eakteam
Configure VLAN for 2 switches connected in series
Thu Nov 10, 2022 3:17 am
Hi, i'm struggling to configure the network like in the diagram below in attachment and had no success :(.
Anyone can help me configuring and best practices that i should follow for that specific case?
I have read that it is better to use switch chipset directly because it help a lot without dealing with CPU work.
Need a step by step guide or a script that can help me configure that network.
Thank you so much!
erlinden
Re: Configure VLAN for 2 switches connected in series
Thu Nov 10, 2022 8:43 am
An excelent starting point is this topic:
viewtopic.php?t=143620
In regards to the switch chipset, please check if it is feasable for your hardware:
https://help.mikrotik.com/docs/display/ ... p+Features
eakteam
Thu Nov 10, 2022 1:42 pm
Thanks for the answer, i have read a lot and searched online too, but practice is another thing.
Can you help me exactly with what i need if you can please ?
anav
Thu Nov 10, 2022 2:36 pm
Post what you have from all three devices.
each one gets a single bridge,
all smart devices get IP from trusted lan (or a separate managment lan).
All data flows on vlans, dont use bridge for dhcp.
Users browsing this forum: Aska, Bing [Bot] and 230 guests
