SchulIT
Export all Neighbors
Fri Oct 21, 2022 12:08 pm
i need an export off all discovered neighbors.
Under: /ip/neighbor print I see them.
But if use: /ip/neighbor export file=xyz there is only exported:
# oct/21/2022 10:00:16 by RouterOS 6.48.4
# software id = ------
# model = CCR1072-1G-8S+
# serial number = --------
set discover-interface-list=all
That's all.
How can I get in a file all discovered neighbors?
Best regards
Harrdy
rextended
Re: Export all Neighbors  [SOLVED]
Fri Oct 21, 2022 2:37 pm
1+1 = 2
if you already know the print command... try to replace export with print on that line....
SchulIT
Fri Oct 21, 2022 2:47 pm
@rextended
Thank you.
This solved my problem!
rextended
Fri Oct 21, 2022 2:54 pm
Thanks, have a nice day.
Users browsing this forum: No registered users and 102 guests
