korg
Anyone tested LHG CAT18 device?
Fri Oct 21, 2022 11:52 am
hi to all
i was and still am using SXT LTE6 and in a quiet times (i mean times where there are not so many mobile users around the basestation i am aiming at) i get aroung 70-75 Mbps DL speed. I was wondering did any of you guys get the new LHG CAT18 device and how are your experiences with the DL/UL speeds.
tx
korg
MikroUser
Re: Anyone tested LHG CAT18 device?
Fri Oct 21, 2022 12:44 pm
In 99% of cases, speed is limited by operators at base stations.
So if you dont have any special agreements with carrier, you never see high speeds, even if LHG CAT18 hardware will be used.
korg
Fri Oct 21, 2022 1:53 pm
Hmmmm ok... i see.. i have ordered one to test.. so i will let you guys know about my experience
uldise
Fri Oct 21, 2022 6:58 pm
It depends.. there are so many factors involved.. so, LTE18 can do 4CA, if you have so much bands available, then you can use them in LTE18.
i have LHG LTE18 for about two weeks now. in my place is get ~150/60 Mbit Down/Up. for me biggest improvement was upload speed, LTE18 can do 2CA in upload, although in very limited cases.
i know some users in my country with LHG LTE18 with >300Mbit Down speed..
korg
Fri Oct 21, 2022 7:25 pm
ok.. thank you for your info .. :)
my current SXT LTE6 speed is like 50/40 and i am more into DL speed.. and hope that i will get over 100 mbps DL speed... definetely.. the UL speed is not to be disregard .. :)
tx again...
korg
Thu Oct 27, 2022 6:08 pm
i just got my new LGH CAT18 antenna and i've tested it immediatelly.
So, not so happy :(...
this is with no bands chosen - default settings and i am getting like 25-30/60 DL/UL mbps
This is if i have chosen only band 7.. i am getting like 65/60 mbps DL/UL...
i did not aligned the antenna yet... in a sense.. i did not try to find the best or better base station location but plan to do it in the near future.
Pls, correct me but CAT18 is not having much sense to buy it resp it is not giving much (like 30-50%) higher speed.
I know that it is a matter of the internet carrier and how it is enabeling the speed resp connection but ... anyhow.. i assumed it would be especially in DL much faster.
Any thoughts?
tx
korg
korg
Thu Oct 27, 2022 6:12 pm
which country is it?
hecatae
Fri Oct 28, 2022 4:45 pm
Can you combine B3+B7?
https://cacombos.com/device/RBD53G-5HacD2HnD-TC-EG18-EA
The chipset is capable, does your mobile network support 4x4 mimo yet?
https://halberdbastion.com/intelligence ... ska-vipnet < may have old information, as they do not list b7, but they state a1 only support 2x2 mimo and 64QAM
uldise
Sat Oct 29, 2022 5:44 pm
i'm in Latvia..
and looks like you have very strong signal, but signal quality is so so.. SINR looks very bad.. do you have direct vision to the tower available?
in my country CA works only when you start utilizing connection.. so run speedtest, and you should see CA bands too.
B20 is useless, switch it off..
You can cell lock your primary band to B7, and then CA with B3. CA is always set by provider.
see here: viewtopic.php?f=13&t=159889#p798970
uldise
Sat Oct 29, 2022 5:45 pm
According to documentation LHG LTE18 have 2x2 mimo only.
4x4 mimo is for new ATL device..
hecatae
Sun Oct 30, 2022 3:20 am
That's bizarre as the Chateau LTE12 has 4x4 mimo, yet it's missing in the more advanced chipset.
korg
Tue Nov 01, 2022 2:04 pm
Yes i can but i get much lower speeds.. especially in DL...
korg
Tue Nov 01, 2022 2:05 pm
Yes.. i have direct visibility to the tower..
ok.. tx.. i'll try to 'play' with locking the B7
i'm in Latvia..
korg
Tue Nov 01, 2022 2:06 pm
yes... true... so... i can not use 4 x 4 with this antenna...
pcunite
Tue Dec 20, 2022 7:48 pm
@korg,
How is your testing going? Would the ATL LTE18 kit perform better in your scenario?
jimint
Tue Dec 27, 2022 6:32 pm
Hello and joy to you all.
I live in an urban area and want to buy a rooftop device for 4G network. Is there a problem with LHG LTE18 if the central 4G antenna is 330 meters away? Does it do for short distances or should the distances be longer?
Users browsing this forum: No registered users and 62 guests
