wassy83
Pppoe terminating continuously
Tue Nov 08, 2022 1:46 am
I have this issue that I cannot figure out..
My configuration is:
italian ISP "Tiscali" providing to me an FTTC VDSL2 that is very good usually Rx:195000 Tx:35000 (Kbps).
Zyxel VMG4005-B50A in full bridge mode(FIREWALL,DHCP etc disabled) Latest Firmware
Mikrotik 951G-2HnD Latest Firmware v6.49.7 (stable)
Following the ISP instructions, I have set In mikrotik a VLAN interface with ID 835 and a pppoe client using this vlan and credentials provided by the ISP.
What is happening is that each time I try to connect the pppoe interface( in example through a modem restart, pressing the pppoe client apply button or rebooting the Zyxel) the connection does not come up quickly, typically it will take from a few seconds to 15 minutes, then it works perfect without issues forever. But this is annoying and I want to understand why it happens. In the log I can see this after disabling/enabling the pppoe client
pppoe-tiscali: disabled
pppoe-tiscali: terminating... - administrator request
pppoe-tiscali: connecting...
pppoe-tiscali: initializing...
pppoe-tiscali: disconnected
pppoe-tiscali: terminating... - disconnected
pppoe-tiscali: authenticated
pppoe-tiscali: connected
I tried to connect the pppoe directly with the zyxel using it in routing mode, and it gives to me the same issue, but the interface of the zyxel is very limited and I cannot do so much stuffs. Anyway I tried in the mikrotik to put on top of my firewall accept rules for everything nothing changes. Any suggestions about this?
Znevna
Re: Pppoe terminating continuously
Tue Nov 08, 2022 9:24 am
Your old PPPoE session is still up at the ISP when your new one tries to connect.
At least enable more logging for pppoe, what you've posted doesn't say much.
rextended
Tue Nov 08, 2022 10:06 am
I think the same.
Probabilmente è quello.
wassy83
Tue Nov 08, 2022 10:51 am
you are right sorry.. here is pppoe Log from when I disable the interface to when comes up again(in this case it tooks 2 minutes)
09:33:05 pppoe,ppp,info pppoe-tiscali: initializing...
09:33:05 pppoe,ppp,info pppoe-tiscali: connecting...
09:33:05 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:33:05 pppoe,debug,packet session-id=0x0000
09:33:05 pppoe,debug,packet host-uniq=0x35005d
09:33:05 pppoe,debug,packet service-name=
09:33:05 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:33:05 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:33:05 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:33:05 pppoe,debug,packet host-uniq=0x35005e
09:33:05 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:33:05 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:33:05 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:33:05 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:33:05 pppoe,debug,packet session-id=0x0379
09:33:05 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:33:05 pppoe,ppp,debug pppoe-tiscali: LCP open
09:33:05 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:05 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x79
09:33:05 pppoe,ppp,debug,packet <mru 1480>
09:33:05 pppoe,ppp,debug,packet <magic 0x480b29d5>
09:33:05 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x79
09:33:06 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:06 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x7a
09:33:06 pppoe,ppp,debug,packet <mru 1480>
09:33:06 pppoe,ppp,debug,packet <magic 0x480b29d5>
09:33:06 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x7a
09:33:08 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:08 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x7b
09:33:08 pppoe,ppp,debug,packet <mru 1480>
09:33:08 pppoe,ppp,debug,packet <magic 0x480b29d5>
09:33:08 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x7b
09:33:08 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x2
09:33:08 pppoe,ppp,debug,packet <mru 1492>
09:33:08 pppoe,ppp,debug,packet <magic 0x434c6089>
09:33:08 pppoe,ppp,debug,packet <auth chap>
09:33:08 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x2
09:33:08 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:33:08 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0x5e
09:33:08 pppoe,ppp,debug,packet <challenge len=16>
09:33:08 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:33:08 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0x5e
09:33:08 pppoe,ppp,debug,packet <response len=16>
09:33:08 pppoe,ppp,debug,packet <name somename@isp.it>
09:33:08 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0x5e
09:33:08 pppoe,ppp,info pppoe-tiscali: authenticated
09:33:08 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:33:08 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:33:08 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x31
09:33:08 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:33:08 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:33:08 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:33:08 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:33:08 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x3a
09:33:08 pppoe,ppp,debug pppoe-tiscali: BCP open
09:33:08 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:33:08 pppoe,ppp,debug pppoe-tiscali: CCP open
09:33:08 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:33:08 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:33:08 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:33:08 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:33:08 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:33:08 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:33:08 pppoe,debug,packet session-id=0x0379
09:33:08 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:33:08 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:33:08 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:33:08 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:33:08 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:33:08 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:33:08 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:33:08 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:33:08 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:33:08 pppoe,ppp,debug pppoe-tiscali: CCP close
09:33:08 pppoe,ppp,debug pppoe-tiscali: BCP close
09:33:08 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:33:08 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:33:08 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:33:08 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:33:08 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:33:08 pppoe,ppp,info pppoe-tiscali: disconnected
09:33:08 pppoe,ppp,info pppoe-tiscali: initializing...
09:33:08 pppoe,ppp,info pppoe-tiscali: connecting...
09:33:09 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:33:09 pppoe,debug,packet session-id=0x0000
09:33:09 pppoe,debug,packet host-uniq=0x35005f
09:33:09 pppoe,debug,packet service-name=
09:33:09 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:33:09 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:33:09 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:33:09 pppoe,debug,packet host-uniq=0x350060
09:33:09 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:33:09 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:33:09 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:33:09 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:33:09 pppoe,debug,packet session-id=0x037a
09:33:09 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:33:09 pppoe,ppp,debug pppoe-tiscali: LCP open
09:33:09 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:09 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x7c
09:33:09 pppoe,ppp,debug,packet <mru 1480>
09:33:09 pppoe,ppp,debug,packet <magic 0x40d20adc>
09:33:09 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x7c
09:33:10 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:10 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x7d
09:33:10 pppoe,ppp,debug,packet <mru 1480>
09:33:10 pppoe,ppp,debug,packet <magic 0x40d20adc>
09:33:10 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x7d
09:33:11 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:11 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x7e
09:33:11 pppoe,ppp,debug,packet <mru 1480>
09:33:11 pppoe,ppp,debug,packet <magic 0x40d20adc>
09:33:11 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x7e
09:33:12 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x2
09:33:12 pppoe,ppp,debug,packet <mru 1492>
09:33:12 pppoe,ppp,debug,packet <magic 0x49fe2a10>
09:33:12 pppoe,ppp,debug,packet <auth chap>
09:33:12 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x2
09:33:12 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:33:12 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0xfc
09:33:12 pppoe,ppp,debug,packet <challenge len=16>
09:33:12 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:33:12 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0xfc
09:33:12 pppoe,ppp,debug,packet <response len=16>
09:33:12 pppoe,ppp,debug,packet <name somename@isp.it>
09:33:12 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0xfc
09:33:12 pppoe,ppp,info pppoe-tiscali: authenticated
09:33:12 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:33:12 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:33:12 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x32
09:33:12 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:33:12 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:33:12 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:33:12 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:33:12 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x3b
09:33:12 pppoe,ppp,debug pppoe-tiscali: BCP open
09:33:12 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:33:12 pppoe,ppp,debug pppoe-tiscali: CCP open
09:33:12 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:33:12 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:33:12 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:33:12 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:33:12 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:33:12 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:33:12 pppoe,debug,packet session-id=0x037a
09:33:12 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:33:12 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:33:12 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:33:12 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:33:12 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:33:12 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:33:12 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:33:12 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:33:12 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:33:12 pppoe,ppp,debug pppoe-tiscali: CCP close
09:33:12 pppoe,ppp,debug pppoe-tiscali: BCP close
09:33:12 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:33:12 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:33:12 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:33:12 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:33:12 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:33:12 pppoe,ppp,info pppoe-tiscali: disconnected
09:33:12 pppoe,ppp,info pppoe-tiscali: initializing...
09:33:12 pppoe,ppp,info pppoe-tiscali: connecting...
