I work on test with the new LHGGM (LHGGM&EG18-EA).
I have a problem with several ISP on FRANCE. With the ISP SFR, impossible to switch on LTE, only HSUPA (FW 7.6 // FW MODEM UP TO DATE)
But, when i try an other ISP, FREE MOBILE, connected on LTE with 2CA perfectly.
So, what's happened with SFR ? Problem with IMEI and spec with this new model ?
What is the way of a new device and own spec (LTE capacities etc...) ?
Current log:
Code: Select all
# nov/ 7/2022 18: 7: 1 by RouterOS 7.6
# software id = JY03-MU8K
nov/04 09:25:05 system,error,critical router was rebooted without proper shutdown
nov/04 09:25:17 lte,async lte1: sent AT E0 V1
nov/04 09:25:17 lte,async lte1: rcvd OK
nov/04 09:25:17 lte,async lte1: sent AT+CMEE=2
nov/04 09:25:17 lte,debug lte1 mbim: state 0=>1
nov/04 09:25:17 lte,debug lte1 mbim: wdm max tx 4096
nov/04 09:25:17 lte,debug lte1 mbim: <<< open
nov/04 09:25:17 lte,packet,raw lte1 mbim: wdm <<< send #1
nov/04 09:25:17 lte,packet,raw 01000000 10000000 01000000 00100000
nov/04 09:25:17 lte,async lte1: sent AT+CGREG=2
nov/04 09:25:17 lte,async lte1: sent AT+CEREG=2
nov/04 09:25:17 lte,async lte1: sent AT+EGMR=0,5
nov/04 09:25:17 lte,async lte1: rcvd +EGMR: "MPA21AL090102310P"
nov/04 09:25:17 lte,async lte1: sent AT+QSIMDET=1,1
nov/04 09:25:17 lte,async lte1: sent AT+QGMR
nov/04 09:25:17 lte,async lte1: rcvd EG18EAPAR01A12M4G_01.001.01.001
nov/04 09:25:17 lte,async lte1: sent AT+QNVFR="/nv/item_files/Thin_UI/enable_thin_ui_cfg"
nov/04 09:25:17 lte,async lte1: rcvd +QNVFR: 00
nov/04 09:25:17 lte,async lte1: sent AT+QCFG="pdp/duplicatechk"
nov/04 09:25:17 lte,async lte1: rcvd +QCFG: "pdp/duplicatechk",0
nov/04 09:25:17 lte,async lte1: sent AT+QNVW=5280,0,"0102000000000000"
nov/04 09:25:17 lte,async lte1: sent AT+QCFG="ims"
nov/04 09:25:17 lte,async lte1: rcvd +QCFG: "ims",0,0
nov/04 09:25:17 lte,async lte1: sent AT+QNETINFO="cmrctl",1
nov/04 09:25:17 lte,async lte1: sent AT+QCFG="lte/bandprior",3,7,1
nov/04 09:25:17 lte,async lte1: sent AT+QNWCFG="rat_seq",0403
nov/04 09:25:17 lte,async lte1: sent AT+QNWCFG="bearer",0,1
nov/04 09:25:18 lte,packet,raw lte1 mbim: wdm >>> recv #1
nov/04 09:25:18 lte,packet,raw 01000080 10000000 01000000 00000000
nov/04 09:25:18 lte,debug lte1 mbim: open done, status: 0
nov/04 09:25:18 lte,debug lte1 mbim: state 1=>2
nov/04 09:25:18 lte,debug lte1 mbim: set radio: off
nov/04 09:25:18 lte,debug lte1 mbim: <<< S service: connect, command: radio state
nov/04 09:25:18 lte,packet,raw lte1 mbim: wdm <<< send #2
nov/04 09:25:18 lte,packet,raw 03000000 34000000 02000000 01000000
nov/04 09:25:18 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
nov/04 09:25:18 lte,packet,raw c2aae6df 03000000 01000000 04000000
nov/04 09:25:18 lte,packet,raw lte1 mbim: wdm >>> recv #2
nov/04 09:25:18 lte,packet,raw 03000080 38000000 02000000 01000000
nov/04 09:25:18 lte,packet,raw c2aae6df 03000000 00000000 08000000
nov/04 09:25:18 lte,packet,raw 01000000 00000000
nov/04 09:25:18 lte,debug lte1 mbim: >>> D service: connect, command: radio state
nov/04 09:25:18 lte,packet lte1 mbim: status data:
nov/04 09:25:18 lte,packet 01000000 00000000
nov/04 09:25:18 lte,debug lte1 mbim: state 2=>6
nov/04 09:25:18 lte,debug lte1 mbim: <<< Q service: connect, command: device services
nov/04 09:25:18 lte,packet,raw lte1 mbim: wdm <<< send #3
nov/04 09:25:18 lte,packet,raw 03000000 30000000 03000000 01000000
nov/04 09:25:18 lte,packet,raw c2aae6df 10000000 00000000 00000000
nov/04 09:25:18 lte,packet,raw lte1 mbim: wdm >>> recv #0
nov/04 09:25:18 lte,packet,raw 07000080 48000000 00000000 01000000
nov/04 09:25:18 lte,packet,raw c2aae6df 0a000000 1c000000 00000000
nov/04 09:25:18 lte,packet,raw 04000000 00000000 00000000 00000000
nov/04 09:25:18 lte,packet,raw 00000000 00000000
nov/04 09:25:18 lte,debug lte1 mbim: >>> N service: connect, command: packet service
nov/04 09:25:18 lte,packet 00000000 04000000 00000000 00000000
nov/04 09:25:18 lte,packet 00000000 00000000 00000000
nov/04 09:25:18 lte,debug lte1 mbim: packet service: detached data class: 0x0 nwe:
nov/04 09:25:18 lte,packet,raw lte1 mbim: wdm >>> recv #3
nov/04 09:25:18 lte,packet,raw 03000080 60030000 03000000 01000000
nov/04 09:25:18 lte,packet,raw c2aae6df 10000000 00000000 30030000
nov/04 09:25:18 lte,packet,raw 0f000000 00000000 80000000 6c000000
nov/04 09:25:18 lte,packet,raw ec000000 30000000 1c010000 20000000
nov/04 09:25:18 lte,packet,raw 3c010000 2c000000 68010000 28000000
nov/04 09:25:18 lte,packet,raw 90010000 24000000 b4010000 20000000
nov/04 09:25:18 lte,packet,raw d4010000 20000000 f4010000 24000000
nov/04 09:25:18 lte,packet,raw 18020000 20000000 38020000 34000000
nov/04 09:25:18 lte,packet,raw 6c020000 28000000 94020000 34000000
nov/04 09:25:18 lte,packet,raw c8020000 44000000 0c030000 24000000
nov/04 09:25:18 lte,packet,raw a289cc33 bcbb8b4f b6b0133e c2aae6df
nov/04 09:25:18 lte,packet,raw 00000000 00000000 14000000 01000000
nov/04 09:25:18 lte,packet,raw 02000000 03000000 04000000 05000000
nov/04 09:25:18 lte,packet,raw 06000000 07000000 08000000 09000000
nov/04 09:25:18 lte,packet,raw 0a000000 0b000000 0c000000 0d000000
nov/04 09:25:18 lte,packet,raw 0f000000 10000000 13000000 14000000
nov/04 09:25:18 lte,packet,raw 15000000 16000000 17000000 533fbeeb
nov/04 09:25:18 lte,packet,raw 14fe4467 9f9033a2 23e56c3f 00000000
nov/04 09:25:18 lte,packet,raw 00000000 05000000 01000000 02000000
nov/04 09:25:18 lte,packet,raw 03000000 04000000 05000000 e550a0c8
nov/04 09:25:18 lte,packet,raw 5e82479e 82f710ab f4c3351f 00000000
nov/04 09:25:18 lte,packet,raw 00000000 01000000 01000000 4bf38476
nov/04 09:25:18 lte,packet,raw 1e6a41db b1d8bed2 89c25bdb 00000000
nov/04 09:25:18 lte,packet,raw 00000000 04000000 01000000 02000000
nov/04 09:25:18 lte,packet,raw 03000000 04000000 d8f20131 fcb54e17
nov/04 09:25:18 lte,packet,raw 8602d6ed 3816164c 00000000 00000000
nov/04 09:25:18 lte,packet,raw 03000000 01000000 02000000 03000000
nov/04 09:25:18 lte,packet,raw 1d2b5ff7 0aa148b2 aa5250f1 5767174e
nov/04 09:25:18 lte,packet,raw 00000000 00000000 02000000 01000000
nov/04 09:25:18 lte,packet,raw 03000000 d1a30bc2 f97a6e43 bf65c7e2
nov/04 09:25:18 lte,packet,raw 4fb0f0d3 00000000 00000000 01000000
nov/04 09:25:18 lte,packet,raw 01000000 883b7c26 985f43fa 980427d7
nov/04 09:25:18 lte,packet,raw fb80959c 00000000 00000000 01000000
nov/04 09:25:18 lte,packet,raw 01000000 2d0c12c9 0e6a495a 915c8d17
nov/04 09:25:18 lte,packet,raw 4fe5d63c 00000000 00000000 02000000
nov/04 09:25:18 lte,packet,raw 01000000 02000000 e9f7dea2 feaf4009
nov/04 09:25:18 lte,packet,raw 93ce90a3 694103b6 00000000 00000000
nov/04 09:25:18 lte,packet,raw 01000000 01000000 5967bdcc 7fd249a2
nov/04 09:25:18 lte,packet,raw 9f5cb2e7 0e527db3 00000000 00000000
nov/04 09:25:18 lte,packet,raw 06000000 01000000 02000000 03000000
nov/04 09:25:18 lte,packet,raw 04000000 09000000 0a000000 6427015f
nov/04 09:25:18 lte,packet,raw 579d48f5 8c54f43e d1e76f83 00000000
nov/04 09:25:18 lte,packet,raw 00000000 03000000 01000000 02000000
nov/04 09:25:18 lte,packet,raw 03000000 c2f6588e f0374bc9 8665f4d4
nov/04 09:25:18 lte,packet,raw 4bd09367 00000000 00000000 06000000
nov/04 09:25:18 lte,packet,raw 01000000 02000000 03000000 04000000
nov/04 09:25:18 lte,packet,raw 05000000 06000000 3d01dcc5 fef54d05
nov/04 09:25:18 lte,packet,raw 0d3abef7 058e9aaf 00000000 00000000
nov/04 09:25:18 lte,packet,raw 0a000000 01000000 03000000 04000000
nov/04 09:25:18 lte,packet,raw 05000000 06000000 07000000 08000000
nov/04 09:25:18 lte,packet,raw 0a000000 0b000000 0c000000 68223d04
nov/04 09:25:18 lte,packet,raw 9f6c4e0f 822d2844 1fb72340 00000000
nov/04 09:25:18 lte,packet,raw 00000000 02000000 01000000 02000000
nov/04 09:25:18 lte,debug lte1 mbim: >>> D service: connect, command: device services
nov/04 09:25:18 lte,packet 0f000000 00000000 80000000 6c000000
nov/04 09:25:18 lte,packet ec000000 30000000 1c010000 20000000
nov/04 09:25:18 lte,packet 3c010000 2c000000 68010000 28000000
nov/04 09:25:18 lte,packet 90010000 24000000 b4010000 20000000
nov/04 09:25:18 lte,packet d4010000 20000000 f4010000 24000000
nov/04 09:25:18 lte,packet 18020000 20000000 38020000 34000000
nov/04 09:25:18 lte,packet 6c020000 28000000 94020000 34000000
nov/04 09:25:18 lte,packet c8020000 44000000 0c030000 24000000
nov/04 09:25:18 lte,packet a289cc33 bcbb8b4f b6b0133e c2aae6df
nov/04 09:25:18 lte,packet 00000000 00000000 14000000 01000000
nov/04 09:25:18 lte,packet 02000000 03000000 04000000 05000000
nov/04 09:25:18 lte,packet 06000000 07000000 08000000 09000000
nov/04 09:25:18 lte,packet 0a000000 0b000000 0c000000 0d000000
nov/04 09:25:18 lte,packet 0f000000 10000000 13000000 14000000
nov/04 09:25:18 lte,packet 15000000 16000000 17000000 533fbeeb
nov/04 09:25:18 lte,packet 14fe4467 9f9033a2 23e56c3f 00000000
nov/04 09:25:18 lte,packet 00000000 05000000 01000000 02000000
nov/04 09:25:18 lte,packet 03000000 04000000 05000000 e550a0c8
nov/04 09:25:18 lte,packet 5e82479e 82f710ab f4c3351f 00000000
nov/04 09:25:18 lte,packet 00000000 01000000 01000000 4bf38476
nov/04 09:25:18 lte,packet 1e6a41db b1d8bed2 89c25bdb 00000000
nov/04 09:25:18 lte,packet 00000000 04000000 01000000 02000000
nov/04 09:25:18 lte,packet 03000000 04000000 d8f20131 fcb54e17
nov/04 09:25:18 lte,packet 8602d6ed 3816164c 00000000 00000000
nov/04 09:25:18 lte,packet 03000000 01000000 02000000 03000000
nov/04 09:25:18 lte,packet 1d2b5ff7 0aa148b2 aa5250f1 5767174e
nov/04 09:25:18 lte,packet 00000000 00000000 02000000 01000000
nov/04 09:25:18 lte,packet 03000000 d1a30bc2 f97a6e43 bf65c7e2
nov/04 09:25:18 lte,packet 4fb0f0d3 00000000 00000000 01000000
nov/04 09:25:18 lte,packet 01000000 883b7c26 985f43fa 980427d7
nov/04 09:25:18 lte,packet fb80959c 00000000 00000000 01000000
nov/04 09:25:18 lte,packet 01000000 2d0c12c9 0e6a495a 915c8d17
nov/04 09:25:18 lte,packet 4fe5d63c 00000000 00000000 02000000
nov/04 09:25:18 lte,packet 01000000 02000000 e9f7dea2 feaf4009
nov/04 09:25:18 lte,packet 93ce90a3 694103b6 00000000 00000000
nov/04 09:25:18 lte,packet 01000000 01000000 5967bdcc 7fd249a2
nov/04 09:25:18 lte,packet 9f5cb2e7 0e527db3 00000000 00000000
nov/04 09:25:18 lte,packet 06000000 01000000 02000000 03000000
nov/04 09:25:18 lte,packet 04000000 09000000 0a000000 6427015f
nov/04 09:25:18 lte,packet 579d48f5 8c54f43e d1e76f83 00000000
nov/04 09:25:18 lte,packet 00000000 03000000 01000000 02000000
nov/04 09:25:18 lte,packet 03000000 c2f6588e f0374bc9 8665f4d4
nov/04 09:25:18 lte,packet 4bd09367 00000000 00000000 06000000
nov/04 09:25:18 lte,packet 01000000 02000000 03000000 04000000
nov/04 09:25:18 lte,packet 05000000 06000000 3d01dcc5 fef54d05
nov/04 09:25:18 lte,packet 0d3abef7 058e9aaf 00000000 00000000
nov/04 09:25:18 lte,packet 0a000000 01000000 03000000 04000000
nov/04 09:25:18 lte,packet 05000000 06000000 07000000 08000000
nov/04 09:25:18 lte,packet 0a000000 0b000000 0c000000 68223d04
nov/04 09:25:18 lte,packet 9f6c4e0f 822d2844 1fb72340 00000000
nov/04 09:25:18 lte,packet 00000000 02000000 01000000 02000000
nov/04 09:25:18 lte,debug lte1 mbim: device service: a289cc33bcbb8b4fb6b0133ec2aae6df command count: 20
nov/04 09:25:18 lte,debug lte1 mbim: device service: 533fbeeb14fe44679f9033a223e56c3f command count: 5
nov/04 09:25:18 lte,debug lte1 mbim: device service: e550a0c85e82479e82f710abf4c3351f command count: 1
nov/04 09:25:18 lte,debug lte1 mbim: device service: 4bf384761e6a41dbb1d8bed289c25bdb command count: 4
nov/04 09:25:18 lte,debug lte1 mbim: device service: d8f20131fcb54e178602d6ed3816164c command count: 3
nov/04 09:25:18 lte,debug lte1 mbim: device service: 1d2b5ff70aa148b2aa5250f15767174e command count: 2
nov/04 09:25:18 lte,debug lte1 mbim: device service: d1a30bc2f97a6e43bf65c7e24fb0f0d3 command count: 1
nov/04 09:25:18 lte,debug lte1 mbim: qmux service
nov/04 09:25:18 lte,debug lte1 mbim: device service: 883b7c26985f43fa980427d7fb80959c command count: 1
nov/04 09:25:18 lte,debug lte1 mbim: device service: 2d0c12c90e6a495a915c8d174fe5d63c command count: 2
nov/04 09:25:18 lte,debug lte1 mbim: device service: e9f7dea2feaf400993ce90a3694103b6 command count: 1
nov/04 09:25:18 lte,debug lte1 mbim: device service: 5967bdcc7fd249a29f5cb2e70e527db3 command count: 6
nov/04 09:25:18 lte,debug lte1 mbim: device service: 6427015f579d48f58c54f43ed1e76f83 command count: 3
nov/04 09:25:18 lte,debug lte1 mbim: device service: c2f6588ef0374bc98665f4d44bd09367 command count: 6
nov/04 09:25:18 lte,debug lte1 mbim: device service: 3d01dcc5fef54d050d3abef7058e9aaf command count: 10
nov/04 09:25:18 lte,debug lte1 mbim: connect ext cids: 1,3,4,5,6,7,8,10,11,12
nov/04 09:25:18 lte,debug lte1 mbim: <<< Q service: connect, command: device caps
nov/04 09:25:18 lte,packet,raw lte1 mbim: wdm <<< send #4
nov/04 09:25:18 lte,packet,raw 03000000 30000000 04000000 01000000
nov/04 09:25:18 lte,packet,raw c2aae6df 01000000 00000000 00000000
nov/04 09:25:18 lte,packet,raw lte1 mbim: wdm >>> recv #4
nov/04 09:25:18 lte,packet,raw 03000080 c4000000 04000000 01000000
nov/04 09:25:18 lte,packet,raw c2aae6df 01000000 00000000 94000000
nov/04 09:25:18 lte,packet,raw 03000000 01000000 01000000 02000000
nov/04 09:25:18 lte,packet,raw 3c000000 03000000 01000000 08000000
nov/04 09:25:18 lte,packet,raw 00000000 00000000 40000000 1e000000
nov/04 09:25:18 lte,packet,raw 60000000 22000000 84000000 0e000000
nov/04 09:25:18 lte,packet,raw 38003600 39003800 31003600 30003400
nov/04 09:25:18 lte,packet,raw 30003900 38003100 39003200 39000000
nov/04 09:25:18 lte,packet,raw 45004700 31003800 45004100 50004100
nov/04 09:25:18 lte,packet,raw 52003000 31004100 31003200 4d003400
nov/04 09:25:18 lte,packet,raw 47000000 45004700 31003800 2d004500
nov/04 09:25:18 lte,packet,raw 41000000
nov/04 09:25:18 lte,debug lte1 mbim: >>> D service: connect, command: device caps
nov/04 09:25:18 lte,packet 03000000 01000000 01000000 02000000
nov/04 09:25:18 lte,packet 3c000000 03000000 01000000 08000000
nov/04 09:25:18 lte,packet 00000000 00000000 40000000 1e000000
nov/04 09:25:18 lte,packet 60000000 22000000 84000000 0e000000
nov/04 09:25:18 lte,packet 38003600 39003800 31003600 30003400
nov/04 09:25:18 lte,packet 30003900 38003100 39003200 39000000
nov/04 09:25:18 lte,packet 45004700 31003800 45004100 50004100
nov/04 09:25:18 lte,packet 52003000 31004100 31003200 4d003400
nov/04 09:25:18 lte,packet 47000000 45004700 31003800 2d004500
nov/04 09:25:18 lte,packet 41000000
nov/04 09:25:18 lte,debug lte1 mbim: device caps: cls:3c sms:3 sim:removable ctr:1 max_sess:8
nov/04 09:25:18 lte,debug lte1 mbim: <<< Q service: conn_ext, command: sys caps
nov/04 09:25:18 lte,packet,raw lte1 mbim: wdm <<< send #5
nov/04 09:25:18 lte,packet,raw 03000000 30000000 05000000 01000000
nov/04 09:25:18 lte,packet,raw 00000000 3d01dcc5 fef54d05 0d3abef7
nov/04 09:25:18 lte,packet,raw 058e9aaf 05000000 00000000 00000000
nov/04 09:25:18 lte,packet,raw lte1 mbim: wdm >>> recv #5
nov/04 09:25:18 lte,packet,raw 03000080 44000000 05000000 01000000
nov/04 09:25:18 lte,packet,raw 058e9aaf 05000000 00000000 14000000
nov/04 09:25:18 lte,packet,raw 01000000 02000000 01000000 00000000
nov/04 09:25:18 lte,debug lte1 mbim: >>> D service: conn_ext, command: sys caps
nov/04 09:25:18 lte,packet 01000000 02000000 01000000 00000000
nov/04 09:25:18 lte,debug lte1 mbim: sys caps exec:1 slots:2 concurrency:1 id:0
nov/04 09:25:18 lte,debug lte1 mbim: <<< Q service: connect, command: provisioned contexts
nov/04 09:25:18 lte,packet,raw lte1 mbim: wdm <<< send #6
nov/04 09:25:18 lte,packet,raw 03000000 30000000 06000000 01000000
nov/04 09:25:18 lte,packet,raw c2aae6df 0d000000 00000000 00000000
nov/04 09:25:18 lte,packet,raw lte1 mbim: wdm >>> recv #6
nov/04 09:25:18 lte,packet,raw 03000080 cc010000 06000000 01000000
nov/04 09:25:18 lte,packet,raw c2aae6df 0d000000 00000000 9c010000
nov/04 09:25:18 lte,packet,raw 06000000 34000000 34000000 68000000
nov/04 09:25:18 lte,packet,raw 3c000000 a4000000 3c000000 e0000000
nov/04 09:25:18 lte,packet,raw 40000000 20010000 3c000000 5c010000
nov/04 09:25:18 lte,packet,raw 40000000 01000000 b43f758c a5604b46
nov/04 09:25:18 lte,packet,raw b35ec586 9641fb54 00000000 00000000
nov/04 09:25:18 lte,packet,raw 00000000 00000000 00000000 00000000
nov/04 09:25:18 lte,packet,raw 00000000 00000000 02000000 b43f758c
nov/04 09:25:18 lte,packet,raw a5604b46 b35ec586 9641fb54 34000000
nov/04 09:25:18 lte,packet,raw 06000000 00000000 00000000 00000000
nov/04 09:25:18 lte,packet,raw 00000000 00000000 00000000 69006d00
nov/04 09:25:18 lte,packet,raw 73000000 03000000 b43f758c a5604b46
nov/04 09:25:18 lte,packet,raw b35ec586 9641fb54 34000000 06000000
nov/04 09:25:18 lte,packet,raw 00000000 00000000 73006f00 73000000
nov/04 09:25:18 lte,packet,raw 04000000 b43f758c a5604b46 b35ec586
nov/04 09:25:18 lte,packet,raw 9641fb54 34000000 0c000000 00000000
nov/04 09:25:18 lte,packet,raw 00000000 69007000 66006900 78006500
nov/04 09:25:18 lte,packet,raw 05000000 b43f758c a5604b46 b35ec586
nov/04 09:25:18 lte,packet,raw 9641fb54 34000000 08000000 00000000
nov/04 09:25:18 lte,packet,raw 00000000 66007200 65006500 06000000
nov/04 09:25:18 lte,packet,raw b43f758c a5604b46 b35ec586 9641fb54
nov/04 09:25:18 lte,packet,raw 34000000 0c000000 00000000 00000000
nov/04 09:25:18 lte,packet,raw 77006500 62007300 66007200
nov/04 09:25:18 lte,debug lte1 mbim: >>> D service: connect, command: provisioned contexts
nov/04 09:25:18 lte,packet 06000000 34000000 34000000 68000000
nov/04 09:25:18 lte,packet 3c000000 a4000000 3c000000 e0000000
nov/04 09:25:18 lte,packet 40000000 20010000 3c000000 5c010000
nov/04 09:25:18 lte,packet 40000000 01000000 b43f758c a5604b46
nov/04 09:25:18 lte,packet b35ec586 9641fb54 00000000 00000000
nov/04 09:25:18 lte,packet 00000000 00000000 00000000 00000000
nov/04 09:25:18 lte,packet 00000000 00000000 02000000 b43f758c
nov/04 09:25:18 lte,packet a5604b46 b35ec586 9641fb54 34000000
nov/04 09:25:18 lte,packet 06000000 00000000 00000000 00000000
nov/04 09:25:18 lte,packet 00000000 00000000 00000000 69006d00
nov/04 09:25:18 lte,packet 73000000 03000000 b43f758c a5604b46
nov/04 09:25:18 lte,packet b35ec586 9641fb54 34000000 06000000
nov/04 09:25:18 lte,packet 00000000 00000000 73006f00 73000000
nov/04 09:25:18 lte,packet 04000000 b43f758c a5604b46 b35ec586
nov/04 09:25:18 lte,packet 9641fb54 34000000 0c000000 00000000
nov/04 09:25:18 lte,packet 00000000 69007000 66006900 78006500
nov/04 09:25:18 lte,packet 05000000 b43f758c a5604b46 b35ec586
nov/04 09:25:18 lte,packet 9641fb54 34000000 08000000 00000000
nov/04 09:25:18 lte,packet 00000000 66007200 65006500 06000000
nov/04 09:25:18 lte,packet b43f758c a5604b46 b35ec586 9641fb54
nov/04 09:25:18 lte,packet 34000000 0c000000 00000000 00000000
nov/04 09:25:18 lte,packet 77006500 62007300 66007200
nov/04 09:25:18 lte,debug lte1 mbim: provisioned ctx: 1, type: none, apn:
nov/04 09:25:18 lte,debug lte1 mbim: provisioned ctx: 2, type: none, apn: ims
nov/04 09:25:18 lte,debug lte1 mbim: provisioned ctx: 3, type: none, apn: sos
nov/04 09:25:18 lte,debug lte1 mbim: provisioned ctx: 4, type: none, apn: ipfixe
nov/04 09:25:18 lte,debug lte1 mbim: provisioned ctx: 5, type: none, apn: free
nov/04 09:25:18 lte,debug lte1 mbim: provisioned ctx: 6, type: none, apn: websfr
nov/04 09:25:18 lte,debug lte1 mbim: state 6=>3
nov/04 09:25:18 lte,debug lte1 mbim: <<< S service: qmux, command: data
nov/04 09:25:18 lte,packet,raw lte1 mbim: wdm <<< send #7
nov/04 09:25:18 lte,packet,raw 03000000 3c000000 07000000 01000000
nov/04 09:25:18 lte,packet,raw 00000000 d1a30bc2 f97a6e43 bf65c7e2
nov/04 09:25:18 lte,packet,raw 4fb0f0d3 01000000 01000000 0c000000
nov/04 09:25:18 lte,packet,raw 010b0000 00000001 27000000
nov/04 09:25:18 lte,packet,raw lte1 mbim: wdm >>> recv #7
nov/04 09:25:18 lte,packet,raw 03000080 43000000 07000000 01000000
nov/04 09:25:18 lte,packet,raw 4fb0f0d3 01000000 00000000 13000000
nov/04 09:25:18 lte,packet,raw 01120080 00000101 27000700 02040000
nov/04 09:25:18 lte,debug lte1 mbim: >>> D service: qmux, command: data
nov/04 09:25:18 lte,packet 01120080 00000101 27000700 02040000
nov/04 09:25:18 lte,debug lte1 mbim: state 3=>4
nov/04 09:25:18 lte,async lte1: sent AT+QNWCFG="lte_l1_para_ctrl"
nov/04 09:25:18 lte,debug lte1 mbim: state 4=>7
nov/04 09:25:18 lte,debug lte1 mbim: <<< Q service: connect, command: subscriber ready status
nov/04 09:25:18 lte,packet,raw lte1 mbim: wdm <<< send #8
nov/04 09:25:18 lte,packet,raw 03000000 30000000 08000000 01000000
nov/04 09:25:18 lte,packet,raw c2aae6df 02000000 00000000 00000000
nov/04 09:25:18 lte,async lte1: rcvd +QNWCFG: "lte_l1_para_ctrl",1
nov/04 09:25:18 lte,async lte1: sent AT+QCFG="band",8d0,000001a0080800d5,0,1
nov/04 09:25:18 lte,async lte1: rcvd OK
nov/04 09:25:18 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:25:18 lte,async,raw lte1: rcvd +QENG: "servingcell","SEARCH"
nov/04 09:25:18 lte,packet,raw lte1 mbim: wdm >>> recv #8
nov/04 09:25:18 lte,packet,raw 03000080 4c000000 08000000 01000000
nov/04 09:25:18 lte,packet,raw c2aae6df 02000000 00000000 1c000000
nov/04 09:25:18 lte,packet,raw 02000000 00000000 00000000 00000000
nov/04 09:25:18 lte,debug lte1 mbim: >>> D service: connect, command: subscriber ready status
nov/04 09:25:18 lte,packet 02000000 00000000 00000000 00000000
nov/04 09:25:18 lte,debug lte1 mbim: subscriber ready state: 2
nov/04 09:25:18 lte,debug lte1 mbim: state 7=>8
nov/04 09:25:21 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:25:21 lte,async,raw lte1: rcvd +QENG: "servingcell","SEARCH"
nov/04 09:25:24 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:25:24 lte,async,raw lte1: rcvd +QENG: "servingcell","SEARCH"
nov/04 09:25:27 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:25:27 lte,async,raw lte1: rcvd +QENG: "servingcell","SEARCH"
nov/04 09:25:30 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:25:30 lte,async,raw lte1: rcvd +QENG: "servingcell","SEARCH"
nov/04 09:25:33 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:25:33 lte,async,raw lte1: rcvd +QENG: "servingcell","SEARCH"
nov/04 09:25:34 lte,packet,raw lte1 mbim: wdm >>> recv #0
nov/04 09:25:34 lte,packet,raw 07000080 34000000 00000000 01000000
nov/04 09:25:34 lte,packet,raw 00000000 3d01dcc5 fef54d05 0d3abef7
nov/04 09:25:34 lte,packet,raw 058e9aaf 08000000 08000000 01000000
nov/04 09:25:34 lte,packet,raw 03000000
nov/04 09:25:34 lte,debug lte1 mbim: >>> N service: conn_ext, command: slot info stats
nov/04 09:25:34 lte,packet lte1 mbim: status data:
nov/04 09:25:34 lte,packet 01000000 03000000
nov/04 09:25:34 lte,debug lte1 mbim: sim slot #1 status: empty
nov/04 09:25:34 lte,packet,raw 058e9aaf 08000000 08000000 00000000
nov/04 09:25:34 lte,packet,raw 05000000
nov/04 09:25:34 lte,packet 00000000 05000000
nov/04 09:25:34 lte,debug lte1 mbim: sim slot #0 status: active
nov/04 09:25:34 lte,packet,raw 07000080 48000000 00000000 01000000
nov/04 09:25:34 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
nov/04 09:25:34 lte,packet,raw c2aae6df 02000000 1c000000 00000000
nov/04 09:25:34 lte,packet,raw 00000000 00000000 00000000 00000000
nov/04 09:25:34 lte,debug lte1 mbim: >>> N service: connect, command: subscriber ready status
nov/04 09:25:34 lte,packet 00000000 00000000 00000000 00000000
nov/04 09:25:34 lte,debug lte1 mbim: subscriber ready state: 0
nov/04 09:25:35 lte,async,event lte1: +CPIN: READY
nov/04 09:25:35 lte,async,event lte1: +QUSIM: 1
nov/04 09:25:36 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:25:36 lte,async,raw lte1: rcvd +QENG: "servingcell","SEARCH"
nov/04 09:25:37 lte,async,event lte1: +QIND: SMS DONE
nov/04 09:25:37 lte,packet,raw lte1 mbim: wdm >>> recv #0
nov/04 09:25:37 lte,packet,raw 07000080 5c000000 00000000 01000000
nov/04 09:25:37 lte,packet,raw 00000000 533fbeeb 14fe4467 9f9033a2
nov/04 09:25:37 lte,packet,raw 23e56c3f 01000000 30000000 01000000
nov/04 09:25:37 lte,packet,raw 00000000 1e000000 00000000 18000000
nov/04 09:25:37 lte,packet,raw 18000000 2b003300 33003600 30003900
nov/04 09:25:37 lte,packet,raw 30003000 31003300 39003000
nov/04 09:25:37 lte,debug lte1 mbim: >>> N service: sms, command: configuration
nov/04 09:25:37 lte,packet lte1 mbim: status data:
nov/04 09:25:37 lte,packet 01000000 00000000 1e000000 00000000
nov/04 09:25:37 lte,packet 18000000 18000000 2b003300 33003600
nov/04 09:25:37 lte,packet 30003900 30003000 31003300 39003000
nov/04 09:25:39 lte,async,event lte1: +QIND: PB DONE
nov/04 09:25:39 lte,packet,raw lte1 mbim: wdm >>> recv #0
nov/04 09:25:39 lte,packet,raw 07000080 40000000 00000000 01000000
nov/04 09:25:39 lte,packet,raw 00000000 4bf38476 1e6a41db b1d8bed2
nov/04 09:25:39 lte,packet,raw 89c25bdb 01000000 14000000 01000000
nov/04 09:25:39 lte,packet,raw fa000000 0e000000 28000000 1e000000
nov/04 09:25:39 lte,debug lte1 mbim: >>> N service: unknown: 4bf384761e6a41dbb1d8bed289c25bdb, command: 1
nov/04 09:25:39 lte,packet lte1 mbim: status data:
nov/04 09:25:39 lte,packet 01000000 fa000000 0e000000 28000000
nov/04 09:25:39 lte,packet 1e000000
nov/04 09:25:39 lte,packet,raw 07000080 a8000000 00000000 01000000
nov/04 09:25:39 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
nov/04 09:25:39 lte,packet,raw c2aae6df 02000000 7c000000 01000000
nov/04 09:25:39 lte,packet,raw 34000000 1e000000 54000000 28000000
nov/04 09:25:39 lte,packet,raw 00000000 00000000 00000000 00000000
nov/04 09:25:39 lte,packet,raw 32003000 38003100 30003500 34003800
nov/04 09:25:39 lte,packet,raw 36003300 38003100 39003900 30000000
nov/04 09:25:39 lte,packet,raw 38003900 33003300 31003000 35003400
nov/04 09:25:39 lte,packet,raw 32003000 30003700 37003500 30003400
nov/04 09:25:39 lte,packet,raw 33003400 35003200
nov/04 09:25:39 lte,debug lte1 mbim: >>> N service: connect, command: subscriber ready status
nov/04 09:25:39 lte,packet 01000000 34000000 1e000000 54000000
nov/04 09:25:39 lte,packet 28000000 00000000 00000000 00000000
nov/04 09:25:39 lte,packet 00000000 00000000 00000000 00000000
nov/04 09:25:39 lte,packet 00000000 32003000 38003100 30003500
nov/04 09:25:39 lte,packet 34003800 36003300 38003100 39003900
nov/04 09:25:39 lte,packet 30000000 38003900 33003300 31003000
nov/04 09:25:39 lte,packet 35003400 32003000 30003700 37003500
nov/04 09:25:39 lte,packet 30003400 33003400 35003200
nov/04 09:25:39 lte,debug lte1 mbim: subscriber ready state: 1
nov/04 09:25:39 lte,async lte1: sent AT+CGEREP=2,0
nov/04 09:25:39 lte,debug lte1 mbim: state 8=>10
nov/04 09:25:39 lte,debug lte1 mbim: set lte attach apn: websfr
nov/04 09:25:39 lte,debug lte1 mbim: <<< S service: conn_ext, command: lte attach config
nov/04 09:25:39 lte,packet,raw lte1 mbim: wdm <<< send #9
nov/04 09:25:39 lte,packet,raw 03000000 f8000000 09000000 01000000
nov/04 09:25:39 lte,packet,raw 00000000 3d01dcc5 fef54d05 0d3abef7
nov/04 09:25:39 lte,packet,raw 058e9aaf 03000000 01000000 c8000000
nov/04 09:25:39 lte,packet,raw 00000000 03000000 20000000 38000000
nov/04 09:25:39 lte,packet,raw 58000000 38000000 90000000 38000000
nov/04 09:25:39 lte,packet,raw 00000000 00000000 01000000 2c000000
nov/04 09:25:39 lte,packet,raw 0c000000 00000000 00000000 00000000
nov/04 09:25:39 lte,packet,raw 00000000 00000000 00000000 77006500
nov/04 09:25:39 lte,packet,raw 62007300 66007200 00000000 01000000
nov/04 09:25:39 lte,packet,raw 01000000 2c000000 0c000000 00000000
nov/04 09:25:39 lte,packet,raw 00000000 77006500 62007300 66007200
nov/04 09:25:39 lte,packet,raw 00000000 02000000 01000000 2c000000
nov/04 09:25:39 lte,async lte1: rcvd OK
nov/04 09:25:39 lte,async lte1: sent AT+CMGF=0
nov/04 09:25:39 lte,async lte1: sent AT+CNMI=1,1,0,1,0
nov/04 09:25:39 lte,async lte1: sent AT+CPMS="SM","SM","SM"
nov/04 09:25:39 lte,async,event lte1: +CPMS: 27,30,27,30,27,30
nov/04 09:25:39 lte,packet,raw 07000080 9c020000 00000000 01000000
nov/04 09:25:39 lte,packet,raw 058e9aaf 01000000 70020000 07000000
nov/04 09:25:39 lte,packet,raw 3c000000 48000000 84000000 50000000
nov/04 09:25:39 lte,packet,raw d4000000 50000000 24010000 54000000
nov/04 09:25:39 lte,packet,raw 78010000 50000000 c8010000 54000000
nov/04 09:25:39 lte,packet,raw 1c020000 54000000 01000000 b43f758c
nov/04 09:25:39 lte,packet,raw a5604b46 b35ec586 9641fb54 03000000
nov/04 09:25:39 lte,packet,raw 01000000 06000000 00000000 03000000
nov/04 09:25:39 lte,packet,raw 02000000 b43f758c a5604b46 b35ec586
nov/04 09:25:39 lte,packet,raw 9641fb54 03000000 01000000 06000000
nov/04 09:25:39 lte,packet,raw 00000000 03000000 48000000 06000000
nov/04 09:25:39 lte,packet,raw 00000000 00000000 69006d00 73000000
nov/04 09:25:39 lte,packet,raw 03000000 b43f758c a5604b46 b35ec586
nov/04 09:25:39 lte,packet,raw 9641fb54 00000000 01000000 06000000
nov/04 09:25:39 lte,packet,raw 00000000 01000000 48000000 06000000
nov/04 09:25:39 lte,packet,raw 00000000 00000000 73006f00 73000000
nov/04 09:25:39 lte,packet,raw 04000000 b43f758c a5604b46 b35ec586
nov/04 09:25:39 lte,packet,raw 00000000 03000000 48000000 0c000000
nov/04 09:25:39 lte,packet,raw 00000000 00000000 69007000 66006900
nov/04 09:25:39 lte,packet,raw 78006500 05000000 b43f758c a5604b46
nov/04 09:25:39 lte,packet,raw b35ec586 9641fb54 00000000 01000000
nov/04 09:25:39 lte,packet,raw 05000000 00000000 03000000 48000000
nov/04 09:25:39 lte,packet,raw 08000000 00000000 00000000 00000000
nov/04 09:25:39 lte,packet,raw 00000000 00000000 00000000 66007200
nov/04 09:25:39 lte,packet,raw 65006500 06000000 b43f758c a5604b46
nov/04 09:25:39 lte,packet,raw 00000000 00000000 01000000 48000000
nov/04 09:25:39 lte,packet,raw 62007300 66007200 07000000 b43f758c
nov/04 09:25:39 lte,packet,raw 48000000 0c000000 00000000 00000000
nov/04 09:25:39 lte,packet,raw 77006500 62007300 66007200
nov/04 09:25:39 lte,debug lte1 mbim: >>> N service: conn_ext, command: provisioned ctx2
nov/04 09:25:39 lte,packet 07000000 3c000000 48000000 84000000
nov/04 09:25:39 lte,packet 50000000 d4000000 50000000 24010000
nov/04 09:25:39 lte,packet 54000000 78010000 50000000 c8010000
nov/04 09:25:39 lte,packet 54000000 1c020000 54000000 01000000
nov/04 09:25:39 lte,packet b43f758c a5604b46 b35ec586 9641fb54
nov/04 09:25:39 lte,packet 03000000 01000000 06000000 00000000
nov/04 09:25:39 lte,packet 03000000 00000000 00000000 00000000
nov/04 09:25:39 lte,packet 00000000 02000000 b43f758c a5604b46
nov/04 09:25:39 lte,packet b35ec586 9641fb54 03000000 01000000
nov/04 09:25:39 lte,packet 06000000 00000000 03000000 48000000
nov/04 09:25:39 lte,packet 06000000 00000000 00000000 00000000
nov/04 09:25:39 lte,packet 00000000 00000000 00000000 69006d00
nov/04 09:25:39 lte,packet 73000000 03000000 b43f758c a5604b46
nov/04 09:25:39 lte,packet b35ec586 9641fb54 00000000 01000000
nov/04 09:25:39 lte,packet 06000000 00000000 01000000 48000000
nov/04 09:25:39 lte,packet 00000000 00000000 00000000 73006f00
nov/04 09:25:39 lte,packet 73000000 04000000 b43f758c a5604b46
nov/04 09:25:39 lte,packet 0c000000 00000000 00000000 00000000
nov/04 09:25:39 lte,packet 00000000 00000000 00000000 69007000
nov/04 09:25:39 lte,packet 66006900 78006500 05000000 b43f758c
nov/04 09:25:39 lte,packet a5604b46 b35ec586 9641fb54 00000000
nov/04 09:25:39 lte,packet 01000000 05000000 00000000 03000000
nov/04 09:25:39 lte,packet 48000000 08000000 00000000 00000000
nov/04 09:25:39 lte,packet 66007200 65006500 06000000 b43f758c
nov/04 09:25:39 lte,packet 01000000 00000000 00000000 01000000
nov/04 09:25:39 lte,packet 48000000 0c000000 00000000 00000000
nov/04 09:25:39 lte,packet 77006500 62007300 66007200 07000000
nov/04 09:25:39 lte,packet 03000000 48000000 0c000000 00000000
nov/04 09:25:39 lte,packet 00000000 77006500 62007300 66007200
nov/04 09:25:39 lte,debug lte1 mbim: provisioned ctx2: 1, type: none, source: modem, ip type: 3, enabled: 1, roam: 6, apn:
nov/04 09:25:39 lte,debug lte1 mbim: provisioned ctx2: 2, type: none, source: modem, ip type: 3, enabled: 1, roam: 6, apn: ims
nov/04 09:25:39 lte,debug lte1 mbim: provisioned ctx2: 3, type: none, source: user, ip type: 0, enabled: 1, roam: 6, apn: sos
nov/04 09:25:39 lte,debug lte1 mbim: provisioned ctx2: 4, type: none, source: modem, ip type: 3, enabled: 1, roam: 6, apn: ipfixe
nov/04 09:25:39 lte,debug lte1 mbim: provisioned ctx2: 5, type: none, source: modem, ip type: 0, enabled: 1, roam: 5, apn: free
nov/04 09:25:39 lte,debug lte1 mbim: provisioned ctx2: 6, type: none, source: user, ip type: 0, enabled: 1, roam: 0, apn: websfr
nov/04 09:25:39 lte,debug lte1 mbim: provisioned ctx2: 7, type: none, source: modem, ip type: 3, enabled: 1, roam: 6, apn: websfr
nov/04 09:25:39 lte,packet,raw 07000080 f0000000 00000000 01000000
nov/04 09:25:39 lte,packet,raw 058e9aaf 03000000 c4000000 03000000
nov/04 09:25:39 lte,packet,raw 1c000000 38000000 54000000 38000000
nov/04 09:25:39 lte,packet,raw 8c000000 38000000 00000000 00000000
nov/04 09:25:39 lte,packet,raw 00000000 01000000 03000000 2c000000
nov/04 09:25:39 lte,packet,raw 62007300 66007200 00000000 02000000
nov/04 09:25:39 lte,debug lte1 mbim: >>> N service: conn_ext, command: lte attach config
nov/04 09:25:39 lte,packet 03000000 1c000000 38000000 54000000
nov/04 09:25:39 lte,packet 38000000 8c000000 38000000 00000000
nov/04 09:25:39 lte,packet 00000000 01000000 2c000000 0c000000
nov/04 09:25:39 lte,packet 00000000 00000000 77006500 62007300
nov/04 09:25:39 lte,packet 66007200 00000000 01000000 03000000
nov/04 09:25:39 lte,packet 2c000000 0c000000 00000000 00000000
nov/04 09:25:39 lte,packet 77006500 62007300 66007200 00000000
nov/04 09:25:39 lte,packet 02000000 01000000 2c000000 0c000000
nov/04 09:25:39 lte,packet,raw lte1 mbim: wdm >>> recv #9
nov/04 09:25:39 lte,packet,raw 03000080 f4000000 09000000 01000000
nov/04 09:25:39 lte,packet,raw 058e9aaf 03000000 00000000 c4000000
nov/04 09:25:39 lte,packet,raw 03000000 1c000000 38000000 54000000
nov/04 09:25:39 lte,packet,raw 38000000 8c000000 38000000 00000000
nov/04 09:25:39 lte,packet,raw 00000000 01000000 2c000000 0c000000
nov/04 09:25:39 lte,packet,raw 00000000 00000000 77006500 62007300
nov/04 09:25:39 lte,packet,raw 66007200 00000000 01000000 01000000
nov/04 09:25:39 lte,packet,raw 2c000000 0c000000 00000000 00000000
nov/04 09:25:39 lte,packet,raw 77006500 62007300 66007200 00000000
nov/04 09:25:39 lte,packet,raw 02000000 01000000 2c000000 0c000000
nov/04 09:25:39 lte,debug lte1 mbim: >>> D service: conn_ext, command: lte attach config
nov/04 09:25:39 lte,packet 66007200 00000000 01000000 01000000
nov/04 09:25:39 lte,debug lte1 mbim: lte attach ctx source: 1 roam: 0 ip: 0 apn: websfr
nov/04 09:25:39 lte,debug lte1 mbim: lte attach ctx source: 1 roam: 1 ip: 0 apn: websfr
nov/04 09:25:39 lte,debug lte1 mbim: lte attach ctx source: 1 roam: 2 ip: 0 apn: websfr
nov/04 09:25:39 lte,debug lte1 mbim: request register, operator: [auto]
nov/04 09:25:39 lte,debug lte1 mbim: <<< S service: connect, command: register state
nov/04 09:25:39 lte,packet,raw lte1 mbim: wdm <<< send #10
nov/04 09:25:39 lte,packet,raw 03000000 40000000 0a000000 01000000
nov/04 09:25:39 lte,packet,raw c2aae6df 09000000 01000000 10000000
nov/04 09:25:39 lte,packet,raw 00000000 00000000 00000000 3c000000
nov/04 09:25:39 lte,packet,raw lte1 mbim: wdm >>> recv #10
nov/04 09:25:39 lte,packet,raw 03000080 60000000 0a000000 01000000
nov/04 09:25:39 lte,packet,raw c2aae6df 09000000 00000000 30000000
nov/04 09:25:39 lte,packet,raw 00000000 01000000 01000000 00000000
nov/04 09:25:39 lte,packet,raw 01000000 00000000 00000000 00000000
nov/04 09:25:39 lte,packet,raw 00000000 00000000 00000000 02000000
nov/04 09:25:39 lte,debug lte1 mbim: >>> D service: connect, command: register state
nov/04 09:25:39 lte,packet 00000000 01000000 01000000 00000000
nov/04 09:25:39 lte,packet 01000000 00000000 00000000 00000000
nov/04 09:25:39 lte,packet 00000000 00000000 00000000 02000000
nov/04 09:25:39 lte,debug lte1 mbim: register state: deregistered
nov/04 09:25:39 lte,debug lte1 mbim: state 10=>11
nov/04 09:25:39 lte,debug lte1 mbim: set radio: on
nov/04 09:25:39 lte,debug lte1 mbim: <<< S service: connect, command: radio state
nov/04 09:25:39 lte,packet,raw lte1 mbim: wdm <<< send #11
nov/04 09:25:39 lte,packet,raw 03000000 34000000 0b000000 01000000
nov/04 09:25:39 lte,packet,raw c2aae6df 03000000 01000000 04000000
nov/04 09:25:39 lte,packet,raw 07000080 34000000 00000000 01000000
nov/04 09:25:39 lte,packet,raw c2aae6df 03000000 08000000 01000000
nov/04 09:25:39 lte,debug lte1 mbim: >>> N service: connect, command: radio state
nov/04 09:25:39 lte,packet 01000000 01000000
nov/04 09:25:39 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:25:39 lte,async,raw lte1: rcvd +QENG: "servingcell","SEARCH"
nov/04 09:25:39 lte,packet,raw lte1 mbim: wdm >>> recv #11
nov/04 09:25:39 lte,packet,raw 03000080 38000000 0b000000 01000000
nov/04 09:25:39 lte,packet,raw c2aae6df 03000000 00000000 08000000
nov/04 09:25:39 lte,packet,raw 01000000 01000000
nov/04 09:25:39 lte,debug lte1 mbim: >>> D service: connect, command: radio state
nov/04 09:25:39 lte,packet,raw 07000080 5c000000 00000000 01000000
nov/04 09:25:39 lte,packet,raw c2aae6df 09000000 30000000 00000000
nov/04 09:25:39 lte,packet,raw 02000000 01000000 00000000 01000000
nov/04 09:25:39 lte,packet,raw 00000000 00000000 02000000
nov/04 09:25:39 lte,debug lte1 mbim: >>> N service: connect, command: register state
nov/04 09:25:39 lte,packet 00000000 02000000 01000000 00000000
nov/04 09:25:39 lte,debug lte1 mbim: register state: searching
nov/04 09:25:39 lte,debug lte1 mbim: state 11=>12
nov/04 09:25:39 lte,async,raw lte1: +CEREG: 2
nov/04 09:25:42 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:25:42 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-95,-11,-62,12,-,-,-
nov/04 09:25:45 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:25:45 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-95,-9,-62,12,10,-,30
nov/04 09:25:48 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:25:48 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-95,-9,-65,12,10,-,31
nov/04 09:25:51 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:25:51 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-92,-11,-61,11,10,-,33
nov/04 09:25:54 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:25:55 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-92,-14,-59,11,-,-,-
nov/04 09:25:58 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:25:58 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-95,-11,-63,12,-,-,-
nov/04 09:26:01 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:01 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-94,-10,-64,11,8,-,31
nov/04 09:26:04 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:04 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-93,-11,-60,9,8,-,32
nov/04 09:26:07 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:07 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-94,-8,-64,12,8,-,31
nov/04 09:26:10 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:10 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-95,-11,-63,13,10,-,-
nov/04 09:26:13 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:13 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-95,-9,-62,12,9,-,30
nov/04 09:26:16 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:16 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-94,-13,-60,11,9,-,31
nov/04 09:26:19 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:19 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-95,-12,-62,9,9,-,30
nov/04 09:26:22 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:22 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-95,-12,-61,9,9,-,30
nov/04 09:26:25 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:25 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-97,-12,-65,11,-,-,-
nov/04 09:26:28 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:28 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-96,-8,-66,11,6,-,29
nov/04 09:26:31 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:31 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-94,-9,-62,11,6,-,32
nov/04 09:26:34 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:34 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-95,-9,-64,12,6,-,30
nov/04 09:26:37 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:37 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F202,410,1501,3,5,5,7904,-97,-9,-64,12,7,-,-
nov/04 09:26:40 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:40 lte,async,raw lte1: rcvd +QENG: "servingcell","SEARCH"
nov/04 09:26:43 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:43 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
nov/04 09:26:44 lte,packet,raw lte1 mbim: wdm >>> recv #0
nov/04 09:26:44 lte,packet,raw 07000080 40000000 00000000 01000000
nov/04 09:26:44 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
nov/04 09:26:44 lte,packet,raw c2aae6df 0b000000 14000000 11000000
nov/04 09:26:44 lte,packet,raw 63000000 05000000 02000000 ffffffff
nov/04 09:26:44 lte,packet,raw 07000080 74000000 00000000 01000000
nov/04 09:26:44 lte,packet,raw c2aae6df 09000000 48000000 00000000
nov/04 09:26:44 lte,packet,raw 03000000 01000000 1c000000 01000000
nov/04 09:26:44 lte,packet,raw 30000000 0a000000 3c000000 0a000000
nov/04 09:26:44 lte,packet,raw 00000000 00000000 02000000 32003000
nov/04 09:26:44 lte,packet,raw 38003100 30000000 46002000 53004600
nov/04 09:26:44 lte,packet,raw 52000000
nov/04 09:26:44 lte,debug lte1 mbim: >>> N service: connect, command: register state
nov/04 09:26:44 lte,packet lte1 mbim: status data:
nov/04 09:26:44 lte,packet 00000000 03000000 01000000 1c000000
nov/04 09:26:44 lte,packet 01000000 30000000 0a000000 3c000000
nov/04 09:26:44 lte,packet 0a000000 00000000 00000000 02000000
nov/04 09:26:44 lte,packet 32003000 38003100 30000000 46002000
nov/04 09:26:44 lte,packet 53004600 52000000
nov/04 09:26:44 lte,debug lte1 mbim: register state: home, gsm operator: 20810, F SFR, avail data classes: 0x1c
