lurch
100% cpu usage bridge vlan switching ppp dslam
Mon Oct 24, 2022 2:42 pm
I have a CRS354-48G-4S+2Q+ with a DSLAM connected to sfp-sfpplus2 (vlan4010). I have a 500down/50up g.fast line connected but the maximum throughput i get is around 360mbit/s and when it reaches this the mikrotik cpu is showing 100% usage thus a bottleneck.
Can anyone help with why i'm getting such bad performance and how to resolve it.
# oct/20/2022 13:22:31 by RouterOS 7.2.3
# software id = AUTI-FPMJ
# model = CRS354-48G-4S+2Q+
add admin-mac= auto-mac=no comment=defconf \
    ingress-filtering=no name=bridge vlan-filtering=yes
set [ find default-name=sfp-sfpplus2 ] auto-negotiation=no full-duplex=no \
    speed=10Gbps
set [ find default-name=sfp-sfpplus4 ] speed=10Gbps
/interface vlan
add interface=bridge name=vlan4010 vlan-id=4010
/interface ethernet switch
set 0 l3-hw-offloading=yes
set 0 l3-hw-offloading=no
set 1 l3-hw-offloading=no
set 2 l3-hw-offloading=no
set 3 l3-hw-offloading=no
set 4 l3-hw-offloading=no
set 5 l3-hw-offloading=no
set 6 l3-hw-offloading=no
set 7 l3-hw-offloading=no
set 10 limit-broadcasts=no
set 12 egress-rate=10.0Mbps ingress-rate=10.0Mbps l3-hw-offloading=no
set 13 egress-rate=20.0Mbps ingress-rate=20.0Mbps
set 14 l3-hw-offloading=no
set 15 l3-hw-offloading=no
set 16 l3-hw-offloading=no
set 17 egress-rate=526.0Mbps ingress-rate=570.0Mbps l3-hw-offloading=no
set 18 egress-rate=526.0Mbps ingress-rate=570.0Mbps l3-hw-offloading=no
set 19 l3-hw-offloading=no
set 20 l3-hw-offloading=no
set 24 l3-hw-offloading=no
set 25 l3-hw-offloading=no
set 26 l3-hw-offloading=no
set 27 l3-hw-offloading=no
set 28 l3-hw-offloading=no
set 29 l3-hw-offloading=no
set 30 l3-hw-offloading=no
set 31 l3-hw-offloading=no
set 32 l3-hw-offloading=no
set 33 l3-hw-offloading=no
set 34 l3-hw-offloading=no
set 35 l3-hw-offloading=no
set 36 l3-hw-offloading=no
set 37 l3-hw-offloading=no
set 38 l3-hw-offloading=no
set 39 l3-hw-offloading=no
set 40 l3-hw-offloading=no
set 41 l3-hw-offloading=no
set 42 l3-hw-offloading=no
set 43 l3-hw-offloading=no
set 44 l3-hw-offloading=no
set 45 l3-hw-offloading=no
set 46 l3-hw-offloading=no
set 47 l3-hw-offloading=no
set 48 l3-hw-offloading=no
set 49 l3-hw-offloading=no
set 50 l3-hw-offloading=no
set 51 l3-hw-offloading=no
set 52 l3-hw-offloading=no
set 53 l3-hw-offloading=no
set 54 l3-hw-offloading=no
set 55 l3-hw-offloading=no
set 56 l3-hw-offloading=no
set 57 l3-hw-offloading=no
set 58 l3-hw-offloading=no
set 59 l3-hw-offloading=no
add name=WAN
add name=LAN
/interface lte apn
add name=vlan208_pool ranges=10.10.0.209-10.10.0.222
add address-pool=vlan4010_pool interface=vlan4010 lease-time=1h name=\
    vlan4010_dhcp
/port
set 0 name=serial0
/ppp profile
add local-address=vlan4010_pool name=profile1 remote-address=vlan4010_pool \
    use-ipv6=no
/queue type
add kind=red name=default_red red-avg-packet=1300
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether1
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=ether6
add bridge=bridge comment=defconf ingress-filtering=no interface=ether7
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8
add bridge=bridge comment=defconf ingress-filtering=no interface=ether9
add bridge=bridge comment=defconf ingress-filtering=no interface=ether10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether11
add bridge=bridge comment=defconf ingress-filtering=no interface=ether12
add bridge=bridge comment=defconf ingress-filtering=no interface=ether13
add bridge=bridge comment=defconf ingress-filtering=no interface=ether14