09:33:12 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:33:12 pppoe,debug,packet session-id=0x0000
09:33:12 pppoe,debug,packet host-uniq=0x350061
09:33:12 pppoe,debug,packet service-name=
09:33:12 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:33:12 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:33:12 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:33:12 pppoe,debug,packet host-uniq=0x350062
09:33:12 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:33:12 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:33:12 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:33:13 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:33:13 pppoe,debug,packet session-id=0x037b
09:33:13 pppoe,debug,packet host-uniq=0x350062
09:33:13 pppoe,debug,packet service-name=
09:33:13 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:33:13 pppoe,ppp,debug pppoe-tiscali: LCP open
09:33:13 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:13 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x7f
09:33:13 pppoe,ppp,debug,packet <mru 1480>
09:33:13 pppoe,ppp,debug,packet <magic 0x49cb6ac9>
09:33:13 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x7f
09:33:14 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:14 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x80
09:33:14 pppoe,ppp,debug,packet <mru 1480>
09:33:14 pppoe,ppp,debug,packet <magic 0x49cb6ac9>
09:33:14 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x80
09:33:15 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:15 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x81
09:33:15 pppoe,ppp,debug,packet <mru 1480>
09:33:15 pppoe,ppp,debug,packet <magic 0x49cb6ac9>
09:33:15 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x81
09:33:16 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x2
09:33:16 pppoe,ppp,debug,packet <mru 1492>
09:33:16 pppoe,ppp,debug,packet <magic 0x231cfe3f>
09:33:16 pppoe,ppp,debug,packet <auth chap>
09:33:16 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x2
09:33:16 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:33:16 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0xc
09:33:16 pppoe,ppp,debug,packet <challenge len=16>
09:33:16 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:33:16 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0xc
09:33:16 pppoe,ppp,debug,packet <response len=16>
09:33:16 pppoe,ppp,debug,packet <name somename@isp.it>
09:33:16 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0xc
09:33:16 pppoe,ppp,info pppoe-tiscali: authenticated
09:33:16 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:33:16 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:33:16 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x33
09:33:16 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:33:16 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:33:16 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:33:16 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:33:16 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x3c
09:33:16 pppoe,ppp,debug pppoe-tiscali: BCP open
09:33:16 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:33:16 pppoe,ppp,debug pppoe-tiscali: CCP open
09:33:16 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:33:16 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:33:16 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:33:16 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:33:16 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:33:16 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:33:16 pppoe,debug,packet session-id=0x037b
09:33:16 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:33:16 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:33:16 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:33:16 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:33:16 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:33:16 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:33:16 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:33:16 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:33:16 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:33:16 pppoe,ppp,debug pppoe-tiscali: CCP close
09:33:16 pppoe,ppp,debug pppoe-tiscali: BCP close
09:33:16 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:33:16 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:33:16 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:33:16 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:33:16 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:33:16 pppoe,ppp,info pppoe-tiscali: disconnected
09:33:17 pppoe,ppp,info pppoe-tiscali: initializing...
09:33:17 pppoe,ppp,info pppoe-tiscali: connecting...
09:33:17 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:33:17 pppoe,debug,packet session-id=0x0000
09:33:17 pppoe,debug,packet host-uniq=0x350063
09:33:17 pppoe,debug,packet service-name=
09:33:17 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:33:17 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:33:17 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:33:17 pppoe,debug,packet host-uniq=0x350064
09:33:17 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:33:17 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:33:17 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:33:17 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:33:17 pppoe,debug,packet session-id=0x037c
09:33:17 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:33:17 pppoe,ppp,debug pppoe-tiscali: LCP open
09:33:17 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:17 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x82
09:33:17 pppoe,ppp,debug,packet <mru 1480>
09:33:17 pppoe,ppp,debug,packet <magic 0x7963c21a>
09:33:17 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x82
09:33:18 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:18 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x83
09:33:18 pppoe,ppp,debug,packet <mru 1480>
09:33:18 pppoe,ppp,debug,packet <magic 0x7963c21a>
09:33:18 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x83
09:33:19 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:19 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x84
09:33:19 pppoe,ppp,debug,packet <mru 1480>
09:33:19 pppoe,ppp,debug,packet <magic 0x7963c21a>
09:33:19 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x84
09:33:20 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x2
09:33:20 pppoe,ppp,debug,packet <mru 1492>
09:33:20 pppoe,ppp,debug,packet <magic 0x426a5673>
09:33:20 pppoe,ppp,debug,packet <auth chap>
09:33:20 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x2
09:33:20 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:33:20 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0x4e
09:33:20 pppoe,ppp,debug,packet <challenge len=16>
09:33:20 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:33:20 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0x4e
09:33:20 pppoe,ppp,debug,packet <response len=16>
09:33:20 pppoe,ppp,debug,packet <name somename@isp.it>
09:33:20 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0x4e
09:33:20 pppoe,ppp,info pppoe-tiscali: authenticated
09:33:20 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:33:20 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:33:20 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x34
09:33:20 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:33:20 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:33:20 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:33:20 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:33:20 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x3d
09:33:20 pppoe,ppp,debug pppoe-tiscali: BCP open
09:33:20 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:33:20 pppoe,ppp,debug pppoe-tiscali: CCP open
09:33:20 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:33:20 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:33:20 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:33:20 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:33:20 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:33:20 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:33:20 pppoe,debug,packet session-id=0x037c
09:33:20 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:33:20 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:33:20 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:33:20 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:33:20 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:33:20 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:33:20 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:33:20 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:33:20 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:33:20 pppoe,ppp,debug pppoe-tiscali: CCP close
09:33:20 pppoe,ppp,debug pppoe-tiscali: BCP close
09:33:20 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:33:20 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:33:20 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:33:20 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:33:20 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:33:20 pppoe,ppp,info pppoe-tiscali: disconnected
09:33:22 pppoe,ppp,info pppoe-tiscali: initializing...
09:33:22 pppoe,ppp,info pppoe-tiscali: connecting...
09:33:22 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:33:22 pppoe,debug,packet session-id=0x0000
09:33:22 pppoe,debug,packet host-uniq=0x350065
09:33:22 pppoe,debug,packet service-name=
09:33:22 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:33:22 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:33:22 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:33:22 pppoe,debug,packet host-uniq=0x350066
09:33:22 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:33:22 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:33:22 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:33:22 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:33:22 pppoe,debug,packet session-id=0x037d
09:33:22 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:33:22 pppoe,ppp,debug pppoe-tiscali: LCP open
09:33:22 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:22 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x85
09:33:22 pppoe,ppp,debug,packet <mru 1480>
09:33:22 pppoe,ppp,debug,packet <magic 0x6db6c5d9>
09:33:22 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x85
09:33:23 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:23 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x86
09:33:23 pppoe,ppp,debug,packet <mru 1480>
09:33:23 pppoe,ppp,debug,packet <magic 0x6db6c5d9>
09:33:23 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x86
09:33:25 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:25 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x87
09:33:25 pppoe,ppp,debug,packet <mru 1480>
09:33:25 pppoe,ppp,debug,packet <magic 0x6db6c5d9>
09:33:25 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x87
09:33:25 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x2
09:33:25 pppoe,ppp,debug,packet <mru 1492>
09:33:25 pppoe,ppp,debug,packet <magic 0x78ae0024>
09:33:25 pppoe,ppp,debug,packet <auth chap>
09:33:25 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x2
09:33:25 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:33:25 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0xc9
09:33:25 pppoe,ppp,debug,packet <challenge len=16>
09:33:25 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:33:25 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0xc9
09:33:25 pppoe,ppp,debug,packet <response len=16>
09:33:25 pppoe,ppp,debug,packet <name somename@isp.it>
09:33:25 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0xc9
09:33:25 pppoe,ppp,info pppoe-tiscali: authenticated
09:33:25 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:33:25 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:33:25 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x35
09:33:25 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:33:25 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:33:25 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:33:25 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:33:25 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x3e
09:33:25 pppoe,ppp,debug pppoe-tiscali: BCP open
09:33:25 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:33:25 pppoe,ppp,debug pppoe-tiscali: CCP open
09:33:25 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:33:25 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:33:25 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:33:25 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:33:25 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:33:25 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:33:25 pppoe,debug,packet session-id=0x037d
09:33:25 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:33:25 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:33:25 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:33:25 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:33:25 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:33:25 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:33:25 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:33:25 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:33:25 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:33:25 pppoe,ppp,debug pppoe-tiscali: CCP close
09:33:25 pppoe,ppp,debug pppoe-tiscali: BCP close
09:33:25 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:33:25 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:33:25 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:33:25 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:33:25 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:33:25 pppoe,ppp,info pppoe-tiscali: disconnected
09:33:28 pppoe,ppp,info pppoe-tiscali: initializing...
09:33:28 pppoe,ppp,info pppoe-tiscali: connecting...