nov/04 09:26:44 lte,debug lte1 mbim: state 12=>14
nov/04 09:26:44 lte,debug lte1 mbim: auto attach
nov/04 09:26:44 lte,async,raw lte1: +CGREG: 1,"7B35","6124FEA",2
nov/04 09:26:44 lte,packet,raw 07000080 38000000 00000000 01000000
nov/04 09:26:44 lte,packet,raw 00000000 3d01dcc5 fef54d05 0d3abef7
nov/04 09:26:44 lte,packet,raw 058e9aaf 0c000000 0c000000 357b0000
nov/04 09:26:44 lte,packet,raw ffffffff ea4f1206
nov/04 09:26:44 lte,debug lte1 mbim: >>> N service: conn_ext, command: location info
nov/04 09:26:44 lte,packet 357b0000 ffffffff ea4f1206
nov/04 09:26:44 lte,packet,raw 07000080 48000000 00000000 01000000
nov/04 09:26:44 lte,packet,raw c2aae6df 0a000000 1c000000 00000000
nov/04 09:26:44 lte,packet,raw 02000000 18000000 1072af00 00000000
nov/04 09:26:44 lte,packet,raw c0eb8302 00000000
nov/04 09:26:44 lte,debug lte1 mbim: >>> N service: connect, command: packet service
nov/04 09:26:44 lte,packet 00000000 02000000 18000000 1072af00
nov/04 09:26:44 lte,packet 00000000 c0eb8302 00000000
nov/04 09:26:44 lte,debug lte1 mbim: packet service: attached data class: 0x18 nwe:
nov/04 09:26:44 lte,debug lte1 mbim: state 14=>17
nov/04 09:26:45 lte,packet,raw lte1 mbim: wdm >>> recv #0
nov/04 09:26:45 lte,packet,raw 07000080 54000000 00000000 01000000
nov/04 09:26:45 lte,packet,raw 00000000 3d01dcc5 fef54d05 0d3abef7
nov/04 09:26:45 lte,packet,raw 058e9aaf 04000000 28000000 00000000
nov/04 09:26:45 lte,packet,raw 00000000 00000000 00000000 00000000
nov/04 09:26:45 lte,debug lte1 mbim: >>> N service: conn_ext, command: lte attach status
nov/04 09:26:45 lte,packet lte1 mbim: status data:
nov/04 09:26:45 lte,packet 00000000 00000000 00000000 00000000
nov/04 09:26:45 lte,debug lte1 mbim: lte status: detached iptype: 0
nov/04 09:26:45 lte,debug lte1 mbim: do connect activate #0
nov/04 09:26:45 lte,debug lte1 mbim: apn: websfr iptype: 0
nov/04 09:26:45 lte,debug lte1 mbim: <<< S service: connect, command: connect
nov/04 09:26:45 lte,packet,raw lte1 mbim: wdm <<< send #12
nov/04 09:26:45 lte,packet,raw 03000000 78000000 0c000000 01000000
nov/04 09:26:45 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
nov/04 09:26:45 lte,packet,raw c2aae6df 0c000000 01000000 48000000
nov/04 09:26:45 lte,packet,raw 00000000 01000000 3c000000 0c000000
nov/04 09:26:45 lte,packet,raw 00000000 00000000 00000000 7e5e2a7e
nov/04 09:26:45 lte,packet,raw 4e6f7272 736b656e 7e5e2a7e 77006500
nov/04 09:26:45 lte,packet,raw 62007300 66007200
nov/04 09:26:46 lte,packet,raw lte1 mbim: wdm >>> recv #0
nov/04 09:26:46 lte,packet,raw 07000080 50000000 00000000 01000000
nov/04 09:26:46 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
nov/04 09:26:46 lte,packet,raw c2aae6df 0c000000 24000000 00000000
nov/04 09:26:46 lte,packet,raw 02000000 00000000 00000000 7e5e2a7e
nov/04 09:26:46 lte,packet,raw 4e6f7272 736b656e 7e5e2a7e 00000000
nov/04 09:26:46 lte,debug lte1 mbim: >>> N service: connect, command: connect
nov/04 09:26:46 lte,packet lte1 mbim: status data:
nov/04 09:26:46 lte,packet 00000000 02000000 00000000 00000000
nov/04 09:26:46 lte,packet 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
nov/04 09:26:46 lte,debug lte1 mbim: connect: #0 activating, nwe:
nov/04 09:26:46 lte,debug lte1 mbim: waiting for done
nov/04 09:26:46 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:46 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-6,-,-,-,-,-
nov/04 09:26:46 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:26:46 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:26:46 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:26:46 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:26:46 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:26:46 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:26:46 lte,async,raw lte1: sent AT+CSQ
nov/04 09:26:46 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:26:49 lte,packet,raw lte1 mbim: wdm >>> recv #12
nov/04 09:26:49 lte,packet,raw 03000080 54000000 0c000000 01000000
nov/04 09:26:49 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
nov/04 09:26:49 lte,packet,raw c2aae6df 0c000000 00000000 24000000
nov/04 09:26:49 lte,packet,raw 00000000 01000000 00000000 03000000
nov/04 09:26:49 lte,packet,raw 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
nov/04 09:26:49 lte,debug lte1 mbim: >>> D service: connect, command: connect
nov/04 09:26:49 lte,packet lte1 mbim: status data:
nov/04 09:26:49 lte,packet 00000000 01000000 00000000 03000000
nov/04 09:26:49 lte,packet 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
nov/04 09:26:49 lte,debug lte1 mbim: connect: #0 activated, nwe:
nov/04 09:26:49 lte,debug lte1 mbim: get ip config #0
nov/04 09:26:49 lte,debug lte1 mbim: <<< Q service: connect, command: ip configuration
nov/04 09:26:49 lte,packet,raw lte1 mbim: wdm <<< send #13
nov/04 09:26:49 lte,packet,raw 03000000 6c000000 0d000000 01000000
nov/04 09:26:49 lte,packet,raw c2aae6df 0f000000 00000000 3c000000
nov/04 09:26:49 lte,packet,raw 00000000 00000000 00000000 00000000
nov/04 09:26:49 lte,packet,raw lte1 mbim: wdm >>> recv #13
nov/04 09:26:49 lte,packet,raw 03000080 c4000000 0d000000 01000000
nov/04 09:26:49 lte,packet,raw c2aae6df 0f000000 00000000 94000000
nov/04 09:26:49 lte,packet,raw 00000000 0f000000 0f000000 01000000
nov/04 09:26:49 lte,packet,raw 3c000000 01000000 50000000 44000000
nov/04 09:26:49 lte,packet,raw 64000000 02000000 48000000 02000000
nov/04 09:26:49 lte,packet,raw 74000000 dc050000 dc050000 1d000000
nov/04 09:26:49 lte,packet,raw 0ae4b8fb 0ae4b8fc ac140227 ac14020a
nov/04 09:26:49 lte,packet,raw 40000000 2a028440 4540da98 6cd4aa8a
nov/04 09:26:49 lte,packet,raw c48e10a9 2a028440 4540da98 0d679154
nov/04 09:26:49 lte,packet,raw 2a536215 2a028400 00000000 00000000
nov/04 09:26:49 lte,packet,raw 00020000 2a028400 00000000 00000000
nov/04 09:26:49 lte,packet,raw 00020001
nov/04 09:26:49 lte,debug lte1 mbim: >>> D service: connect, command: ip configuration
nov/04 09:26:49 lte,packet 00000000 0f000000 0f000000 01000000
nov/04 09:26:49 lte,packet 3c000000 01000000 50000000 44000000
nov/04 09:26:49 lte,packet 64000000 02000000 48000000 02000000
nov/04 09:26:49 lte,packet 74000000 dc050000 dc050000 1d000000
nov/04 09:26:49 lte,packet 0ae4b8fb 0ae4b8fc ac140227 ac14020a
nov/04 09:26:49 lte,packet 40000000 2a028440 4540da98 6cd4aa8a
nov/04 09:26:49 lte,packet c48e10a9 2a028440 4540da98 0d679154
nov/04 09:26:49 lte,packet 2a536215 2a028400 00000000 00000000
nov/04 09:26:49 lte,packet 00020000 2a028400 00000000 00000000
nov/04 09:26:49 lte,packet 00020001
nov/04 09:26:49 lte,debug lte1 mbim: received ip config #0 15,15
nov/04 09:26:49 lte,info lte1 IPv4: 10.228.184.251, DNS: 172.20.2.39,172.20.2.10
nov/04 09:26:49 lte,info lte1 IPv6: 2a02:8440:4540:da98::/64, DNS: 2a02:8400::2:0,2a02:8400::2:1
nov/04 09:26:49 lte,debug lte1 mbim: 1lte1 mbim: state 17=>18
nov/04 09:26:49 interface,info lte1 link up
nov/04 09:26:49 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:49 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-4,-,-,-,-,-
nov/04 09:26:49 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:26:49 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:26:49 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:26:49 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:26:49 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:26:49 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:26:49 lte,async,raw lte1: sent AT+CSQ
nov/04 09:26:49 lte,async,raw lte1: rcvd +CSQ: 19,99
nov/04 09:26:52 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:52 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-4,-,-,-,-,-
nov/04 09:26:52 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:26:52 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:26:52 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:26:52 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:26:52 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:26:52 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:26:52 lte,async,raw lte1: sent AT+CSQ
nov/04 09:26:52 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:26:53 lte,packet,raw lte1 mbim: wdm >>> recv #0
nov/04 09:26:53 lte,packet,raw 07000080 48000000 00000000 01000000
nov/04 09:26:53 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
nov/04 09:26:53 lte,packet,raw c2aae6df 0a000000 1c000000 00000000
nov/04 09:26:53 lte,packet,raw 02000000 18000000 107a8400 00000000
nov/04 09:26:53 lte,packet,raw 107a8400 00000000
nov/04 09:26:53 lte,debug lte1 mbim: >>> N service: connect, command: packet service
nov/04 09:26:53 lte,packet lte1 mbim: status data:
nov/04 09:26:53 lte,packet 00000000 02000000 18000000 107a8400
nov/04 09:26:53 lte,packet 00000000 107a8400 00000000
nov/04 09:26:53 lte,debug lte1 mbim: packet service: attached data class: 0x18 nwe:
nov/04 09:26:55 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:55 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-6,-,-,-,-,-
nov/04 09:26:55 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:26:55 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
nov/04 09:26:55 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:26:55 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:26:55 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:26:55 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:26:55 lte,async,raw lte1: sent AT+CSQ
nov/04 09:26:55 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:26:58 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:26:58 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
nov/04 09:26:58 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:26:58 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
nov/04 09:26:58 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:26:58 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:26:58 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:26:58 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:26:58 lte,async,raw lte1: sent AT+CSQ
nov/04 09:26:58 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:27:01 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:01 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
nov/04 09:27:01 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:01 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:01 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:01 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:01 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:02 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:02 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:02 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:27:05 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:05 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-4,-,-,-,-,-
nov/04 09:27:05 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:05 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:05 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:05 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:05 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:05 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:05 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:05 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:27:08 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:08 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-5,-,-,-,-,-
nov/04 09:27:08 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:08 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:08 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:08 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:08 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:08 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:08 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:08 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:27:11 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:11 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-4,-,-,-,-,-
nov/04 09:27:11 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:11 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:11 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:11 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:11 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:11 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:11 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:11 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:27:14 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:14 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
nov/04 09:27:14 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:14 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:14 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:14 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:14 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:14 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:14 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:14 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:27:17 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:17 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-4,-,-,-,-,-
nov/04 09:27:17 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:17 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:17 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:17 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:17 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:17 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:17 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:17 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:27:20 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:20 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-4,-,-,-,-,-
nov/04 09:27:20 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:20 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:20 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:20 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:20 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:20 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:20 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:20 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:27:23 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:23 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-5,-,-,-,-,-
nov/04 09:27:23 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:23 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:23 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:23 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:23 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:23 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:23 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:23 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:27:26 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:26 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-6,-,-,-,-,-
nov/04 09:27:26 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:26 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:26 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:26 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:26 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:26 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:26 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:26 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:27:29 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:29 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
nov/04 09:27:29 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:29 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:29 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:29 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:29 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:29 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:29 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:29 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:27:32 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:32 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
nov/04 09:27:32 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:32 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:32 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:32 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:32 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:32 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:32 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:32 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:27:35 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:35 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
nov/04 09:27:35 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:35 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:35 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:35 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:35 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:35 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:35 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:35 lte,async,raw lte1: rcvd +CSQ: 16,99
nov/04 09:27:38 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:38 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-5,-,-,-,-,-
nov/04 09:27:38 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:38 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:38 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:38 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:38 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:38 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:38 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:38 lte,async,raw lte1: rcvd +CSQ: 16,99
nov/04 09:27:41 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:41 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
nov/04 09:27:41 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:41 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:41 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:41 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:41 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:41 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:41 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:41 lte,async,raw lte1: rcvd +CSQ: 16,99
nov/04 09:27:44 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:44 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-6,-,-,-,-,-
nov/04 09:27:44 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:44 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:44 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:44 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:44 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:44 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:44 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:44 lte,async,raw lte1: rcvd +CSQ: 16,99
nov/04 09:27:47 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:47 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-4,-,-,-,-,-
nov/04 09:27:47 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:47 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:47 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:47 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:47 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:47 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:47 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:47 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:27:50 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:50 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-6,-,-,-,-,-
nov/04 09:27:50 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:50 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:50 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:50 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:50 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:50 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:50 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:50 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:27:53 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:53 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
nov/04 09:27:53 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:53 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:53 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:53 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:53 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:53 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:53 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:53 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:27:56 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:56 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
nov/04 09:27:56 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:56 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:56 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:56 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:56 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:56 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:56 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:56 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:27:59 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:27:59 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
nov/04 09:27:59 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:27:59 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:27:59 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:27:59 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:27:59 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:27:59 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:27:59 lte,async,raw lte1: sent AT+CSQ
nov/04 09:27:59 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:28:02 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:28:02 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
nov/04 09:28:02 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:28:02 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:28:02 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:28:02 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:28:02 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:28:02 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:28:02 lte,async,raw lte1: sent AT+CSQ
nov/04 09:28:02 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:28:05 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:28:05 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
nov/04 09:28:05 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:28:05 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:28:05 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:28:05 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:28:05 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:28:05 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:28:05 lte,async,raw lte1: sent AT+CSQ
nov/04 09:28:05 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:28:08 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:28:08 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
nov/04 09:28:08 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:28:08 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:28:08 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:28:08 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:28:08 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:28:08 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:28:08 lte,async,raw lte1: sent AT+CSQ
nov/04 09:28:08 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:28:11 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:28:11 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-4,-,-,-,-,-
nov/04 09:28:11 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:28:11 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:28:11 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:28:11 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:28:11 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:28:11 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:28:11 lte,async,raw lte1: sent AT+CSQ
nov/04 09:28:11 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:28:14 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:28:14 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-4,-,-,-,-,-
nov/04 09:28:14 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:28:14 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:28:14 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:28:14 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:28:14 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:28:14 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:28:14 lte,async,raw lte1: sent AT+CSQ
nov/04 09:28:14 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:28:17 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:28:17 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-4,-,-,-,-,-
nov/04 09:28:17 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:28:17 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:28:17 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:28:17 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:28:17 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:28:17 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:28:17 lte,async,raw lte1: sent AT+CSQ
nov/04 09:28:17 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:28:20 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:28:20 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-5,-,-,-,-,-
nov/04 09:28:20 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:28:20 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:28:20 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:28:20 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:28:20 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:28:20 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:28:20 lte,async,raw lte1: sent AT+CSQ
nov/04 09:28:20 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:28:23 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:28:23 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
nov/04 09:28:23 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:28:23 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:28:23 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:28:23 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:28:23 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:28:23 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:28:23 lte,async,raw lte1: sent AT+CSQ
nov/04 09:28:23 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:28:26 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:28:26 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
nov/04 09:28:26 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:28:26 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:28:26 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:28:26 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:28:26 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:28:26 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:28:26 lte,async,raw lte1: sent AT+CSQ
nov/04 09:28:26 lte,async,raw lte1: rcvd +CSQ: 17,99
nov/04 09:28:29 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:28:29 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
nov/04 09:28:29 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:28:29 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:28:29 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:28:29 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:28:29 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:28:29 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:28:29 lte,async,raw lte1: sent AT+CSQ
nov/04 09:28:29 lte,async,raw lte1: rcvd +CSQ: 17,99
nov/04 09:28:32 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:28:32 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-4,-,-,-,-,-
nov/04 09:28:32 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:28:32 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
nov/04 09:28:32 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:28:32 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:28:32 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:28:32 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:28:32 lte,async,raw lte1: sent AT+CSQ
nov/04 09:28:32 lte,async,raw lte1: rcvd +CSQ: 18,99
nov/04 09:28:35 lte,async,raw lte1: sent AT+QENG="servingcell"
nov/04 09:28:35 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-4,-,-,-,-,-
nov/04 09:28:35 lte,async,raw lte1: sent AT+QXPOWER
nov/04 09:28:35 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
nov/04 09:28:35 lte,async,raw lte1: sent AT+QNETINFO="cmr"
nov/04 09:28:35 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
nov/04 09:28:35 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
nov/04 09:28:35 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
nov/04 09:28:35 lte,async,raw lte1: sent AT+CSQ
nov/04 09:28:35 lte,async,raw lte1: rcvd +CSQ: 18,99
16:43:09 system,critical,info cloud change time Nov/04/2022 09:28:35 => Nov/07/2022 16:43:09
17:43:12 lte,async,raw lte1: sent AT+QENG="servingcell"
17:43:12 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-4,-,-,-,-,-
17:43:12 lte,async,raw lte1: sent AT+QXPOWER
17:43:12 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:43:12 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:43:12 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:43:12 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:43:12 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:43:12 lte,async,raw lte1: sent AT+CSQ
17:43:12 lte,async,raw lte1: rcvd +CSQ: 21,99
17:43:15 lte,async,raw lte1: sent AT+QENG="servingcell"
17:43:15 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-3,-,-,-,-,-
17:43:15 lte,async,raw lte1: sent AT+QXPOWER
17:43:15 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:43:15 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:43:15 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:43:15 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:43:15 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:43:15 lte,async,raw lte1: sent AT+CSQ
17:43:15 lte,async,raw lte1: rcvd +CSQ: 18,99
17:43:18 lte,async,raw lte1: sent AT+QENG="servingcell"
17:43:18 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-4,-,-,-,-,-
17:43:18 lte,async,raw lte1: sent AT+QXPOWER
17:43:18 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:43:18 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:43:18 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:43:18 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:43:18 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:43:18 lte,async,raw lte1: sent AT+CSQ
17:43:18 lte,async,raw lte1: rcvd +CSQ: 18,99
17:43:21 lte,async,raw lte1: sent AT+QENG="servingcell"
17:43:21 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-77,-3,-,-,-,-,-
17:43:21 lte,async,raw lte1: sent AT+QXPOWER
17:43:21 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:43:21 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:43:21 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:43:21 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:43:21 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:43:21 lte,async,raw lte1: sent AT+CSQ
17:43:21 lte,async,raw lte1: rcvd +CSQ: 18,99
17:43:24 lte,async,raw lte1: sent AT+QENG="servingcell"
17:43:24 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-4,-,-,-,-,-
17:43:24 lte,async,raw lte1: sent AT+QXPOWER
17:43:24 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:43:24 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:43:24 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:43:24 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:43:24 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:43:24 lte,async,raw lte1: sent AT+CSQ
17:43:24 lte,async,raw lte1: rcvd +CSQ: 18,99
17:43:27 lte,async,raw lte1: sent AT+QENG="servingcell"
17:43:27 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-6,-,-,-,-,-
17:43:27 lte,async,raw lte1: sent AT+QXPOWER
17:43:27 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:43:27 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:43:27 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:43:27 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:43:27 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:43:27 lte,async,raw lte1: sent AT+CSQ
17:43:27 lte,async,raw lte1: rcvd +CSQ: 18,99
17:43:30 lte,async,raw lte1: sent AT+QENG="servingcell"
17:43:30 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
17:43:30 lte,async,raw lte1: sent AT+QXPOWER
17:43:30 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:43:30 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:43:30 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:43:30 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:43:30 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:43:30 lte,async,raw lte1: sent AT+CSQ
17:43:30 lte,async,raw lte1: rcvd +CSQ: 18,99
17:43:33 lte,async,raw lte1: sent AT+QENG="servingcell"
17:43:33 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
17:43:33 lte,async,raw lte1: sent AT+QXPOWER
17:43:33 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:43:33 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:43:33 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:43:33 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:43:33 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:43:33 lte,async,raw lte1: sent AT+CSQ
17:43:33 lte,async,raw lte1: rcvd +CSQ: 18,99
17:43:36 lte,async,raw lte1: sent AT+QENG="servingcell"
17:43:36 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-4,-,-,-,-,-
17:43:36 lte,async,raw lte1: sent AT+QXPOWER
17:43:36 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:43:36 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:43:36 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:43:36 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:43:36 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:43:36 lte,async,raw lte1: sent AT+CSQ
17:43:36 lte,async,raw lte1: rcvd +CSQ: 18,99
17:43:39 lte,async,raw lte1: sent AT+QENG="servingcell"
17:43:39 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-4,-,-,-,-,-
17:43:39 lte,async,raw lte1: sent AT+QXPOWER
17:43:39 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:43:39 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:43:39 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:43:39 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:43:39 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:43:39 lte,async,raw lte1: sent AT+CSQ
17:43:39 lte,async,raw lte1: rcvd +CSQ: 18,99
17:43:42 lte,async,raw lte1: sent AT+QENG="servingcell"
17:43:42 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-75,-6,-,-,-,-,-
17:43:42 lte,async,raw lte1: sent AT+QXPOWER
17:43:42 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:43:42 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:43:42 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:43:42 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:43:42 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:43:42 lte,async,raw lte1: sent AT+CSQ
17:43:42 lte,async,raw lte1: rcvd +CSQ: 18,99
17:43:45 lte,async,raw lte1: sent AT+QENG="servingcell"
17:43:45 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-10,-,-,-,-,-
17:43:45 lte,async,raw lte1: sent AT+QXPOWER
17:43:45 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:43:45 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:43:45 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:43:45 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:43:45 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:43:45 lte,async,raw lte1: sent AT+CSQ
17:43:45 lte,async,raw lte1: rcvd +CSQ: 19,99
17:43:48 lte,async,raw lte1: sent AT+QENG="servingcell"
17:43:48 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-11,-,-,-,-,-
17:43:48 lte,async,raw lte1: sent AT+QXPOWER
17:43:48 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:43:48 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:43:48 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:43:48 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:43:48 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:43:48 lte,async,raw lte1: sent AT+CSQ
17:43:48 lte,async,raw lte1: rcvd +CSQ: 19,99
17:43:51 lte,async,raw lte1: sent AT+QENG="servingcell"
17:43:51 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-10,-,-,-,-,-
17:43:51 lte,async,raw lte1: sent AT+QXPOWER
17:43:51 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:43:51 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:43:51 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:43:51 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:43:51 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:43:51 lte,async,raw lte1: sent AT+CSQ
17:43:51 lte,async,raw lte1: rcvd +CSQ: 18,99
17:43:54 lte,async,raw lte1: sent AT+QENG="servingcell"
17:43:54 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-6,-,-,-,-,-
17:43:54 lte,async,raw lte1: sent AT+QXPOWER
17:43:54 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:43:54 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:43:54 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:43:54 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:43:54 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:43:54 lte,async,raw lte1: sent AT+CSQ
17:43:54 lte,async,raw lte1: rcvd +CSQ: 18,99
17:43:57 lte,async,raw lte1: sent AT+QENG="servingcell"
17:43:57 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-77,-5,-,-,-,-,-
17:43:57 lte,async,raw lte1: sent AT+QXPOWER
17:43:57 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:43:57 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:43:57 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:43:57 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:43:57 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:43:57 lte,async,raw lte1: sent AT+CSQ
17:43:57 lte,async,raw lte1: rcvd +CSQ: 17,99
17:44:00 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:00 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
17:44:00 lte,async,raw lte1: sent AT+QXPOWER
17:44:00 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:44:00 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:00 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:00 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:00 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:00 lte,async,raw lte1: sent AT+CSQ
17:44:00 lte,async,raw lte1: rcvd +CSQ: 18,99
17:44:03 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:03 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-5,-,-,-,-,-
17:44:03 lte,async,raw lte1: sent AT+QXPOWER
17:44:03 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:44:03 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:03 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:03 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:03 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:03 lte,async,raw lte1: sent AT+CSQ
17:44:03 lte,async,raw lte1: rcvd +CSQ: 18,99
17:44:06 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:06 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
17:44:06 lte,async,raw lte1: sent AT+QXPOWER
17:44:06 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:44:06 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:06 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:06 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:06 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:06 lte,async,raw lte1: sent AT+CSQ
17:44:06 lte,async,raw lte1: rcvd +CSQ: 18,99
17:44:09 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:09 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
17:44:09 lte,async,raw lte1: sent AT+QXPOWER
17:44:09 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:44:09 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:09 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:09 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:09 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:09 lte,async,raw lte1: sent AT+CSQ
17:44:09 lte,async,raw lte1: rcvd +CSQ: 18,99
17:44:12 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:12 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
17:44:12 lte,async,raw lte1: sent AT+QXPOWER
17:44:12 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:44:12 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:12 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:12 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:12 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:12 lte,async,raw lte1: sent AT+CSQ
17:44:12 lte,async,raw lte1: rcvd +CSQ: 18,99
17:44:15 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:15 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
17:44:15 lte,async,raw lte1: sent AT+QXPOWER
17:44:15 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:44:15 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:15 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:15 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:15 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:15 lte,async,raw lte1: sent AT+CSQ
17:44:15 lte,async,raw lte1: rcvd +CSQ: 18,99
17:44:18 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:18 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
