sfaqih
checking my ppoe-out1 and ppoe-out2 IP address and disable if equlal to private IP starts with 10.*
Wed Nov 02, 2022 12:33 pm
Dear Team,
I have two lines from ISP which were connected to my mkrotik router 2001 to interfaces pppoe-out1 & pppoe-out2
ISP is disconnecting regularely and I need to check if the connected IP from ISP is to start with private address 10.*.*.*, then disable the interface and reconnect again and keep the connection if IP is none of ip range 10.*.*.*
Note : router model is 2011UiAS-2HnD ; revesion R2 ; upgrade firmware is 6.46.6
Thanks in advance
rextended
Re: checking my ppoe-out1 and ppoe-out2 IP address and disable if equlal to private IP starts with 10.*
Wed Nov 02, 2022 3:42 pm
Why do not you contact your ISP about this?
sfaqih
Thu Nov 03, 2022 12:56 pm
Hi rextended
In fact, the ISP is intended to assign a private IP (10.x.x.x) address with very low speed to the adsl line ( e.g. if Iam paying for 8 Mbps speed plan, they only submit 2 Mbps speed) with this IP. No idea why they are doing this! Maybe they have limited bandwidth.
Anyway, once the line is re-connected with another ip, the line speed is fine. (e.g. buying a 8Mbps speed plan, it reaches in good scenarios to 7.1 Mbps which still good)
I hope I did answer your question.
Finally, this is a WA to get rid of the issue.
rextended
Thu Nov 03, 2022 1:16 pm
[…] this is a WA to get rid of the issue […]
Sorry, what is "WA"?
Probaly when the ISP go out of IPv4 public address assing 10.x to clients, but 10.x must be double natted and is slower...
I have one idea, wait the time I write...
rextended
Thu Nov 03, 2022 1:25 pm
Try this, paste on on-up script on ppp profile used by pppoe-out1 and pppoe-out2:
:if ($"local-address" in 10.0.0.0/8) do={
    :delay 10s
    /interface
    set [get $interface name] name=[get $interface name]
EDIT: added delay for prevent excessive CPU and log usage
rextended
Thu Nov 03, 2022 1:31 pm
Let me know if this work for you.
sfaqih
Thu Nov 03, 2022 10:32 pm
I did paste it this way as shown below:
[img]C:\Users\sfaqih\Desktop\ppp.jpg[/img]
I've created two profiles (profile 1 & profile2)
but I'm not sure which profiles are used by pppoe1 and pppoe2. There must be a way to link the pppoe to the profile number, isn't it?
rextended
Thu Nov 03, 2022 10:34 pm
do not create other profiles, use default or default-encryption, what is used by pppoe-out
sfaqih
Thu Nov 03, 2022 10:39 pm
sorry, here is the attachments
and Yes, you are right, ISP has run of public IPs and there are double NAT for private IPs and tha't why the speed is very low.
sfaqih
Thu Nov 03, 2022 10:44 pm
Ok, I did delete the new profiles and past the script into default and default-encryption but how to test the script. what should it do? Will it find the IP address started with 10.x.x.x and then disconnect the connection and re-connect it again?
Currently, pppoe-out2 has this IP 10.x.x.x as shown in the attachment but nothing changed yet after pasting the script to On Up into the two mentioned profiles above.
rextended
Thu Nov 03, 2022 10:46 pm
you see the effect on next "on-up" when pppoe disconnect and reconnect
sfaqih
Thu Nov 03, 2022 11:12 pm
Yes, I did test this by disconnecting the pppoe-out2 and I've seen in the log that is connected twice. Does it get the same 10.x.x.x IP in the 1st attempt and then tried to reconnect again?!
BTW, in the 2nd attempt, I got a new Ip 134.x.x.x which is good.
it would be pretty if we log info for what happened during the trials of the re-connection. what do you think :)
rextended
Re: checking my ppoe-out1 and ppoe-out2 IP address and disable if equlal to private IP starts with 10.*  [SOLVED]
Thu Nov 03, 2022 11:16 pm
:local pppIP $"local-address"
:local iname [/interface get $interface name]
:if ($pppIP in 10.0.0.0/8) do={
    :log warning "I do not like $pppIP provided by the PPP Server to $iname, I am about to provoke a Reconnect in 10 seconds."
    :delay 10s ; # this prevents excessive CPU usage
    /interface
    set $iname name=$iname
} else={
    :log info "I like $pppIP provided by the PPP Server to $iname"
EDIT: Added delay for not have excessive logging and CPU use...
rextended
Thu Nov 03, 2022 11:48 pm
Work?
sfaqih
Fri Nov 04, 2022 10:58 am
Work?
YES YES, I checked today and it is working pretty fine.
I really appreciate your help. it is genius :)
Thanks a lot and Enjoy the day
I will mark the article as resolved
Users browsing this forum: No registered users and 4 guests