09:33:28 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:33:28 pppoe,debug,packet session-id=0x0000
09:33:28 pppoe,debug,packet host-uniq=0x350067
09:33:28 pppoe,debug,packet service-name=
09:33:28 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:33:28 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:33:28 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:33:28 pppoe,debug,packet host-uniq=0x350068
09:33:28 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:33:28 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:33:28 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:33:29 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:33:29 pppoe,debug,packet session-id=0x037e
09:33:29 pppoe,debug,packet host-uniq=0x350068
09:33:29 pppoe,debug,packet service-name=
09:33:29 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:33:29 pppoe,ppp,debug pppoe-tiscali: LCP open
09:33:29 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:29 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x88
09:33:29 pppoe,ppp,debug,packet <mru 1480>
09:33:29 pppoe,ppp,debug,packet <magic 0x28a0f409>
09:33:29 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x88
09:33:30 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:30 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x89
09:33:30 pppoe,ppp,debug,packet <mru 1480>
09:33:30 pppoe,ppp,debug,packet <magic 0x28a0f409>
09:33:30 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x89
09:33:31 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:31 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x8a
09:33:31 pppoe,ppp,debug,packet <mru 1480>
09:33:31 pppoe,ppp,debug,packet <magic 0x28a0f409>
09:33:31 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x8a
09:33:32 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x2
09:33:32 pppoe,ppp,debug,packet <mru 1492>
09:33:32 pppoe,ppp,debug,packet <magic 0x482b825a>
09:33:32 pppoe,ppp,debug,packet <auth chap>
09:33:32 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x2
09:33:32 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:33:32 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0x0
09:33:32 pppoe,ppp,debug,packet <challenge len=16>
09:33:32 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:33:32 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0x0
09:33:32 pppoe,ppp,debug,packet <response len=16>
09:33:32 pppoe,ppp,debug,packet <name somename@isp.it>
09:33:32 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0x0
09:33:32 pppoe,ppp,info pppoe-tiscali: authenticated
09:33:32 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:33:32 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:33:32 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x36
09:33:32 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:33:32 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:33:32 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:33:32 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:33:32 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x3f
09:33:32 pppoe,ppp,debug pppoe-tiscali: BCP open
09:33:32 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:33:32 pppoe,ppp,debug pppoe-tiscali: CCP open
09:33:32 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:33:32 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:33:32 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:33:32 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:33:32 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:33:32 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:33:32 pppoe,debug,packet session-id=0x037e
09:33:32 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:33:32 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:33:32 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:33:32 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:33:32 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:33:32 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:33:32 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:33:32 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:33:32 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:33:32 pppoe,ppp,debug pppoe-tiscali: CCP close
09:33:32 pppoe,ppp,debug pppoe-tiscali: BCP close
09:33:32 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:33:32 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:33:32 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:33:32 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:33:32 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:33:32 pppoe,ppp,info pppoe-tiscali: disconnected
09:33:38 pppoe,ppp,info pppoe-tiscali: initializing...
09:33:38 pppoe,ppp,info pppoe-tiscali: connecting...
09:33:38 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:33:38 pppoe,debug,packet session-id=0x0000
09:33:38 pppoe,debug,packet host-uniq=0x350069
09:33:38 pppoe,debug,packet service-name=
09:33:38 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:33:38 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:33:38 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:33:38 pppoe,debug,packet host-uniq=0x35006a
09:33:38 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:33:38 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:33:38 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:33:39 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:33:39 pppoe,debug,packet session-id=0x037f
09:33:39 pppoe,debug,packet host-uniq=0x35006a
09:33:39 pppoe,debug,packet service-name=
09:33:39 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:33:39 pppoe,ppp,debug pppoe-tiscali: LCP open
09:33:39 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:39 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x8b
09:33:39 pppoe,ppp,debug,packet <mru 1480>
09:33:39 pppoe,ppp,debug,packet <magic 0x48d75f14>
09:33:39 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x8b
09:33:40 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:40 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x8c
09:33:40 pppoe,ppp,debug,packet <mru 1480>
09:33:40 pppoe,ppp,debug,packet <magic 0x48d75f14>
09:33:40 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x8c
09:33:41 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:41 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x8d
09:33:41 pppoe,ppp,debug,packet <mru 1480>
09:33:41 pppoe,ppp,debug,packet <magic 0x48d75f14>
09:33:41 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x8d
09:33:42 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x2
09:33:42 pppoe,ppp,debug,packet <mru 1492>
09:33:42 pppoe,ppp,debug,packet <magic 0x575c02b6>
09:33:42 pppoe,ppp,debug,packet <auth chap>
09:33:42 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x2
09:33:42 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:33:42 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0x3b
09:33:42 pppoe,ppp,debug,packet <challenge len=16>
09:33:42 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:33:42 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0x3b
09:33:42 pppoe,ppp,debug,packet <response len=16>
09:33:42 pppoe,ppp,debug,packet <name somename@isp.it>
09:33:42 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0x3b
09:33:42 pppoe,ppp,info pppoe-tiscali: authenticated
09:33:42 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:33:42 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:33:42 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x37
09:33:42 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:33:42 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:33:42 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:33:42 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:33:42 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x40
09:33:42 pppoe,ppp,debug pppoe-tiscali: BCP open
09:33:42 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:33:42 pppoe,ppp,debug pppoe-tiscali: CCP open
09:33:42 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:33:42 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:33:42 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:33:42 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:33:42 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:33:42 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:33:42 pppoe,debug,packet session-id=0x037f
09:33:42 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:33:42 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:33:42 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:33:42 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:33:42 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:33:42 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:33:42 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:33:42 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:33:42 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:33:42 pppoe,ppp,debug pppoe-tiscali: CCP close
09:33:42 pppoe,ppp,debug pppoe-tiscali: BCP close
09:33:42 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:33:42 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:33:42 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:33:42 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:33:42 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:33:42 pppoe,ppp,info pppoe-tiscali: disconnected
09:33:52 pppoe,ppp,info pppoe-tiscali: initializing...
09:33:52 pppoe,ppp,info pppoe-tiscali: connecting...
09:33:52 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:33:52 pppoe,debug,packet session-id=0x0000
09:33:52 pppoe,debug,packet host-uniq=0x35006b
09:33:52 pppoe,debug,packet service-name=
09:33:52 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:33:52 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:33:52 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:33:52 pppoe,debug,packet host-uniq=0x35006c
09:33:52 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:33:52 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:33:52 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:33:52 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:33:52 pppoe,debug,packet session-id=0x0380
09:33:52 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:33:52 pppoe,ppp,debug pppoe-tiscali: LCP open
09:33:52 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:52 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x8e
09:33:52 pppoe,ppp,debug,packet <mru 1480>
09:33:52 pppoe,ppp,debug,packet <magic 0x69d1868d>
09:33:52 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x8e
09:33:53 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:53 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x8f
09:33:53 pppoe,ppp,debug,packet <mru 1480>
09:33:53 pppoe,ppp,debug,packet <magic 0x69d1868d>
09:33:53 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x8f
09:33:55 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:33:55 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x90
09:33:55 pppoe,ppp,debug,packet <mru 1480>
09:33:55 pppoe,ppp,debug,packet <magic 0x69d1868d>
09:33:55 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x90
09:33:55 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x2
09:33:55 pppoe,ppp,debug,packet <mru 1492>
09:33:55 pppoe,ppp,debug,packet <magic 0x637a01e4>
09:33:55 pppoe,ppp,debug,packet <auth chap>
09:33:55 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x2
09:33:55 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:33:55 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0x52
09:33:55 pppoe,ppp,debug,packet <challenge len=16>
09:33:55 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:33:55 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0x52
09:33:55 pppoe,ppp,debug,packet <response len=16>
09:33:55 pppoe,ppp,debug,packet <name somename@isp.it>
09:33:55 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0x52
09:33:55 pppoe,ppp,info pppoe-tiscali: authenticated
09:33:55 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:33:55 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:33:55 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x38
09:33:55 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:33:55 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:33:55 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:33:55 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:33:55 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x41
09:33:55 pppoe,ppp,debug pppoe-tiscali: BCP open
09:33:55 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:33:55 pppoe,ppp,debug pppoe-tiscali: CCP open
09:33:55 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:33:55 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:33:55 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:33:55 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:33:55 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:33:56 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:33:56 pppoe,debug,packet session-id=0x0380
09:33:56 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:33:56 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:33:56 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:33:56 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:33:56 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:33:56 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:33:56 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:33:56 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:33:56 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:33:56 pppoe,ppp,debug pppoe-tiscali: CCP close
09:33:56 pppoe,ppp,debug pppoe-tiscali: BCP close
09:33:56 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:33:56 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:33:56 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:33:56 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:33:56 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:33:56 pppoe,ppp,info pppoe-tiscali: disconnected
09:34:06 pppoe,ppp,info pppoe-tiscali: initializing...
09:34:06 pppoe,ppp,info pppoe-tiscali: connecting...
