persianmsr
SSTP Client Problem
Wed Nov 09, 2022 12:56 pm
Hi guys
i have a problem with SSTP Client on Mikrotik Router OS 7.6
When I create a connection SSTP Client in version 7.6, there is a problem and not connecting
But this problem does not exist in version 6.49
In version 7.6, it shows a connection error "Closed by Peer Remote"
please help
anav
Re: SSTP Client Problem
Wed Nov 09, 2022 1:08 pm
105547111
Mon Dec 12, 2022 10:27 pm
Hi guys
please help
@persianmsr
Try downgrading to 7.5. I have same situation. Works perfectly any v6.x and won't work 7.6 and 7.7b10. I downgraded to 7.5 and it works.
I have a ticket open with mikrotik. Let me know if that works for you. Turning on debug logging was useless. Its disconnecting the server end with the same error you are getting.
jman12
Wed Feb 15, 2023 11:27 pm
Hi
Did you get reply from support. I have the same issue 7.5 works as expected.
This in the 7.6 change log
" sstp - added VRF support for client "
Regards
glat
Wed Oct 25, 2023 3:17 pm
I've issues too. I've a bounch of about 20 sstp clients connects to a 7.11.2 CHR sstp server.
In a few seconds the CHR does not ping constantly.
Same config on a 6.49.8 works.
Users browsing this forum: unhuzpt, zalciukaz and 113 guests
