krystian
Mikrotik hAP ax2 wireless speed problem
Wed Oct 19, 2022 11:37 pm
Hello
I have a hAP ax2 router from today and I am a bit disappointed. I have a UPC 750/200 Mbit link and on the UPC router I get speeds of about 500 Mbit / s over Wi-Fi 5. I connected the ax2 router to it and configured it for Wi-Fi 6. On the iPhone 13 speedtest I only have about 250 Mbit / s.
I also tested some time ago on ASUS XD6 and I had about 700 Mbit / s after Wi-Fi 6.
Is something wrongly positioned?
Please help.
Configuration in attachment.
# oct/19/2022 22:06:59 by RouterOS 7.6
# software id = NAHX-XSTS
# model = C52iG-5HaxD2HaxD
# serial number = <CENSORED>
add admin-mac=18:FD:74:BB:9E:5D auto-mac=no name=bridge
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40/80mhz configuration.country=Poland .mode=ap .ssid=\
    MT5 disabled=no security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40mhz configuration.country=Poland .mode=ap .ssid=MT \
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add interface=bridge list=LAN
add interface=ether1 list=WAN
    192.168.88.0
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    "defconf: drop everything else not coming from LAN" in-interface-list=!LAN
    invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
    src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
    dst-address-list=bad_ipv6
    icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
    protocol=udp
    ipsec-ah
    ipsec-esp
/system clock
set time-zone-name=Europe/Warsaw
/tool mac-server
/tool mac-server mac-winbox
When I start doing speedtest, the tx rate drops to 600/600, not 1201 Mbps.
I'm about 3-4 meters from router.
In the same room.
chechito
Re: Mikrotik hAP ax2 wireless speed problem
Thu Oct 20, 2022 12:54 am
looks like only 1 spatial stream is in use
just to be sure try setting in the configuration tab on wireless interface:
chains 0 1 checked
tx chains 0 1 checked
krystian
Thu Oct 20, 2022 1:05 am
I checked and speed is the same...
chechito
Thu Oct 20, 2022 1:09 am
Looks like MikroTIk need to do some fine tuning on MiMo
Try changing de orientation: vertically, horizontal
krystian
Thu Oct 20, 2022 1:13 am
Where can I tuning it?
You talk to me phisicaly orientation?
chechito
Thu Oct 20, 2022 1:23 am
About Tuning i think MikroTIk do that on drivers beyond our reach
Yes i refer to phisicaly orientation
jookraw
Thu Oct 20, 2022 12:47 pm
@krystian do you have any reason to have
skip-dfs-channels=10min-cac
on your wifi-5g interface? are you near some airport or weather radar?
the dfs channels is where you have more bandwidth avaliable.
ivicask
Thu Oct 20, 2022 2:03 pm
What Channel width did it select 40 or 80mhz?Looks like 40, try setting it to 80mhz instead 20/40/80 to see if thats the issue.
Also as mentioned above "skip-dfs-channels=10min-cac" that is also maybe the reason it selected 40mhz on more crowded channel instead using higher one which then may use 80 instead 40.
Users browsing this forum: klaeuser and 19 guests
