andy1989
Is it possible to implment different script with different mode button holding time ?
Wed Nov 09, 2022 5:34 pm
Hi community,
If yes,will you please show me an example ?
If no, is it possible that Mikrotik Team make it as a TODO feature ?
P.S.
what I want to implment is something like this.
/system routerboard mode-button
set enabled=yes if(hold-time=1s..5s) do={on-event=script1};if(hold-time=6s..10s) do={on-event=script2};
I know the syntax isn't correct , but I am just trying to explain what features I want to implment.
eworm
Re: Is it possible to implment different script with different mode button holding time ?
Wed Nov 09, 2022 6:32 pm
I have a script that can act on several mode button presses:
Mode button with multiple presses
Jotne
Wed Nov 09, 2022 7:00 pm
That is an good idea, but maybe I am blind (or not used to git), I do not see the script, only the test for button script.
eworm
Wed Nov 09, 2022 7:31 pm
Read the page from top to bottom please...
You need to do the base installation, then install the script with the commands given. The script does not work on its own as it has dependencies on functions.
Jotne
Wed Nov 09, 2022 10:49 pm
I may be to old to read all ;)
See this now
ℹ️ Info: This script can not be used on its own but requires the base installation. See main README for details.
But I was looking for a small script, not a complete solution for many thing.
andy1989
Sun Nov 13, 2022 12:18 am
Well, Thanks to both of you , for the reply.
See this now
As @Jotne mentioned , I want something simple instead of bring a whole new scripting environment .
eworm
Sun Nov 13, 2022 4:59 pm
Feel free to take the script ans strip it down to not use any of my global functions... Should be more or less easy with this one.
Users browsing this forum: Bing [Bot], hoggins, litogorospe and 85 guests
