alibelali
Setup Ubuntu on Docker Container
Wed Oct 26, 2022 8:12 pm
Hello
I have installed x86 RouterOS 7.6 on my pc and everything works fine but I want to setup ubuntu docker container on RouterOS using code below
/container/add remote-image=ubuntu:bionic interface=veth1 root-dir=disk1/ubuntu logging=yes
the container will add successfully but when i try to run , it will stop after a few seconds
if i add
tail -f /dev/null
in cmd field of container , it will not stop but there is no ssh access to it by ip of veth1
also there is no log about container; even if I enable container topic in logging
I don't know what Envs should be added
thanks
antonsb
Re: Setup Ubuntu on Docker Container  Topic is solved
Thu Oct 27, 2022 8:16 am
openssh isn't installed in ubuntu containers by default. You can use shell to access your container -
/container/print
/container/shell 0
tangent
Fri Oct 28, 2022 1:02 pm
I want to setup ubuntu docker container on RouterOS…
Containers are not VMs.
alibelali
Fri Oct 28, 2022 7:24 pm
/container/print
/container/shell 0
It was a huge help :)
Thanks a lot
alibelali
Fri Oct 28, 2022 7:31 pm
I know, It's for testing purposes
but ability of new ROS for running that stuff is incredible
Thank you for noticing
Users browsing this forum: No registered users and 0 guests
