Darkside
hEX on ROS 7.6
Mon Oct 24, 2022 4:16 am
I am by no means an expert here but have configured and have running a number of Mikrotik routers, including 2 x hEX units.
However; I have a hEX unit running 7.5 that will not route to the internet, even on a very basic config. My last test was a pure default setup, even with that setup I cannot ping or route to the internet at all. I can ping the local router address 192.168.88.1, I can ping my external facing address but nothing further, not even my ISP gateway from the router or LAN PC's
I am using a CRS125-24G-1S on ROS 6.49.6 which is working fine on the same internet connection.
I have compared all internet settings that I can think of and all are correct between the 2 units.
1 x difference I have noticed though is on the route list for the CRS (6.49) it shows WAN reachable comments in the gateway section for the 0.0.0.0/0 entry, but not on the hex (7.6).
I am not sure if there is a setting that needs changing on 7.6 to allow internet access or that 7.6 is not compatible with my service provider, I am at a loss.
Please help this is driving me nuts.
Darkside
Re: hEX on ROS 7.6
Mon Oct 24, 2022 4:39 am
# jan/02/1970 00:01:23 by RouterOS 7.6
# software id = BZ61-FREN
# model = RB750Gr3
# serial number = CC210FD614A8
add admin-mac=DC:2C:6E:EC:F5:B2 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp interface=bridge name=defconf
/port
set 0 name=serial0
192.168.88.0
/ip dhcp-client
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/tool mac-server
/tool mac-server mac-winbox
holvoetn
Re: hEX on ROS 7.6
Mon Oct 24, 2022 8:43 am
I have Hex running since (I think) march 2021 using first 6.<whateverithadoutofthebox>, going over various 7-betas, stable, ... , skipping a few beta-versions (not much) all the way up to 7.6.
Rarely (never ?) had an issue connecting to my ISP.
What device is used to connect to your ISP, the one between Hex and The Big Bad Web :lol: and how is that supposed to happen ? (PPPoE, ethernet, ...)
Darkside
Re: hEX on ROS 7.6
Mon Oct 24, 2022 8:54 am
Being in Australia it is complicated ; ). We have FTTC, so copper to the premise from the street, which connects to a NetCommWireless NDD-0300, then an Ethernet connection to the Mikrotik, using VDSL2.
it all works fine on 6.49 with my CRS, but everything i try on the hEX unit with 7.5 or7.6 results in no internet.
Users browsing this forum: Bing [Bot] and 42 guests
