andronicus
How to download packages from mirror using routerOS cli
Fri Oct 21, 2022 2:16 am
How do we download packages? The documentation discusses downloading the package file and uploading to routerOS:
Acquiring packages
Packages can be downloaded from MikroTik download page or mirrors listed on that page. Either of provided download methods can be used.
However, I cannot find a mirrorlist on the download page.
I would also like to know if we can search, download, and install packages from the routerOS terminal (command line interface).
thanks
rextended
Re: How to download packages from mirror using routerOS cli
Fri Oct 21, 2022 4:46 am
The same line is also shown on the new help site.
https://help.mikrotik.com/docs/display/ROS/Packages
But I don't understand what the problem is,
the files are also available without mirrors,
and with the "/system package update" function you can manage which version to install.
For the other questions, better if you continue reading the guide on the link I has post,
what is not written there, you can not do.
nichky
Fri Oct 21, 2022 5:22 am
Users browsing this forum: Amazon [Bot] and 105 guests