09:34:06 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:34:06 pppoe,debug,packet session-id=0x0000
09:34:06 pppoe,debug,packet host-uniq=0x35006d
09:34:06 pppoe,debug,packet service-name=
09:34:06 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:34:06 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:34:06 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:34:06 pppoe,debug,packet host-uniq=0x35006e
09:34:06 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:34:06 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:34:06 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:34:06 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:34:06 pppoe,debug,packet session-id=0x0381
09:34:06 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:34:06 pppoe,ppp,debug pppoe-tiscali: LCP open
09:34:06 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:34:06 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x91
09:34:06 pppoe,ppp,debug,packet <mru 1480>
09:34:06 pppoe,ppp,debug,packet <magic 0x4ac38b18>
09:34:06 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x91
09:34:07 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:34:07 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x92
09:34:07 pppoe,ppp,debug,packet <mru 1480>
09:34:07 pppoe,ppp,debug,packet <magic 0x4ac38b18>
09:34:07 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x92
09:34:09 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:34:09 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x93
09:34:09 pppoe,ppp,debug,packet <mru 1480>
09:34:09 pppoe,ppp,debug,packet <magic 0x4ac38b18>
09:34:09 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x93
09:34:09 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x2
09:34:09 pppoe,ppp,debug,packet <mru 1492>
09:34:09 pppoe,ppp,debug,packet <magic 0x6f76466e>
09:34:09 pppoe,ppp,debug,packet <auth chap>
09:34:09 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x2
09:34:09 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:34:09 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0x67
09:34:09 pppoe,ppp,debug,packet <challenge len=16>
09:34:09 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:34:09 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0x67
09:34:09 pppoe,ppp,debug,packet <response len=16>
09:34:09 pppoe,ppp,debug,packet <name somename@isp.it>
09:34:09 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0x67
09:34:09 pppoe,ppp,info pppoe-tiscali: authenticated
09:34:09 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:34:09 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:34:09 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x39
09:34:09 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:34:09 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:34:09 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:34:09 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:34:09 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x42
09:34:09 pppoe,ppp,debug pppoe-tiscali: BCP open
09:34:09 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:34:09 pppoe,ppp,debug pppoe-tiscali: CCP open
09:34:09 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:34:09 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:34:09 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:34:09 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:34:09 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:34:09 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:34:09 pppoe,debug,packet session-id=0x0381
09:34:09 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:34:09 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:34:09 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:34:09 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:34:09 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:34:09 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:34:09 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:34:09 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:34:09 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:34:09 pppoe,ppp,debug pppoe-tiscali: CCP close
09:34:09 pppoe,ppp,debug pppoe-tiscali: BCP close
09:34:09 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:34:09 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:34:09 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:34:09 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:34:09 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:34:09 pppoe,ppp,info pppoe-tiscali: disconnected
09:34:19 pppoe,ppp,info pppoe-tiscali: initializing...
09:34:19 pppoe,ppp,info pppoe-tiscali: connecting...
09:34:19 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:34:19 pppoe,debug,packet session-id=0x0000
09:34:19 pppoe,debug,packet host-uniq=0x35006f
09:34:19 pppoe,debug,packet service-name=
09:34:19 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:34:19 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:34:19 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:34:19 pppoe,debug,packet host-uniq=0x350070
09:34:19 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:34:19 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:34:19 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:34:20 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:34:20 pppoe,debug,packet session-id=0x0382
09:34:20 pppoe,debug,packet host-uniq=0x350070
09:34:20 pppoe,debug,packet service-name=
09:34:20 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:34:20 pppoe,ppp,debug pppoe-tiscali: LCP open
09:34:20 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x1
09:34:20 pppoe,ppp,debug,packet <mru 1492>
09:34:20 pppoe,ppp,debug,packet <magic 0x343c3a23>
09:34:20 pppoe,ppp,debug,packet <auth chap>
09:34:20 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x94
09:34:20 pppoe,ppp,debug,packet <mru 1480>
09:34:20 pppoe,ppp,debug,packet <magic 0x1c20215a>
09:34:20 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x1
09:34:20 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x94
09:34:20 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:34:20 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0x92
09:34:20 pppoe,ppp,debug,packet <challenge len=16>
09:34:20 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:34:20 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0x92
09:34:20 pppoe,ppp,debug,packet <response len=16>
09:34:20 pppoe,ppp,debug,packet <name somename@isp.it>
09:34:20 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0x92
09:34:20 pppoe,ppp,info pppoe-tiscali: authenticated
09:34:20 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:34:20 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:34:20 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x3a
09:34:20 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:34:20 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:34:20 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:34:20 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:34:20 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x43
09:34:20 pppoe,ppp,debug pppoe-tiscali: BCP open
09:34:20 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:34:20 pppoe,ppp,debug pppoe-tiscali: CCP open
09:34:20 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:34:20 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:34:20 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:34:20 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:34:20 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:34:20 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:34:20 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:34:20 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:34:20 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:34:20 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:34:20 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:34:20 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:34:20 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:34:20 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:34:20 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:34:20 pppoe,ppp,debug pppoe-tiscali: CCP close
09:34:20 pppoe,ppp,debug pppoe-tiscali: BCP close
09:34:20 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:34:20 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:34:20 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:34:20 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:34:20 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:34:20 pppoe,ppp,info pppoe-tiscali: disconnected
09:34:30 pppoe,ppp,info pppoe-tiscali: initializing...
09:34:30 pppoe,ppp,info pppoe-tiscali: connecting...
09:34:30 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:34:30 pppoe,debug,packet session-id=0x0000
09:34:30 pppoe,debug,packet host-uniq=0x350071
09:34:30 pppoe,debug,packet service-name=
09:34:30 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:34:30 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:34:30 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:34:30 pppoe,debug,packet host-uniq=0x350072
09:34:30 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:34:30 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:34:30 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:34:30 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:34:30 pppoe,debug,packet session-id=0x0383
09:34:30 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:34:30 pppoe,ppp,debug pppoe-tiscali: LCP open
09:34:30 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x1
09:34:30 pppoe,ppp,debug,packet <mru 1492>
09:34:30 pppoe,ppp,debug,packet <magic 0x1599a1ce>
09:34:30 pppoe,ppp,debug,packet <auth chap>
09:34:30 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x95
09:34:30 pppoe,ppp,debug,packet <mru 1480>
09:34:30 pppoe,ppp,debug,packet <magic 0x41700f3e>
09:34:30 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x1
09:34:30 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x95
09:34:30 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:34:30 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0xd6
09:34:30 pppoe,ppp,debug,packet <challenge len=16>
09:34:30 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:34:30 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0xd6
09:34:30 pppoe,ppp,debug,packet <response len=16>
09:34:30 pppoe,ppp,debug,packet <name somename@isp.it>
09:34:31 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0xd6
09:34:31 pppoe,ppp,info pppoe-tiscali: authenticated
09:34:31 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:34:31 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:34:31 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x3b
09:34:31 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:34:31 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:34:31 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:34:31 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:34:31 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x44
09:34:31 pppoe,ppp,debug pppoe-tiscali: BCP open
09:34:31 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:34:31 pppoe,ppp,debug pppoe-tiscali: CCP open
09:34:31 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:34:31 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:34:31 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:34:31 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:34:31 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:34:31 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:34:31 pppoe,debug,packet session-id=0x0383
09:34:31 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:34:31 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:34:31 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:34:31 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:34:31 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:34:31 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:34:31 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:34:31 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:34:31 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:34:31 pppoe,ppp,debug pppoe-tiscali: CCP close
09:34:31 pppoe,ppp,debug pppoe-tiscali: BCP close
09:34:31 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:34:31 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:34:31 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:34:31 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:34:31 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:34:31 pppoe,ppp,info pppoe-tiscali: disconnected
09:34:41 pppoe,ppp,info pppoe-tiscali: initializing...
09:34:41 pppoe,ppp,info pppoe-tiscali: connecting...
