Voklav
Zerotier packages for CHR ?
Wed Oct 19, 2022 3:39 pm
I want to replicate one of my arm64 config to VM (on proxmox if matter with dedicated passthrough WAN card).
But I can't find Zerotier packages for CHR :(
It is available only for arm/arm64...
Any plans to add it?
I'm wondering if I should buy a CHR license ... or buy another arm64 hardware :(
elbob2002
Re: Zerotier packages for CHR ?  [SOLVED]
Wed Oct 19, 2022 10:30 pm
You can run Zerotier in a container on CHR.
I've had success with this one:
https://github.com/zyclonite/zerotier-docker
Instead of using a seperate subnet for the veth interface needed for Docker I just added the veth interface to the existing bridge.
Probably not good practice but it works! Change IP, Bridge names, interface name and disk to suit:
/interface/veth/add name=veth1 address=10.13.0.2/24 gateway=10.13.0.1
/interface/bridge/port add bridge=bridge1 interface=veth1
/container/envs/add key=net name=zt value=host
/container/envs/add key=cap-add name=zt value=NET_ADMIN
/container/envs/add key=device name=zt value=/dev/net/tun
/container/config/set registry-url=https://registry-1.docker.io tmpdir=disk1/pull
/container/add remote-image=zyclonite/zerotier:latest interface=veth1 root-dir=disk1/zerotier envlist=zt
Then shell into your container and join your Zerotier Network.
You can use the IP address of the Zerotier network as a gateway to the networks attached or accessible to your CHR.
dobria
Sun Jan 29, 2023 4:56 pm
Yes, we can. Please take a look at this article: MikroTik CHR ZeroTire Network Controller with UI.
It explains how it can be done for zerotier self-hosted controller, but it includes the zerotier-one. It is working perfectly.
VincentL
Mon Jan 08, 2024 1:28 pm
We 'd like to use ZeroTier on CHR without need to use a container.
One year after the original post, did you have a plan to release a native package for this plateform ?
Regards,
Vincent
Users browsing this forum: No registered users and 31 guests
