lenny77
Hotspot and Station Mode Config
Wed Oct 26, 2022 3:34 pm
I've created the following config for having a MikroTik router operate WLAN1 as Station Mode and WLAN2 as a Hotspot
I'd like to be able to re-route all clients to a specific IP address on ETH2 as they join the Hotspot. Would the be below config allow that?
I'm getting confused around the Hotspot address and the DHCP Pool it'd need to draw from to enable this:
# oct/05/2022 15:34:13 by RouterOS 6.47.10
# software id = V98M-VUTJ
# model = RB952Ui-5ac2nD
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa-psk,wpa2-psk eap-methods="" mode=dynamic-keys \
name=*** supplicant-identity="" wpa-pre-shared-key=***** \
wpa2-pre-shared-key=*****
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
country="united kingdom" disabled=no distance=indoors frequency=auto \
installation=indoor security-profile=*** ssid=*** wireless-protocol=\
802.11
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX country="united kingdom" disabled=no distance=indoors \
frequency=auto installation=indoor mode=ap-bridge ssid=QRCodeSEUK \
wireless-protocol=802.11
add name=bridge
add interface=ether1 list=WAN
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add name=dhcp ranges=192.168.88.10-192.168.88.50
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp disabled=no interface=wlan2 lease-time=1h name=dhcp1
192.168.88.0
add address=192.168.88.5/24 comment="hotspot network" interface=wlan2 \
network=192.168.88.0
/ip hotspot profile
add dns-name=seukqrcode.com hotspot-address=192.168.88.5 html-directory=\
flash/hotspot name=hsprof1
/ip hotspot
add address-pool=dhcp disabled=no interface=wlan2 name=hotspot1 profile=\
hsprof1
/ip hotspot user profile
add add-mac-cookie=no address-pool=dhcp !mac-cookie-timeout name=qrcode
/ip dhcp-client
add disabled=no interface=wlan1
add address=192.168.88.0/24 comment=defconf gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
established,related,untracked
connection-state=invalid
add action=masquerade chain=srcnat src-address=192.168.88.0/24
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
/ip hotspot user
add name=admin password=12345678
add name=qrcodeusr password=qrcodeusr profile=qrcode server=hotspot1
/system clock
set time-zone-name=Europe/London
lenny77
Re: Hotspot and Station Mode Config
Wed Oct 26, 2022 6:51 pm
Ok, so now I have tweaked the config to the below:
# oct/05/2022 15:03:17 by RouterOS 6.47.10
:delay 5s
name=xxx supplicant-identity="" wpa-pre-shared-key=xxx \
wpa2-pre-shared-key=xxx
:delay 5s
/interface wireless
installation=indoor security-profile=xxx ssid=xxx wireless-protocol=\
802.11
/interface wireless
frequency=auto installation=indoor mode=ap-bridge ssid=QRCode \
add name=bridge
add name=staticdev
:delay 5s
add comment=defconf interface=staticdev list=LAN
:delay 5s
add bridge=staticdev interface=ether2
add bridge=staticdev interface=ether3
add bridge=bridge interface=wlan2
:delay 5s
add name=dhcp ranges=10.0.0.10-10.0.0.50
add name=privdhcp ranges=10.0.1.100-10.0.1.10
add address-pool=privpool disabled=no interface=staticdev name=defconf
add address=10.0.0.1/24 comment=defconf interface=bridge network=\
10.0.0.0
add address=10.0.1.1/24 comment=defconf interface=staticdev network=\
10.0.1.0
/ip dhcp-client
add address=10.0.0.0/24 comment=defconf gateway=10.0.0.1 netmask=24
add address=10.0.1.0/24 comment=defconf gateway=10.0.1.1 netmask=24
/ip dns static
add address=10.0.0.1 comment=defconf name=router.lan
add address=10.0.1.1 comment=defconf name=private.lan
add action=masquerade chain=srcnat src-address=10.0.0.0/24
add action=masquerade chain=srcnat src-address=10.0.1.0/24
/system clock
/ip hotspot profile
add dns-name=seukqrcode.com hotspot-address=10.0.0.5 html-directory=\
:delay 5s
/ip hotspot
add address-pool=dhcp disabled=no interface=bridge name=hotspot1 profile=\
hsprof1
/ip hotspot user
While I can browse the internet on both a wired device on eth2 or 3 and I can join the hotspot and browse the internet and send email, I get the attached when trying to browse to a device on eth2
Again, any advice on whether this is possible, or where I am going wrong would be amazing
My alternative is to contract this out to someone on here who can help
Dom
lenny77
Thu Oct 27, 2022 1:37 pm
For anybody wanting to achieve this, the above code worked as expected, it was my phone that was the issue
You can use the above code, but you'll need to amend the "***" for the SSID and Key for your network
I have then edited the HTML to auto re-direct Trial users to the Device page, but ultimately I think this system will not work as I'd like to due to the nature of how phones treat hotspots
On my Android device the auto login works, and I briefly see the "Captive Portal" page before it closes and I am forced to manually open a browser and enter the URL I need
On my iPhone the "Captive Portal" page stays open allowing me to use it as intended
Back to the drawing board
Users browsing this forum: GoogleOther [Bot], Sddaw and 93 guests