09:34:41 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:34:41 pppoe,debug,packet session-id=0x0000
09:34:41 pppoe,debug,packet host-uniq=0x350073
09:34:41 pppoe,debug,packet service-name=
09:34:41 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:34:41 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:34:41 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:34:41 pppoe,debug,packet host-uniq=0x350074
09:34:41 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:34:41 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:34:41 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:34:41 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:34:41 pppoe,debug,packet session-id=0x0384
09:34:41 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:34:41 pppoe,ppp,debug pppoe-tiscali: LCP open
09:34:41 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:34:41 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x96
09:34:41 pppoe,ppp,debug,packet <mru 1480>
09:34:41 pppoe,ppp,debug,packet <magic 0x6782a630>
09:34:41 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x96
09:34:42 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:34:42 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x97
09:34:42 pppoe,ppp,debug,packet <mru 1480>
09:34:42 pppoe,ppp,debug,packet <magic 0x6782a630>
09:34:42 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x97
09:34:43 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:34:43 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x98
09:34:43 pppoe,ppp,debug,packet <mru 1480>
09:34:43 pppoe,ppp,debug,packet <magic 0x6782a630>
09:34:43 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x98
09:34:44 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x2
09:34:44 pppoe,ppp,debug,packet <mru 1492>
09:34:44 pppoe,ppp,debug,packet <magic 0x14a7e525>
09:34:44 pppoe,ppp,debug,packet <auth chap>
09:34:44 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x2
09:34:44 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:34:44 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0x3f
09:34:44 pppoe,ppp,debug,packet <challenge len=16>
09:34:44 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:34:44 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0x3f
09:34:44 pppoe,ppp,debug,packet <response len=16>
09:34:44 pppoe,ppp,debug,packet <name somename@isp.it>
09:34:44 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0x3f
09:34:44 pppoe,ppp,info pppoe-tiscali: authenticated
09:34:44 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:34:44 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:34:44 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x3c
09:34:44 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:34:44 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:34:44 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:34:44 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:34:44 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x45
09:34:44 pppoe,ppp,debug pppoe-tiscali: BCP open
09:34:44 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:34:44 pppoe,ppp,debug pppoe-tiscali: CCP open
09:34:44 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:34:44 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:34:44 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:34:44 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:34:44 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:34:44 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:34:44 pppoe,debug,packet session-id=0x0384
09:34:44 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:34:44 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:34:44 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:34:44 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:34:44 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:34:44 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:34:44 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:34:44 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:34:44 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:34:44 pppoe,ppp,debug pppoe-tiscali: CCP close
09:34:44 pppoe,ppp,debug pppoe-tiscali: BCP close
09:34:44 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:34:44 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:34:44 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:34:44 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:34:44 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:34:44 pppoe,ppp,info pppoe-tiscali: disconnected
09:34:54 pppoe,ppp,info pppoe-tiscali: initializing...
09:34:54 pppoe,ppp,info pppoe-tiscali: connecting...
09:34:54 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:34:54 pppoe,debug,packet session-id=0x0000
09:34:54 pppoe,debug,packet host-uniq=0x350075
09:34:54 pppoe,debug,packet service-name=
09:34:54 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:34:54 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:34:54 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:34:54 pppoe,debug,packet host-uniq=0x350076
09:34:54 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:34:54 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:34:54 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:34:55 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:34:55 pppoe,debug,packet session-id=0x0385
09:34:55 pppoe,debug,packet host-uniq=0x350076
09:34:55 pppoe,debug,packet service-name=
09:34:55 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:34:55 pppoe,ppp,debug pppoe-tiscali: LCP open
09:34:55 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x1
09:34:55 pppoe,ppp,debug,packet <mru 1492>
09:34:55 pppoe,ppp,debug,packet <magic 0x5c2f4371>
09:34:55 pppoe,ppp,debug,packet <auth chap>
09:34:55 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x99
09:34:55 pppoe,ppp,debug,packet <mru 1480>
09:34:55 pppoe,ppp,debug,packet <magic 0x621d0da6>
09:34:55 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x1
09:34:55 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x99
09:34:55 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:34:55 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0xbd
09:34:55 pppoe,ppp,debug,packet <challenge len=16>
09:34:55 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:34:55 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0xbd
09:34:55 pppoe,ppp,debug,packet <response len=16>
09:34:55 pppoe,ppp,debug,packet <name somename@isp.it>
09:34:55 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0xbd
09:34:55 pppoe,ppp,info pppoe-tiscali: authenticated
09:34:55 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:34:55 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:34:55 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x3d
09:34:55 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:34:55 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:34:55 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:34:55 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:34:55 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x46
09:34:55 pppoe,ppp,debug pppoe-tiscali: BCP open
09:34:55 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:34:55 pppoe,ppp,debug pppoe-tiscali: CCP open
09:34:55 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:34:55 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:34:55 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:34:55 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:34:55 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:34:55 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:34:55 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:34:55 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:34:55 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:34:55 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:34:55 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:34:55 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:34:55 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:34:55 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:34:55 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:34:55 pppoe,ppp,debug pppoe-tiscali: CCP close
09:34:55 pppoe,ppp,debug pppoe-tiscali: BCP close
09:34:55 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:34:55 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:34:55 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:34:55 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:34:55 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:34:55 pppoe,ppp,info pppoe-tiscali: disconnected
09:35:05 pppoe,ppp,info pppoe-tiscali: initializing...
09:35:05 pppoe,ppp,info pppoe-tiscali: connecting...
09:35:05 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:35:05 pppoe,debug,packet session-id=0x0000
09:35:05 pppoe,debug,packet host-uniq=0x350077
09:35:05 pppoe,debug,packet service-name=
09:35:05 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:35:05 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:35:05 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:35:05 pppoe,debug,packet host-uniq=0x350078
09:35:05 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:35:05 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:35:05 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:35:05 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:35:05 pppoe,debug,packet session-id=0x0386
09:35:05 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:35:05 pppoe,ppp,debug pppoe-tiscali: LCP open
09:35:05 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x1
09:35:05 pppoe,ppp,debug,packet <mru 1492>
09:35:05 pppoe,ppp,debug,packet <magic 0x4bd142a4>
09:35:05 pppoe,ppp,debug,packet <auth chap>
09:35:05 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x9a
09:35:05 pppoe,ppp,debug,packet <mru 1480>
09:35:05 pppoe,ppp,debug,packet <magic 0x7a947896>
09:35:05 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x1
09:35:05 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x9a
09:35:05 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:35:05 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0x3e
09:35:05 pppoe,ppp,debug,packet <challenge len=16>
09:35:05 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:35:05 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0x3e
09:35:05 pppoe,ppp,debug,packet <response len=16>
09:35:05 pppoe,ppp,debug,packet <name somename@isp.it>
09:35:05 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0x3e
09:35:05 pppoe,ppp,info pppoe-tiscali: authenticated
09:35:05 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:35:05 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:35:05 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x3e
09:35:05 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:35:05 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:35:05 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:35:05 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:35:05 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x47
09:35:05 pppoe,ppp,debug pppoe-tiscali: BCP open
09:35:05 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:35:05 pppoe,ppp,debug pppoe-tiscali: CCP open
09:35:05 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:35:05 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:35:05 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:35:05 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:35:05 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:35:06 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:35:06 pppoe,debug,packet session-id=0x0386
09:35:06 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:35:06 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:35:06 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:35:06 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:35:06 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:35:06 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:35:06 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:35:06 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:35:06 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:35:06 pppoe,ppp,debug pppoe-tiscali: CCP close
09:35:06 pppoe,ppp,debug pppoe-tiscali: BCP close
09:35:06 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:35:06 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:35:06 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:35:06 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:35:06 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:35:06 pppoe,ppp,info pppoe-tiscali: disconnected
09:35:16 pppoe,ppp,info pppoe-tiscali: initializing...
09:35:16 pppoe,ppp,info pppoe-tiscali: connecting...
09:35:16 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:35:16 pppoe,debug,packet session-id=0x0000
09:35:16 pppoe,debug,packet host-uniq=0x350079
09:35:16 pppoe,debug,packet service-name=
09:35:16 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:35:16 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:35:16 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:35:16 pppoe,debug,packet host-uniq=0x35007a
09:35:16 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:35:16 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:35:16 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:35:16 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:35:16 pppoe,debug,packet session-id=0x0387
09:35:16 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:35:16 pppoe,ppp,debug pppoe-tiscali: LCP open
09:35:16 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:35:16 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x9b
09:35:16 pppoe,ppp,debug,packet <mru 1480>
09:35:16 pppoe,ppp,debug,packet <magic 0x69618631>
09:35:16 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x9b
09:35:17 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:35:17 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x9c
09:35:17 pppoe,ppp,debug,packet <mru 1480>
09:35:17 pppoe,ppp,debug,packet <magic 0x69618631>
09:35:17 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x9c
09:35:19 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:35:19 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x9d
09:35:19 pppoe,ppp,debug,packet <mru 1480>
09:35:19 pppoe,ppp,debug,packet <magic 0x69618631>
09:35:19 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x9d
09:35:19 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x2
09:35:19 pppoe,ppp,debug,packet <mru 1492>
09:35:19 pppoe,ppp,debug,packet <magic 0x40aacc82>
09:35:19 pppoe,ppp,debug,packet <auth chap>
09:35:19 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x2
09:35:19 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:35:19 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0x16
09:35:19 pppoe,ppp,debug,packet <challenge len=16>
09:35:19 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:35:19 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0x16
09:35:19 pppoe,ppp,debug,packet <response len=16>
09:35:19 pppoe,ppp,debug,packet <name somename@isp.it>
09:35:19 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0x16
09:35:19 pppoe,ppp,info pppoe-tiscali: authenticated
09:35:19 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:35:19 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:35:19 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x3f
09:35:19 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:35:19 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:35:19 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:35:19 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:35:19 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x48
09:35:19 pppoe,ppp,debug pppoe-tiscali: BCP open
09:35:19 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:35:19 pppoe,ppp,debug pppoe-tiscali: CCP open
09:35:19 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:35:19 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:35:19 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:35:19 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:35:19 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:35:19 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:35:19 pppoe,debug,packet session-id=0x0387
09:35:19 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:35:19 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:35:19 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:35:19 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:35:19 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:35:19 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:35:19 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:35:19 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:35:19 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:35:19 pppoe,ppp,debug pppoe-tiscali: CCP close
09:35:19 pppoe,ppp,debug pppoe-tiscali: BCP close
09:35:19 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:35:19 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:35:19 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:35:19 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:35:19 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:35:19 pppoe,ppp,info pppoe-tiscali: disconnected
09:35:29 pppoe,ppp,info pppoe-tiscali: initializing...
