Amm0
Re: v7.7beta [testing] is released!
Mon Dec 05, 2022 7:42 pm
I would expect that this "new naming scheme" is seen as an improvement, and you have to live with it for once.
Totally, for external drives and fresh install, this change makes total sense and "improved".
Sequentially assigning names like "disk1" probably caused problems for others, e.g. when they plugged in a USB stick and rebooted.
So issue may be more specific to the "Dude Edition" since it has what perhaps looks like "external storage", but isn't.
See on the RB1100AHx4+Dude, it's actually the included, built-in SSD disk from Mikrotik... That, not here, but could, have a running dude instance that referenced "disk1", etc. On a clean install this make sense, but perhaps some special handling for the RB1100 to NOT do this on upgrade OR fix any paths in config that might use "disk1" in path for things. We use these RB1100 is few places, so an upgrade that potentially breaks the dude would not be good, is my concern here.
hecatae
Mon Dec 05, 2022 8:05 pm
Looks like Mikrotik Hap Lite is running out of free space to install further updates. What could be improved here apart from buying new hardware?
It only has 32Mb of RAM, what do you expect ? It has been announced already by MT staff ROS7 is not intented for those devices (even if it may work).
You could try netinstall instead of normal upgrade.
Otherwise the alternative will be to stay on current version of ROS7 or go back to ROS6.
The SMIPS v7 release should be pulled if this is the case.
sirbryan
Mon Dec 05, 2022 8:25 pm
In 7.6 I see that the disk and partition on my CCR2116 are named "nvme1" and "nmve1-part1" respectively; a setting under "/disk" shows "set nvme1-part1 name=disk1".
So it looks like it can be changed manually, which makes me wonder how much of the "enhancement" is taken care of automatically, i.e. fresh install vs. renaming after the fact (during upgrade).
And it's the first time I've noticed the "name-tcp-export", "iscsi-export", and "nfs-export". Boy would those be useful.
jhbarrantes
Tue Dec 06, 2022 9:43 am
Thank you for your reprots. We have managed to reproduce 7.7beta9 DNS type=FWD entry issue and will try to fix it as soon as possible.
Sorry strods, I was out. In my case was even simpler: a brand new ax2 just rebooted with default configuration cannot resolve DNS queries when default gateway is used as DNS server. The router itself is able to ping google.com, but not a client behind the router using 192.168.88.1 as DNS. "allow remote requests" is checked, by default.
Kind regards.
antonsb
Tue Dec 06, 2022 10:05 am
Should I expect the file system on RouterOS to go from using "disk1" to "sata1-part1" as the "root" directory name?
Disks will now carry names where they are physical connected - it will make finding physical disk much easier. After formatting, there will be no issues with name changes (disk1 to disk2 for example) as well as this will fix some disks, that changes their names on reboots or re-plugs.
For larger disk arrays this will make much more sense -
/disk print
 6   pcie1-sas-expander1-sata1   TOSHIBA MG07ACA1 3.5in 7200rpm  71U0A2J7Fxxx               SATA 6.0 Gbit
 7   pcie1-sas-expander1-sata2   TOSHIBA MG07ACA1 3.5in 7200rpm  71U0A2JSxxxx               SATA 6.0 Gbit
 8   pcie1-sas-expander1-sata3   TOSHIBA MG07ACA1 3.5in 7200rpm  91M0A181Fxxx              SATA 6.0 Gbit
rpingar
Long time Member
Long time Member
Tue Dec 06, 2022 11:18 am
we started to test Intel Ethernet Controller E810-C on our x86 platform and with 7.7beta8 and 7.7beta9 (the only one we tested) we have issue with GRE/PPTP protocols.
the packets are not passing the interface.
same config swapping to Mellanox cards the problem disappear.
tieckt [SUP-100233] opened, supout sent
emils
Forum Veteran
Forum Veteran
Tue Dec 06, 2022 12:29 pm
Hi all!
Has anyone tried using ChaChaPoly1305 IKEv2?
strongswan customer goes crazy
It works for me between StrongSwan 5.9.8 on Ubuntu and RouterOS. Can you post your relevant IPsec configuration? Did you check the logs on RouterOS side? You can enable debug logging with this command:
/system logging add topics=ipsec,!packet
DenisPDA
Tue Dec 06, 2022 1:19 pm
StrongSwan Android Client 2.3.3
Log ROS
log.1.txt
emils
Forum Veteran
Forum Veteran
Wed Dec 07, 2022 7:52 am
Can you please send us the supout.rif file from your device which is generated as soon as possible after a failed connection attempt with the debug logs still enabled to support@mikrotik.com?
Amm0
Wed Dec 07, 2022 3:03 pm
[/code]
This makes sense to me, actually a good change. Just surprising.
FWIW, I won't mind being surprised by a "/file aliases feature" so you could have a "fake folder" that reference one of the new "bus-partition" names. Or, at least script-accessible way to know the "default disk" - before this change, you could assume "/flash" or "/disk1".
pe1chl
Wed Dec 07, 2022 3:08 pm
Maybe it could be combined with a new feature to have RAMdisk on ALL devices with sufficient RAM (not only those with insufficient flash) and a compatible
and predictable way to store persistent and nonpersistent files?
Amm0
Wed Dec 07, 2022 3:23 pm
Don't disagree. For container images, their "bus-partition" scheme is great since it's explicit on the physical part. But the flip side is in scripting, you just want a stable name to use. I'm just glad there doing something on this front.
antonsb
Wed Dec 07, 2022 3:31 pm
maybe in next release :)
eworm
Wed Dec 07, 2022 3:44 pm
Yes, please! 👍😁
cklee234
Wed Dec 07, 2022 4:34 pm
For v7.7 beta 9, there is still problem for CAPsMAN. I used beta 9 in CAPsMAN and the other APs used v7.6
I can see SSIDs up and AP all connected to CAPsMAN. However, after sometimes, wifi login failed. Seems authentication parts or others problem. Wired connection is ok.
I revert the CAPsMAN back to v7.6 stable, connection is normal.
pothi
Thu Dec 08, 2022 9:43 am
+1 for RAMdisk!
kivimart
Thu Dec 08, 2022 9:59 am
I reverted to 7.7beta6 and wpa-psk2 worked again
cklee234
Thu Dec 08, 2022 2:37 pm
I can only go back to v7.6 stable
Reason: removed excessive quotting of preceding post; be wise, quote smart. lines of quote, 1 line of post.
buset1974
Fri Dec 09, 2022 4:53 pm
FiX the BGP please
holvoetn
Fri Dec 09, 2022 5:04 pm
Change the download link yourself.
E.g. for arm
https://download.mikrotik.com/routeros/ ... a9-arm.npk
Change 7.7beta9 to 7.7beta6
https://download.mikrotik.com/routeros/ ... a6-arm.npk
Drop the NPK on your Files section and reboot.
spippan
Sun Dec 11, 2022 5:36 pm
FiX the BGP please
+100 :(
sirbryan
Mon Dec 12, 2022 12:53 am
On 7.4.1 and 7.6 with CRS3xx routers/switches (particularly 317 and 310), I'm seeing issues where OSPF updates are happening due to link failure and restoration, but the routes don't propagate down to the ASIC without disabling and reenabling L3HW offload. Despite what the routing table says, it still sends traffic the old/backup way.
Has/is this being addressed in 7.7? I don't see anything in the release notes specifically.
emils
Forum Veteran
Forum Veteran
Mon Dec 12, 2022 1:00 pm
RouterOS v7.7rc1 has been released
viewtopic.php?t=191635
Users browsing this forum: gogle and 37 guests
