miko385
ac AP, mixed n/ac clients - any drawback?
Sat Nov 05, 2022 4:53 pm
i have an ac AP that is now serving 2 clients. priority is high speed to the 1st client, and decent speed to the 2nd client. this was mounted around 2 years ago.
ap is a dyna, the clients are ~800m and 1km away in the same direction (around 3 degrees apart from each other).
one client is a disc ac, other client is sxt ac. the client with sxt is getting bad signal because a tree grew up and is dropping modulation and i was thinking to replace it with lhg 5 or lhg 5 xl (non-ac).
can i replace the sxt with a lhg or lhg xl (AN, not AC)? i'm using 80mhz channel.
can 1 client use 80mhz, and the other client use 40mhz?
my reasoning is that it's better to have a good signal on AN modulation (so it can stay all the time max on 300mbit), than to have an ac client with bad signal that often drops to 87mbits.
anav
Re: ac AP, mixed n/ac clients - any drawback?
Sat Nov 05, 2022 5:33 pm
Users browsing this forum: phascogale and 80 guests
