update: i tried with a windows 10 laptop (with no success) but i tried also with an iphone and it's working fine like the android.
My car does not start...
you are right, my bad! i will post my config at the end of this post!
/export your config (minus serial number and any public WANIP info).
Assuming your MT has a reachable public WANIP.
Yes it has a public IP! Config is on the way!
Wireguard will ALWAYS send. If received stays on 0, it's not working.
Since it works on your android client, the majority of the setup should be correct so probably a small config problem.
As indicated, export of your config please.
That's why im confused because all the videos and posts that i watched for wireguard with mikrotik-server and windows-client shows the same configs.
Anyway here is my config:
# oct/19/2022 12:07:54 by RouterOS 7.5
# software id = KUEL-42ZL
# model = 2011UiAS-2HnD
# serial number = XxXxXxXxXxXxX
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment=Internet-Vodafone
set [ find default-name=ether2 ] comment=Synology#1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
country=greece disabled=no distance=indoors frequency=auto installation=\
indoor mode=ap-bridge ssid=Koukis-Home wireless-protocol=802.11
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
use-peer-dns=yes user=guest@adsl.gr
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] authentication-types=wpa2-psk group-ciphers=\
tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik \
unicast-ciphers=tkip,aes-ccm
/ip kid-control
add fri=0s-1d mon=0s-1d name=system-dummy sat=0s-1d sun=0s-1d thu=0s-1d tue=\
0s-1d tur-fri=0s-1d tur-mon=0s-1d tur-sat=0s-1d tur-sun=0s-1d tur-thu=\
0s-1d tur-tue=0s-1d tur-wed=0s-1d wed=0s-1d
add name=dhcp ranges=10.10.10.100-10.10.10.199
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=ether6
add bridge=bridge comment=defconf ingress-filtering=no interface=ether7
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8
add bridge=bridge comment=defconf ingress-filtering=no interface=ether9
add bridge=bridge comment=defconf ingress-filtering=no interface=ether10
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp1
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface detect-internet
set detect-interface-list=all
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=10.10.99.2/32 comment="Sony Xperia 5" interface=\
wireguard1 persistent-keepalive=25s public-key=\
"XxXxX...="
add allowed-address=10.10.99.3/32 comment=iPhone-Tassos interface=wireguard1 \
"XxXxX..."
add allowed-address=10.10.99.4/32 comment=Asus-Laptop endpoint-address="" \
interface=wireguard1 persistent-keepalive=25s public-key=\
"XxXxX...="
add address=10.10.10.1/24 comment=defconf interface=bridge network=10.10.10.0
add address=10.10.99.1/24 interface=wireguard1 network=10.10.99.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
/ip dhcp-server lease
add address=10.10.10.30 client-id=1:0:11:32:5d:ad:93 comment=Synology#1 \
mac-address=XX:XX:XX:XX:XX:XX server=defconf
add address=10.10.10.2 client-id=1:56:fd:3e:e9:eb:4 comment="Sony Xperia 5" \
add address=10.10.10.0/24 comment=defconf dns-server=9.9.9.9,1.1.1.1 gateway=\
10.10.10.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=10.10.10.1 comment=defconf name=router.lan
add action=accept chain=input comment=Wireguard1 dst-port=13231 protocol=udp
add action=accept chain=input src-address=10.10.99.0/24
established,related,untracked
invalid disabled=yes
add action=drop chain=input comment="defconf: drop ICMP" disabled=yes \
protocol=icmp
disabled=yes in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat comment=Plex dst-port=32400 protocol=tcp \
to-addresses=10.10.10.30 to-ports=32400
add action=dst-nat chain=dstnat comment=Torrents-Synology dst-port=16881 \
protocol=tcp to-addresses=10.10.10.30 to-ports=16881
/lcd interface pages
set 0 interfaces="sfp1,ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8\
,ether9,ether10"
/system clock
set time-zone-name=Europe/Athens
/system identity
set name=MikroTik-Router
/system package update
set channel=development
/tool mac-server
/tool mac-server mac-winbox
