xavierdelphan
2 x WAP60G AP - Sky Q Issue
Sun Oct 30, 2022 10:35 pm
Hi all,
New to Mikrotik kit coming over from Ubiquiti...
I've set up a short distance link (150meters) between two WAP 60G AP's. Set up in bridge mode and working perfectly with gigabit speeds.
The only issue I have come across is with the Sky Q set up - we have the main box on the host AP end and the Sky Q mini on the receivers side. Although the mini box gets an internet connection it can't "see" the main box. Weirdly, if I reset the network on the Sky Q mini box it will boot and work for around 3 mins perfectly, before dropping to an error relating to being unable to find the main box.
This worked perfectly previously on a basic TP-Link 5Ghz PTP set up.
Does anyone have any ideas what I could look at changing? Seems weird that it does work for a few mins (streaming live TV etc) but then stops, almost like the traffic is then being blocked?
Any advice is appreciated - ask for any screenshots of configs etc.
thanks in advance!
stevenma
Re: 2 x WAP60G AP - Sky Q Issue
Fri Nov 04, 2022 8:13 am
Did you resolve this issue?
Are the two Sky Q boxes in the same subnet either side of the radio link? I’m guessing yes as you have the link in Bridge mode. I’m a Sky Q user & former Sky technical project manager but not enough of an MT / networking expert to assist much further.
If you haven’t found a resolution I might be able to ask a former colleague for you.
Rgds, Steve
xavierdelphan
Fri Nov 04, 2022 11:08 am
Hi Steve,
Appreciate the response!
They are indeed set up in bridge mode, so same subnet each end.
Definitely out my depth on the Mikrotik side of things here, but I had assumed that the Mikrotik bridge was blocking some ports or special protocol that the Sky Q requires to see the mini boxes, but the fact it works for a good five mins after a Sky Q network reset before falling back to the error message has thrown me!
I can't understand why it would work for a few mins then completely stop until another reset is performed - the Sky Mini retains its internet connection throughout, just can't see the main Sky Q box after five mins or so. Maybe some weird loopback/addressing issue? Odd that the box seemingly does retain its internet connection.
Anyone other ideas?
thanks
Users browsing this forum: Ahrefs [Bot], patrikg and 123 guests
