Quokka
MikroTik hAP ax2 / no connection between mobile app and server application at network device
Mon Oct 31, 2022 9:55 pm
Hi Forum,
This is to solicit your help to solve a problem I am surely not able to overcome myself, despite perusing the MikroTik WiKi and browsing the messages at this forum. At the same time, I have to admit that I am pretty much a noob when it comes to configuring routers beyond the basics, so please bear with me.
My reason for posting is the fact that I am not able to establish a connection between a client app on my mobile phone (‘HQPDControl’) and a music server application on one of my network devices (‘HQPlayer Desktop’), when the phone is hooked up to a WiFi network created by my new MikroTik hAP ax2. To give you an idea what my network looks like, please see the following diagram.
The primary router in my network is a Vilfo VPN router, which (instead of the FritzBox modem / router) assigns static IP-addresses to all devices that are part of my LAN. So far, I have relied on the WiFi network broadcasted by this router (connection Ia in the diagram above) for 1) getting access to Internet with both my work laptop and my mobile phone, 2) WiFi calling with the latter (such, since mobile coverage in and around my home is absolutely abysmal), and 3) controlling the aforementioned music server application (‘HQPlayer Desktop’) on my Apple Mac Mini by means of the ditto client app on my iPhone (‘HQPDControl’).
However, as the WiFi signal that the Vilfo VPN router generates is far from stable, the WiFi network created by the MikroTik hAP ax2 that arrived last week is meant to serve as a more reliable alterative. It certainly does when it comes to getting access to the Internet and WiFi calling; I had the device running in no time, and I have nothing to complain about in this department. What I cannot get figured out, however, is how to connect to the music server application on my Mac Mini, when my iPhone is hooked up to the WiFi network that is broadcast by the MikroTik hAP ax2 (connection Ib). Whether the internet port of the latter is directly connected to the Vilfo VPN router (connection IIa) or to the QNAP switch (connection IIb) does not make a difference: I have access to the Internet and can make WiFi calls, but I can’t reach the Mac Mini from my iPhone.
Setting up a connection between the client app on the phone and the server application on the Mac Mini is basically really straightforward, for which see the screen shot below.
When the client app is provided with the IP address of the Mac Mini as assigned by the Vilfo VPN router (10.220.0.14) and the port the server application listens to (4321), a connection is set up, and the app can give commands (e.g. select album, start playing, adjust volume etc.) to the music server application. However, this is as long as my iPhone is connected to WiFi network as broadcasted by the Vilfo VPN router (connection Ia). The moment I switch and connect my iPhone to the WiFi network that comes from the MikroTik hAP ax2 (connection Ib), the connection between the client app and the music server application is lost, and there is no way re-establishing it.
It is not as if the MikroTik hAP ax2 does not ‘see’ my Mac Mini, though. When I connect my work laptop to its WiFi network (connection Ib) and log in at the management console, I can run an IP scan, the results of which show my Mac Mini at address 10.220.0.14, as well as all other IP addresses as assigned by the Vilfo router (192.168.88.254 is the laptop, and the address right above it my iPhone when connected to the same network).
When I disable ‘stealth mode’ at the Mac Mini, I can ping it from the MikroTik hAP ax2 as well.
As a further bit of information, when I connect my iPhone to the WiFi network broadcasted by my Vilfo VPN router (connection Ia), the info panel about this connection at the phone looks like this:
And when it is connected to the WiFi network broadcasted by MikroTik hAP ax2 (connection Ib), the info panel is as follows:
Additional information as regards the configuration of my MikroTik hAP ax2 may be found in the attached text file, for which see below.
Although I, like written above, have tried to find an answer by browsing the MikroTik WiKi and the messages at this forum, I am simply lacking the background and knowledge to logically deduce in what direction to look for a solution. Therefore, any help or suggestions you could provide me with to put me at the right trail will be warmly welcomed. Should I need to post further details, please do let me know.
Many thanks in advance!
# oct/31/2022 18:44:07 by RouterOS 7.6
# software id = PLFD-7ZHD
# model = C52iG-5HaxD2HaxD
# serial number = XXXXXXXXXXX
add admin-mac=18:FD:74:BB:A7:96 auto-mac=no comment=defconf name=bridge
/interface wifiwave2
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
    configuration.country=Netherlands .mode=ap .ssid=MikroTik-BBA79A \
    disabled=no
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
    configuration.country=Netherlands .mode=ap .ssid=MikroTik-BBA79B \
    disabled=no
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
    192.168.88.0
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Amsterdam
/tool mac-server
/tool mac-server mac-winbox
Users browsing this forum: No registered users and 46 guests
