I have just upgraded to a new RB750Gr3 by manually importing the DHCP, DNS, etc. settings - but from the outset use the defaults of the current version of RouterOS (6.49.7) - and e.g. the firewall rules have been set up much better than on the old box.
When setting up the new box I used the "QuickSet" to enable VPN. And that turns out to be PPTP - and I can connect from a Windows using the built-in VPN. Very easy!
However, I normally work from a Mac and PPTP has been removed since the last couple of OS versions due to less security. I used to use L2TP - and I guess that is still a good choice now.
But since everything has become so easy I was trying to find the "easy" way to change my current PPTP setup on the router to L2TP using the "current best practice" (instead of following my very old steps from last time).
Does anyone have a pointer to a good description and/or some advice/experience?
Thanks in advance!
/John
