zman85
SIP - Audio only in local network
Sun Nov 06, 2022 2:23 am
I have a Zycoo VOIP gateway. Two locations connected VPN -> IPsec, phones work between locations, but I have a problem with the voip client on the mobile phone. Whether I am in the LAN or am using cellular data, I can register, I can make a call, but only in the local network does my voice work. When disconnecting the WiFi network and connecting to cellular data, despite the fact that I can get through, I can not hear me or the recipient.
I have been sitting for several hours looking for the cause.
Service Port -> sip is enabled.
In addition, the command set in the NAT (because I can not connect without it, being in a different location, despite a VPN connection)
/ ip firewall nat add action = dst-nat chain = dstnat dst-port = 5060 in-interface-list = WAN protocol = udp to-addresses = 192.168.20.200 to-ports = 5060
Where to find the reason for the lack of sound?
loloski
Re: SIP - Audio only in local network
Sun Nov 06, 2022 4:20 am
this is not related to Mikrotik per se and usually audio issue means NAT traversal issue could be in-play, there's a lot of variable here you can start on hunting the issue the way that particular local is configured if they are configured behind a NAT or not in mind
zman85
Sun Nov 06, 2022 7:17 pm
This must be DISABLED, and after disable must be REBOOT.
Everything working. Thank You.
Users browsing this forum: No registered users and 22 guests
