valcob
[Wireguard VPN] route all your traffic through VPN tunnel
Wed Nov 02, 2022 11:31 pm
Hey guys, I have a question regarding properly setting up a wireguard VPN tunnel.
So I have a HA3 connected to internet and I have a wireguard VPN client running on it. VPN is up and running normally. The issue is that I have a PC on the br-lan which is mangled to go through VPN, at least the idea is to have all traffic on that PC routed through VPN but when I run speedtest.net the HTML file is loaded but all the JS files timeout (.
So the question is how can I check why not all content is downloadable through VPN?
The destination IP is pingable from the PC no problem also tracert shows that the requests are going actually through VPN connection like [mik router] > [VPN] > [remote router] > [internet] but when I paste the URL into my browser the content is not loaded
THE CONFIG DOESN NOT MATTER AS LONG AS YOU CAN PING THE OTHER SIDE AND AT LEAST OPEN YOUTUBE OR GOOGLE!!!
on tracert cmd the we have the whole path as
1. is local LAN
2. is VPN tunnel
3. is remote LAN
4. is remote ISP
Also configuring the same Wireguard connection on the PC directly with the exact same settings as used in mikrotik's wireguard makes all the issues to be gone, which makes me think that something wrong is on my router
SOLUTION: [b]JUST SET THE SERVER'S MTU TO 1500[/b] should fix the issue
anav
Re: [Wireguard VPN] route all your traffic through VPN tunnel
Wed Nov 02, 2022 11:46 pm
Note Steps 2 and 1.
viewtopic.php?t=182601
valcob
Thu Nov 03, 2022 7:00 pm
snip useless replay
anav
Thu Nov 03, 2022 8:41 pm
Full config (minus serial # and any public WANIP info) ???
valcob
Thu Nov 03, 2022 9:12 pm
snip useless replay
anav
Thu Nov 03, 2022 11:54 pm
(1) I prefer vlans to bridges, but everyone has their own fetish.
(2) Where is the pool, dhcp server, for bridge IOT, I only see it included in IP address and dhcp-server network??????
(3) Where is interfaces WG-Client-Hassio Defined???
It has to come from somewhere and cannot just be added to interface lists without actually existing??
(4) Remember the purpose of interface lists is to normally simplify the firewall rules such that
a. two or more whole subnets can be described by an interface list
b. an exception is usually just the management interface when used.
c. address lists are better for less than whole subnets ( a subset of IP addresses, within or accross subnets), or with a mix of users described by both subnets and subsets of IP addresses).
d. Single subnets are best decribed by the interface its on, such as vlanX or ether3, or by dst or src address=subnet.
Not sure what you are doing but it feels overly complex and messy than what is required.
(5) Overall I think you are being too cute with sourcenat rules but I am not expert so will ask the questions...
a. What is the purpose of this source nat rule which contains both the same src address and dst address? Hairpin nat?
add action=masquerade chain=srcnat comment="defconf: masquerade" dst-address=\
!192.168.0.0/16 ipsec-policy=out,none out-interface-list=WAN src-address=\
192.168.0.0/16
b. What is the purpose of this rule..............
add action=masquerade chain=srcnat dst-address=!10.20.60.0/24 ipsec-policy=\
out,none out-interface-list=WAN src-address=10.20.60.0/24
Do you want all the incoming remote wireguard users coming into the router to go out your internet natted with the IP of your WAN?
There are a number of ways to accomplish this.
One is to include the interface as part of the WAN list
add interface=WG-Server list=WAN
However why would you want to do this? The router is aware of the clients within it that you have identified. Considering the single clients have an IP address of 10.20.60.X
The router already has a route back to the tunnel.
Where making additional route rules comes into play is if you have subnets coming into the router lets say from a remote MT Router device with client subnets, well they are identified on the local router peer lists.
So its real simple to simply put
add dst-address=remotesubnet (.0/24) gwy=WG-Server server table=main DONE.
Any return traffic from the internet or local subnets will get routed appropriately.
In addition you already added the WG Server interface to the LAN list where it makes more sense with firewall rules.
(6) This naturally falls out in a conversation about the next rule.
Here you want to ensure that users from the local bridge going out the wg tunnel are given a source IP address (natted) to that of the wireguard and not the actual subnet source addresses.
For various reasons............. like going to third party VPN etc...
So this makes more sense to me. EXCEPT it looks like the format is wrong!!
add action=masquerade chain=srcnat comment="masquarade vpn" \
out-interface-list=VPN to-addresses=10.7.0.4
This should be better
add action=src-nat chain=srcnat dst-address=10.7.0.4 in-interface=brg-local
Thus any traffic heading out the wireguard interface from local users will get the IP address 10.7.0.4 as source address.
******************** The assumption here is that you want to send all local bridge users out the wireguard for internet ????????
(7) I cannot comment on routes until assumptions are cleared up on user requirements.
For all I know you want remote users coming in on WG-Server to go out WG-Client tunnel not local users.
The better you state the requirements, the better the config will be!!
(8) Same goes for your mangling.
valcob
Fri Nov 04, 2022 2:20 am
snip useless replay
anav
Re: [Wireguard VPN] route all your traffic through VPN tunnel  [SOLVED]
Fri Nov 04, 2022 3:29 am
Could be an MTU problem. On the WG-Client connection on the local router and on the client router set both MTU to 1500 (default is 1420 - which works fine in 95% of cases) and see if that fixes the web issues........
MikroUser
Fri Nov 04, 2022 12:50 pm
Set MTU to 1420
Try use mangle rules to mark routes exacly to wireguard.
