alejot17
/container: Permission denied (13)
Sun Oct 23, 2022 5:51 pm
Hello.
I am using docker container in RB5009UPr+S+ with RouterOS 7.6
Some containers does not start because "Permission denied (13)".
/container envs
add name=phpmyadmin key=PMA_HOST value=172.17.0.4
/container
add remote-image=phpmyadmin:latest interface=veth4 root-dir=disk1/phpmyadmin envlist=phpmyadmin logging=yes
10:41:50 container,info,debug import successful, container 772a7f2f-3e38-4b7f-a365-6fe1767bd26f
10:41:57 container,info,debug [23-Oct-2022 13:41:57] ERROR: failed to open error_log (/proc/self/fd/2): Permission denied (13)
10:41:57 container,info,debug [23-Oct-2022 13:41:57] ERROR: failed to post process the configuration
10:41:57 container,info,debug [23-Oct-2022 13:41:57] ERROR: FPM initialization failed
/container envs
/container
add remote-image=phpmyadmin:fpm-alpine interface=veth4 root-dir=disk1/phpmyadmin envlist=phpmyadmin logging=yes
10:31:10 container,info,debug import successful, container 9ac4440a-4dd7-402a-9856-2d945b4ee175
10:31:28 container,info,debug AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 172.17.0.5. Set the 'ServerName' directive globally to suppress this
message
10:31:28 container,info,debug (13)Permission denied: AH00091: apache2: could not open error log file /var/log/apache2/error.log.
10:31:28 container,info,debug AH00015: Unable to open logs
It also happens with these cotainers:
* openspeedtest/latest:latest
* httpd:latest
/container/add remote-image=openspeedtest/latest:latest logging=yes interface=veth3 root-dir=disk1/openspeedtest
/container/add remote-image=httpd:latest logging=yes interface=veth4 root-dir=disk1/httpd
Please, can anyone help me with it.
Regards.
alejot17
Re: /container: Permission denied (13)
Sun Oct 23, 2022 6:45 pm
wordpress is not working:
/container/add remote-image=wordpress:php7.4-apache interface=veth4 root-dir=disk1/wordpress logging=yes
12:41:19 container,info,debug import successful, container 34429066-3c6a-4198-a04f-aebf2c64a348
12:41:38 container,info,debug WordPress not found in /var/www/html - copying now...
12:41:49 container,info,debug Complete! WordPress has been successfully copied to /var/www/html
12:41:51 container,info,debug AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 172.17.0.5. Set the 'ServerName' directive globally to suppress this
message
12:41:51 container,info,debug (13)Permission denied: AH00091: apache2: could not open error log file /var/log/apache2/error.log.
12:41:51 container,info,debug AH00015: Unable to open logs
Regards.
elbob2002
Mon Oct 24, 2022 2:02 am
Disk1 one is attached storage I presume - is it formatted as Ext4?
Edit - just tried on a CHR and I get the same permissions errors. Are there any variables that should be set? Any mountpoints according to the image documentation?
tangent
Mon Oct 24, 2022 4:27 am
So map /var/log/apache2 to a volume the container can write to.
kangarie
Mon Oct 24, 2022 9:06 am
i don't know if this a good solution, but this work
elbob2002
Mon Oct 24, 2022 9:44 am
Worked for me on the Openspeedtest container thanks!:
add dst=/var/log/nginx name=openspeed src=/disk1/openspeed/var
antonsb
Re: /container: Permission denied (13)  Topic is solved
Mon Oct 24, 2022 10:56 am
Thank you for reporting this, we found main cause for this issue, but it will take same time until fix will be available. Currently as workaround please mount /var/log as explained by previous posters.
antonsb
Mon Oct 31, 2022 11:48 am
Fix for this will be available in next upcoming versions
Users browsing this forum: tangent and 3 guests
