tobechosen
WIFI Setup with VPN / WireGuard and Non
Thu Oct 20, 2022 9:18 pm
Hi All,
Been using Mikrotik for a while but want to try a few things for the home network.
Currently i have my network send out 2G/5G WiFI signal with a VPN WireGuard system in place. I also have a container running with PiHole for DNS.
I would like to know how can i have the following
1x WiFI ( 5G Prefferably ) with VPN/WireGuard and PIHole active
1X WiFi ( 2/5G ) with just PI Hole active
I dont use LAN ( plugged in devices ) everything operates via WIFI.
I have tried numerous things with vlan and routing but am stuck, if someone could help that would be great.
tobechosen
Re: WIFI Setup with VPN / WireGuard and Non
Tue Nov 15, 2022 12:54 am
anyone??
anav
Tue Nov 15, 2022 5:34 pm
nubesec
Tue Nov 15, 2022 11:00 pm
I have this setup using Juniper SRX and Unifi APs currently, so pretty sure it is doable on Mikrotik.
VLAN-666 Internet DIA w/public IP
VLAN-10 10.100.10.1/24
Server Network (Think DNS Server)
VLAN-11 10.100.11.1/24
Personal network, has access to VPN and all hosts on VLAN-10
VLAN-12 10.100.12.1/24
Family network.. Printers, TVs, xbox, iPads, garage opener, etc.
Has access specific services on server network
does not have access to VPN
Outbound DNS is blocked except for the specifically allowed DNS servers
Unifi APs
SSID-11 - vlan-id=11
SSID-12 - vlan-id=12
I'll probably work on something similar on Mikrotik, where VLAN-11 will default route via VPN. Will probably be a couple of weeks before I get to that project.
tobechosen
Sat Dec 10, 2022 12:17 am
Thanks, i know how to do it on UNIFI, just new to Mikrotik.
About uploading my config ill do that, thanks,
Reason: removed excessive quotting of preceding post; be wise, quote smart.
Users browsing this forum: GoogleOther [Bot] and 95 guests
