blingblouw
Redundant VPLS Termination
Fri Oct 28, 2022 1:09 pm
Hi.
Currently all our sites connect to a single Mikrotik router for VPLS termination.
I'm trying to setup a way so that there is an automatic failover incase of hardware issues. I've run a quick lab and it seems like its possible, just wanted to find out what everyone else is doing and if there is maybe a better way.
I'm using LDP and not BGP based signalling.
Basically the idea is that VPLS1 terminates the tunnels, its got a higher OSPF interface priority (and DR) down to VPLS2, Cust1 & Cust2.
VPLS1 & VPLS2 have the SAME lsr-id and transport-id so that if VPLS1 fails, after sometime the route for 1.1.1.1 will hit VPLS2 and tunnels re-establish.
Is this the correct way to go about this?
VPLS1
/interface vpls
add disabled=no l2mtu=1500 mac-address=02:B7:93:34:5B:24 name=vpls-cust1 remote-peer=1.0.0.100 vpls-id=1:1
add disabled=no l2mtu=1500 mac-address=02:34:D8:F1:08:8B name=vpls-cust2 remote-peer=1.0.0.101 vpls-id=1:2
add address=10.100.0.1/24 interface=ether1 network=10.100.0.0
add address=1.0.0.1 interface=lo1 network=1.0.0.1
add address=1.1.1.1 interface=lo2_ha network=1.1.1.1
/mpls interface
set [ find default=yes ] mpls-mtu=1526
/mpls ldp
set enabled=yes lsr-id=1.1.1.1 transport-address=1.1.1.1
/mpls ldp interface
add interface=ether1
add interface=lo2_ha
/routing ospf instance
set [ find default=yes ] disabled=yes router-id=1.0.0.1
/routing ospf interface
add interface=ether1 priority=100
/routing ospf network
add area=backbone network=1.0.0.1/32
add area=backbone network=10.100.0.0/24
add area=backbone network=1.1.1.1/32
VPLS2
/interface vpls
add disabled=no l2mtu=1500 mac-address=02:F5:36:CC:01:C8 name=vpls-cust1 remote-peer=1.0.0.100 vpls-id=1:1
add disabled=no l2mtu=1500 mac-address=02:D7:5A:E2:9F:FD name=vpls-cust2 remote-peer=1.0.0.101 vpls-id=1:2
set [ find default=yes ] router-id=1.0.0.2
add interface=ether1 priority=90
add cost=20 interface=lo2_HA
add area=backbone network=1.0.0.2/32
add address=10.100.0.2/24 interface=ether1 network=10.100.0.0
add address=1.0.0.2 interface=lo1 network=1.0.0.2
add address=1.1.1.1 interface=lo2_HA network=1.1.1.1
[admin@VPLS2] /interface> /mpls ex
/mpls interface
/mpls ldp
/mpls ldp interface
Cust1
/interface vpls
add disabled=no l2mtu=1500 mac-address=02:80:0A:FF:BF:40 name=vpls-core remote-peer=1.1.1.1 vpls-id=1:1
/mpls interface
/mpls ldp
set enabled=yes lsr-id=1.0.0.100 transport-address=1.0.0.100
/mpls ldp interface
set [ find default=yes ] router-id=1.0.0.100
add interface=ether1 priority=0
add area=backbone network=1.0.0.100/32
Cust2
/interface vpls
add disabled=no l2mtu=1500 mac-address=02:28:8B:ED:29:6B name=vpls-core remote-peer=1.1.1.1 vpls-id=1:2
add address=10.100.0.101/24 interface=ether1 network=10.100.0.0
add address=1.0.0.101 interface=lo1 network=1.0.0.101
add address=192.168.1.101/24 interface=vpls-core network=192.168.1.0
/mpls interface
/mpls ldp
set enabled=yes lsr-id=1.0.0.101 transport-address=1.0.0.101
/mpls ldp interface
set [ find default=yes ] router-id=1.0.0.101
add area=backbone network=1.0.0.101/32
EDIT: just cannot get this formatting right....
athatare81
Re: Redundant VPLS Termination
Mon Apr 10, 2023 1:04 am
Hi blingblouw,
Interesting approach! Does it works the way you expected it to work?
Kind regards
mada3k
Long time Member
Long time Member
Mon Apr 10, 2023 11:23 am
Interesting. I think it's best practice not to have any chance of overlapping LSR-ID's, but I'm not sure. It will probably work.
We have solved our redundant tunnels with basically terminating twice (in core1 and core2) and let RSTP decide path. We also have some EoIP tunnels, but those are bound to a VRRP address, so basiclly running in an active/backup fashion. The failover time is about 10s.
blingblouw
Mon Apr 10, 2023 11:40 am
Unfortunately I wasn’t going to implement this on production without further info.
Our biggest issue was not being able to assign public IPs from radius server. Once we got that resolved, also went down the route of multiple vpls tunnels to different BRAS.
It worked in the lab, but who knows what happens over time in prod. :/
StubArea51
Trainer
Trainer
Mon Apr 10, 2023 6:13 pm
The most stable way to accomplish this in prod is to use scripting to keep one of the VPLS tunnels down at the redundant termination point and tie it into VRRP master/backup state.
glueck05
Thu Jul 06, 2023 12:26 pm
Thanks for the hint. I have set the following scripts and it works very well.
Master
/interface vrrp
add comment=Default:Master interface=ether4.vlan1010 interval=500ms name=ether4.vlan1010.vrrp1 on-backup=\
    "/interface vpls disable vpls1.rt1.test;\r\
    \n/mpls ldp set transport-address=10.0.1.1 lsr-id=10.0.1.1;" on-master="/interface vpls enable vpls1.rt1.test;\r\
    \n/mpls ldp set transport-address=10.0.10.6 lsr-id=10.0.10.6;" preemption-mode=no priority=101 vrid=50
Slave
/interface vrrp
add comment="Default: Backup" interface=ether4.vlan1010 interval=500ms name=\
    ether4.vlan1010.vrrp1 on-backup="/interface vpls disable vpls1.rt1.test;\r\
    \n mpls ldp set transport-address=10.0.6.6 lsr-id=10.0.6.6;" on-master="/int\
    \n/mpls ldp set transport-address=10.0.10.6 lsr-id=10.0.10.6;" \
    preemption-mode=no vrid=50
I have now tried to set load balancing in addition to failover. The idea is another VRRP-IF which is the master on rt2 and always alternately enter rt1 or rt2 as the endpoint on the vpls tunnels at the locations. Due to the change of the "Transport Address" at a central point, the whole thing doesn't work. If I set the "Transport Address" on the interfaces, it is not adopted for the VPLS tunnel. Is there a way to set the transport address on an interface basis and the VPLS tunnel adopts this setting? Currently he always takes the lowest IP which corresponds to the documentation.
thanks,
glueck
Users browsing this forum: Bing [Bot], mkx, Semrush [Bot] and 196 guests
