zpz
ipsec issue authentication fails with remote-id RFC822 and FQDN
Fri Nov 11, 2022 12:05 am
I'm trying to setup an ipsec tunnel with pre-shared key and authenticate a peer with remote-id (user fqdn / RFC822) with IKEv2.
Although I have set the identity like this.
[ble@MikroTik] > /ip/ipsec/identity/print
Flags: D - dynamic; X - disabled
 0    peer=peer1 auth-method=pre-shared-key mode-config=request-only my-id=user-fqdn:myname@mydomain.com remote-id=user-fqdn:remotename@remotedomain.com secret="hiddensecret" generate-policy=port-override policy-template-group=group14
I get the following in the log when a router tries to connect me:
22:54:37 ipsec,info new ike2 SA (R): remotename@remotedomain.com lo.cal.add.ress[500]-re.mote.add.ress[500] spi:cxxxxxxxx:xxxxxxxxxx
22:54:37 ipsec processing payloads: VID (none found)
22:54:37 ipsec processing payloads: NOTIFY
22:54:37 ipsec   notify: NAT_DETECTION_SOURCE_IP
22:54:37 ipsec   notify: NAT_DETECTION_DESTINATION_IP
22:54:37 ipsec (NAT-T) REMOTE LOCAL
22:54:37 ipsec KA list add: lo.cal.add.ress[4500]->re.mote.add.ress[4500]
22:54:37 ipsec payload seen: ID_I (27 bytes)
22:54:37 ipsec payload seen: AUTH (40 bytes)
22:54:37 ipsec payload seen: NOTIFY (8 bytes)
22:54:37 ipsec payload seen: SA (44 bytes)
22:54:37 ipsec payload seen: TS_I (24 bytes)
22:54:37 ipsec payload seen: TS_R (24 bytes)
22:54:37 ipsec   notify: ESP_TFC_PADDING_NOT_SUPPORTED
22:54:37 ipsec ike auth: respond
22:54:37 ipsec processing payload: ID_I
22:54:37 ipsec ID_I (RFC822): remotename@remotedomain.com
22:54:37 ipsec processing payload: ID_R (not found)
22:54:37 ipsec processing payload: AUTH
22:54:37 ipsec,error identity not found for peer: RFC822: remotename@remotedomain.com
22:54:37 ipsec reply notify: AUTHENTICATION_FAILED
22:54:37 ipsec adding notify: AUTHENTICATION_FAILED
Is there anybody who has a tip what could be the problem here?
I don't understand if I have the remote-id set as match-by (which seems default) then why the peer is not identified by the ID_I which is the same as the remote-id in the identity.
I'm using 7.6 stable currently.
As both firewalls (mikrotik and the other vendor) are behind a NAT, therefore IP address id seems not an option.
sindy
Re: ipsec issue authentication fails with remote-id RFC822 and FQDN
Sat Nov 12, 2022 5:17 pm
Is peer1 the only IPsec peer in the responder's configuration (some peers may have been created dynamically)?
If not, the initial message from the initiator may have hit a wrong peer.
If yes, it is either a bug or a typo in the remote ID.
zpz
Sat Nov 19, 2022 4:00 pm
Thanks Sindy.
It took me a while to deal with this issue again. I have a template for road warriors as well.
I found that the issue was that the peer was not specified in the policy. After specifying it it started to work.
I wonder if a policy template for this peer (whenever the specific identity is connected) could be added? As for the templates I cannot specify a peer.
Now I had to create a policy for each subnets (proxy ids). I cannot use 0.0.0.0/0 in this case.
sindy
Sat Nov 19, 2022 11:57 pm
That sounds odd. While having a policy (not a policy template) with no peer specification is definitely possible (for backward compatibility reasons), I cannot imagine how that should prevent the IPsec stack from finding an identity for the peer. So it sounds as if either adding the peer to the policy was not the only change, or the log is misleading.
Sure you can use templates - create a policy template group name dedicated to this peer, and configure a policy template in this group. On the identity row for that peer, set generate-policy to port-strict or port-override, and set policy-template-group to the name of that group. But at least one of the peers must request the policy - if both are configured to generate it from a template, none of them will request it.
It may be a misunderstanding. Bare IPsec indeed needs a separate policy for each combination of local and remote subnet. Generating a policy from template changes nothing about that.
Users browsing this forum: anav, davidvanrensburg, eworm, HansHolgersson, patrikg, sebi099 and 104 guests