Also turn off fasttrack if enabled, in my case fasttrack was a source of all problems with wireguard.
valcob
Fri Nov 04, 2022 1:46 pm
snip useless replay
anav
Fri Nov 04, 2022 2:20 pm
Okay so keep the mtu to defaults 1420, get rid of the mangles noted above and put fastrack back in.
We are going to try MSS Clamp!
Go to client mikrotik, thi is not done on server so on the WG-Client interface........
Go to mangle rules and addd new mangle rule
add chain=forward protocol=tcp out-interface=WG-Client
Then go to ADVANCED TAB at top,
Go to TCP Flags
select from the pull down --> syn
Go to ACTION TAB at top........
select ----> CHANGE MSS
GO TO new TCP MSS:
select --> clamp to pmtu
(if that doesnt work try setting it to 40 less than MTU setting in this case 1420-40=1380)
What is WG client interface connecting to........... whats at the other end another MT router if so please post its config....
If not what is it??? and what settings did they give you to use??
valcob
Fri Nov 04, 2022 2:27 pm
YEP set server to 1500 resolved the issue.
THANKS!!!
anav
Fri Nov 04, 2022 2:48 pm
You still have not stated what the WG-Client is connecting to, nor posted details about that end.
valcob
Fri Nov 04, 2022 2:50 pm
snip useless replay
valcob
Fri Nov 04, 2022 2:51 pm
snip useless replay
anav
Fri Nov 04, 2022 2:54 pm
What settings does it have.................
I am thinking maybe its DNS issues.............
What DNS settings are on that thing what IP address or what gateway is it using for DNS??
anav
Fri Nov 04, 2022 2:55 pm
As for the mangles get rid of it for now as I stated, we will fix your routing issue a better way.
Do you need a whole subnet to go out the wireguard client to the promox or just a single client??
WHat allowed IPs are set at the promox for the WG-client.????
valcob
Fri Nov 04, 2022 3:25 pm
snip useless replay
anav
Fri Nov 04, 2022 3:47 pm
Okay since you have not included the local router subnet or users, on the allowed IPs on the promox wg server, it will be necessary to sourcenat those users to 10.0.7.4 or whatever the wireguard interface address is............ Not the best way to do that as sourcenat is often used when one doesnt have control over the other side..... much clearer and better to set allowed IPs if able....
Yes, understood, you have set it so that the entire subnet will go out the wg-client tunnel to promox.... when you say local traffic assume you mean bridge local.
anav
Fri Nov 04, 2022 3:53 pm
Really tired of the BS,
a. you have no firewall address list in your config and further you have not answered many questions.
b. DNS on promox where does it get it from what gateway
c. What the heck is hassio-client interface not defined anywhere
if not going to be cooperative I will move on.
valcob
Fri Nov 04, 2022 3:57 pm
snip useless replay
valcob
Fri Nov 04, 2022 4:01 pm
snip useless replay
anav
Fri Nov 04, 2022 4:40 pm
a.. this is not defined........
src-address-list=VPN_CLIENTS
where is the firewall address list ????
Keep in mind a firewall address list is NOT the same thing as an interface list!! (interface lists are called by in-interface-list= or out-interface-list=)
valcob
Fri Nov 04, 2022 5:10 pm
snip useless replay
anav
Fri Nov 04, 2022 5:18 pm
Okay so its only one LANIP from subnet 192.168.7.0 that you want to enter the tunnel and not the whole subnet ??
Also, I dont see any firewall rules????? Critical to make sure traffic flows as required.
valcob
Fri Nov 04, 2022 5:35 pm
snip useless replay
anav
Sat Nov 05, 2022 6:28 pm
Okay,,,, Lets simplify and make some changes... (yes remove current mangling you had)
By the way a BIG MISSING ITEM FROM your config is
PEER settings for WG-Server
PEER settings for WG-client
# nov/03/2022 17:05:32 by RouterOS 7.6
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment=name=VPN_LAN
add comment=defconf interface=br-local list=LAN
add interface=br-local list=VPN_LAN
add interface=wan-pppoe-data-vlan list=WAN
add interface=pppoe-wan-data list=WAN
add interface=WG-Server list=LAN
add address=192.168.87.0/24 dns-server=\
10.7.0.1
gateway=192.168.87.1
add address=192.168.87.1/24 interface=br-local network=192.168.87.0
add address=10.7.0.4/24 interface=WG-Client network=10.7.0.0
add address=10.20.60.1/24 interface=WG-Server network=10.20.60.0
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none \
out-interface-list=WAN { General masquerade rule for local traffic including any wireguard traffic from remote sites coming into the router via WG-Server }
add action=masquerade chain=srcnat out-interface=WG-Client { this ensures any traffic leaving router thru tunnel will have IP 10.7.0.4 }
add disabled=no distance=1 dst-address=VPNserver_IP/32 gateway=\
pppoe-wan-data routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
add dst-address=0.0.0.0/0 gateway=WG-Client routing-table=vpn
/routing rule
add src-address=192.168.7.0/24 action=lookup-only-in-gateway table=vpn
{ entire local bridge subnet }
OR
add src-address=192.168.7.44/32 action=lookup-only-in-table table=vpan {single address needing to out tunnel vice local WAN}
Note: if you want user(s) on bridge local to be able to access local internet if the wireguard tunnel is down, change action to action=lookup
After changes made please post COMPLETE config........
If you dont cannot help further......
/export file=anynameyouwish ( minus router serial number and any public WANIP info )
Users browsing this forum: No registered users and 119 guests
