Hook032
Problem Startlink and CCR1009
Thu Nov 10, 2022 9:56 pm
I have a problem with a CCR1009 connected to Starlink.
When I make a direct connection it assigns me a gateway 100.64.0.1 and loses half of the packets
When I connect it to another router (Mikrotik hAP) it works correctly with that gateway.
If I connect the CCR1009 through the hAP and it still works correctly
Both are with basic configuration
What can be?
anav
Re: Problem Startlink and CCR1009
Fri Nov 11, 2022 10:20 pm
The configuration.
sindy
Sat Nov 12, 2022 11:30 am
So to recap what you wrote as I'm not sure I've understood it correctly:
  • 1009 connected directly to Starlink has problems
  • hAP connected directly to the same Starlink works fine
  • 1009 connected to the same hAP connected to the same Starlink works fine
"basic", "usual", "typical", "normal" are adjectives that bear no value when it comes to analysing an issue. Only an export of the actual configuration is useful, as @anav has pointed out.
My "qualified guess" is that in better case, there is a mechanical compatibility problem between the plug on the Ethernet cable you use and the receptacle on the Starlink terminal or the 1009 (I would not mention this if I haven't experienced it myself multiple times); in worse case, there is an electrical incompatibility between the Ethernet ports of the Starlink terminal and the 1009.
To exclude any configuration related issues first, please post the complete exports of both the hAP and the 1009 - see the hint in my automatic signature regarding obfuscation, and remove also the serial numbers. After that, we may move on to debugging the hardware issue.
gotsprings
Sun Nov 13, 2022 7:25 pm
Stick a switch in-between as a test.
folkert
Mon Nov 14, 2022 3:03 pm
Had same problem here with CC1009 and solved it for now with an extra hap between...
sindy
Tue Nov 15, 2022 12:52 pm
What does /interface monitor etherX once show (replace etherX by the actual name of the interface connected to the Starlink) on the hAP and on the CCR?
nichky
Wed Nov 16, 2022 4:18 am
we are using Starlink (one of the best wifi device,god is doing everything for u) with CCR1009 and other MT devices,no problems at all.
Just do what @sindy recommending and you will be all good.
Users browsing this forum: nescafe2002, phascogale and 87 guests
