philan
How do I assign DHCP Client to Virtual WiFi Interfaces?
Mon Oct 31, 2022 12:34 am
On a 'wAP ac', I have dual band setup that gets its IP information from an upstream firewall/router.
It works beautifully.
But, when I add guest networks by adding Virtual WiFi Interfaces, unlike their master interfaces, fail to get DHCP information from upstream firewall/router.
I tried several random things but nothing worked.
Could someone pelase help.
Here is my config.
# oct/31/2022 00:58:17 by RouterOS 7.6
# model = RBwAPG-5HacT2HnD
add name=bridge1
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
    dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=\
    Guest_Security supplicant-identity=MikroTik
    Main_Security supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-eC \
    disabled=no frequency=auto mode=ap-bridge security-profile=Main_Security \
    ssid=MAIN_2G wds-default-bridge=bridge1 wds-ignore-ssid=yes
add disabled=no keepalive-frames=disabled mac-address=CE:2D:xx:xx:xx:94 \
    master-interface=wlan1 multicast-buffering=disabled name=wlan1_guest \
    security-profile=Guest_Security ssid=GUESTS_2G wds-cost-range=0 \
    wds-default-cost=0 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-eCee disabled=no frequency=auto mode=ap-bridge \
    security-profile=Main_Security ssid=MAIN_5G wds-default-bridge=bridge1 \
    wds-ignore-ssid=yes
add disabled=no keepalive-frames=disabled mac-address=CE:2D:xx:xx:xx:95 \
    master-interface=wlan2 multicast-buffering=disabled name=wlan2_guest \
    security-profile=Guest_Security ssid=GUESTS_5G wds-cost-range=0 \
/ip hotspot profile
/interface bridge filter
add action=drop chain=output dst-mac-address=\
    01:80:C2:00:00:00/FF:FF:FF:FF:FF:FF out-interface=ether1
add bridge=bridge1 interface=wlan1
add bridge=bridge1 interface=wlan2
/interface detect-internet
set detect-interface-list=LAN internet-interface-list=LAN lan-interface-list=\
    LAN wan-interface-list=WAN
add interface=bridge1 list=WAN
add interface=ether1 list=LAN
add address=10.0.0.99/8 interface=ether1 network=10.0.0.0
/ip dhcp-client
add dhcp-options=hostname,clientid_duid interface=bridge1
holvoetn
Re: How do I assign DHCP Client to Virtual WiFi Interfaces?
Mon Oct 31, 2022 12:49 am
How are those virtual interfaces supposed to get IP info if they are not part of the bridge ?
Are they supposed to participate in the same DHCP pool ? If so, add them to the bridge.
If not, is there a separate IP pool upstream or do you need to specify your own ? If your own, add a DHCP server and connect those interfaces to it (two servers, since there are 2 interfaces, can use the same pool).
bpwl
Mon Oct 31, 2022 12:55 am
Ether1,wlan1 and wlan2 are all on the bridge1, and together form just one L2 network.
The bridge will define the interface list and IP address, Because ether1, wlan1 and wlan2 are only "slave" interfaces to the bridge (with no IP address, list membership, etc etc)
What is it now for the bridge? WAN or LAN interface list? (WAN by default will activate NAT and masquerade. It probably must just be LAN)
"detect-internet" will alter your settings, what might end in an invalid configuration. Don't use detect-internet.
philan
Mon Oct 31, 2022 1:04 pm
All real interfaces (ether1, wlan1, wlan2) are members of bridge1. (See attached image)
Since the virtual interfaces (wlan1_guest and wlan2_guest) are children of wlan1 and wlan2, respectively, I thought the would automagically get their DHCP information from the DHCP Client that is assigned to bridge1.
If that is not so, do I need to create a DHCP Clent for each of these virtual interfaces?
BTW, in Winbox, how can I see the members of a bridge?
holvoetn
Mon Oct 31, 2022 1:11 pm
Bridge, ports
philan
Mon Oct 31, 2022 1:31 pm
Bridge, ports
I see.
Thank you.
Can I --should I-- simple add wlan1_guest and wlan2_guest to these?
gotsprings
Mon Oct 31, 2022 2:58 pm
Bridge, ports
I see.
Thank you.
If you want them to get an IP from the same DHCP server... yes add them to that bridge.
philan
Mon Oct 31, 2022 4:27 pm
[/quote]
[/quote]
Thank you. I did that and it worked great.
I have question, I am not sure if this is the place to ask:
If I want to limit the bandwidth for guests wlan's, where/how can I do it?
holvoetn
Mon Oct 31, 2022 4:28 pm
Queues.
Be aware though it means FastTrack will have to be disabled and it might put extra load on your cpu.
Users browsing this forum: Billiam, spookymulder84 and 22 guests
