tansuuu
Mikrotik Container
Tue Nov 08, 2022 12:23 pm
Im playing around with containers inside the mikrotik.
Im running a openwrt container with 1 veth so i have one eth in the openwrt container.
Is it possible to add more veth to the same container so i can have more ethernets inside the container.
If so how?
Best regards.
Tansu
cklee234
Re: Mikrotik Container
Thu Nov 10, 2022 2:40 am
Not aware it is possible
tangent
Re: Mikrotik Container  Topic is solved
Thu Nov 10, 2022 9:54 am
This container gets the effect you want using VLANs.
Still, if the “interface” parameter doesn’t take a list, it’s worth filing a feature request for it.
tansuuu
Fri Nov 11, 2022 12:35 pm
I wil look in to this,
Thanks!
Shahid
Sat Nov 12, 2022 11:25 pm
If so how?
Best regards.
Tansu
Can you please post your configs
i am also intrested in openwrt as a container guest in mikrotik.
i was able to run it, but i was'nt able to configure the network properly & was not able to have access to its web or ssh interface outside of winbox.
what i only got is shell access from mikrotiks terminal. where a lot of openwrt shell commands failed with ubus errors.
Users browsing this forum: No registered users and 6 guests
