fpawlak
SXTsq 5 ac - missing wlan interface
Fri Oct 21, 2022 12:54 pm
I have a problem with two STXsq 5 ac - there are no WLAN interfaces.
Devices are new, and the problem is from the beginning. I've already tried updating to the newest ROS(7.6), stable(6.49.7), netinstal, and configuration reset but nothing has helped.
When booting, log shows the following:
DefConf gen: Unable to find wireless interface(s)
error while running customized default configuration script: interrupted
I've added 'interface' and 'wireless' to the log, but they don't have any log entries.
I include a screenshot from WinBox showing the problem:
Do you have any idea what else I can try?
Thanks for your help
fpawlak
Re: SXTsq 5 ac - missing wlan interface
Mon Nov 07, 2022 10:29 am
so nobody has any idea? I've hoped that it can be solved without returning to the reseller.
So I will send it back, hoping they will excache those antennas.
Users browsing this forum: Google [Bot], MrDeepFreeze, scoobyn8 and 82 guests