17:44:18 lte,async,raw lte1: sent AT+QXPOWER
17:44:18 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:44:18 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:18 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:18 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:18 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:18 lte,async,raw lte1: sent AT+CSQ
17:44:18 lte,async,raw lte1: rcvd +CSQ: 18,99
17:44:21 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:21 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
17:44:21 lte,async,raw lte1: sent AT+QXPOWER
17:44:21 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:44:21 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:21 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:21 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:21 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:21 lte,async,raw lte1: sent AT+CSQ
17:44:21 lte,async,raw lte1: rcvd +CSQ: 18,99
17:44:24 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:24 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
17:44:24 lte,async,raw lte1: sent AT+QXPOWER
17:44:24 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:44:24 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:24 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:24 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:24 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:24 lte,async,raw lte1: sent AT+CSQ
17:44:24 lte,async,raw lte1: rcvd +CSQ: 18,99
17:44:27 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:27 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-5,-,-,-,-,-
17:44:27 lte,async,raw lte1: sent AT+QXPOWER
17:44:27 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:44:27 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:27 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:27 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:27 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:27 lte,async,raw lte1: sent AT+CSQ
17:44:27 lte,async,raw lte1: rcvd +CSQ: 18,99
17:44:30 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:30 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
17:44:30 lte,async,raw lte1: sent AT+QXPOWER
17:44:30 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:44:30 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:30 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:30 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:30 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:30 lte,async,raw lte1: sent AT+CSQ
17:44:30 lte,async,raw lte1: rcvd +CSQ: 18,99
17:44:33 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:33 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
17:44:33 lte,async,raw lte1: sent AT+QXPOWER
17:44:33 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:44:33 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:33 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:33 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:33 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:33 lte,async,raw lte1: sent AT+CSQ
17:44:33 lte,async,raw lte1: rcvd +CSQ: 18,99
17:44:36 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:36 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
17:44:36 lte,async,raw lte1: sent AT+QXPOWER
17:44:36 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:44:36 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:36 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:36 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:36 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:36 lte,async,raw lte1: sent AT+CSQ
17:44:36 lte,async,raw lte1: rcvd +CSQ: 18,99
17:44:39 interface,info ether1 link up (speed 1G, full duplex)
17:44:39 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:39 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-5,-,-,-,-,-
17:44:39 lte,async,raw lte1: sent AT+QXPOWER
17:44:39 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:44:39 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:39 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:39 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:39 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:39 lte,async,raw lte1: sent AT+CSQ
17:44:39 lte,async,raw lte1: rcvd +CSQ: 18,99
17:44:41 dhcp,info defconf assigned 192.168.188.254 for 70:5A:0F:CD:33:37 HP-HP
17:44:42 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:42 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-5,-,-,-,-,-
17:44:42 lte,async,raw lte1: sent AT+QXPOWER
17:44:42 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:44:42 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:42 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:42 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:42 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:42 lte,async,raw lte1: sent AT+CSQ
17:44:42 lte,async,raw lte1: rcvd +CSQ: 16,99
17:44:45 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:45 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
17:44:45 lte,async,raw lte1: sent AT+QXPOWER
17:44:45 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:44:45 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:45 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:45 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:45 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:45 lte,async,raw lte1: sent AT+CSQ
17:44:45 lte,async,raw lte1: rcvd +CSQ: 19,99
17:44:48 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:48 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-85,-5,-,-,-,-,-
17:44:48 lte,async,raw lte1: sent AT+QXPOWER
17:44:48 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:44:48 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:48 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:48 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:48 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:48 lte,async,raw lte1: sent AT+CSQ
17:44:48 lte,async,raw lte1: rcvd +CSQ: 19,99
17:44:50 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:44:50 lte,packet,raw 07000080 40000000 00000000 01000000
17:44:50 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:44:50 lte,packet,raw c2aae6df 0b000000 14000000 0e000000
17:44:50 lte,packet,raw 63000000 05000000 02000000 ffffffff
17:44:51 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:51 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-5,-,-,-,-,-
17:44:51 lte,async,raw lte1: sent AT+QXPOWER
17:44:51 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:44:51 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:51 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:51 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:51 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:51 lte,async,raw lte1: sent AT+CSQ
17:44:51 lte,async,raw lte1: rcvd +CSQ: 14,99
17:44:54 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:54 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-6,-,-,-,-,-
17:44:54 lte,async,raw lte1: sent AT+QXPOWER
17:44:54 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:44:54 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:54 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:54 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:54 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:54 lte,async,raw lte1: sent AT+CSQ
17:44:54 lte,async,raw lte1: rcvd +CSQ: 15,99
17:44:57 lte,async,raw lte1: sent AT+QENG="servingcell"
17:44:57 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-85,-6,-,-,-,-,-
17:44:57 lte,async,raw lte1: sent AT+QXPOWER
17:44:57 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:44:57 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:44:57 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:44:57 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:44:57 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:44:57 lte,async,raw lte1: sent AT+CSQ
17:44:57 lte,async,raw lte1: rcvd +CSQ: 15,99
17:45:00 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:00 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-85,-5,-,-,-,-,-
17:45:00 lte,async,raw lte1: sent AT+QXPOWER
17:45:00 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:00 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:00 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:00 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:00 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:00 lte,async,raw lte1: sent AT+CSQ
17:45:00 lte,async,raw lte1: rcvd +CSQ: 15,99
17:45:03 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:03 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-5,-,-,-,-,-
17:45:03 lte,async,raw lte1: sent AT+QXPOWER
17:45:03 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:03 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:03 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:03 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:03 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:03 lte,async,raw lte1: sent AT+CSQ
17:45:03 lte,async,raw lte1: rcvd +CSQ: 15,99
17:45:06 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:06 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-6,-,-,-,-,-
17:45:06 lte,async,raw lte1: sent AT+QXPOWER
17:45:06 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:06 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:06 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:06 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:06 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:06 lte,async,raw lte1: sent AT+CSQ
17:45:06 lte,async,raw lte1: rcvd +CSQ: 15,99
17:45:09 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:09 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-9,-,-,-,-,-
17:45:09 lte,async,raw lte1: sent AT+QXPOWER
17:45:09 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:09 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:09 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:09 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:09 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:09 lte,async,raw lte1: sent AT+CSQ
17:45:09 lte,async,raw lte1: rcvd +CSQ: 15,99
17:45:12 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:12 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-10,-,-,-,-,-
17:45:12 lte,async,raw lte1: sent AT+QXPOWER
17:45:12 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:12 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:12 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:12 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:12 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:12 lte,async,raw lte1: sent AT+CSQ
17:45:12 lte,async,raw lte1: rcvd +CSQ: 14,99
17:45:15 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:15 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-86,-10,-,-,-,-,-
17:45:15 lte,async,raw lte1: sent AT+QXPOWER
17:45:15 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:15 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:15 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:15 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:15 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:15 lte,async,raw lte1: sent AT+CSQ
17:45:15 lte,async,raw lte1: rcvd +CSQ: 14,99
17:45:18 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:18 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-8,-,-,-,-,-
17:45:18 lte,async,raw lte1: sent AT+QXPOWER
17:45:18 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:18 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:18 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:18 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:18 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:18 lte,async,raw lte1: sent AT+CSQ
17:45:18 lte,async,raw lte1: rcvd +CSQ: 14,99
17:45:21 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:21 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-88,-8,-,-,-,-,-
17:45:21 lte,async,raw lte1: sent AT+QXPOWER
17:45:21 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:21 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:21 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:21 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:21 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:21 lte,async,raw lte1: sent AT+CSQ
17:45:21 lte,async,raw lte1: rcvd +CSQ: 15,99
17:45:25 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:25 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-8,-,-,-,-,-
17:45:25 lte,async,raw lte1: sent AT+QXPOWER
17:45:25 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:25 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:25 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:25 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:25 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:25 lte,async,raw lte1: sent AT+CSQ
17:45:25 lte,async,raw lte1: rcvd +CSQ: 15,99
17:45:28 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:28 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-8,-,-,-,-,-
17:45:28 lte,async,raw lte1: sent AT+QXPOWER
17:45:28 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:28 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:28 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:28 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:28 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:28 lte,async,raw lte1: sent AT+CSQ
17:45:28 lte,async,raw lte1: rcvd +CSQ: 15,99
17:45:31 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:31 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-85,-10,-,-,-,-,-
17:45:31 lte,async,raw lte1: sent AT+QXPOWER
17:45:31 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:31 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:31 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:31 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:31 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:31 lte,async,raw lte1: sent AT+CSQ
17:45:31 lte,async,raw lte1: rcvd +CSQ: 15,99
17:45:34 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:34 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-87,-6,-,-,-,-,-
17:45:34 lte,async,raw lte1: sent AT+QXPOWER
17:45:34 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:34 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:34 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:34 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:34 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:34 lte,async,raw lte1: sent AT+CSQ
17:45:34 lte,async,raw lte1: rcvd +CSQ: 15,99
17:45:37 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:37 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-7,-,-,-,-,-
17:45:37 lte,async,raw lte1: sent AT+QXPOWER
17:45:37 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:37 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:37 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:37 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:37 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:37 lte,async,raw lte1: sent AT+CSQ
17:45:37 lte,async,raw lte1: rcvd +CSQ: 15,99
17:45:40 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:40 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-4,-,-,-,-,-
17:45:40 lte,async,raw lte1: sent AT+QXPOWER
17:45:40 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:40 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:40 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:40 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:40 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:40 lte,async,raw lte1: sent AT+CSQ
17:45:40 lte,async,raw lte1: rcvd +CSQ: 16,99
17:45:43 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:43 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-4,-,-,-,-,-
17:45:43 lte,async,raw lte1: sent AT+QXPOWER
17:45:43 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:43 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:43 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:43 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:43 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:43 lte,async,raw lte1: sent AT+CSQ
17:45:43 lte,async,raw lte1: rcvd +CSQ: 16,99
17:45:46 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:46 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
17:45:46 lte,async,raw lte1: sent AT+QXPOWER
17:45:46 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:46 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:46 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:46 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:46 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:46 lte,async,raw lte1: sent AT+CSQ
17:45:46 lte,async,raw lte1: rcvd +CSQ: 16,99
17:45:49 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:49 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-7,-,-,-,-,-
17:45:49 lte,async,raw lte1: sent AT+QXPOWER
17:45:49 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:49 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:49 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:49 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:49 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:49 lte,async,raw lte1: sent AT+CSQ
17:45:49 lte,async,raw lte1: rcvd +CSQ: 16,99
17:45:50 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:45:50 lte,packet,raw 07000080 40000000 00000000 01000000
17:45:50 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:45:50 lte,packet,raw c2aae6df 0b000000 14000000 12000000
17:45:50 lte,packet,raw 63000000 05000000 02000000 ffffffff
17:45:52 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:52 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-85,-8,-,-,-,-,-
17:45:52 lte,async,raw lte1: sent AT+QXPOWER
17:45:52 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:52 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:52 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:52 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:52 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:52 lte,async,raw lte1: sent AT+CSQ
17:45:52 lte,async,raw lte1: rcvd +CSQ: 20,99
17:45:55 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:55 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-8,-,-,-,-,-
17:45:55 lte,async,raw lte1: sent AT+QXPOWER
17:45:55 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:55 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:55 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:55 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:55 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:55 lte,async,raw lte1: sent AT+CSQ
17:45:55 lte,async,raw lte1: rcvd +CSQ: 20,99
17:45:58 lte,async,raw lte1: sent AT+QENG="servingcell"
17:45:58 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-8,-,-,-,-,-
17:45:58 lte,async,raw lte1: sent AT+QXPOWER
17:45:58 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:45:58 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:45:58 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:45:58 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:45:58 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:45:58 lte,async,raw lte1: sent AT+CSQ
17:45:58 lte,async,raw lte1: rcvd +CSQ: 20,99
17:46:00 system,info,account user admin logged in from 192.168.188.254 via winbox
17:46:01 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:01 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
17:46:01 lte,async,raw lte1: sent AT+QXPOWER
17:46:01 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:46:01 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:46:01 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:46:01 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:46:01 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:46:01 lte,async,raw lte1: sent AT+CSQ
17:46:01 lte,async,raw lte1: rcvd +CSQ: 20,99
17:46:04 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:04 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
17:46:04 lte,async,raw lte1: sent AT+QXPOWER
17:46:04 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:46:04 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:46:04 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:46:04 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:46:04 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:46:04 lte,async,raw lte1: sent AT+CSQ
17:46:04 lte,async,raw lte1: rcvd +CSQ: 20,99
17:46:07 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:07 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
17:46:07 lte,async,raw lte1: sent AT+QXPOWER
17:46:07 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:46:07 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:46:07 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:46:07 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:46:07 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:46:07 lte,async,raw lte1: sent AT+CSQ
17:46:07 lte,async,raw lte1: rcvd +CSQ: 20,99
17:46:10 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:10 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-8,-,-,-,-,-
17:46:10 lte,async,raw lte1: sent AT+QXPOWER
17:46:10 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:46:10 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:46:10 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:46:10 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:46:10 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:46:10 lte,async,raw lte1: sent AT+CSQ
17:46:10 lte,async,raw lte1: rcvd +CSQ: 20,99
17:46:10 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:46:10 lte,packet,raw 07000080 40000000 00000000 01000000
17:46:10 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:46:10 lte,packet,raw c2aae6df 0b000000 14000000 10000000
17:46:10 lte,packet,raw 63000000 05000000 02000000 ffffffff
17:46:13 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:13 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-5,-,-,-,-,-
17:46:13 lte,async,raw lte1: sent AT+QXPOWER
17:46:13 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:46:13 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:46:13 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:46:13 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:46:13 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:46:13 lte,async,raw lte1: sent AT+CSQ
17:46:13 lte,async,raw lte1: rcvd +CSQ: 16,99
17:46:16 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:16 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-7,-,-,-,-,-
17:46:16 lte,async,raw lte1: sent AT+QXPOWER
17:46:16 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:46:16 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:46:16 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:46:16 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:46:16 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:46:16 lte,async,raw lte1: sent AT+CSQ
17:46:16 lte,async,raw lte1: rcvd +CSQ: 16,99
17:46:19 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:19 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
17:46:19 lte,async,raw lte1: sent AT+QXPOWER
17:46:19 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:46:19 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:46:19 lte,async,raw lte1: rcvd +QNETINFO: "cmr",6,0,2,0
17:46:19 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:46:19 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,6
17:46:19 lte,async,raw lte1: sent AT+CSQ
17:46:19 lte,async,raw lte1: rcvd +CSQ: 16,99
17:46:20 lte,debug lte1 mbim: state 18=>5
17:46:20 interface,info lte1 link down
17:46:20 lte,account lte1 session: 297s 14413774/830402 bytes 10897/7515 packets
17:46:20 lte,debug lte1 mbim: set radio: off
17:46:20 lte,debug lte1 mbim: <<< S service: connect, command: radio state
17:46:20 lte,packet,raw lte1 mbim: wdm <<< send #14
17:46:20 lte,packet,raw 03000000 34000000 0e000000 01000000
17:46:20 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:46:20 lte,packet,raw c2aae6df 03000000 01000000 04000000
17:46:20 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:46:20 lte,packet,raw 07000080 50000000 00000000 01000000
17:46:20 lte,packet,raw c2aae6df 0c000000 24000000 00000000
17:46:20 lte,packet,raw 01000000 00000000 01000000 7e5e2a7e
17:46:20 lte,packet,raw 4e6f7272 736b656e 7e5e2a7e 00000000
17:46:20 lte,debug lte1 mbim: >>> N service: connect, command: connect
17:46:20 lte,packet lte1 mbim: status data:
17:46:20 lte,packet 00000000 01000000 00000000 01000000
17:46:20 lte,packet 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
17:46:20 lte,debug lte1 mbim: connect: #0 activated, nwe:
17:46:20 lte,packet,raw 03000000 00000000 00000000 7e5e2a7e
17:46:20 lte,packet 00000000 03000000 00000000 00000000
17:46:20 lte,debug lte1 mbim: connect: #0 deactivated, nwe:
17:46:20 system,info device changed by admin
17:46:20 lte,packet,raw 07000080 40000000 00000000 01000000
17:46:20 lte,packet,raw c2aae6df 0b000000 14000000 63000000
17:46:20 lte,packet,raw 63000000 05000000 02000000 ffffffff
17:46:20 lte,packet,raw 07000080 48000000 00000000 01000000
17:46:20 lte,packet,raw c2aae6df 0a000000 1c000000 00000000
17:46:20 lte,packet,raw 04000000 00000000 00000000 00000000
17:46:20 lte,packet,raw 00000000 00000000
17:46:20 lte,debug lte1 mbim: >>> N service: connect, command: packet service
17:46:20 lte,packet 00000000 04000000 00000000 00000000
17:46:20 lte,packet 00000000 00000000 00000000
17:46:20 lte,debug lte1 mbim: packet service: detached data class: 0x0 nwe:
17:46:20 lte,packet,raw 07000080 5c000000 00000000 01000000
17:46:20 lte,packet,raw c2aae6df 09000000 30000000 00000000
17:46:20 lte,packet,raw 01000000 01000000 00000000 01000000
17:46:20 lte,packet,raw 00000000 00000000 00000000 00000000
17:46:20 lte,packet,raw 00000000 00000000 02000000
17:46:20 lte,debug lte1 mbim: >>> N service: connect, command: register state
17:46:20 lte,packet 00000000 01000000 01000000 00000000
17:46:20 lte,packet 01000000 00000000 00000000 00000000
17:46:20 lte,packet 00000000 00000000 00000000 02000000
17:46:21 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:46:21 lte,packet,raw 07000080 5c000000 00000000 01000000
17:46:21 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:46:21 lte,packet,raw c2aae6df 09000000 30000000 00000000
17:46:21 lte,packet,raw 02000000 01000000 00000000 01000000
17:46:21 lte,packet,raw 00000000 00000000 00000000 00000000
17:46:21 lte,packet,raw 00000000 00000000 02000000
17:46:21 lte,debug lte1 mbim: >>> N service: connect, command: register state
17:46:21 lte,packet lte1 mbim: status data:
17:46:21 lte,packet 00000000 02000000 01000000 00000000
17:46:21 lte,packet 01000000 00000000 00000000 00000000
17:46:21 lte,packet 00000000 00000000 00000000 02000000
17:46:21 lte,packet,raw 07000080 54000000 00000000 01000000
17:46:21 lte,packet,raw 00000000 3d01dcc5 fef54d05 0d3abef7
17:46:21 lte,packet,raw 058e9aaf 04000000 28000000 00000000
17:46:21 lte,debug lte1 mbim: >>> N service: conn_ext, command: lte attach status
17:46:21 lte,packet 00000000 00000000 00000000 00000000
17:46:21 lte,debug lte1 mbim: lte status: detached iptype: 0
17:46:22 lte,async,raw lte1: +CGREG: 0
17:46:22 lte,async,event lte1: +CGEV: ME DETACH
17:46:22 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:46:22 lte,packet,raw 07000080 34000000 00000000 01000000
17:46:22 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:46:22 lte,packet,raw c2aae6df 03000000 08000000 01000000
17:46:22 lte,debug lte1 mbim: >>> N service: connect, command: radio state
17:46:22 lte,packet lte1 mbim: status data:
17:46:22 lte,packet 01000000 00000000
17:46:22 lte,packet,raw lte1 mbim: wdm >>> recv #14
17:46:22 lte,packet,raw 03000080 38000000 0e000000 01000000
17:46:22 lte,packet,raw c2aae6df 03000000 00000000 08000000
17:46:22 lte,packet,raw 01000000 00000000
17:46:22 lte,debug lte1 mbim: >>> D service: connect, command: radio state
17:46:22 lte,debug lte1 mbim: state 5=>6
17:46:22 lte,async lte1: sent AT+QCFG="band",8d0,000001a0080800d5,0,1
17:46:22 lte,debug lte1 mbim: state 6=>7
17:46:22 lte,debug lte1 mbim: <<< Q service: connect, command: subscriber ready status
17:46:22 lte,packet,raw lte1 mbim: wdm <<< send #15
17:46:22 lte,packet,raw 03000000 30000000 0f000000 01000000
17:46:22 lte,packet,raw c2aae6df 02000000 00000000 00000000
17:46:22 lte,async lte1: rcvd OK
17:46:22 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:22 lte,async,raw lte1: rcvd +QENG: "servingcell","SEARCH"
17:46:22 lte,packet,raw 07000080 5c000000 00000000 01000000
17:46:22 lte,packet,raw 00000000 533fbeeb 14fe4467 9f9033a2
17:46:22 lte,packet,raw 23e56c3f 01000000 30000000 01000000
17:46:22 lte,packet,raw 00000000 1e000000 00000000 18000000
17:46:22 lte,packet,raw 18000000 2b003300 33003600 30003900
17:46:22 lte,packet,raw 30003000 31003300 39003000
17:46:22 lte,debug lte1 mbim: >>> N service: sms, command: configuration
17:46:22 lte,packet 01000000 00000000 1e000000 00000000
17:46:22 lte,packet 18000000 18000000 2b003300 33003600
17:46:22 lte,packet 30003900 30003000 31003300 39003000
17:46:22 lte,packet,raw c2aae6df 09000000 30000000 00000000
17:46:22 lte,packet,raw 01000000 01000000 00000000 01000000
17:46:22 lte,packet,raw 00000000 00000000 00000000 00000000
17:46:22 lte,packet,raw 00000000 00000000 02000000
17:46:22 lte,debug lte1 mbim: >>> N service: connect, command: register state
17:46:22 lte,packet 00000000 01000000 01000000 00000000
17:46:22 lte,packet 01000000 00000000 00000000 00000000
17:46:22 lte,packet 00000000 00000000 00000000 02000000
17:46:22 lte,packet,raw lte1 mbim: wdm >>> recv #15
17:46:22 lte,packet,raw 03000080 ac000000 0f000000 01000000
17:46:22 lte,packet,raw c2aae6df 02000000 00000000 7c000000
17:46:22 lte,packet,raw 01000000 34000000 1e000000 54000000
17:46:22 lte,packet,raw 28000000 00000000 00000000 00000000
17:46:22 lte,packet,raw 00000000 32003000 38003100 30003500
17:46:22 lte,packet,raw 34003800 36003300 38003100 39003900
17:46:22 lte,packet,raw 30000000 38003900 33003300 31003000
17:46:22 lte,packet,raw 35003400 32003000 30003700 37003500
17:46:22 lte,packet,raw 30003400 33003400 35003200
17:46:22 lte,debug lte1 mbim: >>> D service: connect, command: subscriber ready status
17:46:22 lte,packet 01000000 34000000 1e000000 54000000
17:46:22 lte,packet 28000000 00000000 00000000 00000000
17:46:22 lte,packet 00000000 00000000 00000000 00000000
17:46:22 lte,packet 00000000 32003000 38003100 30003500
17:46:22 lte,packet 34003800 36003300 38003100 39003900
17:46:22 lte,packet 30000000 38003900 33003300 31003000
17:46:22 lte,packet 35003400 32003000 30003700 37003500
17:46:22 lte,packet 30003400 33003400 35003200
17:46:22 lte,debug lte1 mbim: subscriber ready state: 1
17:46:22 lte,debug lte1 mbim: state 7=>10
17:46:22 lte,debug lte1 mbim: set lte attach apn: websfr
17:46:22 lte,debug lte1 mbim: <<< S service: conn_ext, command: lte attach config
17:46:22 lte,packet,raw lte1 mbim: wdm <<< send #16
17:46:22 lte,packet,raw 03000000 f8000000 10000000 01000000
17:46:22 lte,packet,raw 00000000 3d01dcc5 fef54d05 0d3abef7
17:46:22 lte,packet,raw 058e9aaf 03000000 01000000 c8000000
17:46:22 lte,packet,raw 00000000 03000000 20000000 38000000
17:46:22 lte,packet,raw 58000000 38000000 90000000 38000000
17:46:22 lte,packet,raw 00000000 00000000 01000000 2c000000
17:46:22 lte,packet,raw 0c000000 00000000 00000000 00000000
17:46:22 lte,packet,raw 00000000 00000000 00000000 77006500
17:46:22 lte,packet,raw 62007300 66007200 00000000 01000000
17:46:22 lte,packet,raw 01000000 2c000000 0c000000 00000000
17:46:22 lte,packet,raw 00000000 77006500 62007300 66007200
17:46:22 lte,packet,raw 00000000 02000000 01000000 2c000000
17:46:22 lte,packet,raw 07000080 40020000 00000000 01000000
17:46:22 lte,packet,raw 058e9aaf 01000000 14020000 06000000
17:46:22 lte,packet,raw 34000000 48000000 7c000000 50000000
17:46:22 lte,packet,raw cc000000 50000000 1c010000 54000000
17:46:22 lte,packet,raw 70010000 50000000 c0010000 54000000
17:46:22 lte,packet,raw 01000000 b43f758c a5604b46 b35ec586
17:46:22 lte,packet,raw 9641fb54 03000000 01000000 06000000
17:46:22 lte,packet,raw 00000000 03000000 00000000 00000000
17:46:22 lte,packet,raw 00000000 00000000 02000000 b43f758c
17:46:22 lte,packet,raw a5604b46 b35ec586 9641fb54 03000000
17:46:22 lte,packet,raw 01000000 06000000 00000000 03000000
17:46:22 lte,packet,raw 48000000 06000000 00000000 00000000
17:46:22 lte,packet,raw 69006d00 73000000 03000000 b43f758c
17:46:22 lte,packet,raw a5604b46 b35ec586 9641fb54 00000000
17:46:22 lte,packet,raw 01000000 06000000 00000000 01000000
17:46:22 lte,packet,raw 73006f00 73000000 04000000 b43f758c
17:46:22 lte,packet,raw 48000000 0c000000 00000000 00000000
17:46:22 lte,packet,raw 69007000 66006900 78006500 05000000
17:46:22 lte,packet,raw b43f758c a5604b46 b35ec586 9641fb54
17:46:22 lte,packet,raw 00000000 01000000 06000000 00000000
17:46:22 lte,packet,raw 01000000 48000000 08000000 00000000
17:46:22 lte,packet,raw 00000000 66007200 65006500 06000000
17:46:22 lte,packet,raw 03000000 01000000 06000000 00000000
17:46:22 lte,packet,raw 03000000 48000000 0c000000 00000000
17:46:22 lte,debug lte1 mbim: >>> N service: conn_ext, command: provisioned ctx2
17:46:22 lte,packet 06000000 34000000 48000000 7c000000
17:46:22 lte,packet 50000000 cc000000 50000000 1c010000
17:46:22 lte,packet 54000000 70010000 50000000 c0010000
17:46:22 lte,packet 54000000 01000000 b43f758c a5604b46
17:46:22 lte,packet b35ec586 9641fb54 03000000 01000000
17:46:22 lte,packet 06000000 00000000 03000000 00000000
17:46:22 lte,packet b43f758c a5604b46 b35ec586 9641fb54
17:46:22 lte,packet 03000000 01000000 06000000 00000000
17:46:22 lte,packet 03000000 48000000 06000000 00000000
17:46:22 lte,packet 00000000 69006d00 73000000 03000000
17:46:22 lte,packet 00000000 01000000 06000000 00000000
17:46:22 lte,packet 01000000 48000000 06000000 00000000
17:46:22 lte,packet
17:46:22 lte,packet 00000000 73006f00 73000000 04000000
17:46:22 lte,packet 03000000 48000000 0c000000 00000000
17:46:22 lte,packet 00000000 69007000 66006900 78006500
17:46:22 lte,packet 05000000 b43f758c a5604b46 b35ec586
17:46:22 lte,packet 9641fb54 00000000 01000000 06000000
17:46:22 lte,packet 00000000 01000000 48000000 08000000
17:46:22 lte,packet 00000000 00000000 66007200 65006500
17:46:22 lte,packet 06000000 b43f758c a5604b46 b35ec586
17:46:22 lte,packet 9641fb54 03000000 01000000 06000000
17:46:22 lte,packet 00000000 03000000 48000000 0c000000
17:46:22 lte,packet
17:46:22 lte,packet 00000000 00000000 77006500 62007300
17:46:22 lte,packet 66007200
17:46:22 lte,debug lte1 mbim: provisioned ctx2: 1, type: none, source: modem, ip type: 3, enabled: 1, roam: 6, apn:
17:46:22 lte,debug lte1 mbim: provisioned ctx2: 2, type: none, source: modem, ip type: 3, enabled: 1, roam: 6, apn: ims
17:46:22 lte,debug lte1 mbim: provisioned ctx2: 3, type: none, source: user, ip type: 0, enabled: 1, roam: 6, apn: sos
17:46:22 lte,debug lte1 mbim: provisioned ctx2: 4, type: none, source: modem, ip type: 3, enabled: 1, roam: 6, apn: ipfixe
17:46:22 lte,debug lte1 mbim: provisioned ctx2: 5, type: none, source: user, ip type: 0, enabled: 1, roam: 6, apn: free
17:46:22 lte,debug lte1 mbim: provisioned ctx2: 6, type: none, source: modem, ip type: 3, enabled: 1, roam: 6, apn: websfr
17:46:22 lte,packet,raw 07000080 f0000000 00000000 01000000
17:46:22 lte,packet,raw 058e9aaf 03000000 c4000000 03000000
17:46:22 lte,packet,raw 1c000000 38000000 54000000 38000000
17:46:22 lte,packet,raw 8c000000 38000000 00000000 00000000
17:46:22 lte,packet,raw 00000000 01000000 01000000 2c000000
17:46:22 lte,packet,raw 62007300 66007200 00000000 02000000
17:46:22 lte,debug lte1 mbim: >>> N service: conn_ext, command: lte attach config
17:46:22 lte,packet 03000000 1c000000 38000000 54000000
17:46:22 lte,packet 38000000 8c000000 38000000 00000000
17:46:22 lte,packet 00000000 01000000 2c000000 0c000000
17:46:22 lte,packet 66007200 00000000 01000000 01000000
17:46:22 lte,packet 2c000000 0c000000 00000000 00000000
17:46:22 lte,packet 77006500 62007300 66007200 00000000
17:46:22 lte,packet 02000000 01000000 2c000000 0c000000
17:46:22 lte,packet,raw lte1 mbim: wdm >>> recv #16
17:46:22 lte,packet,raw 03000080 f4000000 10000000 01000000
17:46:22 lte,packet,raw 058e9aaf 03000000 00000000 c4000000
17:46:22 lte,packet,raw 03000000 1c000000 38000000 54000000
17:46:22 lte,packet,raw 38000000 8c000000 38000000 00000000
17:46:22 lte,packet,raw 00000000 01000000 2c000000 0c000000
17:46:22 lte,packet,raw 00000000 00000000 77006500 62007300
17:46:22 lte,packet,raw 66007200 00000000 01000000 01000000
17:46:22 lte,packet,raw 2c000000 0c000000 00000000 00000000
17:46:22 lte,packet,raw 77006500 62007300 66007200 00000000
17:46:22 lte,packet,raw 02000000 01000000 2c000000 0c000000
17:46:22 lte,debug lte1 mbim: >>> D service: conn_ext, command: lte attach config
17:46:22 lte,debug lte1 mbim: lte attach ctx source: 1 roam: 0 ip: 0 apn: websfr
17:46:22 lte,debug lte1 mbim: lte attach ctx source: 1 roam: 1 ip: 0 apn: websfr
17:46:22 lte,debug lte1 mbim: lte attach ctx source: 1 roam: 2 ip: 0 apn: websfr
17:46:22 lte,debug lte1 mbim: request register, operator: [auto]
17:46:22 lte,debug lte1 mbim: <<< S service: connect, command: register state
17:46:22 lte,packet,raw lte1 mbim: wdm <<< send #17
17:46:22 lte,packet,raw 03000000 40000000 11000000 01000000
17:46:22 lte,packet,raw c2aae6df 09000000 01000000 10000000
17:46:22 lte,packet,raw 00000000 00000000 00000000 20000000
17:46:22 lte,packet,raw lte1 mbim: wdm >>> recv #17
17:46:22 lte,packet,raw 03000080 60000000 11000000 01000000
17:46:22 lte,packet,raw c2aae6df 09000000 00000000 30000000
17:46:22 lte,packet,raw 00000000 01000000 01000000 00000000
17:46:22 lte,packet,raw 01000000 00000000 00000000 00000000
17:46:22 lte,packet,raw 00000000 00000000 00000000 02000000
17:46:22 lte,debug lte1 mbim: >>> D service: connect, command: register state
17:46:22 lte,debug lte1 mbim: register state: deregistered
17:46:22 lte,debug lte1 mbim: state 10=>11
17:46:22 lte,debug lte1 mbim: set radio: on
17:46:22 lte,debug lte1 mbim: <<< S service: connect, command: radio state
17:46:22 lte,packet,raw lte1 mbim: wdm <<< send #18
17:46:22 lte,packet,raw 03000000 34000000 12000000 01000000
17:46:22 lte,packet,raw c2aae6df 03000000 01000000 04000000
17:46:22 lte,packet 01000000 01000000
17:46:22 lte,packet,raw lte1 mbim: wdm >>> recv #18
17:46:22 lte,packet,raw 03000080 38000000 12000000 01000000
17:46:22 lte,packet,raw 02000000 01000000 00000000 01000000
17:46:22 lte,packet 00000000 02000000 01000000 00000000
17:46:22 lte,debug lte1 mbim: register state: searching
17:46:22 lte,debug lte1 mbim: state 11=>12
17:46:22 lte,async,raw lte1: +CGREG: 2
17:46:25 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:25 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-98,-16,-62,8,8,-,-
17:46:28 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:28 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",65535,65535,FFFFFFFF,0,-1,20,3,3,FFFF,-140,-20,-120,0,-,-,0
17:46:31 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:31 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,7A8F205,442,6300,20,3,3,7904,-86,-10,-58,14,9,-,-
17:46:34 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:34 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,8003D02,351,1501,3,5,5,7675,-101,-17,-64,9,6,-,-
17:46:37 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:37 lte,async,raw lte1: rcvd +QENG: "servingcell","SEARCH"
17:46:40 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:40 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-98,-16,-63,8,7,-,-
17:46:43 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:43 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-14,-61,8,8,-,29
17:46:46 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:46 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-15,-60,7,8,-,29
17:46:49 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:49 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-15,-61,8,8,-,29
17:46:52 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:53 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-98,-16,-60,8,8,-,-
17:46:56 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:56 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-16,-60,8,-,-,28
17:46:59 lte,async,raw lte1: sent AT+QENG="servingcell"
17:46:59 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-15,-60,8,-,-,29
17:47:00 lte,debug lte1 mbim: state 12=>5
17:47:00 lte,debug lte1 mbim: set radio: off
17:47:00 lte,debug lte1 mbim: <<< S service: connect, command: radio state
17:47:00 lte,packet,raw lte1 mbim: wdm <<< send #19
17:47:00 lte,packet,raw 03000000 34000000 13000000 01000000
17:47:00 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:47:00 lte,packet,raw c2aae6df 03000000 01000000 04000000
17:47:00 system,info device changed by admin
17:47:01 lte,async,raw lte1: +CEREG: 0
17:47:01 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:47:01 lte,packet,raw 07000080 5c000000 00000000 01000000
17:47:01 lte,packet,raw 00000000 533fbeeb 14fe4467 9f9033a2
17:47:01 lte,packet,raw 23e56c3f 01000000 30000000 01000000
17:47:01 lte,packet,raw 00000000 1e000000 00000000 18000000
17:47:01 lte,packet,raw 18000000 2b003300 33003600 30003900
17:47:01 lte,packet,raw 30003000 31003300 39003000
17:47:01 lte,debug lte1 mbim: >>> N service: sms, command: configuration
17:47:01 lte,packet lte1 mbim: status data:
17:47:01 lte,packet 01000000 00000000 1e000000 00000000
17:47:01 lte,packet 18000000 18000000 2b003300 33003600