09:35:29 pppoe,ppp,info pppoe-tiscali: connecting...
09:35:29 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:35:29 pppoe,debug,packet session-id=0x0000
09:35:29 pppoe,debug,packet host-uniq=0x35007b
09:35:29 pppoe,debug,packet service-name=
09:35:29 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:35:29 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:35:29 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:35:29 pppoe,debug,packet host-uniq=0x35007c
09:35:29 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:35:29 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:35:29 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:35:30 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:35:30 pppoe,debug,packet session-id=0x0388
09:35:30 pppoe,debug,packet host-uniq=0x35007c
09:35:30 pppoe,debug,packet service-name=
09:35:30 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:35:30 pppoe,ppp,debug pppoe-tiscali: LCP open
09:35:30 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:35:30 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x9e
09:35:30 pppoe,ppp,debug,packet <mru 1480>
09:35:30 pppoe,ppp,debug,packet <magic 0x2673d643>
09:35:30 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x9e
09:35:31 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:35:31 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0x9f
09:35:31 pppoe,ppp,debug,packet <mru 1480>
09:35:31 pppoe,ppp,debug,packet <magic 0x2673d643>
09:35:31 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0x9f
09:35:32 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:35:32 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0xa0
09:35:32 pppoe,ppp,debug,packet <mru 1480>
09:35:32 pppoe,ppp,debug,packet <magic 0x2673d643>
09:35:32 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0xa0
09:35:33 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x2
09:35:33 pppoe,ppp,debug,packet <mru 1492>
09:35:33 pppoe,ppp,debug,packet <magic 0x1544e452>
09:35:33 pppoe,ppp,debug,packet <auth chap>
09:35:33 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x2
09:35:33 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:35:33 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0x42
09:35:33 pppoe,ppp,debug,packet <challenge len=16>
09:35:33 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:35:33 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0x42
09:35:33 pppoe,ppp,debug,packet <response len=16>
09:35:33 pppoe,ppp,debug,packet <name somename@isp.it>
09:35:33 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0x42
09:35:33 pppoe,ppp,info pppoe-tiscali: authenticated
09:35:33 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:35:33 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:35:33 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x40
09:35:33 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:35:33 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:35:33 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:35:33 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:35:33 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x49
09:35:33 pppoe,ppp,debug pppoe-tiscali: BCP open
09:35:33 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:35:33 pppoe,ppp,debug pppoe-tiscali: CCP open
09:35:33 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:35:33 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:35:33 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:35:33 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:35:33 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:35:33 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:35:33 pppoe,debug,packet session-id=0x0388
09:35:33 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:35:33 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:35:33 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:35:33 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:35:33 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:35:33 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:35:33 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:35:33 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:35:33 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:35:33 pppoe,ppp,debug pppoe-tiscali: CCP close
09:35:33 pppoe,ppp,debug pppoe-tiscali: BCP close
09:35:33 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:35:33 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:35:33 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:35:33 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:35:33 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:35:33 pppoe,ppp,info pppoe-tiscali: disconnected
09:35:43 pppoe,ppp,info pppoe-tiscali: initializing...
09:35:43 pppoe,ppp,info pppoe-tiscali: connecting...
09:35:43 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:35:43 pppoe,debug,packet session-id=0x0000
09:35:43 pppoe,debug,packet host-uniq=0x35007d
09:35:43 pppoe,debug,packet service-name=
09:35:43 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:35:43 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:35:43 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:35:43 pppoe,debug,packet host-uniq=0x35007e
09:35:43 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:35:43 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:35:43 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:35:43 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:35:43 pppoe,debug,packet session-id=0x0389
09:35:43 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:35:43 pppoe,ppp,debug pppoe-tiscali: LCP open
09:35:43 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:35:43 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0xa1
09:35:43 pppoe,ppp,debug,packet <mru 1480>
09:35:43 pppoe,ppp,debug,packet <magic 0x16a26b32>
09:35:43 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0xa1
09:35:44 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:35:44 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0xa2
09:35:44 pppoe,ppp,debug,packet <mru 1480>
09:35:44 pppoe,ppp,debug,packet <magic 0x16a26b32>
09:35:44 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0xa2
09:35:46 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:35:46 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0xa3
09:35:46 pppoe,ppp,debug,packet <mru 1480>
09:35:46 pppoe,ppp,debug,packet <magic 0x16a26b32>
09:35:46 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0xa3
09:35:46 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x2
09:35:46 pppoe,ppp,debug,packet <mru 1492>
09:35:46 pppoe,ppp,debug,packet <magic 0x6bc71c72>
09:35:46 pppoe,ppp,debug,packet <auth chap>
09:35:46 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x2
09:35:46 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:35:46 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0x1d
09:35:46 pppoe,ppp,debug,packet <challenge len=16>
09:35:46 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:35:46 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0x1d
09:35:46 pppoe,ppp,debug,packet <response len=16>
09:35:46 pppoe,ppp,debug,packet <name somename@isp.it>
09:35:46 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0x1d
09:35:46 pppoe,ppp,info pppoe-tiscali: authenticated
09:35:46 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:35:46 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:35:46 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x41
09:35:46 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:35:46 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:35:46 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:35:46 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:35:46 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x4a
09:35:46 pppoe,ppp,debug pppoe-tiscali: BCP open
09:35:46 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:35:46 pppoe,ppp,debug pppoe-tiscali: CCP open
09:35:46 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:35:46 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:35:46 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:35:46 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:35:46 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:35:46 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:35:46 pppoe,debug,packet session-id=0x0389
09:35:46 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:35:46 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:35:46 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:35:46 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:35:46 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:35:46 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:35:46 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:35:46 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:35:46 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:35:46 pppoe,ppp,debug pppoe-tiscali: CCP close
09:35:46 pppoe,ppp,debug pppoe-tiscali: BCP close
09:35:46 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:35:46 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:35:46 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:35:46 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:35:46 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:35:46 pppoe,ppp,info pppoe-tiscali: disconnected
09:35:56 pppoe,ppp,info pppoe-tiscali: initializing...
09:35:56 pppoe,ppp,info pppoe-tiscali: connecting...
09:35:56 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:35:56 pppoe,debug,packet session-id=0x0000
09:35:56 pppoe,debug,packet host-uniq=0x35007f
09:35:56 pppoe,debug,packet service-name=
09:35:56 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:35:56 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:35:56 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:35:57 pppoe,debug,packet session-id=0x0000
09:35:57 pppoe,debug,packet host-uniq=0x350080
09:35:57 pppoe,debug,packet service-name=
09:35:57 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:35:57 pppoe,debug,packet host-uniq=0x35007f
09:35:57 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:35:57 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:35:57 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:35:57 pppoe,debug,packet session-id=0x038a
09:35:57 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:35:57 pppoe,ppp,debug pppoe-tiscali: LCP open
09:35:57 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x1
09:35:57 pppoe,ppp,debug,packet <mru 1492>
09:35:57 pppoe,ppp,debug,packet <magic 0x3bdac6c7>
09:35:57 pppoe,ppp,debug,packet <auth chap>
09:35:57 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0xa4
09:35:57 pppoe,ppp,debug,packet <mru 1480>
09:35:57 pppoe,ppp,debug,packet <magic 0x7036ca25>
09:35:57 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x1
09:35:57 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0xa4
09:35:57 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:35:57 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0x92
09:35:57 pppoe,ppp,debug,packet <challenge len=16>
09:35:57 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:35:57 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0x92
09:35:57 pppoe,ppp,debug,packet <response len=16>
09:35:57 pppoe,ppp,debug,packet <name somename@isp.it>
09:35:57 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0x92
09:35:57 pppoe,ppp,info pppoe-tiscali: authenticated
09:35:57 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:35:57 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:35:57 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x42
09:35:57 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:35:57 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:35:57 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:35:57 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:35:57 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x4b
09:35:57 pppoe,ppp,debug pppoe-tiscali: BCP open
09:35:57 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:35:57 pppoe,ppp,debug pppoe-tiscali: CCP open
09:35:57 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:35:57 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:35:57 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:35:57 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:35:57 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:35:57 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:35:57 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:35:57 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:35:57 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:35:57 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:35:57 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:35:57 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:35:57 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:35:57 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:35:57 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:35:57 pppoe,ppp,debug pppoe-tiscali: CCP close
09:35:57 pppoe,ppp,debug pppoe-tiscali: BCP close
09:35:57 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:35:57 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:35:57 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:35:57 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:35:57 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:35:57 pppoe,ppp,info pppoe-tiscali: disconnected
09:36:07 pppoe,ppp,info pppoe-tiscali: initializing...
