good morning
Does anyone know what the FS flag means in the routing table?
This flag does not appear in the mikrotik Wiki
Appears in the new 7.X versions
I add capture
Thanks you
add distance=1 dst-address=172.16.0.0/16 gateway=Hotspot1 pref-src=172.16.0.1 \
routing-table=Internet1 scope=10
add distance=1 dst-address=192.168.32.0/23 gateway=Hotspot1 pref-src=\
192.168.33.1 routing-table=Internet1 scope=10
routing-table=Internet2 scope=10
192.168.33.1 routing-table=Internet2 scope=10
routing-table=Internet3 scope=10
192.168.33.1 routing-table=Internet3 scope=10
add comment=Internet1 distance=1 gateway=62.214.10.249%Internet1 pref-src=\
62.214.10.250 routing-table=Internet1
add comment="Internet1 - main" disabled=no distance=1 dst-address=0.0.0.0/0 \
gateway=62.214.10.249%Internet1 pref-src=62.214.10.250 routing-table=main \
scope=30 suppress-hw-offload=no target-scope=10
add comment=Internet2 distance=1 gateway=192.168.178.1%Internet2 pref-src=\
192.168.178.21 routing-table=Internet2
add comment="Internet2 - main" disabled=no distance=2 dst-address=0.0.0.0/0 \
gateway=192.168.178.1%Internet2 pref-src=192.168.178.21 routing-table=main \
add comment=Internet3 distance=1 gateway=192.168.178.1%Internet3 pref-src=\
192.168.178.20 routing-table=Internet3
add comment="Internet3 - main" disabled=no distance=3 dst-address=0.0.0.0/0 \
gateway=192.168.178.1%Internet3 pref-src=192.168.178.20 routing-table=main \
add distance=1 dst-address=192.168.50.0/24 gateway=Lan1 pref-src=192.168.50.1 \
add distance=1 dst-address=192.168.150.0/24 gateway=Lan2 pref-src=192.168.150.1 \
add distance=1 dst-address=192.168.200.0/24 gateway=Lan4 pref-src=192.168.200.1 \
The concept has not been clear: how should internet routes go?Yes, in v7 you need target-scope which must be smaller than (not smaller than or equal) scope.
So usually you see scope=20 or scope=30 and target-scope=10.
Normally, yes. But as you can see in the screenshot, these routes are not obtained by autorouting and thus not passing filters."F" - filtered, means what the name suggests, routes filtered (rejected) by routing filters.
Maybe this not the topic to explain the utterly confusing concept of scopes. Most of us do not understand it!The concept has not been clear: how should internet routes go?Yes, in v7 you need target-scope which must be smaller than (not smaller than or equal) scope.
I add capture of each one and its scope with its target scope.
What is the order ? All 3 have scope=30 and target Scope=10