17:47:01 lte,packet 30003900 30003000 31003300 39003000
17:47:01 lte,packet,raw 07000080 34000000 00000000 01000000
17:47:01 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:47:01 lte,packet,raw c2aae6df 03000000 08000000 01000000
17:47:01 lte,debug lte1 mbim: >>> N service: connect, command: radio state
17:47:01 lte,packet,raw lte1 mbim: wdm >>> recv #19
17:47:01 lte,packet,raw 03000080 38000000 13000000 01000000
17:47:01 lte,packet,raw c2aae6df 03000000 00000000 08000000
17:47:01 lte,packet,raw 01000000 00000000
17:47:01 lte,debug lte1 mbim: >>> D service: connect, command: radio state
17:47:01 lte,debug lte1 mbim: state 5=>6
17:47:01 lte,async lte1: sent AT+QCFG="band",8d0,000001a0080800d5,0,1
17:47:01 lte,debug lte1 mbim: state 6=>7
17:47:01 lte,debug lte1 mbim: <<< Q service: connect, command: subscriber ready status
17:47:01 lte,packet,raw lte1 mbim: wdm <<< send #20
17:47:01 lte,packet,raw 03000000 30000000 14000000 01000000
17:47:01 lte,packet,raw c2aae6df 02000000 00000000 00000000
17:47:01 lte,async lte1: rcvd OK
17:47:01 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:01 lte,async,raw lte1: rcvd +QENG: "servingcell","SEARCH"
17:47:01 lte,packet,raw c2aae6df 09000000 30000000 00000000
17:47:01 lte,packet,raw 01000000 01000000 00000000 01000000
17:47:01 lte,packet,raw 00000000 00000000 00000000 00000000
17:47:01 lte,packet,raw 00000000 00000000 02000000
17:47:01 lte,debug lte1 mbim: >>> N service: connect, command: register state
17:47:01 lte,packet 00000000 01000000 01000000 00000000
17:47:01 lte,packet 01000000 00000000 00000000 00000000
17:47:01 lte,packet 00000000 00000000 00000000 02000000
17:47:01 lte,packet,raw lte1 mbim: wdm >>> recv #20
17:47:01 lte,packet,raw 03000080 ac000000 14000000 01000000
17:47:01 lte,packet,raw c2aae6df 02000000 00000000 7c000000
17:47:01 lte,packet,raw 01000000 34000000 1e000000 54000000
17:47:01 lte,packet,raw 28000000 00000000 00000000 00000000
17:47:01 lte,packet,raw 00000000 32003000 38003100 30003500
17:47:01 lte,packet,raw 34003800 36003300 38003100 39003900
17:47:01 lte,packet,raw 30000000 38003900 33003300 31003000
17:47:01 lte,packet,raw 35003400 32003000 30003700 37003500
17:47:01 lte,packet,raw 30003400 33003400 35003200
17:47:01 lte,debug lte1 mbim: >>> D service: connect, command: subscriber ready status
17:47:01 lte,packet 01000000 34000000 1e000000 54000000
17:47:01 lte,packet 28000000 00000000 00000000 00000000
17:47:01 lte,packet 00000000 00000000 00000000 00000000
17:47:01 lte,packet 00000000 32003000 38003100 30003500
17:47:01 lte,packet 34003800 36003300 38003100 39003900
17:47:01 lte,packet 30000000 38003900 33003300 31003000
17:47:01 lte,packet 35003400 32003000 30003700 37003500
17:47:01 lte,packet 30003400 33003400 35003200
17:47:01 lte,debug lte1 mbim: subscriber ready state: 1
17:47:01 lte,debug lte1 mbim: state 7=>10
17:47:01 lte,debug lte1 mbim: set lte attach apn: ipfixe
17:47:01 lte,debug lte1 mbim: <<< S service: conn_ext, command: lte attach config
17:47:01 lte,packet,raw lte1 mbim: wdm <<< send #21
17:47:01 lte,packet,raw 03000000 f8000000 15000000 01000000
17:47:01 lte,packet,raw 00000000 3d01dcc5 fef54d05 0d3abef7
17:47:01 lte,packet,raw 058e9aaf 03000000 01000000 c8000000
17:47:01 lte,packet,raw 00000000 03000000 20000000 38000000
17:47:01 lte,packet,raw 58000000 38000000 90000000 38000000
17:47:01 lte,packet,raw 00000000 00000000 01000000 2c000000
17:47:01 lte,packet,raw 0c000000 00000000 00000000 00000000
17:47:01 lte,packet,raw 00000000 00000000 00000000 69007000
17:47:01 lte,packet,raw 66006900 78006500 00000000 01000000
17:47:01 lte,packet,raw 01000000 2c000000 0c000000 00000000
17:47:01 lte,packet,raw 00000000 69007000 66006900 78006500
17:47:01 lte,packet,raw 00000000 02000000 01000000 2c000000
17:47:01 lte,packet,raw lte1 mbim: wdm >>> recv #21
17:47:01 lte,packet,raw 03000080 f4000000 15000000 01000000
17:47:01 lte,packet,raw 058e9aaf 03000000 00000000 c4000000
17:47:01 lte,packet,raw 03000000 1c000000 38000000 54000000
17:47:01 lte,packet,raw 38000000 8c000000 38000000 00000000
17:47:01 lte,packet,raw 00000000 01000000 2c000000 0c000000
17:47:01 lte,packet,raw 00000000 00000000 69007000 66006900
17:47:01 lte,packet,raw 78006500 00000000 01000000 01000000
17:47:01 lte,packet,raw 2c000000 0c000000 00000000 00000000
17:47:01 lte,packet,raw 69007000 66006900 78006500 00000000
17:47:01 lte,packet,raw 02000000 01000000 2c000000 0c000000
17:47:01 lte,debug lte1 mbim: >>> D service: conn_ext, command: lte attach config
17:47:01 lte,packet 03000000 1c000000 38000000 54000000
17:47:01 lte,packet 38000000 8c000000 38000000 00000000
17:47:01 lte,packet 00000000 01000000 2c000000 0c000000
17:47:01 lte,packet 00000000 00000000 69007000 66006900
17:47:01 lte,packet 78006500 00000000 01000000 01000000
17:47:01 lte,packet 2c000000 0c000000 00000000 00000000
17:47:01 lte,packet 69007000 66006900 78006500 00000000
17:47:01 lte,packet 02000000 01000000 2c000000 0c000000
17:47:01 lte,debug lte1 mbim: lte attach ctx source: 1 roam: 0 ip: 0 apn: ipfixe
17:47:01 lte,debug lte1 mbim: lte attach ctx source: 1 roam: 1 ip: 0 apn: ipfixe
17:47:01 lte,debug lte1 mbim: lte attach ctx source: 1 roam: 2 ip: 0 apn: ipfixe
17:47:01 lte,debug lte1 mbim: request register, operator: [auto]
17:47:01 lte,debug lte1 mbim: <<< S service: connect, command: register state
17:47:01 lte,packet,raw lte1 mbim: wdm <<< send #22
17:47:01 lte,packet,raw 03000000 40000000 16000000 01000000
17:47:01 lte,packet,raw c2aae6df 09000000 01000000 10000000
17:47:01 lte,packet,raw 00000000 00000000 00000000 20000000
17:47:01 lte,packet,raw lte1 mbim: wdm >>> recv #22
17:47:01 lte,packet,raw 03000080 60000000 16000000 01000000
17:47:01 lte,packet,raw c2aae6df 09000000 00000000 30000000
17:47:01 lte,packet,raw 00000000 01000000 01000000 00000000
17:47:01 lte,packet,raw 01000000 00000000 00000000 00000000
17:47:01 lte,packet,raw 00000000 00000000 00000000 02000000
17:47:01 lte,debug lte1 mbim: >>> D service: connect, command: register state
17:47:01 lte,debug lte1 mbim: register state: deregistered
17:47:01 lte,debug lte1 mbim: state 10=>11
17:47:01 lte,debug lte1 mbim: set radio: on
17:47:01 lte,debug lte1 mbim: <<< S service: connect, command: radio state
17:47:01 lte,packet,raw lte1 mbim: wdm <<< send #23
17:47:01 lte,packet,raw 03000000 34000000 17000000 01000000
17:47:01 lte,packet,raw c2aae6df 03000000 01000000 04000000
17:47:01 lte,packet 01000000 01000000
17:47:01 lte,packet,raw lte1 mbim: wdm >>> recv #23
17:47:01 lte,packet,raw 03000080 38000000 17000000 01000000
17:47:01 lte,packet,raw 02000000 01000000 00000000 01000000
17:47:01 lte,packet 00000000 02000000 01000000 00000000
17:47:01 lte,debug lte1 mbim: register state: searching
17:47:01 lte,debug lte1 mbim: state 11=>12
17:47:01 lte,async,raw lte1: +CEREG: 2
17:47:04 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:04 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-16,-61,9,8,-,-
17:47:07 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:07 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-13,-63,9,7,-,29
17:47:10 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:10 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-16,-60,7,7,-,28
17:47:13 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:13 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-13,-63,8,7,-,28
17:47:16 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:16 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-15,-64,9,8,210,-
17:47:19 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:19 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-15,-62,8,8,-,-
17:47:22 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:22 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-14,-59,7,8,-,30
17:47:25 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:25 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-13,-63,9,8,-,29
17:47:28 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:28 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-14,-63,8,8,-,29
17:47:31 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:32 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-14,-63,9,8,40,-
17:47:35 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:35 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-13,-63,8,-,-,29
17:47:38 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:38 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-13,-62,8,-,-,29
17:47:41 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:41 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-12,-64,9,-,-,29
17:47:44 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:44 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-16,-60,8,6,-,-
17:47:47 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:47 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-16,-61,7,6,-,-
17:47:50 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:50 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-14,-61,7,6,-,29
17:47:53 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:53 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-15,-62,8,6,-,28
17:47:56 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:56 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-16,-59,7,6,-,28
17:47:59 lte,async,raw lte1: sent AT+QENG="servingcell"
17:47:59 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-98,-16,-60,7,6,-,-
17:48:02 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:02 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-15,-62,7,-,-,29
17:48:05 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:05 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-98,-16,-61,7,-,-,28
17:48:08 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:08 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-98,-17,-60,8,-,-,27
17:48:11 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:11 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-15,-62,7,-,-,28
17:48:14 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:14 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-15,-62,7,-,-,28
17:48:17 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:17 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-15,-61,7,-,-,28
17:48:20 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:20 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-15,-60,7,-,-,29
17:48:23 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:23 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-16,-61,8,-,-,28
17:48:26 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:26 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-13,-61,8,-,-,29
17:48:29 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:29 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-14,-61,7,-,-,29
17:48:32 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:32 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-14,-63,9,-,-,29
17:48:35 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:35 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-13,-62,8,-,-,29
17:48:38 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:38 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-16,-61,7,-,-,29
17:48:41 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:41 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-15,-60,7,-,-,29
17:48:44 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:44 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-13,-61,7,-,-,30
17:48:47 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:47 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-15,-59,7,-,-,30
17:48:50 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:50 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-14,-63,8,-,-,29
17:48:53 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:53 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-15,-60,8,-,-,29
17:48:56 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:56 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-14,-61,9,-,-,29
17:48:59 lte,async,raw lte1: sent AT+QENG="servingcell"
17:48:59 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-14,-63,8,-,-,28
17:49:01 lte,debug lte1 mbim: retrying registration
17:49:01 lte,debug lte1 mbim: request register, operator: [auto]
17:49:01 lte,debug lte1 mbim: <<< S service: connect, command: register state
17:49:01 lte,packet,raw lte1 mbim: wdm <<< send #24
17:49:01 lte,packet,raw 03000000 40000000 18000000 01000000
17:49:01 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:49:01 lte,packet,raw c2aae6df 09000000 01000000 10000000
17:49:01 lte,packet,raw 00000000 00000000 00000000 20000000
17:49:02 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:02 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-15,-61,7,-,-,29
17:49:05 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:05 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-13,-64,8,-,-,28
17:49:08 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:08 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-14,-62,7,-,-,28
17:49:11 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:11 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-14,-63,8,-,-,28
17:49:14 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:14 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-14,-61,7,-,-,29
17:49:17 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:17 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-15,-61,8,-,-,28
17:49:20 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:20 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-15,-60,8,-,-,30
17:49:23 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:23 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-98,-18,-59,7,-,-,27
17:49:26 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:26 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-15,-61,7,-,-,29
17:49:29 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:29 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-14,-62,8,-,-,29
17:49:32 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:32 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-13,-63,8,-,-,28
17:49:35 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:35 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-98,-13,-63,9,-,-,28
17:49:38 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:38 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-16,-61,7,-,-,28
17:49:41 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:41 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-14,-62,8,-,-,29
17:49:44 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:44 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-98,-15,-63,8,-,-,27
17:49:47 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:47 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-13,-62,8,-,-,29
17:49:49 lte,packet,raw lte1 mbim: wdm >>> recv #24
17:49:49 lte,packet,raw 03000080 60000000 18000000 01000000
17:49:49 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:49:49 lte,packet,raw c2aae6df 09000000 00000000 30000000
17:49:49 lte,packet,raw 00000000 01000000 01000000 00000000
17:49:49 lte,packet,raw 01000000 00000000 00000000 00000000
17:49:49 lte,packet,raw 00000000 00000000 00000000 02000000
17:49:49 lte,debug lte1 mbim: >>> D service: connect, command: register state
17:49:49 lte,packet lte1 mbim: status data:
17:49:49 lte,packet 00000000 01000000 01000000 00000000
17:49:49 lte,packet 01000000 00000000 00000000 00000000
17:49:49 lte,packet 00000000 00000000 00000000 02000000
17:49:49 lte,debug lte1 mbim: register state: deregistered
17:49:49 lte,debug lte1 mbim: state 12=>11
17:49:50 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:50 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-15,-60,8,-,-,29
17:49:53 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:53 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-17,-60,7,-,-,28
17:49:56 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:56 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-18,-59,7,-,-,28
17:49:59 lte,async,raw lte1: sent AT+QENG="servingcell"
17:49:59 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-16,-60,7,-,-,28
17:50:02 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:02 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-14,-60,8,-,-,30
17:50:05 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:05 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-16,-61,7,-,-,28
17:50:08 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:08 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-15,-61,6,-,-,29
17:50:11 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:11 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-15,-60,6,-,-,30
17:50:14 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:14 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-13,-63,8,-,-,29
17:50:17 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:17 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-13,-62,8,-,-,30
17:50:20 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:20 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-15,-60,8,-,-,30
17:50:23 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:23 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-12,-64,10,-,-,29
17:50:26 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:26 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-14,-62,9,-,-,29
17:50:29 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:29 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-14,-60,8,-,-,30
17:50:32 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:32 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-15,-59,7,-,-,30
17:50:35 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:35 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-14,-60,8,-,-,30
17:50:38 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:38 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-13,-63,9,-,-,30
17:50:41 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:41 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-15,-60,7,-,-,29
17:50:44 lte,debug lte1 mbim: state 11=>5
17:50:44 lte,debug lte1 mbim: set radio: off
17:50:44 lte,debug lte1 mbim: <<< S service: connect, command: radio state
17:50:44 lte,packet,raw lte1 mbim: wdm <<< send #25
17:50:44 lte,packet,raw 03000000 34000000 19000000 01000000
17:50:44 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:50:44 lte,packet,raw c2aae6df 03000000 01000000 04000000
17:50:44 system,info device changed by admin
17:50:44 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:44 lte,async,raw lte1: rcvd
17:50:45 lte,async,raw lte1: +CEREG: 0
17:50:45 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:50:45 lte,packet,raw 07000080 5c000000 00000000 01000000
17:50:45 lte,packet,raw 00000000 533fbeeb 14fe4467 9f9033a2
17:50:45 lte,packet,raw 23e56c3f 01000000 30000000 01000000
17:50:45 lte,packet,raw 00000000 1e000000 00000000 18000000
17:50:45 lte,packet,raw 18000000 2b003300 33003600 30003900
17:50:45 lte,packet,raw 30003000 31003300 39003000
17:50:45 lte,debug lte1 mbim: >>> N service: sms, command: configuration
17:50:45 lte,packet lte1 mbim: status data:
17:50:45 lte,packet 01000000 00000000 1e000000 00000000
17:50:45 lte,packet 18000000 18000000 2b003300 33003600
17:50:45 lte,packet 30003900 30003000 31003300 39003000
17:50:45 lte,packet,raw 07000080 34000000 00000000 01000000
17:50:45 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:50:45 lte,packet,raw c2aae6df 03000000 08000000 01000000
17:50:45 lte,debug lte1 mbim: >>> N service: connect, command: radio state
17:50:45 lte,packet,raw lte1 mbim: wdm >>> recv #25
17:50:45 lte,packet,raw 03000080 38000000 19000000 01000000
17:50:45 lte,packet,raw c2aae6df 03000000 00000000 08000000
17:50:45 lte,packet,raw 01000000 00000000
17:50:45 lte,debug lte1 mbim: >>> D service: connect, command: radio state
17:50:45 lte,debug lte1 mbim: state 5=>6
17:50:45 lte,async lte1: sent AT+QCFG="band",8d0,000001a0080800d5,0,1
17:50:45 lte,debug lte1 mbim: state 6=>7
17:50:45 lte,debug lte1 mbim: <<< Q service: connect, command: subscriber ready status
17:50:45 lte,packet,raw lte1 mbim: wdm <<< send #26
17:50:45 lte,packet,raw 03000000 30000000 1a000000 01000000
17:50:45 lte,packet,raw c2aae6df 02000000 00000000 00000000
17:50:45 lte,async lte1: rcvd OK
17:50:45 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:45 lte,async,raw lte1: rcvd +QENG: "servingcell","SEARCH"
17:50:45 lte,packet,raw c2aae6df 09000000 30000000 00000000
17:50:45 lte,packet,raw 01000000 01000000 00000000 01000000
17:50:45 lte,packet,raw 00000000 00000000 00000000 00000000
17:50:45 lte,packet,raw 00000000 00000000 02000000
17:50:45 lte,debug lte1 mbim: >>> N service: connect, command: register state
17:50:45 lte,packet 00000000 01000000 01000000 00000000
17:50:45 lte,packet 01000000 00000000 00000000 00000000
17:50:45 lte,packet 00000000 00000000 00000000 02000000
17:50:45 lte,packet,raw lte1 mbim: wdm >>> recv #26
17:50:45 lte,packet,raw 03000080 ac000000 1a000000 01000000
17:50:45 lte,packet,raw c2aae6df 02000000 00000000 7c000000
17:50:45 lte,packet,raw 01000000 34000000 1e000000 54000000
17:50:45 lte,packet,raw 28000000 00000000 00000000 00000000
17:50:45 lte,packet,raw 00000000 32003000 38003100 30003500
17:50:45 lte,packet,raw 34003800 36003300 38003100 39003900
17:50:45 lte,packet,raw 30000000 38003900 33003300 31003000
17:50:45 lte,packet,raw 35003400 32003000 30003700 37003500
17:50:45 lte,packet,raw 30003400 33003400 35003200
17:50:45 lte,debug lte1 mbim: >>> D service: connect, command: subscriber ready status
17:50:45 lte,packet 01000000 34000000 1e000000 54000000
17:50:45 lte,packet 28000000 00000000 00000000 00000000
17:50:45 lte,packet 00000000 00000000 00000000 00000000
17:50:45 lte,packet 00000000 32003000 38003100 30003500
17:50:45 lte,packet 34003800 36003300 38003100 39003900
17:50:45 lte,packet 30000000 38003900 33003300 31003000
17:50:45 lte,packet 35003400 32003000 30003700 37003500
17:50:45 lte,packet 30003400 33003400 35003200
17:50:45 lte,debug lte1 mbim: subscriber ready state: 1
17:50:45 lte,debug lte1 mbim: state 7=>10
17:50:45 lte,debug lte1 mbim: set lte attach apn: ipfixe
17:50:45 lte,debug lte1 mbim: <<< S service: conn_ext, command: lte attach config
17:50:45 lte,packet,raw lte1 mbim: wdm <<< send #27
17:50:45 lte,packet,raw 03000000 f8000000 1b000000 01000000
17:50:45 lte,packet,raw 00000000 3d01dcc5 fef54d05 0d3abef7
17:50:45 lte,packet,raw 058e9aaf 03000000 01000000 c8000000
17:50:45 lte,packet,raw 00000000 03000000 20000000 38000000
17:50:45 lte,packet,raw 58000000 38000000 90000000 38000000
17:50:45 lte,packet,raw 00000000 00000000 01000000 2c000000
17:50:45 lte,packet,raw 0c000000 00000000 00000000 00000000
17:50:45 lte,packet,raw 00000000 00000000 00000000 69007000
17:50:45 lte,packet,raw 66006900 78006500 00000000 01000000
17:50:45 lte,packet,raw 01000000 2c000000 0c000000 00000000
17:50:45 lte,packet,raw 00000000 69007000 66006900 78006500
17:50:45 lte,packet,raw 00000000 02000000 01000000 2c000000
17:50:45 lte,packet,raw lte1 mbim: wdm >>> recv #27
17:50:45 lte,packet,raw 03000080 f4000000 1b000000 01000000
17:50:45 lte,packet,raw 058e9aaf 03000000 00000000 c4000000
17:50:45 lte,packet,raw 03000000 1c000000 38000000 54000000
17:50:45 lte,packet,raw 38000000 8c000000 38000000 00000000
17:50:45 lte,packet,raw 00000000 01000000 2c000000 0c000000
17:50:45 lte,packet,raw 00000000 00000000 69007000 66006900
17:50:45 lte,packet,raw 78006500 00000000 01000000 01000000
17:50:45 lte,packet,raw 2c000000 0c000000 00000000 00000000
17:50:45 lte,packet,raw 69007000 66006900 78006500 00000000
17:50:45 lte,packet,raw 02000000 01000000 2c000000 0c000000
17:50:45 lte,debug lte1 mbim: >>> D service: conn_ext, command: lte attach config
17:50:45 lte,packet 03000000 1c000000 38000000 54000000
17:50:45 lte,packet 38000000 8c000000 38000000 00000000
17:50:45 lte,packet 00000000 01000000 2c000000 0c000000
17:50:45 lte,packet 00000000 00000000 69007000 66006900
17:50:45 lte,packet 78006500 00000000 01000000 01000000
17:50:45 lte,packet 2c000000 0c000000 00000000 00000000
17:50:45 lte,packet 69007000 66006900 78006500 00000000
17:50:45 lte,packet 02000000 01000000 2c000000 0c000000
17:50:45 lte,debug lte1 mbim: lte attach ctx source: 1 roam: 0 ip: 0 apn: ipfixe
17:50:45 lte,debug lte1 mbim: lte attach ctx source: 1 roam: 1 ip: 0 apn: ipfixe
17:50:45 lte,debug lte1 mbim: lte attach ctx source: 1 roam: 2 ip: 0 apn: ipfixe
17:50:45 lte,debug lte1 mbim: request register, operator: [auto]
17:50:45 lte,debug lte1 mbim: <<< S service: connect, command: register state
17:50:45 lte,packet,raw lte1 mbim: wdm <<< send #28
17:50:45 lte,packet,raw 03000000 40000000 1c000000 01000000
17:50:45 lte,packet,raw c2aae6df 09000000 01000000 10000000
17:50:45 lte,packet,raw 00000000 00000000 00000000 3c000000
17:50:45 lte,packet,raw lte1 mbim: wdm >>> recv #28
17:50:45 lte,packet,raw 03000080 60000000 1c000000 01000000
17:50:45 lte,packet,raw c2aae6df 09000000 00000000 30000000
17:50:45 lte,packet,raw 00000000 01000000 01000000 00000000
17:50:45 lte,packet,raw 01000000 00000000 00000000 00000000
17:50:45 lte,packet,raw 00000000 00000000 00000000 02000000
17:50:45 lte,debug lte1 mbim: >>> D service: connect, command: register state
17:50:45 lte,debug lte1 mbim: register state: deregistered
17:50:45 lte,debug lte1 mbim: state 10=>11
17:50:45 lte,debug lte1 mbim: set radio: on
17:50:45 lte,debug lte1 mbim: <<< S service: connect, command: radio state
17:50:45 lte,packet,raw lte1 mbim: wdm <<< send #29
17:50:45 lte,packet,raw 03000000 34000000 1d000000 01000000
17:50:45 lte,packet,raw c2aae6df 03000000 01000000 04000000
17:50:45 lte,packet 01000000 01000000
17:50:45 lte,packet,raw lte1 mbim: wdm >>> recv #29
17:50:45 lte,packet,raw 03000080 38000000 1d000000 01000000
17:50:45 lte,packet,raw 02000000 01000000 00000000 01000000
17:50:45 lte,packet 00000000 02000000 01000000 00000000
17:50:45 lte,debug lte1 mbim: register state: searching
17:50:45 lte,debug lte1 mbim: state 11=>12
17:50:46 lte,async,raw lte1: +CEREG: 2
17:50:48 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:48 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-16,-61,7,7,-,-
17:50:51 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:51 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-15,-61,7,7,-,29
17:50:54 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:54 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-15,-59,8,7,-,30
17:50:57 lte,async,raw lte1: sent AT+QENG="servingcell"
17:50:57 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-14,-60,8,7,-,30
17:51:00 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:00 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-16,-62,8,7,-,-
17:51:03 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:03 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-14,-62,8,9,-,-
17:51:06 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:06 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-14,-60,7,8,-,30
17:51:09 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:09 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-13,-62,8,8,-,30
17:51:12 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:12 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-14,-60,7,8,-,30
17:51:15 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:16 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-97,-14,-62,9,8,-,-
17:51:19 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:19 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-12,-63,9,-,-,30
17:51:22 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:22 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-12,-62,9,-,-,30
17:51:25 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:25 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-14,-61,8,-,-,30
17:51:28 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:28 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-13,-62,9,-,-,30
17:51:31 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:31 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-14,-63,9,8,60,-
17:51:34 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:34 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-15,-61,9,9,-,29
17:51:37 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:37 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-95,-15,-60,9,9,-,30
17:51:40 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:40 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-13,-62,8,9,-,30
17:51:43 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:43 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-14,-59,9,9,-,-
17:51:46 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:46 lte,async,raw lte1: rcvd +QENG: "servingcell","LIMSRV","LTE","FDD",208,10,802E901,478,1501,3,5,5,7673,-96,-14,-62,9,7,-,-
17:51:49 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:51:49 lte,packet,raw 07000080 40000000 00000000 01000000
17:51:49 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:51:49 lte,packet,raw c2aae6df 0b000000 14000000 11000000
17:51:49 lte,packet,raw 63000000 05000000 02000000 ffffffff
17:51:49 lte,packet,raw 07000080 74000000 00000000 01000000
17:51:49 lte,packet,raw c2aae6df 09000000 48000000 00000000
17:51:49 lte,packet,raw 03000000 01000000 1c000000 01000000
17:51:49 lte,packet,raw 30000000 0a000000 3c000000 0a000000
17:51:49 lte,packet,raw 00000000 00000000 02000000 32003000
17:51:49 lte,packet,raw 38003100 30000000 46002000 53004600
17:51:49 lte,packet,raw 52000000
17:51:49 lte,debug lte1 mbim: >>> N service: connect, command: register state
17:51:49 lte,packet lte1 mbim: status data:
17:51:49 lte,packet 00000000 03000000 01000000 1c000000
17:51:49 lte,packet 01000000 30000000 0a000000 3c000000
17:51:49 lte,packet 0a000000 00000000 00000000 02000000
17:51:49 lte,packet 32003000 38003100 30000000 46002000
17:51:49 lte,packet 53004600 52000000
17:51:49 lte,debug lte1 mbim: register state: home, gsm operator: 20810, F SFR, avail data classes: 0x1c
17:51:49 lte,debug lte1 mbim: state 12=>14
17:51:49 lte,debug lte1 mbim: auto attach
17:51:49 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:49 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-6,-,-,-,-,-
17:51:49 lte,async,raw lte1: sent AT+QXPOWER
17:51:49 lte,async,raw lte1: rcvd +QXPOWER: -1021260416,1070904783,25,-1021260408
17:51:49 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:51:49 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:51:49 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:51:49 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:51:49 lte,async,raw lte1: sent AT+CSQ
17:51:49 lte,async,raw lte1: rcvd +CSQ: 17,99
17:51:50 lte,async,raw lte1: +CGREG: 1,"7B35","6124FEA",2
17:51:50 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:51:50 lte,packet,raw 07000080 48000000 00000000 01000000
17:51:50 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:51:50 lte,packet,raw c2aae6df 0a000000 1c000000 00000000
17:51:50 lte,packet,raw 02000000 18000000 1072af00 00000000
17:51:50 lte,packet,raw c0eb8302 00000000
17:51:50 lte,debug lte1 mbim: >>> N service: connect, command: packet service
17:51:50 lte,packet lte1 mbim: status data:
17:51:50 lte,packet 00000000 02000000 18000000 1072af00
17:51:50 lte,packet 00000000 c0eb8302 00000000
17:51:50 lte,debug lte1 mbim: packet service: attached data class: 0x18 nwe:
17:51:50 lte,debug lte1 mbim: state 14=>17
17:51:50 lte,packet,raw 07000080 54000000 00000000 01000000
17:51:50 lte,packet,raw 00000000 3d01dcc5 fef54d05 0d3abef7
17:51:50 lte,packet,raw 058e9aaf 04000000 28000000 00000000
17:51:50 lte,packet,raw 00000000 00000000 00000000 00000000
17:51:50 lte,debug lte1 mbim: >>> N service: conn_ext, command: lte attach status
17:51:50 lte,packet 00000000 00000000 00000000 00000000
17:51:50 lte,debug lte1 mbim: lte status: detached iptype: 0
17:51:51 lte,debug lte1 mbim: do connect activate #0
17:51:51 lte,debug lte1 mbim: apn: ipfixe iptype: 0
17:51:51 lte,debug lte1 mbim: <<< S service: connect, command: connect
17:51:51 lte,packet,raw lte1 mbim: wdm <<< send #30
17:51:51 lte,packet,raw 03000000 78000000 1e000000 01000000
17:51:51 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:51:51 lte,packet,raw c2aae6df 0c000000 01000000 48000000
17:51:51 lte,packet,raw 00000000 01000000 3c000000 0c000000
17:51:51 lte,packet,raw 00000000 00000000 00000000 00000000
17:51:51 lte,packet,raw 00000000 00000000 00000000 7e5e2a7e
17:51:51 lte,packet,raw 4e6f7272 736b656e 7e5e2a7e 69007000
17:51:51 lte,packet,raw 66006900 78006500
17:51:51 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:51:51 lte,packet,raw 07000080 50000000 00000000 01000000
17:51:51 lte,packet,raw c2aae6df 0c000000 24000000 00000000
17:51:51 lte,packet,raw 02000000 00000000 00000000 7e5e2a7e
17:51:51 lte,packet,raw 4e6f7272 736b656e 7e5e2a7e 00000000
17:51:51 lte,debug lte1 mbim: >>> N service: connect, command: connect
17:51:51 lte,packet lte1 mbim: status data:
17:51:51 lte,packet 00000000 02000000 00000000 00000000
17:51:51 lte,packet 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
17:51:51 lte,debug lte1 mbim: connect: #0 activating, nwe:
17:51:51 lte,debug lte1 mbim: waiting for done
17:51:52 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:52 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-4,-,-,-,-,-
17:51:52 lte,async,raw lte1: sent AT+QXPOWER
17:51:52 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:51:52 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:51:52 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:51:52 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:51:52 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:51:52 lte,async,raw lte1: sent AT+CSQ
17:51:52 lte,async,raw lte1: rcvd +CSQ: 17,99
17:51:54 lte,packet,raw lte1 mbim: wdm >>> recv #30
17:51:54 lte,packet,raw 03000080 54000000 1e000000 01000000
17:51:54 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:51:54 lte,packet,raw c2aae6df 0c000000 00000000 24000000
17:51:54 lte,packet,raw 00000000 01000000 00000000 03000000
17:51:54 lte,packet,raw 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
17:51:54 lte,debug lte1 mbim: >>> D service: connect, command: connect
17:51:54 lte,packet lte1 mbim: status data:
17:51:54 lte,packet 00000000 01000000 00000000 03000000
17:51:54 lte,packet 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
17:51:54 lte,debug lte1 mbim: connect: #0 activated, nwe:
17:51:54 lte,debug lte1 mbim: get ip config #0
17:51:54 lte,debug lte1 mbim: <<< Q service: connect, command: ip configuration
17:51:54 lte,packet,raw lte1 mbim: wdm <<< send #31
17:51:54 lte,packet,raw 03000000 6c000000 1f000000 01000000
17:51:54 lte,packet,raw c2aae6df 0f000000 00000000 3c000000
17:51:54 lte,packet,raw 00000000 00000000 00000000 00000000
17:51:54 lte,packet,raw lte1 mbim: wdm >>> recv #31
17:51:54 lte,packet,raw 03000080 c4000000 1f000000 01000000
17:51:54 lte,packet,raw c2aae6df 0f000000 00000000 94000000
17:51:54 lte,packet,raw 00000000 0f000000 0f000000 01000000
17:51:54 lte,packet,raw 3c000000 01000000 50000000 44000000
17:51:54 lte,packet,raw 64000000 02000000 48000000 02000000
17:51:54 lte,packet,raw 74000000 dc050000 dc050000 1d000000
17:51:54 lte,packet,raw 4d84f6cb 4d84f6cc ac14020a ac140227
17:51:54 lte,packet,raw 40000000 2a028440 33e00eb4 051ac306
17:51:54 lte,packet,raw a0be9df8 2a028440 33e00eb4 d11c60fc
17:51:54 lte,packet,raw 8fe6dec8 2a028400 00000000 00000000
17:51:54 lte,packet,raw 00020000 2a028400 00000000 00000000
17:51:54 lte,packet,raw 00020001
17:51:54 lte,debug lte1 mbim: >>> D service: connect, command: ip configuration
17:51:54 lte,packet 00000000 0f000000 0f000000 01000000
17:51:54 lte,packet 3c000000 01000000 50000000 44000000
17:51:54 lte,packet 64000000 02000000 48000000 02000000
17:51:54 lte,packet 74000000 dc050000 dc050000 1d000000
17:51:54 lte,packet 4d84f6cb 4d84f6cc ac14020a ac140227
17:51:54 lte,packet 40000000 2a028440 33e00eb4 051ac306
17:51:54 lte,packet a0be9df8 2a028440 33e00eb4 d11c60fc
17:51:54 lte,packet 8fe6dec8 2a028400 00000000 00000000
17:51:54 lte,packet 00020000 2a028400 00000000 00000000
17:51:54 lte,packet 00020001
17:51:54 lte,debug lte1 mbim: received ip config #0 15,15
17:51:54 lte,info lte1 IPv4: 77.132.246.203, DNS: 172.20.2.10,172.20.2.39
17:51:54 lte,info lte1 IPv6: 2a02:8440:33e0:eb4::/64, DNS: 2a02:8400::2:0,2a02:8400::2:1
17:51:54 lte,debug lte1 mbim: 1lte1 mbim: state 17=>18
17:51:54 interface,info lte1 link up
17:51:55 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:55 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-5,-,-,-,-,-
17:51:55 lte,async,raw lte1: sent AT+QXPOWER
17:51:55 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:51:55 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:51:55 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:51:55 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:51:55 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:51:55 lte,async,raw lte1: sent AT+CSQ
17:51:55 lte,async,raw lte1: rcvd +CSQ: 17,99
17:51:57 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:51:57 lte,packet,raw 07000080 40000000 00000000 01000000
17:51:57 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:51:57 lte,packet,raw c2aae6df 0b000000 14000000 0f000000
17:51:57 lte,packet,raw 63000000 05000000 02000000 ffffffff
17:51:58 lte,async,raw lte1: sent AT+QENG="servingcell"
17:51:58 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-6,-,-,-,-,-
17:51:58 lte,async,raw lte1: sent AT+QXPOWER
17:51:58 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:51:58 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:51:58 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:51:58 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:51:58 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:51:58 lte,async,raw lte1: sent AT+CSQ
17:51:58 lte,async,raw lte1: rcvd +CSQ: 15,99
17:52:01 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:01 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-4,-,-,-,-,-
17:52:01 lte,async,raw lte1: sent AT+QXPOWER
17:52:01 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:52:01 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:01 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:01 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:01 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:01 lte,async,raw lte1: sent AT+CSQ
17:52:01 lte,async,raw lte1: rcvd +CSQ: 16,99
17:52:04 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:04 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
17:52:04 lte,async,raw lte1: sent AT+QXPOWER
17:52:04 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:52:04 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:04 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:04 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:04 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:04 lte,async,raw lte1: sent AT+CSQ
17:52:04 lte,async,raw lte1: rcvd +CSQ: 16,99
17:52:07 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:07 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-8,-,-,-,-,-
17:52:07 lte,async,raw lte1: sent AT+QXPOWER
17:52:07 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:52:07 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:07 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:07 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:07 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:07 lte,async,raw lte1: sent AT+CSQ
17:52:07 lte,async,raw lte1: rcvd +CSQ: 16,99
17:52:10 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:10 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-9,-,-,-,-,-
17:52:10 lte,async,raw lte1: sent AT+QXPOWER
17:52:10 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:52:10 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:10 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:10 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:10 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:10 lte,async,raw lte1: sent AT+CSQ
17:52:10 lte,async,raw lte1: rcvd +CSQ: 16,99
17:52:13 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:13 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-10,-,-,-,-,-
17:52:13 lte,async,raw lte1: sent AT+QXPOWER
17:52:13 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:52:13 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:13 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:13 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:13 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:13 lte,async,raw lte1: sent AT+CSQ
17:52:13 lte,async,raw lte1: rcvd +CSQ: 15,99
17:52:16 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:16 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
17:52:16 lte,async,raw lte1: sent AT+QXPOWER
17:52:16 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:52:16 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:16 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:16 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:16 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:16 lte,async,raw lte1: sent AT+CSQ
17:52:16 lte,async,raw lte1: rcvd +CSQ: 16,99
17:52:19 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:19 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
17:52:19 lte,async,raw lte1: sent AT+QXPOWER
17:52:19 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:52:19 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:19 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:19 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:19 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:19 lte,async,raw lte1: sent AT+CSQ
