
Why not?
eldoncito2019
Wed Oct 19, 2022 1:06 pm
Is there a way to do it when you sync the time from the cloud
EL DONCITO.
Users browsing this forum: Bing [Bot] and 44 guests
