litz
RB3011 DHCP server fails to assign IPs to many Linux devices
Thu Oct 20, 2022 5:07 pm
Seeing an issue that is slowly crippling my network:
RouterOS 7.6 on RB3011
DHCP Server is failing to assign IPs to Linux servers, and linux based hardware devices (IoT, Android phones, etc etc).
Windows servers work perfectly, no issues at all.
The issue is, client requests IP, and gets an address of 0.0.0.x
No amount of reboot, reset, clear on either DHCP server *or* client fixes the issue. Static assigned IPs do not fix the issue.
Happens with both wired and wireless (external bridge access point, utilizing router's DHCP)
The ONLY fix, so far, is to not use Mikrotik DHCP, which is by far not an acceptable or ideal solution.
Any ideas on what's going on?
rextended
Re: RB3011 DHCP server fails to assign IPs to many Linux devices
Thu Oct 20, 2022 5:22 pm
Do not use 3rd party sites, this forum can handle text and files.
erlinden
Thu Oct 20, 2022 5:56 pm
Can you please share the config of the Mikrotik (without any privacy information)?
/export file=anynameyoulike
Besides...have you already debugged DHCP on the Mikrotik (or used Wireshark to have a look why it is failing)?
litz
Thu Oct 20, 2022 6:19 pm
# oct/20/2022 09:22:47 by RouterOS 7.6
# software id = MA6F-EWD1
# model = RB3011UiAS
# serial number = xxxx
add admin-mac=CC:2D:E0:A2:BE:23 auto-mac=no comment="Main Bridge" name=\
    "main bridge"
set [ find default-name=sfp1 ] comment="Comcastic! Internet via MB8611"
/interface bonding
add mode=balance-xor name="Switch Trunk" slaves=ether1,ether2,ether3
add comment="Comcastic! Internet" name=WAN
add comment="Main Network" name=LAN
/interface lte apn
add name=main-dhcp ranges=xx.xx.xx.100-xx.xx.xx.199
add add-arp=yes address-pool=main-dhcp always-broadcast=yes client-mac-limit=\
    0 interface="main bridge" lease-time=1h name="Main DHCP"
/port
set 0 name=serial0
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge="main bridge" ingress-filtering=no interface=\
    ether5
add bridge="main bridge" ingress-filtering=no \
    interface=ether9
    interface="Switch Trunk"
    interface=ether4
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add comment="Main Network" interface="main bridge" list=LAN
add comment="Comcastic Internet!" interface=sfp1 list=WAN
/interface ovpn-server server
set auth=sha1,md5
add address=xx.xx.xx.1/24 comment="Main DHCP" interface="main bridge" \
    network=xx.xx.xx.0
/ip dhcp-client
/ip dhcp-server lease
add address=xx.xx.xx.2 client-id=1:2c:c8:1b:54:66:fc mac-address=2C:C8:1B:54:66:FC server=\
    "Main DHCP"
add address=xx.xx.xx.4 client-id=1:2c:c8:1b:35:b7:63 mac-address=2C:C8:1B:35:B7:63 server="Main DHCP"
add address=xx.xx.xx.7 client-id=1:78:8c:77:e4:4:f9 mac-address=78:8C:77:E4:04:F9 server="Main DHCP"
add address=xx.xx.xx.8 client-id=1:0:11:32:2b:5f:dd mac-address=00:11:32:2B:5F:DD server="Main DHCP"
add address=xx.xx.xx.9 client-id=1:0:11:32:2e:e8:7d mac-address=00:11:32:2E:E8:7D server="Main DHCP"
add address=xx.xx.xx.10 client-id=1:54:a0:50:d1:39:98 mac-address=54:A0:50:D1:39:98 server="Main DHCP"
add address=xx.xx.xx.23 client-id=1:50:46:5d:9:b1:7 mac-address=50:46:5D:09:B1:07 server="Main DHCP"
add address=xx.xx.xx.0/24 comment="Main Network" gateway=xx.xx.xx.1 netmask=\
    24
set allow-remote-requests=yes
/ip dns static
/ip firewall address-list
add address=xx.xx.xx.1-xx.xx.xx.255 list="Main Network"
add action=accept chain=input comment="accept established,related,untracked" \
add action=drop chain=input comment="drop invalid" connection-state=invalid
add action=accept chain=input comment="accept ICMP" in-interface-list=LAN \
    protocol=icmp
    "accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="drop all not coming from LAN" \
    in-interface-list=!LAN
add action=accept chain=forward comment="accept in ipsec policy" \
    ipsec-policy=in,ipsec
add action=accept chain=forward comment="accept out ipsec policy" \
    ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=fasttrack \
    "accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add action=drop chain=forward comment="drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="Comcast WAN: masquerade" \
/lcd
set default-screen=stat-slideshow
/system clock
set time-zone-name=America/New_York
/system identity
set name="MikroTik RB 3011UiAS"
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
/system ntp client servers
add address=129.6.15.26
add address=132.163.97.6
add address=132.163.96.6
add address=128.138.141.172
/tool mac-server
/tool mac-server mac-winbox
litz
Thu Oct 20, 2022 6:22 pm
I've attempted to debug as best I can, but I've not seen anything amiss.
As noted above, this *only* happens on Linux based devices. Currently affecting several IoT devices (e.g. smart clock, Ecobee, etc), a Microtik CSS switch, and Android phones.
It does NOT affect any Windows PCs.
There are no "foreign" DHCP servers on the network that could be intercepting requests, either.
biomesh
Long time Member
Long time Member
Thu Oct 20, 2022 6:37 pm
How about removing
client-mac-limit=0
from your dhcp server.
rextended
Thu Oct 20, 2022 6:39 pm
What is this???
"Main DHCP"
24
You cut too much...
And also why censore internal IPs?
Can be wrong and can not be checked on this way.
You have all Public IPs for internal network?
Paste this on terminal
set [find] always-broadcast=no client-mac-limit=""
litz
Thu Oct 20, 2022 6:56 pm
Just assume xx.xx.xx is 192.168.0 ... or 10.10.10 ... it's just the subnet being served. The #s bear no relevence.
litz
Thu Oct 20, 2022 7:37 pm
This:
did not fix the issue. It is still failing to assign addresses to linux based clients.
e.g., on my Pixel phone, it's assigning it 0.0.0.98. I know it's connecting because it's receiving Subnet Mask/DNS information from DHCP. Just not an IP.
(the devices also appear in ARP with 0.0.0 addresses)
e.g.
IP Address MAC Address Interface Bridge Port Host Name
- DC 0.0.0.98 D4:3A:2C:94:C3:0E main bridge
- DC 0.0.0.110 86:A7:74:8E:76:4D main bridge
- D 0.0.0.111 26:27:2D:1B:7E:A3 main bridge
- DC 0.0.0.112 02:0F:B5:DD:A4:8C main bridge
- DC 0.0.0.117 02:0F:B5:D1:A8:4D main bridge
Also, I *know* the DHCP server is seeing the client, because if the client is set up as a static lease, DHCP server is showing a "last seen" value (in addition to the ARP entry)
erlinden
Sat Oct 22, 2022 10:53 am
Can you start with a DHCP server using default settings (just remove the current and add a new one)?
dbegic
Mon Mar 31, 2025 3:09 pm
I know the thread is old but we are facing the same problem. Did you maybe figure out solution?
erlinden
Mon Mar 31, 2025 3:40 pm
Have you tried all suggestions mentioned in this topic?
You might want to consider either adding your config or opening an new topic.
