aidanonym
Container environment variable passing not working? (7.6/x86)
Sat Oct 29, 2022 1:05 pm
I've been playing with RouterOS/x86 containers using Hyper-V, but I have not been able to get environment variables passing properly as per the example pihole youtube video. Apologies if there's something simple I'm missing, but I'm not seeing it. My plan was to experiment with ROS/x86 version before shifting to ARM.
This set of steps will reproduce the problem. I'm expecting the shell envrionment variables $FOO and $BAR to be set inside the container, but they are not.
/container config
set registry-url=https://registry-1.docker.io tmpdir=containers/pull
/container envs
add name=ubuntu_env key=FOO value=bar
add name=ubuntu_env key=BAR value=baz
/container/add remote-image=ubuntu:bionic interface=veth1 root-dir=container/ubuntu logging=yes envlist=ubuntu_env cmd="tail -f /dev/null"
# wait for download and extract, then
/container/start number=0
# wait for container to start, then
/container/shell number=0
# "env" command shows shell environment variables are not set from ubuntu_env
Thanks in advance,
- aidan
Version info:
[admin@ROS-x86] /container> /system/resource/print
                   uptime: 1h17m21s
                  version: 7.6 (stable)
               build-time: Oct/17/2022 10:55:40
         factory-software: 7.1
              free-memory: 331.8MiB
             total-memory: 960.0MiB
                      cpu: Intel(R)
                cpu-count: 1
            cpu-frequency: 4708MHz
                 cpu-load: 0%
           free-hdd-space: 1846.9MiB
          total-hdd-space: 1934.1MiB
  write-sect-since-reboot: 1542112
         write-sect-total: 1542112
        architecture-name: x86_64
               board-name: x86
                 platform: MikroTik
aidanonym
Re: Container environment variable passing not working? (7.6/x86)  Topic is solved
Sun Nov 06, 2022 12:55 am
Environment variables passed in are only set for the CMD that runs inside the container in the Mikrotik environment. The shell has no access to these variables.
That the variables are being set can be validated by setting cmd=env and checking the log file:
/container/add remote-image=ubuntu:bionic interface=veth1 root-dir=container/ubuntu logging=yes envlist=ubuntu_env cmd="env"
/container/start 1
/log/print
oct/31 23:49:09 container,info,debug PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
oct/31 23:49:09 container,info,debug FOO=bar
oct/31 23:49:09 container,info,debug BAR=baz
This behaviour is different on my Ubuntu Linux docker environment:
$ docker run -d -e FOO=bar ubuntu "tail -f /dev/null"
$ docker exec -it 2b93a49adca2 bash
root@2b93a49adca2:/# env
HOSTNAME=2b93a49adca2
PWD=/
FOO=bar
HOME=/root
CTSsean
Fri Dec 16, 2022 7:16 pm
aidanonym,
I tried your recommendation when I check the log, I get this...
/container
/container
add cmd=env envlist=ZTnetwork1 interface=veth1-ZT logging=yes start-on-boot=yes
/container envs
add key=NETWORK_ID name=ZTnetwork1 value=1234
/log/print
17:13:16 container,info,debug r=> Configuring networks to join
 17:13:16 container,info,debug r=> Joining networks: [env]
 17:13:16 container,info,debug r===> Configuring join: [env]
 17:13:16 container,info,debug r=> Starting ZeroTier
 17:13:16 container,info,debug r=> Writing healthcheck for networks: [env]
I don't see the variable being set. Any suggestions?
Users browsing this forum: No registered users and 6 guests
