Matta
hAP ax² - second virtual WLAN on 2.4GHz ?
Fri Nov 04, 2022 4:08 pm
I just got my hAP ax² and having hard time with wifiwave 2 config.
I need two virtual WLANs on both 2.4 and 5GHz. I made two on 5GHz without issues, but when I try to make second one on 2.4GHz (main 2.4 interface set as master), I get message "failed to create interface". On the other hand, if I set first 2.4 virtual as master for second, interface is created.
What to do here ?
erlinden
Re: hAP ax² - second virtual WLAN on 2.4GHz ?
Fri Nov 04, 2022 4:12 pm
What version of RouterOS are you running?
And can you share your config (/export hide-sensitive file=anynameyoulike, don't forget to remove any personal information)?
Matta
Fri Nov 04, 2022 4:21 pm
Here's the config, I just started, ignore everything except wifi (nothing is configured for now).
Matta
Fri Nov 04, 2022 4:59 pm
I've configured everything, cannot get 2nd "virtual WLAN" on 2.4GHz interface (which is set as master to both of them). If I enable first, second gets "failed to create interface" message. If I enable second, first one gets that message. If I set first virtual WLAN to be master on second virtual WLAN, I don't get above message but it doesn't work (obviously).
Config in attachment.
Matta
Sat Nov 05, 2022 2:02 pm
*bump* for this
Anyone tried to replicate ?
FToms
Re: hAP ax² - second virtual WLAN on 2.4GHz ?  [SOLVED]
Wed Nov 09, 2022 9:13 am
The reason you cannot run both guest-wlan and private-guest2 interfaces at the same time is that you've configured identical MAC addresses for both of them.
anav
Thu Nov 10, 2022 11:48 pm
Ftoms, did the software do that or does the admin have to manually shoot themselves in the foot?
Why would one set the same mac address?? Seems like running naked with scissors. ;-)
Matta
Fri Nov 11, 2022 9:16 am
Thank you, I guess I never went to look there, because I never had issue like that.
I certainly didn't do that. It was made from scratch, same as for two 5GHz virtual APs, which didn't get same MAC.
I guess I ran into a small bug. :D
Anyway, thank again, everything is working as it should ! :)
anav
Sat Nov 12, 2022 5:49 pm
Nice find matta, please ensure you send in a ticket- bug report.
Users browsing this forum: No registered users and 10 guests
