kyled27
Wireguard Setup Assistance
Fri Oct 21, 2022 11:27 pm
Good day Mikrotik Community,
Hope you are all doing well,
I had this setup in the past and trying to do it again on a new mikrotik router but I seem to not be winning.
I have wireguard setup on a mikrotik router and using the windows client on a laptop to connect, It looks like it completes the handshake and I can see in the wireguard app and on the mikrotik that traffic is being sent and received.
However I cannot seem to ping or access anything through the tunnel.
My wireguard interface is 10.1.0.1/24
The Peer Allowed Address is 10.1.0.2/32
When I connect my windows client I cannot ping 10.1.0.1
[admin@MikroTik] > export
# oct/21/2022 22:13:23 by RouterOS 7.3.1
# software id = KCSW-U7CS
# model = RouterBOARD 3011UiAS
# serial number = 780E06967849
add admin-mac=6C:3B:6B:EC:B2:C0 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment="HP 48-Port PoE Switch"
set [ find default-name=ether4 ] comment="Milestone Server"
set [ find default-name=ether6 ] comment="T8516 16-Port PoE Switch"
set [ find default-name=ether7 ] comment="T8516 16-Port PoE Switch"
set [ find default-name=ether8 ] comment="Viewing Station"
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add name=dhcp_pool1 ranges=10.0.0.20-10.0.0.254
add address-pool=dhcp_pool1 interface=bridge name=dhcp1
/port
set 0 name=serial0
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=ether6
add bridge=bridge comment=defconf ingress-filtering=no interface=ether7
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8
add bridge=bridge comment=defconf ingress-filtering=no interface=ether9
add bridge=bridge comment=defconf ingress-filtering=no interface=ether10
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp1
/interface bridge settings
set use-ip-firewall=yes
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=10.1.0.2/32 interface=wireguard1 public-key=\
    "MmfYnKBKpBTvUHAe2qqRW+4vpisFzanw6YESeCu38wU="
add address=10.0.0.1/24 comment=defconf interface=bridge network=10.0.0.0
add address=161.120.227.206/29 interface=ether1 network=161.120.227.200
add address=10.1.0.1/24 interface=wireguard1 network=10.1.0.0
add address=10.0.0.0/24 dns-server=10.0.0.1 gateway=10.0.0.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=10.0.0.1 comment=defconf name=router.lan
add action=accept chain=input dst-port=13231 protocol=udp
add action=accept chain=input protocol=udp src-address=10.1.0.0/24
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
add action=dst-nat chain=dstnat comment="ACS Mobile" dst-address=\
    161.120.227.206 dst-port=55756 in-interface=ether1 protocol=tcp \
    to-addresses=10.0.0.2 to-ports=55756
add action=dst-nat chain=dstnat comment="ACS PC" dst-address=161.120.227.206 \
    dst-port=55752 in-interface=ether1 protocol=tcp to-addresses=10.0.0.2 \
    to-ports=55752
add action=dst-nat chain=dstnat comment=Node-Red dst-address=161.120.227.206 \
    dst-port=3005 in-interface=ether1 protocol=tcp to-addresses=10.0.0.102 \
    to-ports=1880
add action=dst-nat chain=dstnat comment="P8815-2 3D People Counter" \
    dst-address=161.120.227.206 dst-port=4100 in-interface=ether1 protocol=tcp \
    to-addresses=10.0.0.223 to-ports=80
add action=dst-nat chain=dstnat comment="P3375-LV for MatLab" dst-address=\
    161.120.227.206 dst-port=4200 in-interface=ether1 protocol=tcp \
    to-addresses=10.0.0.215 to-ports=554
add action=dst-nat chain=dstnat dst-address=161.120.227.206 dst-port=3006 \
    in-interface=ether1 protocol=tcp to-addresses=10.0.0.102 to-ports=80
add disabled=no dst-address=0.0.0.0/0 gateway=161.120.227.201
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    "defconf: drop everything else not coming from LAN" in-interface-list=!LAN
    invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
    src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
    dst-address-list=bad_ipv6
    icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
    protocol=udp
    ipsec-ah
    ipsec-esp
/system clock
set time-zone-name=Africa/Johannesburg
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
smyers119
Re: Wireguard Setup Assistance
Sat Oct 22, 2022 1:02 am
AllowedIPs= 0.0.0.0/24
This means the only allowed ips are 0.0.0.0-0.0.0.255
I doubt that's what you actually meant to restrict it to, as that will not match anything
holvoetn
Sat Oct 22, 2022 10:39 am
Why not provide the solution ?
Kyled27
Change that to 0.0.0.0/0
All traffic will be allowed to go over tunnel then.
kyled27
Mon Oct 24, 2022 11:18 am
Thank you!
I have changed it but it doesn't seem to work, I have installed wireguard on another laptop and setup seems to be working from that one,
I will try reinstalling wireguard on the laptop im having issues with and see if that solves the issue without making any mistakes in the config
Another question now im hoping I dont need to start a new thread is how do I get my wireguard IP range to communicate to the other IP range that has the devices I need to communicate with
Wireguard IP and Gateway: 10.1.0.2 GW: 10.1.0.1
LAN IP I need to communicate with: 10.0.0.1/24
holvoetn
Mon Oct 24, 2022 11:37 am
If on the laptop client you specify 0.0.0.0/0, all will be accepted.
If you narrow it down to certain subnets, make sure the ones you want are included in allowed addresses.
anav
Tue Oct 25, 2022 12:17 am
To be clear.
Typically if one wants the client (laptop) to connect to the router one puts, in ALLOWED ADDRESSES (peer settings)
a. the IP address of the wireguard network,
b. the IP address of any subnets on the router or elsewhere that will be the destination addresses of local users.
So for example if the wg iP networks is 192.168.45.1/24
One could put
allowed addresses=192.168.45.0/24,192.168.10.0/24,192.168.20.0/24
Where the two subnets that need to be reached on the server outer are 192.168.10.0/24 and 192.168.20.0/24
However if your local users are also expecting to go out the internet on the server router one needs to ONLY put
allowed addresses=0.0.0.0/0
Its safe for the DNS entry to put the interface IP, in my example it would be 192.168.45.1
As the all addresses are covered by the above including the specific ones if internet is not required.
The key here is to use firwall rules on the server to allow specific access to subnets and internet as appropriate.
(could have a subset of client only allowed to go to certain devices on the subnets for example).
Since one laptop works and the other doesnt, it sounds like a problem with the key swap was not done correctly or a firewall setting on the laptop...........
Users browsing this forum: Amazon [Bot], Bing [Bot] and 45 guests
