BratSinot
IKEv2/IPSec PSK server
Tue Oct 18, 2022 9:03 pm
Greetings!
I can't find anything about setup IKEv2/IPSec PSK in RouterOS. Is that possible? If yes, any documentation?
I want IKEv2/IPSec PSK because Android are dropping L2TP/IPsec support and WireGuard from time to time can't connect. RSA isn't very convinient way, because I should import certificates on every phone I have / use.
P.S. I have hAP^2.
Babujnik
Re: IKEv2/IPSec PSK server
Wed Oct 26, 2022 1:36 pm
you configure it like any other IPSEC/IKEv2, just in "identities" you set up "pre shared key" as authorisation method. that's your PSK for android client.
massinia
Thu May 04, 2023 9:36 am
Hi, so if I understand correctly I should follow this guide
https://help.mikrotik.com/docs/display/ ... entication
But instead of "auth-method=digital-signature" I have to use "pre shared key"?
own3r1138
Long time Member
Long time Member
Thu May 04, 2023 10:33 am
massinia
Thu May 04, 2023 12:12 pm
Thanks for the advice, with IKEv2 EAP-MSCHAPv2 is it necessary to create the Let's Encrypt certificate?
own3r1138
Long time Member
Long time Member
Thu May 04, 2023 12:50 pm
It should have a valid certificate. Both IKEv2 Identity and user manager will use that. Otherwise, one should import the CA.
massinia
Thu May 04, 2023 4:51 pm
I tried and it doesn't work, there is probably more to change but i don't know what.
@own3r1138 thanks with certificate works perfectly, but the problem of importing the certificate in all android clients remains.
Unfortunately I can't use Let's Encrypt...
I'll do more tests these days.
own3r1138
Long time Member
Long time Member
Thu May 04, 2023 4:58 pm
Out of curiosity, why can't you use it?
massinia
Thu May 04, 2023 5:39 pm
Because the VPN can not depend on external services like Let's Encrypt, it's not my choice...
massinia
Fri May 05, 2023 6:32 pm
Just to say that IKEv2 PSK works fine with macOS Ventura, iPad and android 13 (Windows not tested).
With android and iPad you need to enter IPSec identifier, in my case it works with the DDNS address (MikroTik IP Cloud).
ToTheCLI
Sat May 27, 2023 10:56 pm
Could you post full setup steps From Firewall to IPSec settings on Mikrotik.
own3r1138
Long time Member
Long time Member
Sun May 28, 2023 12:52 am
massinia
Sun May 28, 2023 11:46 am
If you want to connect to devices in LAN I also recommend to add in firewall
add action=accept chain=input comment="Allow IKEv2 Traffic" src-address=\
    172.17.153.0/24
@own3r1138
Thanks for the screenshots, they will be very useful!
own3r1138
Long time Member
Long time Member
Sun May 28, 2023 2:58 pm
You're welcome. I have too much shit going on. I rather not confuse anyone.
ToTheCLI
Sun May 28, 2023 3:02 pm
In Android IPSec identifier has to be set to something or will not connect.
FalconWiFi
Tue May 30, 2023 4:02 pm
Hello all!
After millions of tries, I finally gave up with PSK and configured my IKEv2 server with certificates. I got it working, but Android client keeps saying that its not safe, or not secure (not sure how to translate it to English). Does anyone know how can I fix this?
Thanks in advance.
antosusan
Tue Jun 20, 2023 10:58 am
Hello all!
Thanks in advance.
i have same problem with you for make PSK connect on my phone i set indentifier PSK "ipsec" is connect
but on other phone cant connect use PSK, when use certificate connect but status is "connect, not secure"
btmikigigs
Thu Jan 11, 2024 9:25 am
Hello everyone
I configured IPsec according to the above instructions, everything works, but when I enter the ddns name "cloud mikrotik" in the Android VPN client instead of the IP address, it does not want to connect. Someone has an idea to solve this problem?
https://drive.google.com/file/d/14WnAjo ... sp=sharing
Users browsing this forum: Amazon [Bot], worm and 68 guests
