nichky
Wireless 20km
Tue Nov 08, 2022 3:27 am
i'm running a wireless link of 20km.
When its on 802.11(security profile=default) im getting a lot of disconnections and the ping is up to 200ms, Nv2 solve the issues.ping is 1ms. (see the log)
AP - v6.47.9
Station - v6.47.9
Im wondering could be the distance reason for that?
nichky
Re: Wireless 20km
Wed Nov 09, 2022 12:06 pm
any?
sindy
Re: Wireless 20km
Wed Nov 09, 2022 12:10 pm
200 ms vs. 1 ms are a huge difference, what is the CCQ value when it works in 802.11 mode?
nichky
Re: Wireless 20km
Thu Nov 10, 2022 12:01 am
neam pojma
that how ccq works , need to send some data through to be able to get the max of ccq, by using 802.11 i cant even ping
- nv2 details:
ccq 60/60
tx/rx rate 144.4
signal to noise 45dB
signal 56dBm
Was working fine on 802.11 for at least two years
sindy
Re: Wireless 20km
Thu Nov 10, 2022 12:16 am
-56 dBm sounds reasonable, 45 dB SNR means there is no interference (noise floor -101 dBm looks like receiver noise). So are you sure the same frequency channel is used in 802.11 mode like in the Nv2 mode? In particular, maybe you use some channel extensions (40/80/160 MHz) and thus you catch interference from a neighbour link which wasn't there before, and which is unseen in Nv2 mode because Nv2 only uses a 20 MHz channel?
nichky
Re: Wireless 20km
Thu Nov 10, 2022 2:07 am
100%
at the moment is 20/40 xx, Do u want me to try 20MHz only?
i forgot one thing , i'm playing with superchannel
sindy
Re: Wireless 20km
Thu Nov 10, 2022 8:57 am
You wrote it had been working for two years but haven't mentioned any change of the settings; was superchannel in use all that time? What particular aspect of superchannel are you using, non-standard channel center frequency or non-standard channel width?
In any case, I would start from a 20 MHz channel and try more than one center frequency to see whether there is no interference.
nichky
Re: Wireless 20km
Thu Nov 10, 2022 9:08 am
nothing has been changed. just i've changed to nv2.
it's running on 5285.
sindy
Re: Wireless 20km
Thu Nov 10, 2022 5:16 pm
So it was working on 802.11 for two years, then you've changed to Nv2, and once you!ve switched it back to 802.11, it doesn't work any more? No other changes?
nichky
Re: Wireless 20km
Thu Nov 10, 2022 11:42 pm
absolutely yes.
from now i'll be starting changing other parameters.
Users browsing this forum: Bing [Bot], Google [Bot], GoogleOther [Bot], PLJ020 and 100 guests
