dadaniel
RB260/RBFTC problem with 1000BASE-LX link and 100BASE-T device
Wed Nov 02, 2022 12:18 pm
RB260 and RBFTC stop forwarding traffic if there is at least one 100Mbit-only device connected when at the same time a 1000BASE-LX SFP is plugged in.
Is that an intended behavior? Which Mikrotik devices support 1000Mbit fiber and 100Mbit copper at the same time?
pe1chl
Re: RB260/RBFTC problem with 1000BASE-LX link and 100BASE-T device
Wed Nov 02, 2022 4:28 pm
Not my experience, RB260 with 1Gbit SFP and devices on 100 Mbit should work.
Of course you must not feed >100 Mbps data intended for a 100 Mbps device into the SFP and then still expect the other connected devices to work flawlessly.
Some flow control on a higher level (e.g. TCP with suitable window) is always required in switches with different portspeeds. Ethernet flow control usually does not work.
Users browsing this forum: Bing [Bot], Fogga, Google [Bot] and 214 guests
