hi How are you guys?
i need an advice.
i have a hotspot which is working fine; and I have installed another mikrotik on that. consider the scenario below.
Hotspot(192.168.10.1/24)
MKT Router (192.168.10.20/24. This router is bypassed as we cannot login)
|(wireless bridge (192.168.15.1)
Mkt Router(192.168.15.2)
| Ether Port (192.168.60.0/24)
Computers
Explanation: A router 192.168.10.20 is connected to the hotspot and working and is accessible. 10.20 router has a wireless bridge with another router and it connects another network 192.168.60.0/24.
Issue is:
I am not able to access the wireless bridge i.e. 192.168.15.0/24 and the network behind that i.e. 192.168.60.0/24 whenever I enable hotspot. If I disable the hotspot, everything works. I can only access 192.168.10.20. So the routing isnt an issue, just when the hotspot enabled, no access. No hotspot no issue. But hotspot is my need, cannot disable it.
