dima1002
Run script and another script
Mon Oct 24, 2022 7:43 pm
I want to run 2 scripts in a loop. How can this work?
do={ /system/scheduler/disable test AND /system reboot }"
rextended
Re: Run script and another script
Mon Oct 24, 2022 8:22 pm
2 scripts or 2 instructions?
in a loop or one after the other?
Is better you change your translator...
You only wrote a fragment,
writing "do={}" is useless at all, unless there is some very specific reason, it is useless.
It's not the first time I've seen scripts that use it unnecessarily.
in same row:
/system scheduler disable test ; /system reboot
in two row
/system reboot
dima1002
Mon Oct 24, 2022 9:28 pm
Hello Rextended,
1. I want one Script
2. One after the other
3. I would like to query a status, if the status is not the same, a script should be deactivated and then a reboot
For example like this
( [get xxxx] != [get xxxx] ) do={ SCRIPT DISABLE AND system reboot }"
rextended
Mon Oct 24, 2022 10:12 pm
is not a "SCRIPT DISABLE" is one instruction...
please provide at the start the details, for example "get what"...
example code
:if ([get xxxx] != [get xxxx]) do={ /system scheduler disable test ; /system reboot }
dima1002
Mon Oct 24, 2022 11:36 pm
OK thanks, the script works perfectly.
But I have a logic error.
I need a scheduler that runs once on startup and then disables itself.
or a scheduler script that is only executed once at boot.
rextended
Tue Oct 25, 2022 12:27 am
executed once at first boot after the scheduler is set, then disable itself and reboot:
/system scheduler
add name=reboot_script start-time=startup policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    on-event=":delay 20s; :if (true != false) do={ /system scheduler disable reboot_script; /system reboot }"
self destructing scheduler, after the scheduler is set, once executed at boot, delete itself and reboot
/system scheduler
    on-event=":delay 20s; :if (true != false) do={ /system scheduler remove reboot_script; :delay 1s; /system reboot }"
various delays on scripts are needed, are not optionals
replace "true != false" with the condition you need
rextended
Tue Oct 25, 2022 12:32 am
something suggests to me that you might need to check if the firmware is updated, and in case restart for apply the new version???
dima1002
Tue Oct 25, 2022 9:34 am
Yes, I had something similar in mind. How do you know?
rextended
Tue Oct 25, 2022 11:39 am
after years I have some intuition... :lol:
If you do not want dual reboot, extract the firmware file from the corresponding .npk with 7-zip and update before reboot.
For example, if the device is one CRS112-8P-4S, check what is the right firmware type on system / routerboard, on this case is qca8513L
Open with winzip the file routeros mipsbe .npk, go to etc folder, extract qca8513L_xxx.fwf, place it on root of the routerboard,
and when on system / routerboard appear new version under upgrade firmware, upgrade
on this way is not needed the dual reboot.
(after upgrade you do not see the current firmware change, is the old until reboot)
Obviously if the device is one CPE, this can suffice:
/system scheduler
    on-event=":delay 20s; :if ([/sys rou get current-firmware] != [/sys rou get upgrade-firmware]) \
    do={ /system scheduler remove reboot_script; :delay 1s; /system reboot } \
    else={ /system scheduler remove reboot_script }"
Users browsing this forum: Google [Bot], totpbi, UkRainUa and 19 guests