17:52:19 lte,async,raw lte1: rcvd +CSQ: 16,99
17:52:22 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:22 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
17:52:22 lte,async,raw lte1: sent AT+QXPOWER
17:52:23 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:52:23 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:23 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:23 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:23 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:23 lte,async,raw lte1: sent AT+CSQ
17:52:23 lte,async,raw lte1: rcvd +CSQ: 16,99
17:52:26 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:26 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
17:52:26 lte,async,raw lte1: sent AT+QXPOWER
17:52:26 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:52:26 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:26 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:26 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:26 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:26 lte,async,raw lte1: sent AT+CSQ
17:52:26 lte,async,raw lte1: rcvd +CSQ: 15,99
17:52:29 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:29 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-6,-,-,-,-,-
17:52:29 lte,async,raw lte1: sent AT+QXPOWER
17:52:29 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:52:29 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:29 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:29 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:29 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:29 lte,async,raw lte1: sent AT+CSQ
17:52:29 lte,async,raw lte1: rcvd +CSQ: 15,99
17:52:32 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:32 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-86,-7,-,-,-,-,-
17:52:32 lte,async,raw lte1: sent AT+QXPOWER
17:52:32 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:52:32 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:32 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:32 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:32 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:32 lte,async,raw lte1: sent AT+CSQ
17:52:32 lte,async,raw lte1: rcvd +CSQ: 15,99
17:52:35 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:35 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-7,-,-,-,-,-
17:52:35 lte,async,raw lte1: sent AT+QXPOWER
17:52:35 lte,async,raw lte1: rcvd +QXPOWER: 0,0,0,0
17:52:35 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:35 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:35 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:35 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:35 lte,async,raw lte1: sent AT+CSQ
17:52:35 lte,async,raw lte1: rcvd +CSQ: 15,99
17:52:35 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:52:35 lte,packet,raw 07000080 48000000 00000000 01000000
17:52:35 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:52:35 lte,packet,raw c2aae6df 0a000000 1c000000 00000000
17:52:35 lte,packet,raw 02000000 18000000 107a8400 00000000
17:52:35 lte,packet,raw 107a8400 00000000
17:52:35 lte,debug lte1 mbim: >>> N service: connect, command: packet service
17:52:35 lte,packet lte1 mbim: status data:
17:52:35 lte,packet 00000000 02000000 18000000 107a8400
17:52:35 lte,packet 00000000 107a8400 00000000
17:52:35 lte,debug lte1 mbim: packet service: attached data class: 0x18 nwe:
17:52:38 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:38 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
17:52:38 lte,async,raw lte1: sent AT+QXPOWER
17:52:38 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:52:38 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:38 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:38 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:38 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:38 lte,async,raw lte1: sent AT+CSQ
17:52:38 lte,async,raw lte1: rcvd +CSQ: 15,99
17:52:41 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:41 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-7,-,-,-,-,-
17:52:41 lte,async,raw lte1: sent AT+QXPOWER
17:52:41 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:52:41 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:41 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:41 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:41 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:41 lte,async,raw lte1: sent AT+CSQ
17:52:41 lte,async,raw lte1: rcvd +CSQ: 15,99
17:52:44 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:44 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-7,-,-,-,-,-
17:52:44 lte,async,raw lte1: sent AT+QXPOWER
17:52:44 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:52:44 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:44 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:44 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:44 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:44 lte,async,raw lte1: sent AT+CSQ
17:52:44 lte,async,raw lte1: rcvd +CSQ: 15,99
17:52:47 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:47 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
17:52:47 lte,async,raw lte1: sent AT+QXPOWER
17:52:47 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:52:47 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:47 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:47 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:47 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:47 lte,async,raw lte1: sent AT+CSQ
17:52:47 lte,async,raw lte1: rcvd +CSQ: 15,99
17:52:50 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:50 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-7,-,-,-,-,-
17:52:50 lte,async,raw lte1: sent AT+QXPOWER
17:52:50 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:52:50 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:50 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:50 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:50 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:50 lte,async,raw lte1: sent AT+CSQ
17:52:50 lte,async,raw lte1: rcvd +CSQ: 15,99
17:52:53 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:53 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
17:52:53 lte,async,raw lte1: sent AT+QXPOWER
17:52:53 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:52:53 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:53 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:53 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:53 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:53 lte,async,raw lte1: sent AT+CSQ
17:52:53 lte,async,raw lte1: rcvd +CSQ: 15,99
17:52:56 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:56 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
17:52:56 lte,async,raw lte1: sent AT+QXPOWER
17:52:56 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:52:56 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:56 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:56 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:56 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:56 lte,async,raw lte1: sent AT+CSQ
17:52:56 lte,async,raw lte1: rcvd +CSQ: 16,99
17:52:59 lte,async,raw lte1: sent AT+QENG="servingcell"
17:52:59 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-4,-,-,-,-,-
17:52:59 lte,async,raw lte1: sent AT+QXPOWER
17:52:59 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:52:59 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:52:59 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:52:59 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:52:59 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:52:59 lte,async,raw lte1: sent AT+CSQ
17:52:59 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:02 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:02 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-4,-,-,-,-,-
17:53:02 lte,async,raw lte1: sent AT+QXPOWER
17:53:02 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:02 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:02 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:02 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:02 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:02 lte,async,raw lte1: sent AT+CSQ
17:53:02 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:05 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:05 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
17:53:05 lte,async,raw lte1: sent AT+QXPOWER
17:53:05 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:05 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:05 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:05 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:05 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:05 lte,async,raw lte1: sent AT+CSQ
17:53:05 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:08 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:08 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-7,-,-,-,-,-
17:53:08 lte,async,raw lte1: sent AT+QXPOWER
17:53:08 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:08 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:08 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:08 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:08 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:08 lte,async,raw lte1: sent AT+CSQ
17:53:08 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:11 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:11 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
17:53:11 lte,async,raw lte1: sent AT+QXPOWER
17:53:11 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:11 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:11 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:11 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:11 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:11 lte,async,raw lte1: sent AT+CSQ
17:53:11 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:14 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:14 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
17:53:14 lte,async,raw lte1: sent AT+QXPOWER
17:53:14 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:14 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:14 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:14 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:14 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:14 lte,async,raw lte1: sent AT+CSQ
17:53:14 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:17 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:17 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
17:53:17 lte,async,raw lte1: sent AT+QXPOWER
17:53:17 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:17 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:17 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:17 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:17 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:17 lte,async,raw lte1: sent AT+CSQ
17:53:17 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:20 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:20 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-85,-5,-,-,-,-,-
17:53:20 lte,async,raw lte1: sent AT+QXPOWER
17:53:20 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:20 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:20 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:20 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:20 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:20 lte,async,raw lte1: sent AT+CSQ
17:53:20 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:23 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:23 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-5,-,-,-,-,-
17:53:23 lte,async,raw lte1: sent AT+QXPOWER
17:53:23 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:23 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:23 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:23 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:23 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:23 lte,async,raw lte1: sent AT+CSQ
17:53:23 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:26 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:26 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-4,-,-,-,-,-
17:53:26 lte,async,raw lte1: sent AT+QXPOWER
17:53:26 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:26 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:26 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:26 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:26 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:26 lte,async,raw lte1: sent AT+CSQ
17:53:26 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:29 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:29 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-11,-,-,-,-,-
17:53:29 lte,async,raw lte1: sent AT+QXPOWER
17:53:29 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:29 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:29 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:29 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:29 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:29 lte,async,raw lte1: sent AT+CSQ
17:53:29 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:32 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:32 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-11,-,-,-,-,-
17:53:32 lte,async,raw lte1: sent AT+QXPOWER
17:53:32 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:32 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:32 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:32 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:32 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:32 lte,async,raw lte1: sent AT+CSQ
17:53:32 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:35 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:35 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
17:53:35 lte,async,raw lte1: sent AT+QXPOWER
17:53:35 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:35 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:35 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:35 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:35 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:35 lte,async,raw lte1: sent AT+CSQ
17:53:35 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:38 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:38 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
17:53:38 lte,async,raw lte1: sent AT+QXPOWER
17:53:38 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:38 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:38 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:38 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:38 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:38 lte,async,raw lte1: sent AT+CSQ
17:53:38 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:41 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:41 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
17:53:41 lte,async,raw lte1: sent AT+QXPOWER
17:53:41 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:41 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:41 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:41 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:41 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:41 lte,async,raw lte1: sent AT+CSQ
17:53:41 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:44 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:44 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
17:53:44 lte,async,raw lte1: sent AT+QXPOWER
17:53:44 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:44 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:44 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:44 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:44 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:44 lte,async,raw lte1: sent AT+CSQ
17:53:44 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:47 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:47 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-10,-,-,-,-,-
17:53:47 lte,async,raw lte1: sent AT+QXPOWER
17:53:47 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:47 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:47 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:47 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:47 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:47 lte,async,raw lte1: sent AT+CSQ
17:53:47 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:50 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:50 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
17:53:50 lte,async,raw lte1: sent AT+QXPOWER
17:53:50 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:50 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:50 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:50 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:50 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:50 lte,async,raw lte1: sent AT+CSQ
17:53:50 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:53 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:53 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-5,-,-,-,-,-
17:53:53 lte,async,raw lte1: sent AT+QXPOWER
17:53:53 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:53 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:53 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:53 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:53 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:53 lte,async,raw lte1: sent AT+CSQ
17:53:53 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:56 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:56 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-7,-,-,-,-,-
17:53:56 lte,async,raw lte1: sent AT+QXPOWER
17:53:56 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:56 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:56 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:56 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:56 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:56 lte,async,raw lte1: sent AT+CSQ
17:53:56 lte,async,raw lte1: rcvd +CSQ: 16,99
17:53:59 lte,async,raw lte1: sent AT+QENG="servingcell"
17:53:59 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
17:53:59 lte,async,raw lte1: sent AT+QXPOWER
17:53:59 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:53:59 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:53:59 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:53:59 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:53:59 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:53:59 lte,async,raw lte1: sent AT+CSQ
17:53:59 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:02 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:02 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-7,-,-,-,-,-
17:54:02 lte,async,raw lte1: sent AT+QXPOWER
17:54:02 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:02 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:02 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:02 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:02 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:02 lte,async,raw lte1: sent AT+CSQ
17:54:02 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:05 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:05 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-10,-,-,-,-,-
17:54:05 lte,async,raw lte1: sent AT+QXPOWER
17:54:05 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:05 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:05 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:05 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:05 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:05 lte,async,raw lte1: sent AT+CSQ
17:54:05 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:08 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:08 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
17:54:08 lte,async,raw lte1: sent AT+QXPOWER
17:54:08 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:08 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:08 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:08 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:08 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:08 lte,async,raw lte1: sent AT+CSQ
17:54:08 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:11 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:11 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
17:54:11 lte,async,raw lte1: sent AT+QXPOWER
17:54:11 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:11 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:11 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:11 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:11 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:11 lte,async,raw lte1: sent AT+CSQ
17:54:11 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:14 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:14 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-11,-,-,-,-,-
17:54:14 lte,async,raw lte1: sent AT+QXPOWER
17:54:14 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:14 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:14 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:14 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:14 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:14 lte,async,raw lte1: sent AT+CSQ
17:54:14 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:17 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:17 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-4,-,-,-,-,-
17:54:17 lte,async,raw lte1: sent AT+QXPOWER
17:54:17 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:17 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:17 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:17 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:17 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:17 lte,async,raw lte1: sent AT+CSQ
17:54:17 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:20 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:20 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-5,-,-,-,-,-
17:54:20 lte,async,raw lte1: sent AT+QXPOWER
17:54:20 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:20 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:20 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:20 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:20 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:20 lte,async,raw lte1: sent AT+CSQ
17:54:20 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:23 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:23 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-11,-,-,-,-,-
17:54:23 lte,async,raw lte1: sent AT+QXPOWER
17:54:23 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:23 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:23 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:23 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:23 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:23 lte,async,raw lte1: sent AT+CSQ
17:54:23 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:26 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:26 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
17:54:26 lte,async,raw lte1: sent AT+QXPOWER
17:54:26 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:26 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:26 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:26 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:26 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:26 lte,async,raw lte1: sent AT+CSQ
17:54:26 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:29 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:29 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
17:54:29 lte,async,raw lte1: sent AT+QXPOWER
17:54:29 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:29 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:29 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:29 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:29 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:29 lte,async,raw lte1: sent AT+CSQ
17:54:29 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:32 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:32 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
17:54:32 lte,async,raw lte1: sent AT+QXPOWER
17:54:32 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:32 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:32 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:32 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:32 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:32 lte,async,raw lte1: sent AT+CSQ
17:54:32 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:35 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:35 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-5,-,-,-,-,-
17:54:35 lte,async,raw lte1: sent AT+QXPOWER
17:54:35 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:35 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:35 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:35 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:35 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:35 lte,async,raw lte1: sent AT+CSQ
17:54:35 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:38 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:38 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
17:54:38 lte,async,raw lte1: sent AT+QXPOWER
17:54:38 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:38 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:38 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:38 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:38 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:38 lte,async,raw lte1: sent AT+CSQ
17:54:38 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:41 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:41 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
17:54:41 lte,async,raw lte1: sent AT+QXPOWER
17:54:41 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:41 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:41 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:41 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:41 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:41 lte,async,raw lte1: sent AT+CSQ
17:54:41 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:42 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:54:42 lte,packet,raw 07000080 40000000 00000000 01000000
17:54:42 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:54:42 lte,packet,raw c2aae6df 0b000000 14000000 12000000
17:54:42 lte,packet,raw 63000000 05000000 02000000 ffffffff
17:54:44 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:44 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
17:54:44 lte,async,raw lte1: sent AT+QXPOWER
17:54:44 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:44 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:44 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:44 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:44 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:44 lte,async,raw lte1: sent AT+CSQ
17:54:44 lte,async,raw lte1: rcvd +CSQ: 19,99
17:54:44 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:54:44 lte,packet,raw 07000080 40000000 00000000 01000000
17:54:44 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:54:44 lte,packet,raw c2aae6df 0b000000 14000000 10000000
17:54:44 lte,packet,raw 63000000 05000000 02000000 ffffffff
17:54:47 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:47 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
17:54:47 lte,async,raw lte1: sent AT+QXPOWER
17:54:47 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:47 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:47 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:47 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:47 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:47 lte,async,raw lte1: sent AT+CSQ
17:54:47 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:50 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:50 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-10,-,-,-,-,-
17:54:50 lte,async,raw lte1: sent AT+QXPOWER
17:54:50 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:50 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:50 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:50 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:50 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:50 lte,async,raw lte1: sent AT+CSQ
17:54:50 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:53 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:53 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-10,-,-,-,-,-
17:54:53 lte,async,raw lte1: sent AT+QXPOWER
17:54:53 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:53 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:53 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:53 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:53 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:53 lte,async,raw lte1: sent AT+CSQ
17:54:53 lte,async,raw lte1: rcvd +CSQ: 16,99
17:54:53 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:54:53 lte,packet,raw 07000080 40000000 00000000 01000000
17:54:53 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:54:53 lte,packet,raw c2aae6df 0b000000 14000000 12000000
17:54:53 lte,packet,raw 63000000 05000000 02000000 ffffffff
17:54:56 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:56 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-11,-,-,-,-,-
17:54:56 lte,async,raw lte1: sent AT+QXPOWER
17:54:56 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:56 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:56 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:56 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:56 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:56 lte,async,raw lte1: sent AT+CSQ
17:54:56 lte,async,raw lte1: rcvd +CSQ: 18,99
17:54:59 lte,async,raw lte1: sent AT+QENG="servingcell"
17:54:59 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-8,-,-,-,-,-
17:54:59 lte,async,raw lte1: sent AT+QXPOWER
17:54:59 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:54:59 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:54:59 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:54:59 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:54:59 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:54:59 lte,async,raw lte1: sent AT+CSQ
17:54:59 lte,async,raw lte1: rcvd +CSQ: 17,99
17:55:02 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:02 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-7,-,-,-,-,-
17:55:02 lte,async,raw lte1: sent AT+QXPOWER
17:55:02 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:02 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:02 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:02 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:02 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:02 lte,async,raw lte1: sent AT+CSQ
17:55:02 lte,async,raw lte1: rcvd +CSQ: 19,99
17:55:05 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:05 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-10,-,-,-,-,-
17:55:05 lte,async,raw lte1: sent AT+QXPOWER
17:55:05 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:05 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:05 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:05 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:05 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:05 lte,async,raw lte1: sent AT+CSQ
17:55:05 lte,async,raw lte1: rcvd +CSQ: 19,99
17:55:08 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:08 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-85,-11,-,-,-,-,-
17:55:08 lte,async,raw lte1: sent AT+QXPOWER
17:55:08 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:08 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:08 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:08 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:08 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:08 lte,async,raw lte1: sent AT+CSQ
17:55:08 lte,async,raw lte1: rcvd +CSQ: 18,99
17:55:09 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:55:09 lte,packet,raw 07000080 40000000 00000000 01000000
17:55:09 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:55:09 lte,packet,raw c2aae6df 0b000000 14000000 0f000000
17:55:09 lte,packet,raw 63000000 05000000 02000000 ffffffff
17:55:11 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:55:11 lte,packet,raw 07000080 40000000 00000000 01000000
17:55:11 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:55:11 lte,packet,raw c2aae6df 0b000000 14000000 12000000
17:55:11 lte,packet,raw 63000000 05000000 02000000 ffffffff
17:55:11 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:11 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
17:55:11 lte,async,raw lte1: sent AT+QXPOWER
17:55:11 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:11 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:11 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:11 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:11 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:11 lte,async,raw lte1: sent AT+CSQ
17:55:11 lte,async,raw lte1: rcvd +CSQ: 18,99
17:55:14 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:14 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-86,-9,-,-,-,-,-
17:55:14 lte,async,raw lte1: sent AT+QXPOWER
17:55:14 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:14 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:14 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:14 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:14 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:14 lte,async,raw lte1: sent AT+CSQ
17:55:14 lte,async,raw lte1: rcvd +CSQ: 18,99
17:55:17 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:17 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-10,-,-,-,-,-
17:55:17 lte,async,raw lte1: sent AT+QXPOWER
17:55:17 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:17 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:17 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:17 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:17 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:17 lte,async,raw lte1: sent AT+CSQ
17:55:17 lte,async,raw lte1: rcvd +CSQ: 17,99
17:55:18 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:55:18 lte,packet,raw 07000080 40000000 00000000 01000000
17:55:18 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:55:18 lte,packet,raw c2aae6df 0b000000 14000000 10000000
17:55:18 lte,packet,raw 63000000 05000000 02000000 ffffffff
17:55:20 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:20 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-11,-,-,-,-,-
17:55:20 lte,async,raw lte1: sent AT+QXPOWER
17:55:20 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:20 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:20 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:20 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:20 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:20 lte,async,raw lte1: sent AT+CSQ
17:55:20 lte,async,raw lte1: rcvd +CSQ: 16,99
17:55:23 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:23 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-6,-,-,-,-,-
17:55:23 lte,async,raw lte1: sent AT+QXPOWER
17:55:23 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:23 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:23 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:23 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:23 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:23 lte,async,raw lte1: sent AT+CSQ
17:55:23 lte,async,raw lte1: rcvd +CSQ: 16,99
17:55:26 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:26 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-86,-6,-,-,-,-,-
17:55:26 lte,async,raw lte1: sent AT+QXPOWER
17:55:26 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:26 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:26 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:26 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:26 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:26 lte,async,raw lte1: sent AT+CSQ
17:55:26 lte,async,raw lte1: rcvd +CSQ: 18,99
17:55:29 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:29 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-8,-,-,-,-,-
17:55:29 lte,async,raw lte1: sent AT+QXPOWER
17:55:29 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:29 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:29 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:29 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:29 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:29 lte,async,raw lte1: sent AT+CSQ
17:55:29 lte,async,raw lte1: rcvd +CSQ: 17,99
17:55:32 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:32 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-86,-7,-,-,-,-,-
17:55:32 lte,async,raw lte1: sent AT+QXPOWER
17:55:32 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:32 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:32 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:32 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:32 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:32 lte,async,raw lte1: sent AT+CSQ
17:55:32 lte,async,raw lte1: rcvd +CSQ: 17,99
17:55:35 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:35 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-8,-,-,-,-,-
17:55:35 lte,async,raw lte1: sent AT+QXPOWER
17:55:35 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:35 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:35 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:35 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:35 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:35 lte,async,raw lte1: sent AT+CSQ
17:55:35 lte,async,raw lte1: rcvd +CSQ: 18,99
17:55:36 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:55:36 lte,packet,raw 07000080 40000000 00000000 01000000
17:55:36 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:55:36 lte,packet,raw c2aae6df 0b000000 14000000 0e000000
17:55:36 lte,packet,raw 63000000 05000000 02000000 ffffffff
17:55:38 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:38 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-6,-,-,-,-,-
17:55:38 lte,async,raw lte1: sent AT+QXPOWER
17:55:38 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:38 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:38 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:38 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:38 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:38 lte,async,raw lte1: sent AT+CSQ
17:55:38 lte,async,raw lte1: rcvd +CSQ: 14,99
17:55:41 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:41 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-10,-,-,-,-,-
17:55:41 lte,async,raw lte1: sent AT+QXPOWER
17:55:41 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:41 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:41 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:41 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:41 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:41 lte,async,raw lte1: sent AT+CSQ
17:55:41 lte,async,raw lte1: rcvd +CSQ: 14,99
17:55:44 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:44 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-9,-,-,-,-,-
17:55:44 lte,async,raw lte1: sent AT+QXPOWER
17:55:44 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:44 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:44 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:44 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:44 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:44 lte,async,raw lte1: sent AT+CSQ
17:55:44 lte,async,raw lte1: rcvd +CSQ: 16,99
17:55:45 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:55:45 lte,packet,raw 07000080 40000000 00000000 01000000
17:55:45 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:55:45 lte,packet,raw c2aae6df 0b000000 14000000 12000000
17:55:45 lte,packet,raw 63000000 05000000 02000000 ffffffff
17:55:47 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:47 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-7,-,-,-,-,-
17:55:47 lte,async,raw lte1: sent AT+QXPOWER
17:55:47 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:47 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:47 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:47 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:47 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:47 lte,async,raw lte1: sent AT+CSQ
17:55:47 lte,async,raw lte1: rcvd +CSQ: 18,99
17:55:50 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:50 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-4,-,-,-,-,-
17:55:50 lte,async,raw lte1: sent AT+QXPOWER
17:55:50 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:50 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:50 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:50 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:50 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:50 lte,async,raw lte1: sent AT+CSQ
