You must change the IP on your PC,
after that, change the IP inside the Hikvision with DHCP client, and restore DHCP client on PC.
After that you can see inside WinBox what lease give your camera (and change it to static for other use) and access the camera with the PC.
Or directly use NVR or SADP to change the camera config.
This is a complex method, you need to make it simpler as the method below.
Or just add another address/subnet to router:
add interface=<your LAN interface> address=192.168.0.1/24
The 192.168.0.1 is most likely default gateway for camera, so it has good chance to work like this. If not, add srcnat:
add chain=srcnat dst-address=192.168.0.64 action=masquerade
I did everything, but nothing works. maybe you forgot something or did it wrong?
icmp packets do not pass.
open the address in the browser
http://192.168.0.64 / I can't
in the logs I see only broadcast messages from this address.
