murrayis
v7 Rest API - ANSIBLE - PUT/Post
Thu Nov 03, 2022 8:08 am
Hi All,
I am trying to add a couple of v7 devices into Ansible and as the standard commands appear to fail with v7 I'm looking to replicate the following playbook tasks into a Rest API query.
Task 1:
   - name: Adding VLAN to parent interface
     routeros_command:
      commands:
       - /interface/vlan/add vlan-id=123 name=123 interface=[/interface/get [/interface/find comment~"{{HE_FNN}}"] name]
Task 2:
   - name: Adding IP address to parent VLAN
     routeros_command:
      commands:
       - /ip address add address $Svc_IP interface=$vlan_id comment='Cust: {{Cust_Name}} ['{{Svc_BW}}'] ('{{Svc_Car}}') {'{{Svc_ID}}'}'
The above examples do not contain working variables; that's another issue however the concept is all the matters.
Looking through the limited documentation of the REST API i'm striking out in trying to complete the first task of creating a VLAN without searching for a specific interface based on a unique identifier in the comment.
Playbook:
- hosts: all
  connection: network_cli
  gather_facts: false
  vars:
   ansible_network_os: routeros
  tasks:
      uri:
        url: "{{item.url}}"
        method: PUT
        url_username: username
        url_password: password_is_secure_goes_brrr
        force_basic_auth: yes
        validate_certs: false
        body_format: json
        body: {}
      register: results
      loop:
        - {url: 'https://X.X.X.X/rest/interface/vlan', body: '{vlan-id: "69",name: "69",interface: "sfp-sfpplus8"}' }
Error:
    "item": {
        "body": "{vlan-id: \"69\",name: \"69\",interface: \"sfp-sfpplus8\"}",
        "url": "https://X.X.X.X/rest/interface/vlan"
    "json": {
        "detail": "failure: vlan-id bad",
        "error": 400,
        "message": "Bad Request"
    "msg": "Status code was 400 and not [200]: HTTP Error 400: Bad Request",
    "redirected": false,
    "status": 400,
    "url": "https://X.X.X.X/rest/interface/vlan",
    "x_frame_options": "sameorigin"
Any assistance is greatly appreciated.
murrayis
Re: v7 Rest API - ANSIBLE - PUT/Post
Fri Nov 04, 2022 12:55 am
Quick Update:
I managed to push through and get most of the requests working however I am stuck now on the
.query
function and how to use it with regex?
Working Interface Creation:
      uri:
        url: "{{item.url}}"
        method: POST
        url_username: user
        body_format: json
        body: "{{item.body}}"
        status_code: 200
      register: results
      loop:
        - {url: 'https://x.x.x.x/rest/interface/vlan/add', body: '{"interface":"sfp-sfpplus8","name":"69","vlan-id":"69","comment":"Cust: {{Cust_Name}} [{{Svc_BW}}] ({{Svc_Carrier}}) { {{Svc_FNN}} } "}' }
        - {url: 'https://x.x.x.x/rest/ip/address/add', body: '{"interface":"{{Svc_VLAN}}","address":"{{Svc_IP}}","comment":"Cust: {{Cust_Name}} { {{Svc_FNN}} } "}' }
Regex Query Issue:
        - {url: 'https://x.x.x.x/rest/interface/', body: '{".proplist": ["name"], ".query": ["comment~69"]}' }
mrz
Fri Nov 04, 2022 10:13 am
~ in api is not valid, you cannot use regexps that way.
Any parsing or filtering with regexps must be done on the APP side.
murrayis
Tue Nov 08, 2022 12:55 am
Thanks for the confirmation MRZ.
colin
Thu Aug 24, 2023 1:04 pm
rest api still doesn't support regex query, right?
Users browsing this forum: No registered users and 17 guests
