oencelbu
Using WifiWave2 interface on station mode
Tue Nov 08, 2022 11:10 am
I am configurating the WifiWave2 package on a hAPax2 router running on WinBox v7.6 (arm64). I am using wifi1 on station mode.
I want to connect wifi1 to a different router in the network. I already did that with a different wireless package, but I don't know how it works on WifiWave2.
Where can I select the SSID of the other router in my Wifi1 settings. Or does anybody know the command to add the SSID of the other router to the wifi1 interface?
The config that I did so far is in the attachments.
Thanks for helping!
erlinden
Re: Using WifiWave2 interface on station mode  [SOLVED]
Tue Nov 08, 2022 11:42 am
In station mode the SSID that is configured is used as the SSID it will connect to.
Tip: check your Wifi settings, there is room for improvement.
Users browsing this forum: Amazon [Bot] and 29 guests