09:36:07 pppoe,ppp,info pppoe-tiscali: connecting...
09:36:07 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:36:07 pppoe,debug,packet session-id=0x0000
09:36:07 pppoe,debug,packet host-uniq=0x350081
09:36:07 pppoe,debug,packet service-name=
09:36:07 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:36:07 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:36:07 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:36:07 pppoe,debug,packet host-uniq=0x350082
09:36:07 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:36:07 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:36:07 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:36:07 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:36:07 pppoe,debug,packet session-id=0x038b
09:36:07 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:36:07 pppoe,ppp,debug pppoe-tiscali: LCP open
09:36:07 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:36:07 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0xa5
09:36:07 pppoe,ppp,debug,packet <mru 1480>
09:36:07 pppoe,ppp,debug,packet <magic 0x58c0f234>
09:36:08 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0xa5
09:36:08 pppoe,ppp,debug,packet <mru 1480>
09:36:08 pppoe,ppp,debug,packet <magic 0x58c0f234>
09:36:08 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:36:08 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0xa6
09:36:08 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0xa6
09:36:10 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:36:10 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0xa7
09:36:10 pppoe,ppp,debug,packet <mru 1480>
09:36:10 pppoe,ppp,debug,packet <magic 0x58c0f234>
09:36:10 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0xa7
09:36:10 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x2
09:36:10 pppoe,ppp,debug,packet <mru 1492>
09:36:10 pppoe,ppp,debug,packet <magic 0xcd3efb>
09:36:10 pppoe,ppp,debug,packet <auth chap>
09:36:10 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x2
09:36:10 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:36:10 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0x1
09:36:10 pppoe,ppp,debug,packet <challenge len=16>
09:36:10 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:36:10 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0x1
09:36:10 pppoe,ppp,debug,packet <response len=16>
09:36:10 pppoe,ppp,debug,packet <name somename@isp.it>
09:36:11 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0x1
09:36:11 pppoe,ppp,info pppoe-tiscali: authenticated
09:36:11 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:36:11 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:36:11 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x43
09:36:11 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:36:11 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:36:11 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:36:11 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:36:11 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x4c
09:36:11 pppoe,ppp,debug pppoe-tiscali: BCP open
09:36:11 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:36:11 pppoe,ppp,debug pppoe-tiscali: CCP open
09:36:11 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:36:11 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:36:11 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:36:11 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:36:11 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:36:11 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:36:11 pppoe,debug,packet session-id=0x038b
09:36:11 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:36:11 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:36:11 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:36:11 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:36:11 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:36:11 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:36:11 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:36:11 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:36:11 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:36:11 pppoe,ppp,debug pppoe-tiscali: CCP close
09:36:11 pppoe,ppp,debug pppoe-tiscali: BCP close
09:36:11 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:36:11 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:36:11 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:36:11 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:36:11 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:36:11 pppoe,ppp,info pppoe-tiscali: disconnected
09:36:21 pppoe,ppp,info pppoe-tiscali: initializing...
09:36:21 pppoe,ppp,info pppoe-tiscali: connecting...
09:36:21 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:36:21 pppoe,debug,packet session-id=0x0000
09:36:21 pppoe,debug,packet host-uniq=0x350083
09:36:21 pppoe,debug,packet service-name=
09:36:21 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:36:21 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:36:21 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:41:2E:04
09:36:21 pppoe,debug,packet host-uniq=0x350084
09:36:21 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:36:21 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:36:21 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:36:21 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:41:2E:04
09:36:21 pppoe,debug,packet session-id=0x038c
09:36:21 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:36:21 pppoe,ppp,debug pppoe-tiscali: LCP open
09:36:21 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:36:21 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0xa8
09:36:21 pppoe,ppp,debug,packet <mru 1480>
09:36:21 pppoe,ppp,debug,packet <magic 0x1d2be6e2>
09:36:21 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0xa8
09:36:22 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:36:22 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0xa9
09:36:22 pppoe,ppp,debug,packet <mru 1480>
09:36:22 pppoe,ppp,debug,packet <magic 0x1d2be6e2>
09:36:22 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0xa9
09:36:24 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:36:24 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0xaa
09:36:24 pppoe,ppp,debug,packet <mru 1480>
09:36:24 pppoe,ppp,debug,packet <magic 0x1d2be6e2>
09:36:24 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0xaa
09:36:24 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x2
09:36:24 pppoe,ppp,debug,packet <mru 1492>
09:36:24 pppoe,ppp,debug,packet <magic 0x2a908775>
09:36:24 pppoe,ppp,debug,packet <auth chap>
09:36:24 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x2
09:36:24 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:36:24 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0x73
09:36:24 pppoe,ppp,debug,packet <challenge len=16>
09:36:24 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-04>
09:36:24 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0x73
09:36:24 pppoe,ppp,debug,packet <response len=16>
09:36:24 pppoe,ppp,debug,packet <name somename@isp.it>
09:36:24 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0x73
09:36:24 pppoe,ppp,info pppoe-tiscali: authenticated
09:36:24 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:36:24 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:36:24 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x44
09:36:24 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:36:24 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:36:24 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:36:24 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:36:24 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x4d
09:36:24 pppoe,ppp,debug pppoe-tiscali: BCP open
09:36:24 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:36:24 pppoe,ppp,debug pppoe-tiscali: CCP open
09:36:24 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:36:24 pppoe,ppp,debug,packet <addr 213.205.52.146>
09:36:24 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:36:24 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x2
09:36:24 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x2
09:36:24 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
09:36:24 pppoe,debug,packet session-id=0x038c
09:36:24 pppoe,ppp,debug pppoe-tiscali: LCP lowerdown
09:36:24 pppoe,ppp,debug pppoe-tiscali: LCP closed
09:36:24 pppoe,ppp,debug pppoe-tiscali: CCP lowerdown
09:36:24 pppoe,ppp,debug pppoe-tiscali: BCP lowerdown
09:36:24 pppoe,ppp,debug pppoe-tiscali: BCP down event in starting state
09:36:24 pppoe,ppp,debug pppoe-tiscali: IPCP lowerdown
09:36:24 pppoe,ppp,debug pppoe-tiscali: IPV6CP lowerdown
09:36:24 pppoe,ppp,debug pppoe-tiscali: IPV6CP down event in starting state
09:36:24 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerdown
09:36:24 pppoe,ppp,debug pppoe-tiscali: CCP close
09:36:24 pppoe,ppp,debug pppoe-tiscali: BCP close
09:36:24 pppoe,ppp,debug pppoe-tiscali: IPCP close
09:36:24 pppoe,ppp,debug pppoe-tiscali: IPV6CP close
09:36:24 pppoe,ppp,debug pppoe-tiscali: MPLSCP close
09:36:24 pppoe,ppp,info pppoe-tiscali: terminating... - disconnected
09:36:24 pppoe,ppp,debug pppoe-tiscali: LCP down event in starting state
09:36:24 pppoe,ppp,info pppoe-tiscali: disconnected
09:36:34 pppoe,ppp,info pppoe-tiscali: initializing...
09:36:34 pppoe,ppp,info pppoe-tiscali: connecting...
