ericdriver
BGP ECMP doesn't work
Tue Nov 08, 2022 12:14 pm
current version 7.6
BGP ECMP doesn't work, all BGP attributes are the same, any ideas?
mrz
Re: BGP ECMP doesn't work
Tue Nov 08, 2022 12:24 pm
It is not supposed to work. BGP elects only one best route. BGP multipath is additional feature that is not implemented yet.
ericdriver
Tue Nov 08, 2022 12:37 pm
in this topic you can see that it works(but the soft version in 7.5)
viewtopic.php?t=189029
mrz
Tue Nov 08, 2022 12:45 pm
In that topic ECMP is not the result of BGP best path selection.
You can get ECMP by running bgp on a loopbacks recursively resolved over ECMP, or by running two BGP instances, but then best path selection will not work.
As I already mentioned BGP multipath is not implemented and was not implemented in v7.5 too.
Users browsing this forum: No registered users and 25 guests
