pants6000
-48V and AC power supplies in the same router?
Wed Nov 09, 2022 5:56 pm
Is the combination of a -48V power supply (PW48V-12V85W) and an AC power supply a supported configuration? CCR2116 is my likely target.
smyers119
Re: -48V and AC power supplies in the same router?
Wed Nov 09, 2022 6:22 pm
It show's that combination in the brochure, and even mentions that specific combination in the product description. Did you try it and are having problems?
rextended
Wed Nov 09, 2022 6:32 pm
The PW48V-12V85W work regardless - or + 48V
The + or - on voltage do not mean to "cross" the DC cables to power the device, but:
-48V = positive on the chassis/ground
48V = is supposed +48V but better know if is one error...
+48V = negative on the chassis/ground
I have the same configuration, also mixed on the same rack devices with "-" and "+", and all work as expected, without short-circuits,
because both the AC and DC power sources are galvanically isolated
but better do some test woth your other equipments before do any....
pants6000
Thu Nov 10, 2022 2:19 am
Exactly what I need to know... again. Thanks!
pants6000
Thu Nov 10, 2022 2:28 am
I didn't, I missed that in the description somehow... "Simply remove one of the current power supplies..."; implying that mixing them is ok.
I have some brands where this is explicitly not supported and needed to be sure, I want to keep the magic smoke where it belongs.
Thanks!
Users browsing this forum: No registered users and 29 guests
