Hi all,
got a little trobule to sort through, I know this is a dumb setup, but it is what it is, plz dont give me lectures that it should be done differently, it's been a s**t show from the very start of the project,
too much different people involved, not enough info, and it is what it is, a frankestein which has to live - somehow...
Picture attached on imgur for more clarification https://imgur.com/a/62Ea5ZK
Anyway,
I got a Mikrotik behind ISP's router, and UDMSE behind MT.
UDMSE is only for guest network (that was the idea at the begining) separate from the rest of the network (security, alot of users, blah blah blah).
And all of a sudden "we need a Corp Wifi on Unifi AP's, not all selected few)
The only problem is that Corp LAN is on the MT side not the UDMSE side.
I was thinking that on the MT side eth2 that goes towards UDMSE is made as a trunk port (mgmt VLAN - which gives access to the internet, and corp VLAN - which will give the IP pool of MT to the unifi AP's), then on the UDMSE side I make a VLAN only network (Corp LAN) and setup IP as is on the MT side.
Do the rest config for making WiFi on UDMSE side. So when someone connects to Corp Wifi he gets the IP from MT pool of Corp LAN, and has access to stuff thats gonna be there (printers,NAS and god knows what else they plan on putting there later on)
The only issue is that it seems all to simple, I think im missing something crucial.
Thx for any input