17:55:50 lte,async,raw lte1: rcvd +CSQ: 17,99
17:55:51 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:55:51 lte,packet,raw 07000080 40000000 00000000 01000000
17:55:51 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:55:51 lte,packet,raw c2aae6df 0b000000 14000000 10000000
17:55:51 lte,packet,raw 63000000 05000000 02000000 ffffffff
17:55:53 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:53 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-5,-,-,-,-,-
17:55:53 lte,async,raw lte1: sent AT+QXPOWER
17:55:53 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:53 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:53 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:53 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:53 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:53 lte,async,raw lte1: sent AT+CSQ
17:55:53 lte,async,raw lte1: rcvd +CSQ: 16,99
17:55:56 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:56 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-4,-,-,-,-,-
17:55:56 lte,async,raw lte1: sent AT+QXPOWER
17:55:56 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:56 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:56 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:56 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:56 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:56 lte,async,raw lte1: sent AT+CSQ
17:55:56 lte,async,raw lte1: rcvd +CSQ: 16,99
17:55:59 lte,async,raw lte1: sent AT+QENG="servingcell"
17:55:59 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-6,-,-,-,-,-
17:55:59 lte,async,raw lte1: sent AT+QXPOWER
17:55:59 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:55:59 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:55:59 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:55:59 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:55:59 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:55:59 lte,async,raw lte1: sent AT+CSQ
17:55:59 lte,async,raw lte1: rcvd +CSQ: 16,99
17:56:02 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:02 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-10,-,-,-,-,-
17:56:02 lte,async,raw lte1: sent AT+QXPOWER
17:56:02 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:02 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:02 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:02 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:02 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:02 lte,async,raw lte1: sent AT+CSQ
17:56:02 lte,async,raw lte1: rcvd +CSQ: 16,99
17:56:05 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:05 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
17:56:05 lte,async,raw lte1: sent AT+QXPOWER
17:56:05 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:05 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:05 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:05 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:05 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:05 lte,async,raw lte1: sent AT+CSQ
17:56:05 lte,async,raw lte1: rcvd +CSQ: 16,99
17:56:08 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:08 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
17:56:08 lte,async,raw lte1: sent AT+QXPOWER
17:56:08 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:08 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:08 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:08 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:08 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:08 lte,async,raw lte1: sent AT+CSQ
17:56:08 lte,async,raw lte1: rcvd +CSQ: 16,99
17:56:11 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:11 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-10,-,-,-,-,-
17:56:11 lte,async,raw lte1: sent AT+QXPOWER
17:56:11 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:11 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:11 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:11 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:11 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:11 lte,async,raw lte1: sent AT+CSQ
17:56:11 lte,async,raw lte1: rcvd +CSQ: 16,99
17:56:14 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:14 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-10,-,-,-,-,-
17:56:14 lte,async,raw lte1: sent AT+QXPOWER
17:56:14 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:14 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:14 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:14 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:14 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:14 lte,async,raw lte1: sent AT+CSQ
17:56:14 lte,async,raw lte1: rcvd +CSQ: 17,99
17:56:17 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:17 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-10,-,-,-,-,-
17:56:17 lte,async,raw lte1: sent AT+QXPOWER
17:56:17 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:17 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:17 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:17 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:17 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:17 lte,async,raw lte1: sent AT+CSQ
17:56:17 lte,async,raw lte1: rcvd +CSQ: 17,99
17:56:20 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:20 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-10,-,-,-,-,-
17:56:20 lte,async,raw lte1: sent AT+QXPOWER
17:56:20 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:20 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:20 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:20 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:20 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:20 lte,async,raw lte1: sent AT+CSQ
17:56:20 lte,async,raw lte1: rcvd +CSQ: 16,99
17:56:23 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:23 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-9,-,-,-,-,-
17:56:23 lte,async,raw lte1: sent AT+QXPOWER
17:56:23 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:23 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:23 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:23 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:23 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:23 lte,async,raw lte1: sent AT+CSQ
17:56:23 lte,async,raw lte1: rcvd +CSQ: 16,99
17:56:26 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:26 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-85,-8,-,-,-,-,-
17:56:26 lte,async,raw lte1: sent AT+QXPOWER
17:56:26 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:26 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:26 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:26 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:26 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:26 lte,async,raw lte1: sent AT+CSQ
17:56:26 lte,async,raw lte1: rcvd +CSQ: 18,99
17:56:29 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:29 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-5,-,-,-,-,-
17:56:29 lte,async,raw lte1: sent AT+QXPOWER
17:56:29 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:29 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:29 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:29 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:29 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:29 lte,async,raw lte1: sent AT+CSQ
17:56:29 lte,async,raw lte1: rcvd +CSQ: 16,99
17:56:32 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:32 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
17:56:32 lte,async,raw lte1: sent AT+QXPOWER
17:56:32 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:32 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:32 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:32 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:32 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:32 lte,async,raw lte1: sent AT+CSQ
17:56:32 lte,async,raw lte1: rcvd +CSQ: 16,99
17:56:33 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:56:33 lte,packet,raw 07000080 40000000 00000000 01000000
17:56:33 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:56:33 lte,packet,raw c2aae6df 0b000000 14000000 12000000
17:56:33 lte,packet,raw 63000000 05000000 02000000 ffffffff
17:56:35 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:35 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-10,-,-,-,-,-
17:56:35 lte,async,raw lte1: sent AT+QXPOWER
17:56:35 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:35 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:35 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:35 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:35 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:35 lte,async,raw lte1: sent AT+CSQ
17:56:35 lte,async,raw lte1: rcvd +CSQ: 18,99
17:56:36 lte,packet,raw lte1 mbim: wdm >>> recv #0
17:56:36 lte,packet,raw 07000080 40000000 00000000 01000000
17:56:36 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
17:56:36 lte,packet,raw c2aae6df 0b000000 14000000 10000000
17:56:36 lte,packet,raw 63000000 05000000 02000000 ffffffff
17:56:38 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:38 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-11,-,-,-,-,-
17:56:38 lte,async,raw lte1: sent AT+QXPOWER
17:56:38 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:38 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:38 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:38 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:38 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:38 lte,async,raw lte1: sent AT+CSQ
17:56:38 lte,async,raw lte1: rcvd +CSQ: 16,99
17:56:41 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:41 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
17:56:41 lte,async,raw lte1: sent AT+QXPOWER
17:56:41 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:41 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:41 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:41 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:41 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:41 lte,async,raw lte1: sent AT+CSQ
17:56:41 lte,async,raw lte1: rcvd +CSQ: 16,99
17:56:44 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:44 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
17:56:44 lte,async,raw lte1: sent AT+QXPOWER
17:56:44 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:44 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:44 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:44 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:44 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:44 lte,async,raw lte1: sent AT+CSQ
17:56:44 lte,async,raw lte1: rcvd +CSQ: 16,99
17:56:47 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:47 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-7,-,-,-,-,-
17:56:47 lte,async,raw lte1: sent AT+QXPOWER
17:56:47 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:47 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:47 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:47 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:47 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:47 lte,async,raw lte1: sent AT+CSQ
17:56:47 lte,async,raw lte1: rcvd +CSQ: 16,99
17:56:50 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:50 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
17:56:50 lte,async,raw lte1: sent AT+QXPOWER
17:56:50 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:50 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:50 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:50 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:50 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:50 lte,async,raw lte1: sent AT+CSQ
17:56:50 lte,async,raw lte1: rcvd +CSQ: 16,99
17:56:53 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:53 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
17:56:53 lte,async,raw lte1: sent AT+QXPOWER
17:56:53 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:53 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:53 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:53 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:53 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:53 lte,async,raw lte1: sent AT+CSQ
17:56:53 lte,async,raw lte1: rcvd +CSQ: 16,99
17:56:56 lte,async,raw lte1: sent AT+QENG="servingcell"
17:56:56 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-5,-,-,-,-,-
17:56:56 lte,async,raw lte1: sent AT+QXPOWER
17:56:56 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:56:56 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:56:56 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:56:56 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:56:57 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:56:57 lte,async,raw lte1: sent AT+CSQ
17:56:57 lte,async,raw lte1: rcvd +CSQ: 16,99
17:57:00 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:00 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
17:57:00 lte,async,raw lte1: sent AT+QXPOWER
17:57:00 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:00 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:00 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:00 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:00 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:00 lte,async,raw lte1: sent AT+CSQ
17:57:00 lte,async,raw lte1: rcvd +CSQ: 16,99
17:57:03 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:03 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
17:57:03 lte,async,raw lte1: sent AT+QXPOWER
17:57:03 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:03 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:03 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:03 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:03 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:03 lte,async,raw lte1: sent AT+CSQ
17:57:03 lte,async,raw lte1: rcvd +CSQ: 16,99
17:57:06 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:06 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-6,-,-,-,-,-
17:57:06 lte,async,raw lte1: sent AT+QXPOWER
17:57:06 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:06 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:06 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:06 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:06 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:06 lte,async,raw lte1: sent AT+CSQ
17:57:06 lte,async,raw lte1: rcvd +CSQ: 16,99
17:57:09 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:09 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
17:57:09 lte,async,raw lte1: sent AT+QXPOWER
17:57:09 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:09 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:09 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:09 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:09 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:09 lte,async,raw lte1: sent AT+CSQ
17:57:09 lte,async,raw lte1: rcvd +CSQ: 16,99
17:57:12 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:12 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-5,-,-,-,-,-
17:57:12 lte,async,raw lte1: sent AT+QXPOWER
17:57:12 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:12 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:12 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:12 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:12 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:12 lte,async,raw lte1: sent AT+CSQ
17:57:12 lte,async,raw lte1: rcvd +CSQ: 16,99
17:57:15 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:15 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-77,-5,-,-,-,-,-
17:57:15 lte,async,raw lte1: sent AT+QXPOWER
17:57:15 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:15 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:15 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:15 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:15 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:15 lte,async,raw lte1: sent AT+CSQ
17:57:15 lte,async,raw lte1: rcvd +CSQ: 16,99
17:57:15 interface,info ether1 link down
17:57:18 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:18 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-8,-,-,-,-,-
17:57:18 lte,async,raw lte1: sent AT+QXPOWER
17:57:18 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:18 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:18 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:18 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:18 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:18 lte,async,raw lte1: sent AT+CSQ
17:57:18 lte,async,raw lte1: rcvd +CSQ: 16,99
17:57:21 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:21 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-6,-,-,-,-,-
17:57:21 lte,async,raw lte1: sent AT+QXPOWER
17:57:21 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:21 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:21 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:21 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:21 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:21 lte,async,raw lte1: sent AT+CSQ
17:57:21 lte,async,raw lte1: rcvd +CSQ: 16,99
17:57:24 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:24 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-5,-,-,-,-,-
17:57:24 lte,async,raw lte1: sent AT+QXPOWER
17:57:24 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:24 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:24 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:24 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:24 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:24 lte,async,raw lte1: sent AT+CSQ
17:57:24 lte,async,raw lte1: rcvd +CSQ: 17,99
17:57:27 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:27 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-7,-,-,-,-,-
17:57:27 lte,async,raw lte1: sent AT+QXPOWER
17:57:27 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:27 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:27 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:27 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:27 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:27 lte,async,raw lte1: sent AT+CSQ
17:57:27 lte,async,raw lte1: rcvd +CSQ: 17,99
17:57:30 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:30 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
17:57:30 lte,async,raw lte1: sent AT+QXPOWER
17:57:30 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:30 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:30 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:30 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:30 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:30 lte,async,raw lte1: sent AT+CSQ
17:57:30 lte,async,raw lte1: rcvd +CSQ: 17,99
17:57:33 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:33 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
17:57:33 lte,async,raw lte1: sent AT+QXPOWER
17:57:33 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:33 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:33 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:33 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:33 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:33 lte,async,raw lte1: sent AT+CSQ
17:57:33 lte,async,raw lte1: rcvd +CSQ: 16,99
17:57:35 system,info,account user admin logged in from 82.66.10.138 via winbox
17:57:36 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:36 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
17:57:36 lte,async,raw lte1: sent AT+QXPOWER
17:57:36 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:36 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:36 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:36 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:36 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:36 lte,async,raw lte1: sent AT+CSQ
17:57:36 lte,async,raw lte1: rcvd +CSQ: 16,99
17:57:36 system,info,account user admin logged in from 82.66.10.138 via local
17:57:39 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:39 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-7,-,-,-,-,-
17:57:39 lte,async,raw lte1: sent AT+QXPOWER
17:57:39 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:39 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:39 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:39 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:39 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:39 lte,async,raw lte1: sent AT+CSQ
17:57:39 lte,async,raw lte1: rcvd +CSQ: 17,99
17:57:42 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:42 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
17:57:42 lte,async,raw lte1: sent AT+QXPOWER
17:57:42 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:42 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:42 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:42 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:42 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:42 lte,async,raw lte1: sent AT+CSQ
17:57:42 lte,async,raw lte1: rcvd +CSQ: 17,99
17:57:45 system,info,account user admin logged out from 192.168.188.254 via winbox
17:57:45 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:45 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-6,-,-,-,-,-
17:57:45 lte,async,raw lte1: sent AT+QXPOWER
17:57:45 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:45 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:45 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:45 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:45 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:45 lte,async,raw lte1: sent AT+CSQ
17:57:45 lte,async,raw lte1: rcvd +CSQ: 17,99
17:57:48 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:48 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
17:57:48 lte,async,raw lte1: sent AT+QXPOWER
17:57:48 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:48 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:48 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:48 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:48 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:48 lte,async,raw lte1: sent AT+CSQ
17:57:48 lte,async,raw lte1: rcvd +CSQ: 17,99
17:57:51 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:51 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-6,-,-,-,-,-
17:57:51 lte,async,raw lte1: sent AT+QXPOWER
17:57:51 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:51 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:51 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:51 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:51 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:51 lte,async,raw lte1: sent AT+CSQ
17:57:51 lte,async,raw lte1: rcvd +CSQ: 17,99
17:57:54 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:54 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-6,-,-,-,-,-
17:57:54 lte,async,raw lte1: sent AT+QXPOWER
17:57:54 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:54 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:54 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:54 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:54 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:54 lte,async,raw lte1: sent AT+CSQ
17:57:54 lte,async,raw lte1: rcvd +CSQ: 17,99
17:57:57 lte,async,raw lte1: sent AT+QENG="servingcell"
17:57:57 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
17:57:57 lte,async,raw lte1: sent AT+QXPOWER
17:57:57 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:57:57 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:57:57 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:57:57 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:57:57 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:57:57 lte,async,raw lte1: sent AT+CSQ
17:57:57 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:00 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:00 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
17:58:00 lte,async,raw lte1: sent AT+QXPOWER
17:58:00 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:00 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:00 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:00 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:00 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:00 lte,async,raw lte1: sent AT+CSQ
17:58:00 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:03 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:03 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-8,-,-,-,-,-
17:58:03 lte,async,raw lte1: sent AT+QXPOWER
17:58:03 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:03 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:03 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:03 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:03 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:03 lte,async,raw lte1: sent AT+CSQ
17:58:03 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:06 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:06 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-8,-,-,-,-,-
17:58:06 lte,async,raw lte1: sent AT+QXPOWER
17:58:06 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:06 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:06 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:06 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:06 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:06 lte,async,raw lte1: sent AT+CSQ
17:58:06 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:09 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:09 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-6,-,-,-,-,-
17:58:09 lte,async,raw lte1: sent AT+QXPOWER
17:58:09 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:09 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:09 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:09 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:09 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:09 lte,async,raw lte1: sent AT+CSQ
17:58:09 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:12 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:12 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-7,-,-,-,-,-
17:58:12 lte,async,raw lte1: sent AT+QXPOWER
17:58:12 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:12 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:12 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:12 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:12 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:12 lte,async,raw lte1: sent AT+CSQ
17:58:12 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:15 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:15 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-7,-,-,-,-,-
17:58:15 lte,async,raw lte1: sent AT+QXPOWER
17:58:15 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:15 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:15 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:15 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:15 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:15 lte,async,raw lte1: sent AT+CSQ
17:58:15 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:18 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:18 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-7,-,-,-,-,-
17:58:18 lte,async,raw lte1: sent AT+QXPOWER
17:58:18 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:18 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:18 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:18 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:18 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:18 lte,async,raw lte1: sent AT+CSQ
17:58:18 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:21 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:21 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-7,-,-,-,-,-
17:58:21 lte,async,raw lte1: sent AT+QXPOWER
17:58:21 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:21 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:21 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:21 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:21 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:21 lte,async,raw lte1: sent AT+CSQ
17:58:21 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:24 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:24 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-6,-,-,-,-,-
17:58:24 lte,async,raw lte1: sent AT+QXPOWER
17:58:24 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:24 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:24 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:24 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:24 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:24 lte,async,raw lte1: sent AT+CSQ
17:58:24 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:27 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:27 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-6,-,-,-,-,-
17:58:27 lte,async,raw lte1: sent AT+QXPOWER
17:58:27 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:27 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:27 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:27 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:27 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:27 lte,async,raw lte1: sent AT+CSQ
17:58:27 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:30 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:30 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
17:58:30 lte,async,raw lte1: sent AT+QXPOWER
17:58:30 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:30 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:30 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:30 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:30 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:30 lte,async,raw lte1: sent AT+CSQ
17:58:30 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:33 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:33 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
17:58:33 lte,async,raw lte1: sent AT+QXPOWER
17:58:33 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:33 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:33 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:33 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:33 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:33 lte,async,raw lte1: sent AT+CSQ
17:58:33 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:36 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:36 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-5,-,-,-,-,-
17:58:36 lte,async,raw lte1: sent AT+QXPOWER
17:58:36 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:36 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:36 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:36 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:36 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:36 lte,async,raw lte1: sent AT+CSQ
17:58:36 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:39 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:39 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-10,-,-,-,-,-
17:58:39 lte,async,raw lte1: sent AT+QXPOWER
17:58:39 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:39 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:39 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:39 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:39 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:39 lte,async,raw lte1: sent AT+CSQ
17:58:39 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:42 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:42 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
17:58:42 lte,async,raw lte1: sent AT+QXPOWER
17:58:42 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:42 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:42 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:42 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:42 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:42 lte,async,raw lte1: sent AT+CSQ
17:58:42 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:45 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:45 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
17:58:45 lte,async,raw lte1: sent AT+QXPOWER
17:58:45 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:45 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:45 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:45 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:45 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:45 lte,async,raw lte1: sent AT+CSQ
17:58:45 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:48 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:48 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
17:58:48 lte,async,raw lte1: sent AT+QXPOWER
17:58:48 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:48 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:48 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:48 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:48 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:48 lte,async,raw lte1: sent AT+CSQ
17:58:48 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:51 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:51 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
17:58:51 lte,async,raw lte1: sent AT+QXPOWER
17:58:51 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:51 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:51 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:51 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:51 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:51 lte,async,raw lte1: sent AT+CSQ
17:58:51 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:54 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:54 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-10,-,-,-,-,-
17:58:54 lte,async,raw lte1: sent AT+QXPOWER
17:58:54 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:54 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:54 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:54 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:54 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:54 lte,async,raw lte1: sent AT+CSQ
17:58:54 lte,async,raw lte1: rcvd +CSQ: 17,99
17:58:57 lte,async,raw lte1: sent AT+QENG="servingcell"
17:58:57 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-5,-,-,-,-,-
17:58:57 lte,async,raw lte1: sent AT+QXPOWER
17:58:57 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:58:57 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:58:57 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:58:57 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:58:57 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:58:57 lte,async,raw lte1: sent AT+CSQ
17:58:57 lte,async,raw lte1: rcvd +CSQ: 17,99
17:59:00 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:00 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
17:59:00 lte,async,raw lte1: sent AT+QXPOWER
17:59:00 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:00 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:00 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:00 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:00 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:00 lte,async,raw lte1: sent AT+CSQ
17:59:00 lte,async,raw lte1: rcvd +CSQ: 17,99
17:59:03 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:03 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
17:59:03 lte,async,raw lte1: sent AT+QXPOWER
17:59:03 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:03 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:03 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:03 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:03 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:03 lte,async,raw lte1: sent AT+CSQ
17:59:03 lte,async,raw lte1: rcvd +CSQ: 17,99
17:59:06 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:06 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
17:59:06 lte,async,raw lte1: sent AT+QXPOWER
17:59:06 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:06 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:06 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:06 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:06 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:06 lte,async,raw lte1: sent AT+CSQ
17:59:06 lte,async,raw lte1: rcvd +CSQ: 17,99
17:59:09 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:09 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
17:59:09 lte,async,raw lte1: sent AT+QXPOWER
17:59:09 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:09 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:09 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:09 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:09 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:09 lte,async,raw lte1: sent AT+CSQ
17:59:09 lte,async,raw lte1: rcvd +CSQ: 17,99
17:59:12 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:12 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
17:59:12 lte,async,raw lte1: sent AT+QXPOWER
17:59:12 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:12 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:12 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:12 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:12 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:12 lte,async,raw lte1: sent AT+CSQ
17:59:12 lte,async,raw lte1: rcvd +CSQ: 17,99
17:59:15 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:15 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
17:59:15 lte,async,raw lte1: sent AT+QXPOWER
17:59:15 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:15 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:15 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:15 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:15 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:15 lte,async,raw lte1: sent AT+CSQ
17:59:15 lte,async,raw lte1: rcvd +CSQ: 17,99
17:59:18 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:18 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
17:59:18 lte,async,raw lte1: sent AT+QXPOWER
17:59:18 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:18 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:18 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:18 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:18 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:18 lte,async,raw lte1: sent AT+CSQ
17:59:18 lte,async,raw lte1: rcvd +CSQ: 17,99
17:59:21 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:21 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
17:59:21 lte,async,raw lte1: sent AT+QXPOWER
17:59:21 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:21 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:21 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:21 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:21 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:21 lte,async,raw lte1: sent AT+CSQ
17:59:21 lte,async,raw lte1: rcvd +CSQ: 17,99
17:59:24 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:24 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-78,-5,-,-,-,-,-
17:59:24 lte,async,raw lte1: sent AT+QXPOWER
17:59:24 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:24 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:24 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:24 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:24 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:24 lte,async,raw lte1: sent AT+CSQ
17:59:24 lte,async,raw lte1: rcvd +CSQ: 17,99
17:59:27 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:27 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
17:59:27 lte,async,raw lte1: sent AT+QXPOWER
17:59:27 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:27 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:27 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:27 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:27 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:27 lte,async,raw lte1: sent AT+CSQ
17:59:27 lte,async,raw lte1: rcvd +CSQ: 17,99
17:59:30 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:30 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
17:59:30 lte,async,raw lte1: sent AT+QXPOWER
17:59:30 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:30 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:30 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:30 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:30 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:30 lte,async,raw lte1: sent AT+CSQ
17:59:30 lte,async,raw lte1: rcvd +CSQ: 17,99
17:59:33 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:33 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-7,-,-,-,-,-
17:59:33 lte,async,raw lte1: sent AT+QXPOWER