09:36:34 pppoe,debug,packet vlan1: sent PADI to FF:FF:FF:FF:FF:FF
09:36:34 pppoe,debug,packet session-id=0x0000
09:36:34 pppoe,debug,packet host-uniq=0x350085
09:36:34 pppoe,debug,packet service-name=
09:36:34 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:39:8B:48
09:36:34 pppoe,debug,packet ac-name=A9001.rms-PE-A1-03
09:36:34 pppoe,debug,packet vlan1: sent PADR to 08:EC:F5:39:8B:48
09:36:34 pppoe,debug,packet host-uniq=0x350086
09:36:34 pppoe,debug,packet vlan1: rcvd PADO from 08:EC:F5:41:2E:04
09:36:34 pppoe,debug,packet ac-name=A9001.rms-PE-A1-04
09:36:34 pppoe,debug vlan1: received PADO with unknown host-uniq, dropping
09:36:35 pppoe,debug,packet vlan1: rcvd PADS from 08:EC:F5:39:8B:48
09:36:35 pppoe,debug,packet session-id=0x4f40
09:36:35 pppoe,debug,packet host-uniq=0x350086
09:36:35 pppoe,debug,packet service-name=
09:36:35 pppoe,ppp,debug pppoe-tiscali: LCP lowerup
09:36:35 pppoe,ppp,debug pppoe-tiscali: LCP open
09:36:35 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:36:35 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0xab
09:36:35 pppoe,ppp,debug,packet <mru 1480>
09:36:35 pppoe,ppp,debug,packet <magic 0x5506b8b6>
09:36:35 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0xab
09:36:36 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:36:36 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0xac
09:36:36 pppoe,ppp,debug,packet <mru 1480>
09:36:36 pppoe,ppp,debug,packet <magic 0x5506b8b6>
09:36:36 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0xac
09:36:37 pppoe,ppp,debug pppoe-tiscali: LCP timer
09:36:37 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfReq id=0xad
09:36:37 pppoe,ppp,debug,packet <mru 1480>
09:36:37 pppoe,ppp,debug,packet <magic 0x5506b8b6>
09:36:37 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfAck id=0xad
09:36:38 pppoe,ppp,debug,packet pppoe-tiscali: rcvd LCP ConfReq id=0x2
09:36:38 pppoe,ppp,debug,packet <mru 1492>
09:36:38 pppoe,ppp,debug,packet <magic 0xf6db5b1>
09:36:38 pppoe,ppp,debug,packet <auth chap>
09:36:38 pppoe,ppp,debug,packet pppoe-tiscali: sent LCP ConfAck id=0x2
09:36:38 pppoe,ppp,debug pppoe-tiscali: LCP opened
09:36:38 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Challenge id=0xd0
09:36:38 pppoe,ppp,debug,packet <challenge len=16>
09:36:38 pppoe,ppp,debug,packet <name a9001.rms-pe-a1-03>
09:36:38 pppoe,ppp,debug,packet pppoe-tiscali: sent CHAP Response id=0xd0
09:36:38 pppoe,ppp,debug,packet <response len=16>
09:36:38 pppoe,ppp,debug,packet <name somename@isp.it>
09:36:38 pppoe,ppp,debug,packet pppoe-tiscali: rcvd CHAP Success id=0xd0
09:36:38 pppoe,ppp,info pppoe-tiscali: authenticated
09:36:38 pppoe,ppp,debug pppoe-tiscali: IPCP lowerup
09:36:38 pppoe,ppp,debug pppoe-tiscali: IPCP open
09:36:38 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x45
09:36:38 pppoe,ppp,debug,packet <addr 0.0.0.0>
09:36:38 pppoe,ppp,debug pppoe-tiscali: IPV6CP open
09:36:38 pppoe,ppp,debug pppoe-tiscali: MPLSCP lowerup
09:36:38 pppoe,ppp,debug pppoe-tiscali: MPLSCP open
09:36:38 pppoe,ppp,debug,packet pppoe-tiscali: sent MPLSCP ConfReq id=0x4e
09:36:38 pppoe,ppp,debug pppoe-tiscali: BCP open
09:36:38 pppoe,ppp,debug pppoe-tiscali: CCP lowerup
09:36:38 pppoe,ppp,debug pppoe-tiscali: CCP open
09:36:38 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfReq id=0x1
09:36:38 pppoe,ppp,debug,packet <addr 213.205.52.144>
09:36:38 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfAck id=0x1
09:36:38 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfNak id=0x45
09:36:38 pppoe,ppp,debug,packet <addr xxx.xxx.xxx.xxx>
09:36:38 pppoe,ppp,debug,packet pppoe-tiscali: sent IPCP ConfReq id=0x46
09:36:38 pppoe,ppp,debug,packet pppoe-tiscali: rcvd IPCP ConfAck id=0x46
09:36:38 pppoe,ppp,debug pppoe-tiscali: IPCP opened
09:36:38 pppoe,ppp,info pppoe-tiscali: connected
Znevna
Re: Pppoe terminating continuously
Tue Nov 08, 2022 11:06 am
From your log:
	Line   85: 09:33:08 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line  189: 09:33:12 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line  293: 09:33:16 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line  397: 09:33:20 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line  501: 09:33:25 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line  605: 09:33:32 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line  709: 09:33:42 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line  813: 09:33:56 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line  917: 09:34:09 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line 1006: 09:34:20 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line 1095: 09:34:31 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line 1199: 09:34:44 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line 1288: 09:34:55 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line 1377: 09:35:06 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line 1481: 09:35:19 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line 1585: 09:35:33 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line 1689: 09:35:46 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line 1778: 09:35:57 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line 1882: 09:36:11 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
	Line 1986: 09:36:24 pppoe,debug,packet vlan1: rcvd PADT from 08:EC:F5:41:2E:04
So like I've said above, your ISP is sending you termination requests most likely because of a previous hanged PPPoE session.
wassy83
Tue Nov 08, 2022 11:16 am
From your log:
So I cannot do anything about this.. i'm sure that if I call support they will never give me assistance for this because with the oem router that they provide to me it works without issues
Znevna
Tue Nov 08, 2022 11:33 am
I don't see the issue though.
Probably your ISP device boots slower than your MikroTik, allowing the old session to timeout.
Put your devices on an UPS and disconnect the PPPoE session properly and you'll be fine.
I see no reason to reboot the modem and/or tinkering with the PPPoE settings all the time.
wassy83
Tue Nov 08, 2022 11:44 am
For me this is an issue, devices can stuck sometimes, I have on this mikrotik stuffs like, VPN, VOIP PHONES, and 30 desktop connected. If for any reason the guys in this boxe restarts the modem, they could stay locked for 15 minutes without a real reason. This doesn't happens often, but when it happens it could be a problem for me. In example we have a remote management software provided by an external company that is really problematic and sometimes we end in a black list without reasons, so guys restarts the mikrotik just for changing our ip address, and they can turn back to work immediately. I know this is not a solution, but is just an example why this could happen.
They are already attached to an UPS, can you please clarify to me what you mean with "disconnect the PPPoE session properly"?
Znevna
Tue Nov 08, 2022 11:48 am
Ask your company network administrator.
wassy83
Tue Nov 08, 2022 11:56 am
What's wrong with you? Too much negative vibes, sometimes people just try to help each other without a particular reason, if you are not interested to support my thread just don't reply. Have a nice day.
Znevna
Tue Nov 08, 2022 12:17 pm
You have all the information needed pointed out already in this topic to help you into doing your job.
Cheers.
rextended
Tue Nov 08, 2022 1:56 pm
[…] If for any reason the guys in this boxe restarts the modem, […]
Ma non gli hai fatto una canata???
Probabilmente perché le connessioni nel NAT rimangono appese, usa uno dei miei script for clear the conn-track when IP change.
E che aspetti a cambiare quel troiaio, or to contact the company for fix the problem?
Just open winbox and disable and re-enable the pppoe-client...
Read previous line...
sindy
Tue Nov 08, 2022 2:28 pm
ROS 6.47.9 (not 6.49.7) on my test CHR sends a PADT to terminate a current session before sending PADI to establish a new one if I change a parameter on an /interface pppoe-client row using a CLI command, or if I change a parameter forth and back in Winbox and then press [Apply]. If I just press [Apply] without touching any parameter, the current session remains active.
As you say the Zyxel in routing mode (i.e. where the PPPoE client is running on the Zyxel provided by Tiscali) has the same issue, I would definitely talk to Tiscali support about it.
To gather more data, you can set /tool sniffer set file-name=pppoe-cycle.pcap, then run /tool sniffer quick interface=vlan1 mac-protocol=pppoe-discovery and cycle the pppoe-client interface the way you normally do. Then stop the sniffer, download pppoe-cycle.pcap, and open it in Wireshark to see whether the first packet is PADT from the Mikrotik. If yes, there's clearly an issue at Tiscali side, which you cannot resolve using any means at Mikrotik side.
You can also sniff also the pppoe traffic (not just the pppoe-discovery one) to a file for a longer time if you connect an external disk, the goal would be to see how often the keepalives from Tiscali actually come. Just once in 15 minutes sounds really strange to me.
sindy
Tue Nov 08, 2022 2:34 pm
This is a good point, but it would only make sense as a reason if the IP assigned by IPCP was changing at every connection, which doesn't seem to be the case according to the log. Plus if it was the case, the OP would have to use action=masquerade rather than action=srcnat, and all connections whose reply-dst-address is lost are dropped automatically if they have been NATed using a masquerade rule.
Users browsing this forum: benbgg, flapviv, GoogleOther [Bot], infabo, Marc1963, quezhou and 116 guests
