mihaifpopa
Reject DHCP lease
Thu Nov 03, 2022 12:55 pm
Hello!
I have a problem with my hAP AC3. Whenever my cable modem goes down, my MikroTik gets a 192.168.100.x IP from it instead of the WAN public address. Coming from pfSense, which had this option to reject DHCP leases from an IP, how can I get this done on RouterOS?
Link here for the option on pfSense: https://www.reddit.com/r/PFSENSE/commen ... are_button
Thank you!
BrateloSlava
Re: Reject DHCP lease
Thu Nov 03, 2022 5:21 pm
If you receive an address from the 192.168.100.0 subnet, is the global network available?
Or rather, not even so. See, what gateway address your router is getting on the 192.168.100.0 network. I understand, that this address will be available only if there is no access to the global network. Therefore, through NetWatch, you can check. If this address is available, execute the dhcp client reset command on the required interface.
This is the first thing, that came to mind.
mihaifpopa
Mon Nov 07, 2022 5:45 pm
I have no clue how to do that, honestly. Any help with that?
Thank you so much!
rextended
Re: Reject DHCP lease  [SOLVED]
Mon Nov 07, 2022 6:04 pm
Based on this:
viewtopic.php?t=190573#p965860
Paste this on DHCP Client / Advanced / Script
:if ($bound = 1) do={
    :local leaseIP $"lease-address"
    :local iname   [/interface get $interface name]
    :if ($leaseIP in 192.168.100.0/24) do={
        :log warning "I do not like $leaseIP provided by the DHCP Server on $iname, I am about to provoke a Release in 10 seconds."
        :delay 10s ; # this prevents excessive CPU usage
        /ip dhcp-client
        release [find where interface=$iname]
    } else={
        :log info "I like $leaseIP provided by the DHCP Server on $iname."
mihaifpopa
Mon Nov 07, 2022 7:09 pm
While I have found this workaround which is similar but less efficient since it pings 8.8.8.8 continuously, I'm using yours because it's much, much more efficient.
viewtopic.php?t=153318#p839035
Thank you so much for your quick reply! Tested and it's working amazing!
Reason: removed excessive quotting of preceding post; be wise, quote smart.
Users browsing this forum: No registered users and 11 guests