17:59:33 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:33 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:33 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:33 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:33 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:33 lte,async,raw lte1: sent AT+CSQ
17:59:33 lte,async,raw lte1: rcvd +CSQ: 16,99
17:59:36 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:36 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-7,-,-,-,-,-
17:59:36 lte,async,raw lte1: sent AT+QXPOWER
17:59:36 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:36 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:36 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:36 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:36 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:36 lte,async,raw lte1: sent AT+CSQ
17:59:36 lte,async,raw lte1: rcvd +CSQ: 16,99
17:59:39 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:39 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
17:59:39 lte,async,raw lte1: sent AT+QXPOWER
17:59:39 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:39 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:39 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:39 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:39 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:39 lte,async,raw lte1: sent AT+CSQ
17:59:39 lte,async,raw lte1: rcvd +CSQ: 16,99
17:59:42 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:42 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
17:59:42 lte,async,raw lte1: sent AT+QXPOWER
17:59:42 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:42 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:42 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:42 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:42 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:42 lte,async,raw lte1: sent AT+CSQ
17:59:42 lte,async,raw lte1: rcvd +CSQ: 16,99
17:59:45 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:45 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
17:59:45 lte,async,raw lte1: sent AT+QXPOWER
17:59:45 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:45 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:45 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:45 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:45 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:45 lte,async,raw lte1: sent AT+CSQ
17:59:45 lte,async,raw lte1: rcvd +CSQ: 16,99
17:59:48 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:48 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-8,-,-,-,-,-
17:59:48 lte,async,raw lte1: sent AT+QXPOWER
17:59:48 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:48 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:48 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:48 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:48 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:48 lte,async,raw lte1: sent AT+CSQ
17:59:48 lte,async,raw lte1: rcvd +CSQ: 15,99
17:59:51 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:51 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-7,-,-,-,-,-
17:59:51 lte,async,raw lte1: sent AT+QXPOWER
17:59:51 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:51 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:51 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:51 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:51 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:51 lte,async,raw lte1: sent AT+CSQ
17:59:51 lte,async,raw lte1: rcvd +CSQ: 15,99
17:59:54 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:54 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
17:59:54 lte,async,raw lte1: sent AT+QXPOWER
17:59:54 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:54 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:54 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:54 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:54 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:54 lte,async,raw lte1: sent AT+CSQ
17:59:54 lte,async,raw lte1: rcvd +CSQ: 16,99
17:59:57 lte,async,raw lte1: sent AT+QENG="servingcell"
17:59:57 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
17:59:57 lte,async,raw lte1: sent AT+QXPOWER
17:59:57 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
17:59:57 lte,async,raw lte1: sent AT+QNETINFO="cmr"
17:59:57 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
17:59:57 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
17:59:57 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
17:59:57 lte,async,raw lte1: sent AT+CSQ
17:59:57 lte,async,raw lte1: rcvd +CSQ: 17,99
18:00:00 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:00 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
18:00:00 lte,async,raw lte1: sent AT+QXPOWER
18:00:00 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:00 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:00 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:00 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:00 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:00 lte,async,raw lte1: sent AT+CSQ
18:00:00 lte,async,raw lte1: rcvd +CSQ: 17,99
18:00:03 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:03 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
18:00:03 lte,async,raw lte1: sent AT+QXPOWER
18:00:03 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:03 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:03 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:03 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:03 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:03 lte,async,raw lte1: sent AT+CSQ
18:00:03 lte,async,raw lte1: rcvd +CSQ: 17,99
18:00:06 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:06 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
18:00:06 lte,async,raw lte1: sent AT+QXPOWER
18:00:06 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:06 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:06 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:06 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:06 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:06 lte,async,raw lte1: sent AT+CSQ
18:00:06 lte,async,raw lte1: rcvd +CSQ: 17,99
18:00:09 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:09 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:00:09 lte,async,raw lte1: sent AT+QXPOWER
18:00:09 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:09 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:09 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:09 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:09 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:09 lte,async,raw lte1: sent AT+CSQ
18:00:09 lte,async,raw lte1: rcvd +CSQ: 17,99
18:00:12 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:12 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
18:00:12 lte,async,raw lte1: sent AT+QXPOWER
18:00:12 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:12 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:12 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:12 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:12 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:12 lte,async,raw lte1: sent AT+CSQ
18:00:12 lte,async,raw lte1: rcvd +CSQ: 16,99
18:00:15 lte,packet,raw lte1 mbim: wdm >>> recv #0
18:00:15 lte,packet,raw 07000080 40000000 00000000 01000000
18:00:15 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
18:00:15 lte,packet,raw c2aae6df 0b000000 14000000 12000000
18:00:15 lte,packet,raw 63000000 05000000 02000000 ffffffff
18:00:15 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:15 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-9,-,-,-,-,-
18:00:15 lte,async,raw lte1: sent AT+QXPOWER
18:00:15 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:15 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:15 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:15 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:15 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:15 lte,async,raw lte1: sent AT+CSQ
18:00:15 lte,async,raw lte1: rcvd +CSQ: 18,99
18:00:18 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:18 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-9,-,-,-,-,-
18:00:18 lte,async,raw lte1: sent AT+QXPOWER
18:00:18 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:18 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:18 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:18 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:18 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:18 lte,async,raw lte1: sent AT+CSQ
18:00:18 lte,async,raw lte1: rcvd +CSQ: 17,99
18:00:20 lte,packet,raw lte1 mbim: wdm >>> recv #0
18:00:20 lte,packet,raw 07000080 40000000 00000000 01000000
18:00:20 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
18:00:20 lte,packet,raw c2aae6df 0b000000 14000000 10000000
18:00:20 lte,packet,raw 63000000 05000000 02000000 ffffffff
18:00:21 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:21 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-7,-,-,-,-,-
18:00:21 lte,async,raw lte1: sent AT+QXPOWER
18:00:21 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:21 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:21 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:21 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:21 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:21 lte,async,raw lte1: sent AT+CSQ
18:00:21 lte,async,raw lte1: rcvd +CSQ: 16,99
18:00:24 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:24 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:00:24 lte,async,raw lte1: sent AT+QXPOWER
18:00:24 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:24 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:24 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:24 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:25 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:25 lte,async,raw lte1: sent AT+CSQ
18:00:25 lte,async,raw lte1: rcvd +CSQ: 16,99
18:00:28 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:28 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
18:00:28 lte,async,raw lte1: sent AT+QXPOWER
18:00:28 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:28 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:28 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:28 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:28 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:28 lte,async,raw lte1: sent AT+CSQ
18:00:28 lte,async,raw lte1: rcvd +CSQ: 16,99
18:00:31 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:31 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
18:00:31 lte,async,raw lte1: sent AT+QXPOWER
18:00:31 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:31 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:31 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:31 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:31 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:31 lte,async,raw lte1: sent AT+CSQ
18:00:31 lte,async,raw lte1: rcvd +CSQ: 16,99
18:00:34 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:34 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-7,-,-,-,-,-
18:00:34 lte,async,raw lte1: sent AT+QXPOWER
18:00:34 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:34 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:34 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:34 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:34 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:34 lte,async,raw lte1: sent AT+CSQ
18:00:34 lte,async,raw lte1: rcvd +CSQ: 16,99
18:00:37 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:37 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-8,-,-,-,-,-
18:00:37 lte,async,raw lte1: sent AT+QXPOWER
18:00:37 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:37 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:37 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:37 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:37 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:37 lte,async,raw lte1: sent AT+CSQ
18:00:37 lte,async,raw lte1: rcvd +CSQ: 16,99
18:00:40 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:40 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-7,-,-,-,-,-
18:00:40 lte,async,raw lte1: sent AT+QXPOWER
18:00:40 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:40 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:40 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:40 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:40 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:40 lte,async,raw lte1: sent AT+CSQ
18:00:40 lte,async,raw lte1: rcvd +CSQ: 16,99
18:00:43 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:43 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
18:00:43 lte,async,raw lte1: sent AT+QXPOWER
18:00:43 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:43 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:43 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:43 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:43 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:43 lte,async,raw lte1: sent AT+CSQ
18:00:43 lte,async,raw lte1: rcvd +CSQ: 16,99
18:00:46 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:46 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:00:46 lte,async,raw lte1: sent AT+QXPOWER
18:00:46 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:46 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:46 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:46 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:46 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:46 lte,async,raw lte1: sent AT+CSQ
18:00:46 lte,async,raw lte1: rcvd +CSQ: 16,99
18:00:49 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:49 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-11,-,-,-,-,-
18:00:49 lte,async,raw lte1: sent AT+QXPOWER
18:00:49 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:49 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:49 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:49 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:49 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:49 lte,async,raw lte1: sent AT+CSQ
18:00:49 lte,async,raw lte1: rcvd +CSQ: 16,99
18:00:52 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:52 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-11,-,-,-,-,-
18:00:52 lte,async,raw lte1: sent AT+QXPOWER
18:00:52 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:52 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:52 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:52 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:52 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:52 lte,async,raw lte1: sent AT+CSQ
18:00:52 lte,async,raw lte1: rcvd +CSQ: 16,99
18:00:55 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:55 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-11,-,-,-,-,-
18:00:55 lte,async,raw lte1: sent AT+QXPOWER
18:00:55 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:55 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:55 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:55 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:55 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:55 lte,async,raw lte1: sent AT+CSQ
18:00:55 lte,async,raw lte1: rcvd +CSQ: 16,99
18:00:58 lte,async,raw lte1: sent AT+QENG="servingcell"
18:00:58 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-11,-,-,-,-,-
18:00:58 lte,async,raw lte1: sent AT+QXPOWER
18:00:58 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:00:58 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:00:58 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:00:58 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:00:58 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:00:58 lte,async,raw lte1: sent AT+CSQ
18:00:58 lte,async,raw lte1: rcvd +CSQ: 16,99
18:01:01 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:01 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-11,-,-,-,-,-
18:01:01 lte,async,raw lte1: sent AT+QXPOWER
18:01:01 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:01 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:01 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:01 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:01 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:01 lte,async,raw lte1: sent AT+CSQ
18:01:01 lte,async,raw lte1: rcvd +CSQ: 16,99
18:01:04 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:04 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-11,-,-,-,-,-
18:01:04 lte,async,raw lte1: sent AT+QXPOWER
18:01:04 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:04 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:04 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:04 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:04 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:04 lte,async,raw lte1: sent AT+CSQ
18:01:04 lte,async,raw lte1: rcvd +CSQ: 16,99
18:01:07 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:07 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-11,-,-,-,-,-
18:01:07 lte,async,raw lte1: sent AT+QXPOWER
18:01:07 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:07 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:07 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:07 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:07 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:07 lte,async,raw lte1: sent AT+CSQ
18:01:07 lte,async,raw lte1: rcvd +CSQ: 16,99
18:01:10 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:10 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-11,-,-,-,-,-
18:01:10 lte,async,raw lte1: sent AT+QXPOWER
18:01:10 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:10 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:10 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:10 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:10 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:10 lte,async,raw lte1: sent AT+CSQ
18:01:10 lte,async,raw lte1: rcvd +CSQ: 16,99
18:01:13 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:13 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-11,-,-,-,-,-
18:01:13 lte,async,raw lte1: sent AT+QXPOWER
18:01:13 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:13 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:13 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:13 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:13 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:13 lte,async,raw lte1: sent AT+CSQ
18:01:13 lte,async,raw lte1: rcvd +CSQ: 16,99
18:01:16 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:16 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-11,-,-,-,-,-
18:01:16 lte,async,raw lte1: sent AT+QXPOWER
18:01:16 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:16 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:16 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:16 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:16 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:16 lte,async,raw lte1: sent AT+CSQ
18:01:16 lte,async,raw lte1: rcvd +CSQ: 16,99
18:01:19 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:19 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-11,-,-,-,-,-
18:01:19 lte,async,raw lte1: sent AT+QXPOWER
18:01:19 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:19 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:19 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:19 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:19 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:19 lte,async,raw lte1: sent AT+CSQ
18:01:19 lte,async,raw lte1: rcvd +CSQ: 16,99
18:01:22 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:22 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-11,-,-,-,-,-
18:01:22 lte,async,raw lte1: sent AT+QXPOWER
18:01:22 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:22 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:22 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:22 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:22 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:22 lte,async,raw lte1: sent AT+CSQ
18:01:22 lte,async,raw lte1: rcvd +CSQ: 16,99
18:01:25 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:25 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-11,-,-,-,-,-
18:01:25 lte,async,raw lte1: sent AT+QXPOWER
18:01:25 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:25 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:25 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:25 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:25 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:25 lte,async,raw lte1: sent AT+CSQ
18:01:25 lte,async,raw lte1: rcvd +CSQ: 16,99
18:01:28 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:28 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-11,-,-,-,-,-
18:01:28 lte,async,raw lte1: sent AT+QXPOWER
18:01:28 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:28 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:28 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:28 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:28 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:28 lte,async,raw lte1: sent AT+CSQ
18:01:28 lte,async,raw lte1: rcvd +CSQ: 16,99
18:01:31 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:31 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-11,-,-,-,-,-
18:01:31 lte,async,raw lte1: sent AT+QXPOWER
18:01:31 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:31 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:31 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:31 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:31 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:31 lte,async,raw lte1: sent AT+CSQ
18:01:31 lte,async,raw lte1: rcvd +CSQ: 15,99
18:01:34 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:34 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-10,-,-,-,-,-
18:01:34 lte,async,raw lte1: sent AT+QXPOWER
18:01:34 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:34 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:34 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:34 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:34 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:34 lte,async,raw lte1: sent AT+CSQ
18:01:34 lte,async,raw lte1: rcvd +CSQ: 15,99
18:01:37 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:37 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-10,-,-,-,-,-
18:01:37 lte,async,raw lte1: sent AT+QXPOWER
18:01:37 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:37 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:37 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:37 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:37 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:37 lte,async,raw lte1: sent AT+CSQ
18:01:37 lte,async,raw lte1: rcvd +CSQ: 15,99
18:01:40 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:40 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-11,-,-,-,-,-
18:01:40 lte,async,raw lte1: sent AT+QXPOWER
18:01:40 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:40 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:40 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:40 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:40 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:40 lte,async,raw lte1: sent AT+CSQ
18:01:40 lte,async,raw lte1: rcvd +CSQ: 16,99
18:01:43 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:43 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-11,-,-,-,-,-
18:01:43 lte,async,raw lte1: sent AT+QXPOWER
18:01:43 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:43 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:43 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:43 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:43 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:43 lte,async,raw lte1: sent AT+CSQ
18:01:43 lte,async,raw lte1: rcvd +CSQ: 17,99
18:01:46 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:46 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-11,-,-,-,-,-
18:01:46 lte,async,raw lte1: sent AT+QXPOWER
18:01:46 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:46 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:46 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:46 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:46 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:46 lte,async,raw lte1: sent AT+CSQ
18:01:46 lte,async,raw lte1: rcvd +CSQ: 17,99
18:01:49 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:49 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-10,-,-,-,-,-
18:01:49 lte,async,raw lte1: sent AT+QXPOWER
18:01:49 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:49 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:49 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:49 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:49 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:49 lte,async,raw lte1: sent AT+CSQ
18:01:49 lte,async,raw lte1: rcvd +CSQ: 17,99
18:01:52 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:52 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-8,-,-,-,-,-
18:01:52 lte,async,raw lte1: sent AT+QXPOWER
18:01:52 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:52 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:52 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:52 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:52 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:52 lte,async,raw lte1: sent AT+CSQ
18:01:52 lte,async,raw lte1: rcvd +CSQ: 17,99
18:01:55 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:55 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-11,-,-,-,-,-
18:01:55 lte,async,raw lte1: sent AT+QXPOWER
18:01:55 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:55 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:55 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:55 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:55 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:55 lte,async,raw lte1: sent AT+CSQ
18:01:55 lte,async,raw lte1: rcvd +CSQ: 17,99
18:01:58 lte,async,raw lte1: sent AT+QENG="servingcell"
18:01:58 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-11,-,-,-,-,-
18:01:58 lte,async,raw lte1: sent AT+QXPOWER
18:01:58 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:01:58 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:01:58 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:01:58 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:01:58 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:01:58 lte,async,raw lte1: sent AT+CSQ
18:01:58 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:01 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:01 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-11,-,-,-,-,-
18:02:01 lte,async,raw lte1: sent AT+QXPOWER
18:02:01 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:01 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:01 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:01 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:01 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:01 lte,async,raw lte1: sent AT+CSQ
18:02:01 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:04 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:04 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-10,-,-,-,-,-
18:02:04 lte,async,raw lte1: sent AT+QXPOWER
18:02:04 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:04 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:04 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:04 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:04 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:04 lte,async,raw lte1: sent AT+CSQ
18:02:04 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:07 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:07 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-11,-,-,-,-,-
18:02:07 lte,async,raw lte1: sent AT+QXPOWER
18:02:07 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:07 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:07 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:07 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:07 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:07 lte,async,raw lte1: sent AT+CSQ
18:02:07 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:10 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:10 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-11,-,-,-,-,-
18:02:10 lte,async,raw lte1: sent AT+QXPOWER
18:02:10 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:10 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:10 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:10 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:10 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:10 lte,async,raw lte1: sent AT+CSQ
18:02:10 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:13 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:13 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-11,-,-,-,-,-
18:02:13 lte,async,raw lte1: sent AT+QXPOWER
18:02:13 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:13 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:13 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:13 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:13 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:13 lte,async,raw lte1: sent AT+CSQ
18:02:13 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:16 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:16 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-11,-,-,-,-,-
18:02:16 lte,async,raw lte1: sent AT+QXPOWER
18:02:16 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:16 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:16 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:16 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:16 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:16 lte,async,raw lte1: sent AT+CSQ
18:02:16 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:19 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:19 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-11,-,-,-,-,-
18:02:19 lte,async,raw lte1: sent AT+QXPOWER
18:02:19 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:19 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:19 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:19 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:19 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:19 lte,async,raw lte1: sent AT+CSQ
18:02:19 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:22 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:22 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-11,-,-,-,-,-
18:02:22 lte,async,raw lte1: sent AT+QXPOWER
18:02:22 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:22 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:22 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:22 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:22 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:22 lte,async,raw lte1: sent AT+CSQ
18:02:22 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:25 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:25 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-11,-,-,-,-,-
18:02:25 lte,async,raw lte1: sent AT+QXPOWER
18:02:25 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:25 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:25 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:25 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:25 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:25 lte,async,raw lte1: sent AT+CSQ
18:02:25 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:28 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:28 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-11,-,-,-,-,-
18:02:28 lte,async,raw lte1: sent AT+QXPOWER
18:02:28 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:28 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:28 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:28 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:28 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:28 lte,async,raw lte1: sent AT+CSQ
18:02:28 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:31 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:31 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-11,-,-,-,-,-
18:02:31 lte,async,raw lte1: sent AT+QXPOWER
18:02:31 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:31 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:31 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:31 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:31 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:31 lte,async,raw lte1: sent AT+CSQ
18:02:31 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:34 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:34 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-84,-8,-,-,-,-,-
18:02:34 lte,async,raw lte1: sent AT+QXPOWER
18:02:34 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:34 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:34 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:34 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:34 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:34 lte,async,raw lte1: sent AT+CSQ
18:02:34 lte,async,raw lte1: rcvd +CSQ: 15,99
18:02:37 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:37 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
18:02:37 lte,async,raw lte1: sent AT+QXPOWER
18:02:37 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:37 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:37 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:37 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:37 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:37 lte,async,raw lte1: sent AT+CSQ
18:02:37 lte,async,raw lte1: rcvd +CSQ: 15,99
18:02:40 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:40 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
18:02:40 lte,async,raw lte1: sent AT+QXPOWER
18:02:40 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:40 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:40 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:40 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:40 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:40 lte,async,raw lte1: sent AT+CSQ
18:02:40 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:43 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:43 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-77,-6,-,-,-,-,-
18:02:43 lte,async,raw lte1: sent AT+QXPOWER
18:02:43 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:43 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:43 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:43 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:43 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:43 lte,async,raw lte1: sent AT+CSQ
18:02:43 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:46 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:46 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
18:02:46 lte,async,raw lte1: sent AT+QXPOWER
18:02:46 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:46 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:46 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:46 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:46 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:46 lte,async,raw lte1: sent AT+CSQ
18:02:46 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:49 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:49 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:02:49 lte,async,raw lte1: sent AT+QXPOWER
18:02:49 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:49 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:49 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:49 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:49 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:49 lte,async,raw lte1: sent AT+CSQ
18:02:49 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:52 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:52 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:02:52 lte,async,raw lte1: sent AT+QXPOWER
18:02:52 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:52 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:52 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:52 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:52 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:52 lte,async,raw lte1: sent AT+CSQ
18:02:52 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:55 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:55 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
18:02:55 lte,async,raw lte1: sent AT+QXPOWER
18:02:55 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:55 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:55 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:55 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:55 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:55 lte,async,raw lte1: sent AT+CSQ
18:02:55 lte,async,raw lte1: rcvd +CSQ: 17,99
18:02:58 lte,async,raw lte1: sent AT+QENG="servingcell"
18:02:58 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
18:02:58 lte,async,raw lte1: sent AT+QXPOWER
18:02:58 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:02:58 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:02:58 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:02:58 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:02:58 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:02:58 lte,async,raw lte1: sent AT+CSQ
18:02:58 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:01 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:01 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
18:03:01 lte,async,raw lte1: sent AT+QXPOWER
18:03:01 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:01 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:01 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:01 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:01 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:01 lte,async,raw lte1: sent AT+CSQ
18:03:01 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:04 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:04 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
18:03:04 lte,async,raw lte1: sent AT+QXPOWER
18:03:04 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:04 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:04 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:04 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:04 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:04 lte,async,raw lte1: sent AT+CSQ
18:03:04 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:07 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:07 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-7,-,-,-,-,-
18:03:07 lte,async,raw lte1: sent AT+QXPOWER
18:03:07 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:07 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:07 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:07 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:07 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:07 lte,async,raw lte1: sent AT+CSQ
18:03:07 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:10 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:10 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:03:10 lte,async,raw lte1: sent AT+QXPOWER
18:03:10 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:10 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:10 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:10 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:10 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:10 lte,async,raw lte1: sent AT+CSQ
18:03:10 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:13 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:13 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-6,-,-,-,-,-
18:03:13 lte,async,raw lte1: sent AT+QXPOWER
18:03:13 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:13 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:13 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:13 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:13 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:13 lte,async,raw lte1: sent AT+CSQ
18:03:13 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:16 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:16 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-5,-,-,-,-,-
18:03:16 lte,async,raw lte1: sent AT+QXPOWER
18:03:16 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:16 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:16 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:16 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:16 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:16 lte,async,raw lte1: sent AT+CSQ