add bridge=bridge comment=defconf ingress-filtering=no interface=ether15
add bridge=bridge comment=defconf ingress-filtering=no interface=ether16
add bridge=bridge comment=defconf ingress-filtering=no interface=ether17
add bridge=bridge comment=defconf ingress-filtering=no interface=ether18
add bridge=bridge comment=defconf ingress-filtering=no interface=ether19
add bridge=bridge comment=defconf ingress-filtering=no interface=ether21
add bridge=bridge comment=defconf ingress-filtering=no interface=ether22
add bridge=bridge comment=defconf ingress-filtering=no interface=ether23
add bridge=bridge comment=defconf ingress-filtering=no interface=ether24
add bridge=bridge comment=defconf ingress-filtering=no interface=ether25
add bridge=bridge comment=defconf ingress-filtering=no interface=ether26
add bridge=bridge comment=defconf ingress-filtering=no interface=ether27
add bridge=bridge comment=defconf ingress-filtering=no interface=ether28
add bridge=bridge comment=defconf ingress-filtering=no interface=ether29
add bridge=bridge comment=defconf ingress-filtering=no interface=ether30
add bridge=bridge comment=defconf ingress-filtering=no interface=ether31
add bridge=bridge comment=defconf ingress-filtering=no interface=ether32
add bridge=bridge comment=defconf ingress-filtering=no interface=ether33
add bridge=bridge comment=defconf ingress-filtering=no interface=ether34
add bridge=bridge comment=defconf ingress-filtering=no interface=ether35
add bridge=bridge comment=defconf ingress-filtering=no interface=ether36
add bridge=bridge comment=defconf ingress-filtering=no interface=ether37
add bridge=bridge comment=defconf ingress-filtering=no interface=ether38
add bridge=bridge comment=defconf ingress-filtering=no interface=ether39
add bridge=bridge comment=defconf ingress-filtering=no interface=ether40
add bridge=bridge comment=defconf ingress-filtering=no interface=ether41
add bridge=bridge comment=defconf ingress-filtering=no interface=ether42
add bridge=bridge comment=defconf ingress-filtering=no interface=ether43
add bridge=bridge comment=defconf ingress-filtering=no interface=ether44
add bridge=bridge comment=defconf ingress-filtering=no interface=ether45
add bridge=bridge comment=defconf ingress-filtering=no interface=ether46
add bridge=bridge comment=defconf ingress-filtering=no interface=ether47
add bridge=bridge comment=defconf ingress-filtering=no interface=ether48
add bridge=bridge comment=defconf ingress-filtering=no interface=ether49
add bridge=bridge comment=defconf ingress-filtering=no interface=qsfpplus1-1
add bridge=bridge comment=defconf ingress-filtering=no interface=qsfpplus1-2
add bridge=bridge comment=defconf ingress-filtering=no interface=qsfpplus1-3
add bridge=bridge comment=defconf ingress-filtering=no interface=qsfpplus1-4
add bridge=bridge comment=defconf ingress-filtering=no interface=qsfpplus2-1
add bridge=bridge comment=defconf ingress-filtering=no interface=qsfpplus2-2
add bridge=bridge comment=defconf ingress-filtering=no interface=qsfpplus2-3
add bridge=bridge comment=defconf ingress-filtering=no interface=qsfpplus2-4
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp-sfpplus1
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp-sfpplus3
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp-sfpplus4
add bridge=bridge interface=ether20
add bridge=bridge interface=sfp-sfpplus2
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface bridge vlan
add bridge=bridge vlan-ids=1
add bridge=bridge tagged=sfp-sfpplus1,bridge
add bridge=bridge tagged=sfp-sfpplus2,sfp-sfpplus1,bridge vlan-ids=4010
