Chaosphere64
DHCP-Client report hostname to external server
Thu Oct 27, 2022 3:39 pm
Hi everyone,
I am trying to get the MT DHCP-Client to report the device's hostname back to an external DHCP server. According to the https://wiki.mikrotik.com/wiki/Manual:IP/DHCP_Client there are three options supported, including hostname. So my questions would be:
1.) is the System Identity the same as the $hostname (or even FQDN), and if not: how can I set it?
2.) how does the DHCP Client / Advanced menu work? You select all DHCP client options you want to report to the server in the upper part of the menu? And you can sort them (why?)?
3.) what would the configuration needed to report the hostname to the DHCP server look like on the MikroTik?
Thanks in advance!
Edit: posted in the wrong section, pls move to Beginner Basics
Sob
Re: DHCP-Client report hostname to external server
Fri Oct 28, 2022 3:03 am
Based on quick test, default hostname sent by DHCP client is taken from system identity. If you want something else without touching identity, you can do:
/ip dhcp-client option
add code=12 name=custom_hostname value="'myrouter'"
/ip dhcp-client
add dhcp-options=custom_hostname,clientid interface=<interface>
Chaosphere64
Fri Oct 28, 2022 11:59 am
Thanks for taking the time to help, much appreciated!
rextended
Fri Oct 28, 2022 1:09 pm
Or more simply....
/ip dhcp-client option set hostname value="'mydevicenicename'"
Notice:
the strig must be delimited between ' and '
and is why used " " for represent one string on script and inside is used ' ' for represent a DHCP option string value.
Users browsing this forum: No registered users and 20 guests