18:03:16 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:19 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:19 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
18:03:19 lte,async,raw lte1: sent AT+QXPOWER
18:03:19 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:19 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:19 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:19 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:19 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:19 lte,async,raw lte1: sent AT+CSQ
18:03:19 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:22 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:22 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
18:03:22 lte,async,raw lte1: sent AT+QXPOWER
18:03:22 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:22 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:22 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:22 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:22 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:22 lte,async,raw lte1: sent AT+CSQ
18:03:22 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:25 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:25 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:03:25 lte,async,raw lte1: sent AT+QXPOWER
18:03:25 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:25 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:25 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:25 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:25 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:25 lte,async,raw lte1: sent AT+CSQ
18:03:25 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:28 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:28 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
18:03:28 lte,async,raw lte1: sent AT+QXPOWER
18:03:28 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:28 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:28 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:28 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:28 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:28 lte,async,raw lte1: sent AT+CSQ
18:03:28 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:31 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:31 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
18:03:31 lte,async,raw lte1: sent AT+QXPOWER
18:03:31 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:31 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:31 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:31 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:31 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:31 lte,async,raw lte1: sent AT+CSQ
18:03:31 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:34 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:34 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
18:03:34 lte,async,raw lte1: sent AT+QXPOWER
18:03:34 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:34 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:34 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:34 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:34 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:34 lte,async,raw lte1: sent AT+CSQ
18:03:34 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:37 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:37 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
18:03:37 lte,async,raw lte1: sent AT+QXPOWER
18:03:37 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:37 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:37 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:37 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:37 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:37 lte,async,raw lte1: sent AT+CSQ
18:03:37 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:40 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:40 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
18:03:40 lte,async,raw lte1: sent AT+QXPOWER
18:03:40 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:40 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:40 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:40 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:40 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:40 lte,async,raw lte1: sent AT+CSQ
18:03:40 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:43 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:43 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:03:43 lte,async,raw lte1: sent AT+QXPOWER
18:03:43 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:43 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:43 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:43 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:43 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:43 lte,async,raw lte1: sent AT+CSQ
18:03:43 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:46 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:46 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
18:03:46 lte,async,raw lte1: sent AT+QXPOWER
18:03:46 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:46 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:46 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:46 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:46 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:46 lte,async,raw lte1: sent AT+CSQ
18:03:46 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:49 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:49 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
18:03:49 lte,async,raw lte1: sent AT+QXPOWER
18:03:49 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:49 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:49 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:49 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:49 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:49 lte,async,raw lte1: sent AT+CSQ
18:03:49 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:52 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:52 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:03:52 lte,async,raw lte1: sent AT+QXPOWER
18:03:52 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:52 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:52 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:52 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:52 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:52 lte,async,raw lte1: sent AT+CSQ
18:03:52 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:55 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:55 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
18:03:55 lte,async,raw lte1: sent AT+QXPOWER
18:03:55 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:55 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:55 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:55 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:55 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:55 lte,async,raw lte1: sent AT+CSQ
18:03:55 lte,async,raw lte1: rcvd +CSQ: 17,99
18:03:58 lte,async,raw lte1: sent AT+QENG="servingcell"
18:03:58 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-7,-,-,-,-,-
18:03:58 lte,async,raw lte1: sent AT+QXPOWER
18:03:58 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:03:58 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:03:58 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:03:58 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:03:58 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:03:58 lte,async,raw lte1: sent AT+CSQ
18:03:58 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:01 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:01 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-7,-,-,-,-,-
18:04:01 lte,async,raw lte1: sent AT+QXPOWER
18:04:01 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:01 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:01 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:01 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:01 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:01 lte,async,raw lte1: sent AT+CSQ
18:04:01 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:04 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:04 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-7,-,-,-,-,-
18:04:04 lte,async,raw lte1: sent AT+QXPOWER
18:04:04 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:04 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:04 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:04 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:04 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:04 lte,async,raw lte1: sent AT+CSQ
18:04:04 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:07 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:07 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
18:04:07 lte,async,raw lte1: sent AT+QXPOWER
18:04:07 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:07 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:07 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:07 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:07 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:07 lte,async,raw lte1: sent AT+CSQ
18:04:07 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:10 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:10 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
18:04:10 lte,async,raw lte1: sent AT+QXPOWER
18:04:10 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:10 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:10 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:10 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:10 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:10 lte,async,raw lte1: sent AT+CSQ
18:04:10 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:13 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:13 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
18:04:13 lte,async,raw lte1: sent AT+QXPOWER
18:04:13 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:13 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:13 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:13 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:13 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:13 lte,async,raw lte1: sent AT+CSQ
18:04:13 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:16 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:16 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
18:04:16 lte,async,raw lte1: sent AT+QXPOWER
18:04:16 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:16 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:16 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:16 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:16 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:16 lte,async,raw lte1: sent AT+CSQ
18:04:16 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:19 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:19 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-5,-,-,-,-,-
18:04:19 lte,async,raw lte1: sent AT+QXPOWER
18:04:19 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:19 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:19 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:19 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:19 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:19 lte,async,raw lte1: sent AT+CSQ
18:04:19 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:22 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:22 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
18:04:22 lte,async,raw lte1: sent AT+QXPOWER
18:04:22 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:22 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:22 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:22 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:22 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:22 lte,async,raw lte1: sent AT+CSQ
18:04:22 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:25 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:25 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
18:04:25 lte,async,raw lte1: sent AT+QXPOWER
18:04:25 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:25 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:25 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:25 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:25 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:25 lte,async,raw lte1: sent AT+CSQ
18:04:25 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:28 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:28 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
18:04:28 lte,async,raw lte1: sent AT+QXPOWER
18:04:28 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:28 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:28 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:28 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:28 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:28 lte,async,raw lte1: sent AT+CSQ
18:04:28 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:31 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:31 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-8,-,-,-,-,-
18:04:31 lte,async,raw lte1: sent AT+QXPOWER
18:04:31 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:31 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:31 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:31 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:31 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:31 lte,async,raw lte1: sent AT+CSQ
18:04:31 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:34 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:34 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-8,-,-,-,-,-
18:04:34 lte,async,raw lte1: sent AT+QXPOWER
18:04:34 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:34 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:34 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:34 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:34 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:34 lte,async,raw lte1: sent AT+CSQ
18:04:34 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:37 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:37 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-7,-,-,-,-,-
18:04:37 lte,async,raw lte1: sent AT+QXPOWER
18:04:37 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:37 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:37 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:37 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:37 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:37 lte,async,raw lte1: sent AT+CSQ
18:04:37 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:40 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:40 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
18:04:40 lte,async,raw lte1: sent AT+QXPOWER
18:04:40 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:40 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:40 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:40 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:40 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:40 lte,async,raw lte1: sent AT+CSQ
18:04:40 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:41 dhcp,info defconf deassigned 192.168.188.254 for 70:5A:0F:CD:33:37 HP-HP
18:04:43 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:43 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
18:04:43 lte,async,raw lte1: sent AT+QXPOWER
18:04:43 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:43 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:43 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:43 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:43 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:43 lte,async,raw lte1: sent AT+CSQ
18:04:43 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:46 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:46 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:04:46 lte,async,raw lte1: sent AT+QXPOWER
18:04:46 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:46 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:46 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:46 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:46 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:46 lte,async,raw lte1: sent AT+CSQ
18:04:46 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:49 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:49 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:04:49 lte,async,raw lte1: sent AT+QXPOWER
18:04:49 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:49 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:49 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:49 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:49 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:49 lte,async,raw lte1: sent AT+CSQ
18:04:49 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:52 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:53 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-7,-,-,-,-,-
18:04:53 lte,async,raw lte1: sent AT+QXPOWER
18:04:53 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:53 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:53 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:53 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:53 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:53 lte,async,raw lte1: sent AT+CSQ
18:04:53 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:56 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:56 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-7,-,-,-,-,-
18:04:56 lte,async,raw lte1: sent AT+QXPOWER
18:04:56 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:56 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:56 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:56 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:56 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:56 lte,async,raw lte1: sent AT+CSQ
18:04:56 lte,async,raw lte1: rcvd +CSQ: 17,99
18:04:59 lte,async,raw lte1: sent AT+QENG="servingcell"
18:04:59 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:04:59 lte,async,raw lte1: sent AT+QXPOWER
18:04:59 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:04:59 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:04:59 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:04:59 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:04:59 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:04:59 lte,async,raw lte1: sent AT+CSQ
18:04:59 lte,async,raw lte1: rcvd +CSQ: 17,99
18:05:02 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:02 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-6,-,-,-,-,-
18:05:02 lte,async,raw lte1: sent AT+QXPOWER
18:05:02 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:02 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:02 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:02 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:02 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:02 lte,async,raw lte1: sent AT+CSQ
18:05:02 lte,async,raw lte1: rcvd +CSQ: 17,99
18:05:05 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:05 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-7,-,-,-,-,-
18:05:05 lte,async,raw lte1: sent AT+QXPOWER
18:05:05 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:05 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:05 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:05 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:05 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:05 lte,async,raw lte1: sent AT+CSQ
18:05:05 lte,async,raw lte1: rcvd +CSQ: 17,99
18:05:08 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:08 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-7,-,-,-,-,-
18:05:08 lte,async,raw lte1: sent AT+QXPOWER
18:05:08 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:08 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:08 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:08 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:08 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:08 lte,async,raw lte1: sent AT+CSQ
18:05:08 lte,async,raw lte1: rcvd +CSQ: 17,99
18:05:11 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:11 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-6,-,-,-,-,-
18:05:11 lte,async,raw lte1: sent AT+QXPOWER
18:05:11 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:11 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:11 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:11 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:11 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:11 lte,async,raw lte1: sent AT+CSQ
18:05:11 lte,async,raw lte1: rcvd +CSQ: 17,99
18:05:14 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:14 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-7,-,-,-,-,-
18:05:14 lte,async,raw lte1: sent AT+QXPOWER
18:05:14 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:14 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:14 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:14 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:14 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:14 lte,async,raw lte1: sent AT+CSQ
18:05:14 lte,async,raw lte1: rcvd +CSQ: 17,99
18:05:17 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:17 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:05:17 lte,async,raw lte1: sent AT+QXPOWER
18:05:17 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:17 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:17 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:17 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:17 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:17 lte,async,raw lte1: sent AT+CSQ
18:05:17 lte,async,raw lte1: rcvd +CSQ: 17,99
18:05:20 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:20 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:05:20 lte,async,raw lte1: sent AT+QXPOWER
18:05:20 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:20 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:20 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:20 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:20 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:20 lte,async,raw lte1: sent AT+CSQ
18:05:20 lte,async,raw lte1: rcvd +CSQ: 17,99
18:05:23 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:23 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-5,-,-,-,-,-
18:05:23 lte,async,raw lte1: sent AT+QXPOWER
18:05:23 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:23 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:23 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:23 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:23 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:23 lte,async,raw lte1: sent AT+CSQ
18:05:23 lte,async,raw lte1: rcvd +CSQ: 17,99
18:05:26 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:26 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-6,-,-,-,-,-
18:05:26 lte,async,raw lte1: sent AT+QXPOWER
18:05:26 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:26 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:26 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:26 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:26 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:26 lte,async,raw lte1: sent AT+CSQ
18:05:26 lte,async,raw lte1: rcvd +CSQ: 16,99
18:05:29 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:29 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-5,-,-,-,-,-
18:05:29 lte,async,raw lte1: sent AT+QXPOWER
18:05:29 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:29 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:29 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:29 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:29 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:29 lte,async,raw lte1: sent AT+CSQ
18:05:29 lte,async,raw lte1: rcvd +CSQ: 16,99
18:05:32 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:32 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-79,-6,-,-,-,-,-
18:05:32 lte,async,raw lte1: sent AT+QXPOWER
18:05:32 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:32 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:32 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:32 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:32 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:32 lte,async,raw lte1: sent AT+CSQ
18:05:32 lte,async,raw lte1: rcvd +CSQ: 16,99
18:05:35 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:35 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:05:35 lte,async,raw lte1: sent AT+QXPOWER
18:05:35 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:35 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:35 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:35 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:35 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:35 lte,async,raw lte1: sent AT+CSQ
18:05:35 lte,async,raw lte1: rcvd +CSQ: 16,99
18:05:38 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:38 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:05:38 lte,async,raw lte1: sent AT+QXPOWER
18:05:38 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:38 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:38 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:38 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:38 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:38 lte,async,raw lte1: sent AT+CSQ
18:05:38 lte,async,raw lte1: rcvd +CSQ: 16,99
18:05:41 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:41 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-8,-,-,-,-,-
18:05:41 lte,async,raw lte1: sent AT+QXPOWER
18:05:41 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:41 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:41 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:41 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:41 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:41 lte,async,raw lte1: sent AT+CSQ
18:05:41 lte,async,raw lte1: rcvd +CSQ: 16,99
18:05:44 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:44 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-9,-,-,-,-,-
18:05:44 lte,async,raw lte1: sent AT+QXPOWER
18:05:44 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:44 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:44 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:44 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:44 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:44 lte,async,raw lte1: sent AT+CSQ
18:05:44 lte,async,raw lte1: rcvd +CSQ: 16,99
18:05:47 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:47 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-10,-,-,-,-,-
18:05:47 lte,async,raw lte1: sent AT+QXPOWER
18:05:47 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:47 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:47 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:47 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:47 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:47 lte,async,raw lte1: sent AT+CSQ
18:05:47 lte,async,raw lte1: rcvd +CSQ: 16,99
18:05:50 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:50 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-9,-,-,-,-,-
18:05:50 lte,async,raw lte1: sent AT+QXPOWER
18:05:50 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:50 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:50 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:50 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:50 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:50 lte,async,raw lte1: sent AT+CSQ
18:05:50 lte,async,raw lte1: rcvd +CSQ: 16,99
18:05:53 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:53 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-8,-,-,-,-,-
18:05:53 lte,async,raw lte1: sent AT+QXPOWER
18:05:53 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:53 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:53 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:53 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:53 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:53 lte,async,raw lte1: sent AT+CSQ
18:05:53 lte,async,raw lte1: rcvd +CSQ: 16,99
18:05:56 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:56 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-8,-,-,-,-,-
18:05:56 lte,async,raw lte1: sent AT+QXPOWER
18:05:56 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:56 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:56 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:56 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:56 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:56 lte,async,raw lte1: sent AT+CSQ
18:05:56 lte,async,raw lte1: rcvd +CSQ: 16,99
18:05:59 lte,async,raw lte1: sent AT+QENG="servingcell"
18:05:59 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-8,-,-,-,-,-
18:05:59 lte,async,raw lte1: sent AT+QXPOWER
18:05:59 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:05:59 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:05:59 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:05:59 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:05:59 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:05:59 lte,async,raw lte1: sent AT+CSQ
18:05:59 lte,async,raw lte1: rcvd +CSQ: 16,99
18:06:02 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:02 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-8,-,-,-,-,-
18:06:02 lte,async,raw lte1: sent AT+QXPOWER
18:06:02 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:02 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:02 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:02 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:02 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:02 lte,async,raw lte1: sent AT+CSQ
18:06:02 lte,async,raw lte1: rcvd +CSQ: 16,99
18:06:05 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:05 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-8,-,-,-,-,-
18:06:05 lte,async,raw lte1: sent AT+QXPOWER
18:06:05 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:05 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:05 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:05 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:05 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:05 lte,async,raw lte1: sent AT+CSQ
18:06:05 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:08 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:08 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-7,-,-,-,-,-
18:06:08 lte,async,raw lte1: sent AT+QXPOWER
18:06:08 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:08 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:08 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:08 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:08 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:08 lte,async,raw lte1: sent AT+CSQ
18:06:08 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:11 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:11 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:06:11 lte,async,raw lte1: sent AT+QXPOWER
18:06:11 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:11 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:11 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:11 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:11 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:11 lte,async,raw lte1: sent AT+CSQ
18:06:11 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:14 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:14 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-83,-8,-,-,-,-,-
18:06:14 lte,async,raw lte1: sent AT+QXPOWER
18:06:14 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:14 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:14 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:14 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:14 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:14 lte,async,raw lte1: sent AT+CSQ
18:06:14 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:17 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:17 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-8,-,-,-,-,-
18:06:17 lte,async,raw lte1: sent AT+QXPOWER
18:06:17 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:17 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:17 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:17 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:17 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:17 lte,async,raw lte1: sent AT+CSQ
18:06:17 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:20 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:20 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-8,-,-,-,-,-
18:06:20 lte,async,raw lte1: sent AT+QXPOWER
18:06:20 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:20 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:20 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:20 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:20 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:20 lte,async,raw lte1: sent AT+CSQ
18:06:20 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:23 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:23 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-8,-,-,-,-,-
18:06:23 lte,async,raw lte1: sent AT+QXPOWER
18:06:23 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:23 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:23 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:23 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:23 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:23 lte,async,raw lte1: sent AT+CSQ
18:06:23 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:26 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:26 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-8,-,-,-,-,-
18:06:26 lte,async,raw lte1: sent AT+QXPOWER
18:06:26 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:26 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:26 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:26 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:26 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:26 lte,async,raw lte1: sent AT+CSQ
18:06:26 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:29 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:29 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-8,-,-,-,-,-
18:06:29 lte,async,raw lte1: sent AT+QXPOWER
18:06:29 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:29 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:29 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:29 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:29 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:29 lte,async,raw lte1: sent AT+CSQ
18:06:29 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:32 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:32 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-10,-,-,-,-,-
18:06:32 lte,async,raw lte1: sent AT+QXPOWER
18:06:32 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:32 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:32 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:32 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:32 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:32 lte,async,raw lte1: sent AT+CSQ
18:06:32 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:35 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:35 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-9,-,-,-,-,-
18:06:35 lte,async,raw lte1: sent AT+QXPOWER
18:06:35 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:35 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:35 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:35 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:35 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:35 lte,async,raw lte1: sent AT+CSQ
18:06:35 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:38 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:38 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-8,-,-,-,-,-
18:06:38 lte,async,raw lte1: sent AT+QXPOWER
18:06:38 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:38 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:38 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:38 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:38 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:38 lte,async,raw lte1: sent AT+CSQ
18:06:38 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:41 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:41 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-8,-,-,-,-,-
18:06:41 lte,async,raw lte1: sent AT+QXPOWER
18:06:41 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:41 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:41 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:41 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:41 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:41 lte,async,raw lte1: sent AT+CSQ
18:06:41 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:44 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:44 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-9,-,-,-,-,-
18:06:44 lte,async,raw lte1: sent AT+QXPOWER
18:06:44 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:44 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:44 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:44 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:44 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:44 lte,async,raw lte1: sent AT+CSQ
18:06:44 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:47 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:47 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-81,-10,-,-,-,-,-
18:06:47 lte,async,raw lte1: sent AT+QXPOWER
18:06:47 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:47 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:47 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:47 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:47 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:47 lte,async,raw lte1: sent AT+CSQ
18:06:47 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:50 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:50 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-8,-,-,-,-,-
18:06:50 lte,async,raw lte1: sent AT+QXPOWER
18:06:50 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:50 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:50 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:50 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:50 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:50 lte,async,raw lte1: sent AT+CSQ
18:06:50 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:53 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:53 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-6,-,-,-,-,-
18:06:53 lte,async,raw lte1: sent AT+QXPOWER
18:06:53 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:53 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:53 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:53 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:53 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:53 lte,async,raw lte1: sent AT+CSQ
18:06:53 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:55 system,info,account user admin logged in from 82.66.10.138 via local
18:06:56 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:56 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-11,-,-,-,-,-
18:06:56 lte,async,raw lte1: sent AT+QXPOWER
18:06:56 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:56 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:56 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:56 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:56 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:56 lte,async,raw lte1: sent AT+CSQ
18:06:56 lte,async,raw lte1: rcvd +CSQ: 17,99
18:06:59 lte,async,raw lte1: sent AT+QENG="servingcell"
18:06:59 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-82,-7,-,-,-,-,-
18:06:59 lte,async,raw lte1: sent AT+QXPOWER
18:06:59 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:06:59 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:06:59 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:06:59 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:06:59 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:06:59 lte,async,raw lte1: sent AT+CSQ
18:06:59 lte,async,raw lte1: rcvd +CSQ: 17,99
18:07:02 lte,async,raw lte1: sent AT+QENG="servingcell"
18:07:02 lte,async,raw lte1: rcvd +QENG: "servingcell","NOCONN","WCDMA",208,10,7B35,6124FEA,3075,168,1,-80,-6,-,-,-,-,-
18:07:02 lte,async,raw lte1: sent AT+QXPOWER
18:07:02 lte,async,raw lte1: rcvd +QXPOWER: 0,7,1072562363,-1021258920
18:07:02 lte,async,raw lte1: sent AT+QNETINFO="cmr"
18:07:02 lte,async,raw lte1: rcvd +QNETINFO: "cmr",8,0,1,1
18:07:02 lte,async,raw lte1: sent AT+QNWCFG="lte_l1_para"
18:07:02 lte,async,raw lte1: rcvd +QNWCFG: "lte_l1_para",0,4,2,8
18:07:02 lte,async,raw lte1: sent AT+CSQ
18:07:02 lte,async,raw lte1: rcvd +CSQ: 17,99