add interface=ether1 list=LAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=ether6 list=LAN
add interface=ether7 list=LAN
add interface=ether8 list=LAN
add interface=ether9 list=LAN
add interface=ether10 list=LAN
add interface=ether11 list=LAN
add interface=ether12 list=LAN
add interface=ether13 list=LAN
add interface=ether14 list=LAN
add interface=ether15 list=LAN
add interface=ether16 list=LAN
add interface=ether17 list=LAN
add interface=ether18 list=LAN
add interface=ether19 list=LAN
add interface=ether20 list=LAN
add interface=ether21 list=LAN
add interface=ether22 list=LAN
add interface=ether23 list=LAN
add interface=ether24 list=LAN
add interface=ether25 list=LAN
add interface=ether26 list=LAN
add interface=ether27 list=LAN
add interface=ether28 list=LAN
add interface=ether29 list=LAN
add interface=ether30 list=LAN
add interface=ether31 list=LAN
add interface=ether32 list=LAN
add interface=ether33 list=LAN
add interface=ether34 list=LAN
add interface=ether35 list=LAN
add interface=ether36 list=LAN
add interface=ether37 list=LAN
add interface=ether38 list=LAN
add interface=ether39 list=LAN
add interface=ether40 list=LAN
add interface=ether41 list=LAN
add interface=ether42 list=LAN
add interface=ether43 list=LAN
add interface=ether44 list=LAN
add interface=ether45 list=LAN
add interface=ether46 list=LAN
add interface=ether47 list=LAN
add interface=ether48 list=LAN
add interface=ether49 list=LAN
add interface=qsfpplus1-1 list=LAN
add interface=qsfpplus1-2 list=LAN
add interface=qsfpplus1-3 list=LAN
add interface=qsfpplus1-4 list=LAN
add interface=qsfpplus2-1 list=LAN
add interface=qsfpplus2-2 list=LAN
add interface=qsfpplus2-3 list=LAN
add interface=qsfpplus2-4 list=LAN
add interface=sfp-sfpplus1 list=LAN
add interface=sfp-sfpplus2 list=LAN
add interface=sfp-sfpplus3 list=LAN
add interface=sfp-sfpplus4 list=LAN
/interface ovpn-server server
set auth=sha1,md5
/interface pppoe-server server
add authentication=pap,chap default-profile=profile1 disabled=no interface=\
    vlan4010 service-name=service1
    192.168.88.0
add address=10.10.0.9/24 interface=bridge network=10.10.0.0
add address=10.78.0.254/24 interface=vlan4010 network=10.78.0.0
/ip dhcp-server lease
add address=10.78.0.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=10.78.0.254 \
    netmask=24
set servers=1.1.1.1
add action=fasttrack-connection chain=forward connection-state=\
    established,related hw-offload=yes protocol=tcp
    established,related hw-offload=no
add action=accept chain=forward connection-state=established,related
add action=masquerade chain=srcnat out-interface=bridge src-address=\
    10.78.0.0/24
add action=masquerade chain=srcnat log=yes out-interface=bridge src-address=\
    10.10.0.208/28
add action=accept chain=dstnat in-interface=bridge
add disabled=no dst-address=0.0.0.0/0 gateway=10.10.0.2
/ppp secret
add name=ppp1 profile=profile1
/system clock
set time-zone-name=Europe/London
/system identity
set name=RouterOS
/system routerboard settings
set boot-os=router-os
mkx
Re: 100% cpu usage bridge vlan switching ppp dslam
Mon Oct 24, 2022 9:00 pm
It's a switch with L3 capabilities. Without any special tricks (such as L3HW offload) it's capable of routing at around 300 Mbps give or take. Which is what you see. Either get L3HW offload active (no guarantee that your particular use case fits) or get a proper router (and keep uding your CRS as a very decent switch).
If you'll try with L3HW, upgrade ROS to latest stable (currently it's 7.6).
Users browsing this forum: Google [Bot], rextended and 13 guests
